Tire chat (nerds only)
4/5/2026 10:48am
Will Radial come to trail tires? A few people here say they don't feel slower, but I'm not so sure. My radials are on the ebike so I have no idea.
I'm also trying to decide what to put on my shorter travel bike.
aaronufl
Poulsbo, WA, USA
4/5/2026 11:10am
Will Radial come to trail tires? A few people here say they don't feel slower, but I'm not so sure. My radials are on the ebike...
I've ridden the radials and standard schwalbes on my trail bike (trail casings on both). They radials definitely roll slower but offer better grip in the wet. I'm sold on the radials for the PNW winters and super trail casings for the drier parts of the year.
I'd be curious how the Tacky chan radials perform, but not sure I want a more malleable casing on a tire that's main selling point is precision/locked in cornering.
Evil96
Portogruaro, VE, IT
4/5/2026 12:29pm
i'd say it depends, they feel slower on smooth terrain, road climbs, as you get to roots, rocks they're faster as they "hug"the obstacle rather than wasting energy going around it by bouncing on it, that's my experience while climbing, downhill i'm faster as they track better and grip more while being more comfortable
PhoS
PNW, WA, USA
4/5/2026 1:11pm
You can buy trail radials right now, they're definitely slower though..  Dual Alberts?
Friday
Atlanta, GA, USA
4/6/2026 6:39am
Thank you! Do you mean cooking BBQ or eating? Because we've heard the "Nashville 20" - as in you gain 20 pounds when you first move here...
Thank you!
Do you mean cooking BBQ or eating? Because we've heard the "Nashville 20" - as in you gain 20 pounds when you first move here - is a thing. You can't throw a rock here without hitting a BBQ, hot chicken, burger, or taco place.
On the topic of tires... the trails here skew more towards XC with some flow bits thrown in. I had Dissectors on my Stumpjumper front and rear, but even that tread is a bit too much for around here. Swapped out to an Ikon rear and Forekaster front yesterday, which was an improvement in rolling speed, but I'm interested in y'all's opinions on fast trail tires.
I've always been "meh" on the Rekon, but looking for something in that vein. Maybe a Dubnital or Wicked Will?
Ive been running Forekaster/Ikon on the XC trails here, and I think its a really solid combo. Honestly surprised how much I can trust the Forekaster. The ikon also has a lot more braking grip than I thought it would, makes me think I could scale down to an aspen or rekon race in the rear and still be good.
4/6/2026 8:21am
Ha, the Albert is hardly a trail tire
jalopyj
Concord, CA, USA
4/6/2026 8:40am
Just one short ride in. Removed ground control + rimpact out front. Swapped with Eliminator no insert. Was 20g heavier compared previous tire set up. As expected, rolling resistance is one notch slower climbing but it then pays dividends on the way back down. Noticeable increase in grip and more defined cornering edge vs ground controls.
I feel like this setup pulls it out of the xc and squarely into the light trail category but liking it so far.
4/6/2026 8:48am
This has been covered a number of times, but I'll update again since there seems to be a lot of bad info about rolling resistance. @Evil96 is correct in his analysis. Over rocks/roots, etc. Radials will be more energy efficient because of their supple casings. And yes, on pavement or hard pan smooth trails, the Radials will feel slower since there is more contact patch on the ground. BUT the size of the contact patch is determined by the pressure run in the tire. You CAN increase the pressure in Radials much higher than you would in a normal tire of the same volume and same casing compound, but still have a more supple ride. That is where the lines are blurred. The contact patch will shrink to that of about a 'normal' tire but it will still be more supple, and the actual deformation of where the tire is actually bending on the road is low, so they're likely just as efficient. The Schwalbe World Cup XC racers were on Radial casings last year and had an amazing season. So Radial CAN be efficient. Just like tubular tires in road and cyclocross. You just have to run higher pressures than if you want the absolute max grip out of them. The issue however, with the high pressures in lighter weight trail/XC casings is that they can become 'bouncy feeling'. So it's a balance.
4/6/2026 9:16am
Thank you!
Friday wrote:
Ive been running Forekaster/Ikon on the XC trails here, and I think its a really solid combo. Honestly surprised how much I can trust the Forekaster...
I’m digging the Forekaster/Ikon combo a lot. I prefer the Ikon to the Rekon Race or regular Rekon for that matter. Aspen also tops the RR for me as the RR pushes in anything but the hardest, buffest terrain.
4/6/2026 10:25am
This has been covered a number of times, but I'll update again since there seems to be a lot of bad info about rolling resistance. @Evil96...
Great answer!
We just need something a bit lighter (in weight and tread)  than the Albert
Evil96
Portogruaro, VE, IT
4/6/2026 12:17pm
Great answer!
The Roamy
Fox
Durango, CO, USA
4/6/2026 2:34pm
Agree with this assessment of the radial. Can't wait to run try the Tacky Chan radial front and rear on the enduro bike.
Agree with above comment on the Forecaster. I'm runnin one on the front of my Spur and it hooks up  well, rolls well and is lasting too.
4/6/2026 2:48pm Edited Date/Time 4/6/2026 2:57pm
FIrst real ride on the MM+Albert radials. Started above what should be rideable. Muddy slop. Finished 3.1k feet lower where it's dusty, loose, and dry. The radials handled it all noticeably gripper than the Assegai. And, since I was running 5psi more, the tire held its shape really well too (I hate it when you feel a tire fold over)
TLDR hype is real. I want a Forecaster in radial!
1000016686 0.jpg?VersionId=m8EyZLd
onxx
Laguna Beach, CA, USA
4/6/2026 4:13pm
Torbo24 wrote:
Im interested in lighter tires, too. I run trail casing butcher/eliminator right now, and i think id like to try something faster during the summer. I...
Im interested in lighter tires, too. I run trail casing butcher/eliminator right now, and i think id like to try something faster during the summer. I was thinking about eliminator/dissector on the front, but not sure what to pair with it in the rear. Whats up with the purgatory, would that be a good rear tire to pair with an eliminator? Would the magno's be comparable or a little faster? Are forekasters similar to the magno? I saw some forekasters at the lbs and they looked tiny, like an old 2.0. i dont really have much experience with faster tires and im kinda hesitant, i dont know how much grip i can reasonably give up?
afreak wrote:
I have run several versions of Butcher/Eliminators on my Sentinel and Spur. Now I have a Purgatory grid trail t7 on the back of my Spur...
I have run several versions of Butcher/Eliminators on my Sentinel and Spur. Now I have a Purgatory grid trail t7 on the back of my Spur, paired with the old Butcher grid t7 2.3 on the front. I don’t like the grid casing at all, feels sketchy. I bet an Eliminator grid trail 2.4 would feel way better in the front, or even double Purgatories, put a t9 up front. They’re a little skinnier 2.4 than the Eliminator 2.4. Dissector front, Purgatory rear might be nice. What bike are you on? The purgatory t7 rolls quite fast.
Also, that Magnotal trail casing will be stronger than specialized grid casing, Ground Controls only come in grid. I just ordered  magnotal to run in the back of my Spur for “racing”, paired with a Purgatory up front.
It depends on which versions you are asking about.
The Magnotal grip is close to the same speed as the ground control T7 (assuming the "T7" compound is the same in both GC and purgatory etc). The magnotal I think is more of a hardpack/loose over hard tire. I haven't ridden it on the front, but I do have it in the back with a xynotal soft front, and the grip is insane. Loving it compared to the Assegai maxxgrip that it replaced. But I am riding hardpack with some slight sandyness on top, so it makes sense that the dedicated hardpack tire is better (less knob chatter/flex/etc). I think the xynotal might be closer to the purgatory from a knob style standpoint, but I think xynotal soft will be a bit slower, grip will be much higher though (T7 vs conti soft).
General rule of thumb is maxxis is slower than other brands. I haven't ridden the new forekaster but if you're looking for more speed I just don't think maxxis really does that. Heresy I know, but like all the rolling resistance data I've seen and testing I've done backs that up.
The confusing thing with compounds is that some brands really call a compound by one name and it's literally the same despite different tread patterns. And other brands (kenda) claim every tread pattern has a unique compound. I'm not sure how the new Conti stuff is. Does anyone know? Cause compound is the main factor with rolling resistance (hysteresis).
pejzaż
Phoenix, AZ, USA
4/6/2026 8:03pm
What I managed to throw together for the new pedal bike was a Trinotal rear and Xynotal E soft front. The trail casing on the Trinotal was way too flimsy as I expected, put a hole in it immediately. Almost as good as anything grip-wise on sand/granite though
I suppose what I'm waiting for is the "Roamy", whatever that ends up being, can't find any sneak photos of it. In the meantime, need to decide between a Forekaster and Nobby Nic for a rear. Anyone have any opinions either way on those two tread patterns or Exo+/Super Trail?
aaronufl
Poulsbo, WA, USA
4/6/2026 8:55pm
pejzaż wrote:
What I managed to throw together for the new pedal bike was a Trinotal rear and Xynotal E soft front. The trail casing on the Trinotal...
I was actually a bit underwhelmed with the forekaster. The one I used on the rear was undersized and didn't last terribly long.
In comparison the Nobby Nic has worn better and rolls faster, though I don't think it matches the forekaster for outright cornering grip.
Torbo24
Syracuse, NY, USA
4/7/2026 8:15am
i also like the looks of a xynotal for the front, but i dont want to have to run the enduro casing on the front to get a soft. Do we know how the endurance compound compares to the xc tires 'grip' or 'soft'? For that matter, is 'soft' the same on the magno as it is on the gravity tires?
pejzaż
Phoenix, AZ, USA
4/7/2026 9:30am Edited Date/Time 4/7/2026 9:30am
Torbo24 wrote:
i also like the looks of a xynotal for the front, but i dont want to have to run the enduro casing on the front to...
According to continental, endurance compound is between rapid and grip in terms of rolling resistance but worse than both in terms of grip/damping. I just happened to have the Xynotal in the pile, Dissector 2 seems like a much better option for a fast-ish front
4/7/2026 9:34am
Yeah i'm in a similar boat - I don't need the puncture protection from the enduro casing where I live so it's a bummer you can't get the trail casing and soft / supersoft compound. I ran the xyno/trail/endurance for a brief bit when they first came out and it was fine - got more traction than a MT rekon but didn't run it long enough to get a real opinion on it. As far as compound is concerned, i too would be curious if it's the same. At the same time the knob sizes are so different I'm not sure how much it matters, whether we're talking about grip or longevity I don't think you can just pull the tread pattern out of the equation when evaluating performanmce.
4/8/2026 5:39am
As far as I heard, both the trail casing and endurance rubber are utter garbage. Enduro and DH casing, soft and super soft rubber are apparently disproportionately amazing in comparison.
ex-ballz
Ouagadougou, EH
4/8/2026 6:31am
As far as I heard, both the trail casing and endurance rubber are utter garbage. Enduro and DH casing, soft and super soft rubber are apparently...
I made the mistake of getting a Xynotal and a Kryptotal in trail casing and endurance compound and they went straight to the heap of tires never to be ridden again. They are horrible.
4/8/2026 9:35pm
@schwalbai or others, anyone has the overall diameter of a 29" 2.5 Albert Gravity ?
My 2.6 is 758mm diameter and doesn't leave a lot of clearance on my RXF38m.2's arch. For comparison, my used Kryptotal Fr 2.4 is 751mm diameter.
I'd like to try a 2.5 Albert Gravity rear to get more rear tire clearance at the seat stays, and would probably keep the 2.6s that I have for the front even if it's a bit tight on the RXF with a mud guard. But if the difference between the 2.5 and 2.6 is minimal, I won't bother. Thanks for any info!
4/8/2026 9:52pm
Yes, based on the hardness of Conti's 'soft' compound, their endurance compound is likely close to plastic Smile
Evil96
Portogruaro, VE, IT
4/9/2026 12:02am
mntnmrtn wrote:
@schwalbai or others, anyone has the overall diameter of a 29" 2.5 Albert Gravity ? My 2.6 is 758mm diameter and doesn't leave a lot of clearance...
Mines are 752
Trail chasing, 30mm internal rim
750 for the latest Mary trail pro with the blue logo
Evil96
Portogruaro, VE, IT
4/9/2026 1:07am
Curious thing I haven’t noticed on the first round of radials
“Not tlr: mount only on hooked rims”
My carbon rims are hookless like the majority at this stage I’d say 🤔🤔
IMG 9780.jpeg?VersionId=IzlEwZKtSHIdOdLAbEv
afreak
Big Sky, MT, USA
4/9/2026 7:19am
My Purgatory knobs are peeling off the casing with low mileage, maybe 200 miles mostly dirt roads. Similar to the old Eliminator. Specialized says this: That's part of how our tires wear unfortunately. It is normal and expected.
4/9/2026 7:24am
afreak wrote:
My Purgatory knobs are peeling off the casing with low mileage, maybe 200 miles mostly dirt roads. Similar to the old Eliminator. Specialized says this: That's...
Bullshit reasoning. 200 miles is nothing, if you are not constantly riding dh trails or keep on skidding the tire on asphalt
afreak
Big Sky, MT, USA
4/9/2026 7:30am
The purgatory seems to be between XC and trail, I’m looking for something similar. Maybe Wicked Will, Agressor, Forekaster. Continental needs something between Magnotal and Zynotal.
Johnnyfoes
New Haven, CT, USA
4/9/2026 7:58am
I agree! Continental should explore and test a Tread pattern in between Xynotal&Magnotal for XC/TRAIL and EVEN A TRAIL/ENDURO REAR SPECIFIC TIRE ONLY!!
4/9/2026 9:58am
Likely no company is reading this, but I will give my wishes.  Make enduro Casing fast trail rear tire.  I run Xynotol enduro soft in the rear and I like it but sometimes wish wonder what a faster tire would change my 5010.  I've tried a WTB Trail boss light fast (why are tough now 1500g!?) and liked it (but flatted it), and I would love to try a Forekaster, but I haven't had great luck with Exo+ in the rear but have had luck with Conti Enduro.  I am curious to try a faster Magnotol or Forekaster, but no enduro casing takes it out for me.
Something like a Dissector Exo+ Grip / Forekaster Dual or Terra DD sounds be sweet for me.  Or a Xynotol trail super soft and magnotol enduro soft (or something between).  Whats a Schwalbe equivalent?
