Tire chat (nerds only)
5/19/2026 12:28pm
Great replies everyone, thanks.  I told her to go for a good pavement ride to see if helps on the dirt.  From there we will see where we end up.  Since she complained her bike is slow compared to her XC bike, if I did replace I'd probably lean away from radial since they are heavier.  No sense make it feel slower.  Dissector Exo maxx terra seems like a good happy medium if so.
Evil96
Portogruaro, VE, IT
5/19/2026 1:06pm
aaronufl wrote:
Unless I'm trying to maximize grip in the wet I much prefer radial front/non-radial rear. I like being able to break the rear tire loose often...
Unless I'm trying to maximize grip in the wet I much prefer radial front/non-radial rear. I like being able to break the rear tire loose often and for better or worse the radial rear makes that much more difficult to do.
Horses for courses I suppose. I just want different things from my rear tire vs front.
snowsnakes wrote:
Exactly my reasoning for picking up a Romy diagonal for the rear - I prefer being able to slide the back a little instead of the...
Exactly my reasoning for picking up a Romy diagonal for the rear - I prefer being able to slide the back a little instead of the Velcro feeling of the Albert, and a little pep while pedaling goes a long way for our locals.
snowsnakes wrote:
First ride with the Romy Trail Pro Diagonal Soft (what are we, Maxxis?) was a success! With the radial Magic Mary up front, it reminds me...
First ride with the Romy Trail Pro Diagonal Soft (what are we, Maxxis?) was a success! With the radial Magic Mary up front, it reminds me of a modernized version of my benchmark Vigilante Light/High Grip and Trail Boss Tough/Fast Rolling combo from WTB. It’s no XC tire, but it gives the Sentinel the pep I’d been missing when it comes to climbing and cornering.
I hope the radial 2.4 does the same at a beautiful 30psi
snowsnakes
Anchorage, AK, USA
5/19/2026 6:07pm
jasbushey wrote:
Great replies everyone, thanks.  I told her to go for a good pavement ride to see if helps on the dirt.  From there we will see...
Could try her on the WTB peacekeepers, I’ve been loving them for a faster trial tire.
yzedf
Hebron, CT, USA
5/20/2026 4:43am
If she’s anything like my wife, give her the previous tire combo that she used.
5/20/2026 6:52am Edited Date/Time 5/20/2026 6:55am
Back to radial talk.  3rd ride on my Tacky Chan + Romy trail radial, and slashed the sidewall on the Romy.  No idea how or where, no moment of "oh crap", on a trail I've ridden 50 times before without a puncture.  Its been years since I've had a sidewall puncture, I used to puncture Exo+ on the bead or top of tread.  Hoping it was a fluke but I'm concerned how thin they are for me.  I'm going to patch it and keep trying.  This was my concern switching from Conti enduro to the trail Schwalbe.
Before the puncture I was liking them quite a bit.  Conforms really nice over small chatter, especially noticable while doing technical climbing.  The Romy broke free fine for me and hooked up well on flat corners.  The Tacky Chan was great leaned over.  I was digging it.  Was going between 24-25 on the front and 27-28 on the rear (150lbs), which was 2-4psi higher than previous tires.  I don't think more pressure would have stopped the sidewall tear.
notthatbryan
Acworth, GA, USA
5/20/2026 7:31am
jasbushey wrote:
Back to radial talk.  3rd ride on my Tacky Chan + Romy trail radial, and slashed the sidewall on the Romy.  No idea how or where...
In theory radials will be easier to cut than a regular bias ply MTB tire. Because the threads in the carcass are more parallel to each other it's easier to slice between them.
5/20/2026 8:02am Edited Date/Time 5/20/2026 8:04am
In theory radials will be easier to cut than a regular bias ply MTB tire. Because the threads in the carcass are more parallel to each...
For me, the main data points on radials is that comparing my previous Continental Xynotol Enduro Soft vs the Schwalbe Trail Pro Radial Soft is that the Schwalbe is 35g lighter (3%), the radials have more grip, roll similar, are more comfortable at slower speeds, but seem to puncture significantly easier on the sidewall.  The enduro mag test seemed to confirm that, where enduro casing had a ~28% puncture resistance compared to 9% on trail radial, although I am not sure where on the tire that was tested, and they did not change the pressures.  Puncture resistance was my main concern trying this tire, but I did not want to add 175g to the rear of my trail bike with gravity. I want to do more testing to confirm if this is a fluke or not, but 3rd ride on a very familiar trail isn't confidence inspiring.
Depending what people are looking for in tires or how hard they are on them would help people consider the benefits of radial vs non.
5/20/2026 9:10am
Anyone have time on the new Vee radial offerings? Treads look good for what ever that's worth.
5/20/2026 10:14am
In kind of a "duh... what were you thinking, dummy" moment since I started running radials again... I had noticed that it felt like my rear suspension was occasionally blowing through its travel (landing jumps, square edge brake bumps).  I added a bunch of LSC & HSC, still was happening.  Added shock pressure and it still would happen.  Then I realized I just didn't have enough rear tire pressure, and that I was just bottoming out the tire in certain situations (even though it was stable most of the time).  Good thing my Reserve rims are tough.  🤣 I added ~2 psi to the rear and it seems to have mostly resolved it.
rpearce1475
Bremerton, WA, USA
5/20/2026 11:55am
Alright, need new tires for my enduro bike and Trail bike, keen to try the Schwalbe radials and looking for some advice. I'm in the greater Seattle area, mostly ride natural trails, bike parks at most 3 times a year. I prefer tires that I can ride year round and don't ride much in the wettest parts of winter. Was thinking:
Enduro bike: magic Mary super soft radial DH front, tacky Chan soft radial DH rear
Trail bike: having some trouble with this one. Romy radial front and rear? Tacky Chan front romy rear? Albert front romy rear?
Planning on radials front and rear. Not too much high speed cornering for where I ride regularly.
5/20/2026 11:38pm
NonLineon wrote:
Here is some non radial tire talk - I’ve been running the Michelin Wild Enduro MS Racing Line front and rear for a season and a...
Here is some non radial tire talk - I’ve been running the Michelin Wild Enduro MS Racing Line front and rear for a season and a half now. In general I’d say it’s been the best set and forget tire I have used. Similar loose condition performance to other all-rounders like the Magic Mary or High Roller, but holds up better on hard pack. I really like the casing too - supportive without being harsh, not too heavy, and haven’t had any flats (yet).
Thinking I’ll try the new Performance Line option as a rear tire to get more life out of it. Hopefully the harder compound doesn’t sacrifice too much on wet roots/rocks.
Evil96 wrote:
Even the performance line still rolls slow af while being average in grip
They were mounted on different bikes but the Wild Enduro MS mounted front & rear roll way faster than a Hillbilly/Cannibal combo.
I agree with @NonLineon  - the Wild Enduro MS fly under the radar a bit (in these forums at least). I have been using them exclusively for the last year or so across all UK condituons and I can't remember using a grippier tyre. They are spiky enough for UK winter mud but stable enough for hardpack, high speed corners too. The casing strikes a nice balance in my experience. They do wear out extremely fast on the back though
NonLineon
Medford, MA, USA
5/21/2026 6:11am
Jacker123 wrote:
They were mounted on different bikes but the Wild Enduro MS mounted front & rear roll way faster than a Hillbilly/Cannibal combo.I agree with @NonLineon  -...
Agreed on all points. I’ve also thought about throwing a dh16 on the back - looks pretty comparable to a dhr2. Do you have any experience with that tire? It’s only available in their DH casing, so might be too stiff for me as I haven’t had issues with their enduro casing.
5/21/2026 6:20am
NonLineon wrote:
Agreed on all points. I’ve also thought about throwing a dh16 on the back - looks pretty comparable to a dhr2. Do you have any experience...
Not the DH16, but I have used the DH22 in the past (which I assume has the same casing). If you ride a lot of bikepark or fast and rough trails it might be ok, but I found it too stiff for more general UK enduro stuff
5/21/2026 7:06am
I've noticed that even at higher pressures radials bottom more easily. Will radials resurrect tire inserts??
5/21/2026 7:08am
Also, I'm thinking of converting my ebike to a mullet. It's current MM R front,  Albert R rear. Ill be needing a new rear tire.
If the Tacky Chan really does roll faster than the Albert, and is better on the DH, is that what I should get in 650b for the rear?
Again, if the Tacky Chan rolls faster than the Albert, whats the point of the Albert?
5/21/2026 8:49am
Also, I'm thinking of converting my ebike to a mullet. It's current MM R front,  Albert R rear. Ill be needing a new rear tire. If the...
Albert is for people who are scared of gaps between center and side knobs.
5/21/2026 9:36am
I do hate the DHF
5/21/2026 10:57am
Alright, need new tires for my enduro bike and Trail bike, keen to try the Schwalbe radials and looking for some advice. I'm in the greater...
Sounds like good combos to me!
Since you have a enduro bike, im guessing you want the trail bike to be a bit more speedy?
You should consider:
F - Romy Trail Soft Radial
R - Romy Trail Mid (aka Speedgrip) Radial
Could also opt for Romy Race Mid on the back. Not Radial, but it will roll quite fast because of the race casing.
5/21/2026 11:51am
Jacker123 wrote:
Not the DH16, but I have used the DH22 in the past (which I assume has the same casing). If you ride a lot of bikepark...
I have the dh16 on the back of my enduro bike currently. I haven't ridden a dhr in a long time but i'd say the dh16 is similiar to a tacky chan 2.4 on the rear, but more. It feels a bit heavier, rolls a bit slower, brakes a bit better, but has similar handling characteristics wrt to the gap in between center and cornering knobs and the locked in cornering feel.
Overall the dh16 is a bit more tire than the TC, and for me I prefer the dh16 for shuttles and bike park, and the TC everywhere else (as a rear tire)
Torbo24
Syracuse, NY, USA
5/27/2026 1:20pm
in my search for "downcountry" tires, i found good deals on some specialized tires. Going to try an eliminator t9 (im familiar with the tread pattern as a back tire) on the front and a purgatory t7 on the back, both the light grid casing. Will report back once i get some miles on them.
5/28/2026 1:27am
@schwalbai How noticble is the change to the Gravity casing with all other things being equal? Same tread, compound, etc OLD vs NEW? Are we having...
@schwalbai How noticble is the change to the Gravity casing with all other things being equal? Same tread, compound, etc OLD vs NEW? Are we having to change PSI? thanks
schwalbai wrote:
Haven't ridden the updated Gravity Pro yet, so i couldn't tell you from personal experience. I'm a 200lb enduro rider, and i generally find the Trail Pro...
I'm a 200lb enduro rider, and i generally find the Trail Pro to be sufficient.
From a technical standpoint;
The previous Gravity Pro was a 4 layers of 67epi carcass under the tread, and 4 on the sidewall. Snakeskin on sidewall only, and apex supportive layer up the sidewall.
The updated Gravity Pro (where PRO is in blue) is now 6 layers under the tread, and 4 on the sidewall. Snakeskin is the same, and maybe Apex to?
I can't find documentation about it, but it could even be taller? Bending back the bead/sidewall shows the rigidity and height of our apex layer, so i will do this when i have a old and new version at the same time.
TLDR: Due to the increased rigidity of the updated Gravity Pro casing, you will likely need less pressure than the previous Gravity Pro casing.
So the new one would be also heavier?
storm.racing
Silverton, CO, USA
5/28/2026 12:10pm
Anyone having issues with the new HR3s? My first two on the rear have had cracking at the base of almost every knob while still nearly new. Fresh tires with only a couple rides on them. I am even getting it on my front too. Not as bad as the rear but still noticeable.
notseanday
cumming, GA, USA
5/28/2026 12:46pm
Anyone having issues with the new HR3s? My first two on the rear have had cracking at the base of almost every knob while still nearly...
Please reach out to the warranty dept and they can get you sorted with a new set and send you a label to return the cracking tires. I am an engineer at Maxxis (not in the compound team) and can get these into the right hands for analysis to see why this is happening on your set.
https://www.maxxis.com/us/warranty/bicycle-warranty/
storm.racing
Silverton, CO, USA
5/28/2026 1:21pm
notseanday wrote:
Please reach out to the warranty dept and they can get you sorted with a new set and send you a label to return the cracking...
I very much appreciate the follow up!
Reached out awhile back when it first started happening and not much was said other than just submit a warranty. Didn't end up submitting, but it now has done it to multiple others, so I finally just submitted for one of them.
Curious what's causing it or if it's common. 3/3 of mine having same issue. Still absolutely loving the tires but a bummer to see.
notseanday
cumming, GA, USA
5/28/2026 1:42pm
I very much appreciate the follow up!Reached out awhile back when it first started happening and not much was said other than just submit a warranty...
Glad to hear you’re liking the tires! I was on the design of the HR and it was a super fun project and love to hear when people enjoy them.
How do you store the bike / tires? Climate controlled? Near any large appliances?
storm.racing
Silverton, CO, USA
5/28/2026 2:11pm Edited Date/Time 5/28/2026 2:12pm
notseanday wrote:
Glad to hear you’re liking the tires! I was on the design of the HR and it was a super fun project and love to hear...
Took a lot for me to steer from the classic Assegai/DHRII combo but been absolutely stoked on the change to HR3. For all conditions. Been real stoked on em and probably will be all I run now. Appreciate your work on them and what they turned out to be!
Always very climate controlled, inside, and not located near anything else. Pretty moderate/dry climate where ridden primarily (SW CO). The fastest deterioration in cracking was on my first one while in Revy/Whistler last fall. I had wondered if the back and forth between wet and dry had anything to do with it. That one went fastest to crack but wore down the slowest. Back home now, they wear faster for me but cracking less quickly. First happened within a few rides. The other two cracked within a few weeks.
5/28/2026 2:21pm
Am I an idiot for considering schwalbe radial trail casing for the rear? I Usually run conti enduro casing with an insert to save rims but I now run a pretty hefty DH rim on my trail bike. Considering it to save some weight on the rear. Will I die?
5/28/2026 6:57pm
Just curious - is the reason the HR is not available in MT for use as a rear tire because the design was mostly for race or loose conditions where rolling speed / durability take a backseat?  I'm a big fan of the HR up front here in California, but cannot run MG in the back unless I'm going to replace it in a couple hundred miles.  Our dirt is just too abrasive.
Looking forward to trying the DHx whenever you guys finally release that!
I'm digging these new generation of open pattern / good side knob tires that still roll fast (HR, Tacky Chan).  The TC is good but I am burning through their Soft rubber fast in the rear so likely to go back to Conti rear or try out the new version of MaxxTerra.
5/29/2026 9:02am Edited Date/Time 5/29/2026 9:04am
The next radial?
image 721.png?VersionId=
