Tire chat (nerds only)
5/5/2026 10:47am Edited Date/Time 5/5/2026 10:47am
StilPhone wrote:
Did I read here that radial casing HillBilly and Cannibals are on their way? If so, anyone know roughly when?
I think soon.There is a TLR (tubeless radial?) version on the site and a 2bliss version (old version)When you look at the new demo specs it...
I think soon.
When you look at the new demo specs it puts the TLR version as the factory tire as well.
Before you try, no, there is no stock and doesn't say when it will be available
I'm not sure exactly what the TLR stands for, but Specialized has been using it for all their MTB tires for the past year or two...
I'm not sure exactly what the TLR stands for, but Specialized has been using it for all their MTB tires for the past year or two, so the R sadly isn't radial.
I'm still hearing that Specialized Gravity has a year of exclusivity on the radial Cannibal and Hillbilly, so they won't hit the market until this time next year. I desperately hope that's wrong though.
TubeLessReady if I'm not mistaken
KylerOnBikes
Vernon, BC, CA
5/5/2026 11:38am
There are two downhill versions on the site right now. The one labeled TLR isn't available for purchase.
I'm just guessing here, maybe they are just rebranding their 2bliss (tubeless) to TLR
1000001674
5/5/2026 11:42am
Speaking of radials, I am starting to think that Schwalbe revamped their radial casings more than the press release this year indicated.  I've had more rides on the Tacky Chan in both Trail Pro and Gravity Pro, and am able to run both at the same or slightly higher pressures (like 0.5-1 psi) than I run for equivalent Maxxis/Conti casings, while still retaining support.  When I tried the first gen MM & Albert, I was running +4 or +5 psi.  As a consequence, they've got less of a velcro stuck to the ground feel, but still conform to roots and stick to off-camber much better than typical casings.
5/5/2026 12:14pm
AndehM wrote:
Speaking of radials, I am starting to think that Schwalbe revamped their radial casings more than the press release this year indicated.  I've had more rides...
I noticed the same but I have to believe it's due to the more supportive sidewall and slower rebounding rubber. Both of which they highlight. I can't think of what else could cause it they haven't mentioned?
I'm also back to my prior to Radial Maxxis PSI. Which made me say a prayer for my rims but after a highly chunky ride this past weekend not a single rim ping.
5/5/2026 12:20pm
I noticed the same but I have to believe it's due to the more supportive sidewall and slower rebounding rubber. Both of which they highlight. I...
I thought I read that it was just the Gravity casing layup that got changed - maybe I misread.  That's why I am so surprised at being able to run normal pressures in the Trail Pro.  Not complaining at all though!
5/5/2026 12:32pm
AndehM wrote:
I thought I read that it was just the Gravity casing layup that got changed - maybe I misread.  That's why I am so surprised at...
I got bombarded by them on instagram, posts on every blog, multiple tire related forums... I don't even remember everything I read it was such a frenzy.
FY, I should have said was referring only to Gravity since that's my experience.
snowsnakes
Anchorage, AK, USA
5/5/2026 12:33pm
Anyone have a read on the differences between the 2.4 and 2.5 Radial Tacky Chan? If it’s just a wider casing, I’m inclined to order the 2.4 for less transition between center and side knobs, but I wasn’t sure if there were other differences.
KylerOnBikes
Vernon, BC, CA
5/5/2026 12:42pm
snowsnakes wrote:
Anyone have a read on the differences between the 2.4 and 2.5 Radial Tacky Chan? If it’s just a wider casing, I’m inclined to order the...
The tread pattern was also changed to make less of transition. Schwalbe say the 2.5 will be better if this is what you're looking for
5/5/2026 12:45pm
The tread is very different, take a look at the photos on their website.  Before it was like a pair of wide knobs, then 3 small/narrow rows of 2, then the wide ones again.  Now it's 2 wide, 2 medium, 2 wide.
snowsnakes
Anchorage, AK, USA
5/5/2026 11:16pm
Thanks @KylerOnBikes and @AndehM !
I wasn’t sure if the 2.4 had an updated pattern, but now I see it clearly doesn’t, and also isn’t offered in Radial! Looks like I’ll try the Romy Diagonal rear for now with the Magic Mary front I already have, and then swap it for a 2.5 TC Radial in June if I can get one.
5/6/2026 2:14pm
Anyone finding the Trail Pro radial casings incredibly thin in the sidewall? Just slashed one on some not that rocky terrain and I haven't had that happen in ages, even back when I was running Grid Trail casings and living somewhere far rockier. Plus just by hand they feel like by far the thinnest sidewalls of any >1100g tire I've ever felt.
 Bummer after just two days with everything else about how they ride being pretty fantastic.
ehfour
5/7/2026 1:24pm Edited Date/Time 5/7/2026 1:24pm
So Eliminator, Romy, Grapper or Butcher radial for BC/PNW riding this summer- Lightweight midpower ebike
Currently have a Albert, but the knobs are starting to tear off and the sidewall has developed a ton of sidewall leaks
5/7/2026 2:07pm Edited Date/Time 5/7/2026 2:10pm
ehfour wrote:
So Eliminator, Romy, Grapper or Butcher radial for BC/PNW riding this summer- Lightweight midpower ebikeCurrently have a Albert, but the knobs are starting to tear off...
I only have 1 ride on the Romy so can't tell you how it fully is, but visually it is a very different tire than the other three.  It compares more to a Dissector or Xynotol.  Visually it seems like a fast rolling tire for harder conditions and may not be where you want to prioritize.  Looks like a great mid travel trail bike Colorado tire if it holds up for me tbh.
I have the Tacky Chan on the front, and it is much more aggressive tire that would be closer to those others.  I was a bit surprised how large the blocks are the lugs are taller than a DHR and the Conti Kryptotal.
5/7/2026 3:26pm
First off, there is warranty on schwalbe tires so you should check that out.
You should consider the Eddy Current, now comes in radial. Gravity casing weighs 1480g for 29x2.5, but it's pretty damn durable. Ideal for rear wheel on e-bikes.
Romy could be good. Defintley faster rolling and lighter at 1355g. But on the rear you may chew through the tread pretty fast.
Its typicaly reccomended for 130-140mm trail bikes.
Or like others mentioned, split the difference and go Tacky Chan.
P.S. Nice to see the Mary in your profile pic come out at the listed 1190g.
Evil96
Portogruaro, VE, IT
5/7/2026 6:32pm
schwalbai wrote:
First off, there is warranty on schwalbe tires so you should check that out. You should consider the Eddy Current, now comes in radial. Gravity casing weighs...
Was there any update to the trail pro radial chasing to the previous/ first gen ?
5/7/2026 6:58pm
Would like to know this too, to relay info to guys I ride with.  It certainly feels like this on the TC (well done on that BTW, loving it).
theweaz
Victor, ID, USA
5/7/2026 9:39pm
Anyone finding the Trail Pro radial casings incredibly thin in the sidewall? Just slashed one on some not that rocky terrain and I haven't had that...
I sliced an albert gravity at the tail end of last season after only 5 or so rides on it and haven’t sliced a dh casing tire in probably 10 years. The conti dh tire I took off had threads starting to expose on the sidewall and made it 1.5 seasons without a slice. So I’d say the schwable radials don’t hold up as well as I would expect given their weight.
5/8/2026 6:16am
theweaz wrote:
I sliced an albert gravity at the tail end of last season after only 5 or so rides on it and haven’t sliced a dh casing...
I’ve sliced a Conti DH tire but it was in the Massunutten rock garden so not entirely unexpected. (Just riding not racing)
5/8/2026 6:21am
First trail bike ride on the Romy Trail Radial Soft yesterday and I’m very conflicted on it. It was great on trail/tech climbing and all my times were the same and great on the downhills where I hit off cambers and side hits outside of the trail. Where I didn’t like it were flat sections of trail and pavement. It feels like you have exhaust back pressure slowing you down slightly, slightly, slightly. I’m trying to convince myself this doesn’t matter and is worth the tradeoff of grip and trail feel.
The feel of radials front and rear is unmatched. It’s like riding in a Honda vs a Mercedes. I like a snappy bike but I just can’t stop thinking about how damped and refined the rear radial makes the bike feel.
5/8/2026 7:21am
I currently have four radial Albert Gravity SuperSoft tires mounted (first version) and one 2.6 has a pretty decent wobble on my just-built-and-straight wheel. Front, no inserts, with TPU tube. Hopefully that's just the fold from the packaging, otherwise I'll warranty it. Has anyone else had a wobbly one?
5/8/2026 7:58am
AndehM wrote:
Would like to know this too, to relay info to guys I ride with.  It certainly feels like this on the TC (well done on that...
I think the other commenters were correct in saying the refined tread pattern of the TC, and the updated Ultrasoft Compound, may be what you are noticing.
No updates to the Trail, just the Gravity casing.
@theweaz you'd probably like this. The previous gen Gravity Pro casing leaned more towards a Super Gravity casing. The updated version is closer to a Super Downhill.
snowsnakes
Anchorage, AK, USA
5/8/2026 3:50pm
First trail bike ride on the Romy Trail Radial Soft yesterday and I’m very conflicted on it. It was great on trail/tech climbing and all my...
I’m personally really excited to try swapping the Albert Radial rear for a Romy Diagonal in the same compound and casing (Trail Soft). The Albert is definitely plush feeling, but it does feel like it saps a ton of energy from the bike when climbing or on moderate downhills. I also really prefer being able to slide the rear wheel around a bit instead of the “always locked on” feeling of the Albert’s very full tread.
5/8/2026 4:43pm
snowsnakes wrote:
I’m personally really excited to try swapping the Albert Radial rear for a Romy Diagonal in the same compound and casing (Trail Soft). The Albert is...
Tacky Chan rolls faster than Albert and is a lot easier to initiate a drift in (rear).  That was one of my issues with Albert also - it was really hard to consistently get it to slide into corner pockets.  TC behaves a lot like a DHR in that regard.
Tom_Mtb
Kuala Lumpur, Kuala Lumpur, MY
5/10/2026 9:53pm
With the removal of the old gravity pro casing, what are you guys going to run on your trail bikes?
I'm currently trail pro front and gravity pro (old) rear on my canyon spectral and was originally planning to go gravity pro front and rear after the front gives out because it just feels way too balloon like to give me confidence in corners.
But now, I would have to go new gravity casing front and rear, so basically downhill casings on a trail bike. I can quickly see me hating life.
5/11/2026 11:07am
Tom_Mtb wrote:
With the removal of the old gravity pro casing, what are you guys going to run on your trail bikes?I'm currently trail pro front and gravity...
Trail casing for trail bikes.
I get your concern.  I primarily go with a trail casing front, enduro rear if given the chance on my ~130mm bike.  I decided front and rear trail with Schwalbe based on weight.  The Schwalbe Trail casings are the same weights as comparable Conti Enduro.  General forum talk and tests make it seem less robust than that option, but I haven't seen an actual test with increased pressures accounted for.  We'll see if it holds up, I'm a bit skeptical.
5/11/2026 11:17am
I had issues with the 2024 radial trail casings being too squirmy, but have not had that problem with the 2026 Trail Pro casings.  I'm happy to run those front & rear on my trail bike... will eventually replace the Grav Pro on front end of my ebike with one too once it wears out, might try it rear also as I'm on the lighter end of the spectrum.  2026 weights seem dead on for the 4 I've purchased & weighed.
5/11/2026 11:20am
Simply no „radial“ casings and instead the regular ones.
5/11/2026 12:56pm
Sadly it seems like the best solution is going with a different brand that has a more robust trail casing. I just picked up a Gravity Pro casing Romy to replace my sliced Trail Pro version and as I'd expect it's a bit of a pig, but sturdy and nice to not have to worry about. It just seems like there's a big gulf between the two, with the Gravity Pro casings feeling like a pretty proper DH casing and the Trail Pro casings having absolutely paper thin sidewalls that at this point I don't trust to hold up, even if the support feels decent.
Evil96
Portogruaro, VE, IT
5/12/2026 12:42am
Sadly it seems like the best solution is going with a different brand that has a more robust trail casing. I just picked up a Gravity...
Yeah I’m kind of pissed they just added 2 layer of chasing to the gravity, when I need a gravity rear I don’t want a DH tyre, and now there’s no option anymore to stay with the radial, and imo radial front and non rear feels like 💩
5/12/2026 3:37am
FYI, casing, not chasing. There is no H in tyre casings.
