Tire chat (nerds only)
2/26/2025 6:59am
Dh front, enduro rear? Seriously?
I have heard this before as well with the excuse of "good damped feeling in the front" and "little bit lighter on the rear to pedal".. so.. may be this is the case here..
2/26/2025 8:51am
Ritemance wrote:
Radials are not discounted it's only the normal bias tires. 20-30€ per tire. From what I've gathered for my purposes the radials have more downsides than...
Radials are not discounted it's only the normal bias tires. 20-30€ per tire. From what I've gathered for my purposes the radials have more downsides than up. I was thinking about it as small bump compliance and grip would be interesting but if the rolling resistance is worse then it's not going to be a faster tire for me.
Tacky Chan looks a lot like Minion which I don't like front or rear. More so looking for the better rolling resistance for the rear tire so Minion isn't very good there. I might move over to Aggressor if I stay on Maxxiss. Doesn't seem to be anything corresponding on Schwalbe. I don't think Nobby Nic rolls very well you'd usually want flatter more together center line than that.
Hans Dampf looks okay. Just with those small nobs I don't think it can match Dissector with the flatter longer center nobs. Especially with the horizontal cuts in every nob.
I don't really like how JVP describes the Magic Mary so I might just stay on Assegais. Still have 2 Assegais half worn for next season so will only need one tire to the front.
I feel I understand the Schwalbe tires now but gotta think about it.
The tacky chan, imo, rides like a much better DHF more so than it rides like a DHR - perhaps the best of both. I'll reemphasize...
The tacky chan, imo, rides like a much better DHF more so than it rides like a DHR - perhaps the best of both. I'll reemphasize that the TC has the strong corner grip of the DHF but requires much less lean angle, has the rolling speed of a dissector, but brakes as well as the DHR after a couple rides.
I had the same experience with the Magic Mary v Assegai in Arizona and California terrain as JVP. I did find that running low tire pressure in the MM helps it out a lot in the dry - still like a vague velcro grip feeling though. I found my self riding at 20 psi, and having to more purposely weight the front tire. There would be a small bit of vague feeling followed by a lot of grip as long as it was loaded up... not my preferred ride feel.
If you're schwalbe curious, i'd really recommend giving TC front and back a try. I used to run assegai/dhr type setups and was never a fan of the lean angle needed to ride DHFs... but the TC have been a bit of a transformative ride for me. The tire rolls, brakes, and just hooks up with not that much lean angle.
My next favorite setups are the conti kryptotal fr front and xylontal rear. Kryp fr will be more similar to the assegai feel that you're used to, xylontal rolls well but the corner knobs are not as prominent as the TC. Kyrp fr on the rear tire is great imo, especially when the center knobs are worn down.
Evil96 wrote:
i'm trying now the double Tacky combo and i prefer the Mary up front, it just digs when it's needed on the steep stuff, much more...
i'm trying now the double Tacky combo and i prefer the Mary up front, it just digs when it's needed on the steep stuff, much more confidence, on fast trails i struggle to find the difference, i also like the xynotal as a rear tire but find it slowe than the Tacky and with much less braking/wet grip, i really love the tacky as a rear tyre, rolls fast like a Hans Dampf, brakes hard like a Big Betty but it's more predictable
What terrain and casing do you ride? I've only ridden the MM in super gravity ultra soft in the Southwest US.
At Sunrise bike park in Arizona it's probably as steep and loamy as Arizona gets, I did prefer the MM upfront to the TC. At Big Bear in California, thought, I found myself enjoying the TC more. FWIW, I keep both a TC and MM mounted up and switch them out up front as desired.
How did you find the cornering of the Big Betty compared to the TC?
Suns_PSD
Austin, TX US
2/26/2025 9:41am Edited Date/Time 2/26/2025 12:24pm
I found the TC to be small and pingy.
I've never had any trouble leaning my bikes consistently and getting the tires to lock in until the TC, but my terrain is just loose rocks and half of the time, I could not get the TC leaned over enough to get there.
When the terrain was right, they locked in incredibly well however. But then even medium pebbles would have it skipping, slipping, and pinging.
I then installed it as a front trail tire (instead of on my AM e-bike) and it was pretty good there and being so small sort of fit those narrower wheels better, rolled well too. Yet it still had the same issue, if I didn't have something to lock that tire into, it didn't have that much grip and was vague. It actually worked better on the trail bike just because that bike sees a fair bit more dirt, and less loose rubble. But still a notable step behind, well sort of everything else I run up front on both of these bikes.
I settled for now on the MM US Radial up front on my Relay.
I settled for now on the Albert US 2.5 Radial up front on my Smuggler.
2/26/2025 9:56am
luisgutrod wrote:
I have heard this before as well with the excuse of "good damped feeling in the front" and "little bit lighter on the rear to pedal"...
I've done this before with Dissectors & zynotals in exo / trail casings + Cushcore. If you can get away with a harder compound tire, and your durability needs are more for rim-smashy / pinch flat stuff rather than punctures / tears from sharp rocks the setup will roll a good bit faster.
Evil96
Portogruaro, VE IT
2/26/2025 10:05am
What terrain and casing do you ride? I've only ridden the MM in super gravity ultra soft in the Southwest US.At Sunrise bike park in Arizona...
Right now in hard pack/loam/soft dirt and slippery roots
Super trail chasing 82kg rider 19psi front 25psi back
The Betty was ridden in different terrains but gave me the feeling of being great on braking, super grippy in corners until sliding suddenly, vs the tacky being more predictable
Mary I had many versions, the latest and favorite is the super trail ultrasoft
And I feel that when I need the tyre to hold the most she’s there, vs the tacky being great when I don’t need it too much ( when in the front )
2/26/2025 10:24am Edited Date/Time 2/26/2025 12:21pm
I've done this before with Dissectors & zynotals in exo / trail casings + Cushcore. If you can get away with a harder compound tire, and...
This is exactly what I'm going for. I want the front to be a bit more damped and "tracky", while the motivation for a lighter casing rear tire is to save some weight. I get along really well with the feeling of a MaxxGrip Exo+/cushcore combo.
I have in the past found cushcore with a heavier casing tire to feel a bit lethargic, especially for day-to-day riding (which involves no shuttles of lifts and avg. 700+ meters of climbing).
2/26/2025 11:43am
Suns_PSD wrote:
I found the TC to be small and pingy.I've never had any trouble leaning my bikes consistently and getting the tires to lock in until the...
I think the terrain might have more to do it with it - I've ridden the TC at spider mountain and also at howler in MO and I agree that tires with constant traction are better suited to those areas. I also flatted a TC in the rear at howler when I caught a sharp rock in between the middle and shoulder lugs. The guys working howler all swore by conti's for that reason.
For places like spider mountain, I wish conti would come out with a xlyontal with big shoulder lugs
The Duffman
Fresno, CA US
2/28/2025 9:44am
Don't save money by buying cheap tires. Schwalbe will be phasing out all their old tire (casings) over time. Go with Radial gravity casing if you're normally...
Go with Radial gravity casing if you're normally on Maxxis DD and DH.
This is exactly how I feel about the TC and the Conti setups.  I came from Krypto fr xynotal rear and would have happily gone that route again if super soft was offered in the enduro casing.  I just didn't want to pedal around the DH casing anymore on big days.  So while waiting for the enduro casing to be released I decided to give the TC a try and am really impressed.  However, the Conty setup was the longest lasting setup I've ever run while the TC doesnt look like it will last nearly as long.
ballz
Ouagadougou EH
2/28/2025 12:14pm
How terrible are the tough/grippy 2.6 Terrene Chunks in the front? Buddy just gave me an older 29 rim so I figured $28 for the Chunk would not be too big throwaway money if I don't like the MX setup on teh Brönsön.
3/1/2025 5:38pm
I'm having a hard time drawing any conclusions from all the reviews and chatter on the radials.  Opinions seem to vary wildly.How many pros are still...
How many pros are still reaching for the paint pen and running non-sponsor tires?  Or have tires gotten better across the board and/or have sponsors cracked down on this?
If it's still happening somewhat frequently, a very interesting data point on the radials will be how many pros we see running them without being paid to do so.  I'm generally slow to conclude that what's best for the pros is best for me, but I think it would indicate the radials give you something materially different from other tires.  And if the pros only switch for certain tracks or conditions, that would be even more telling.
The feedback I’ve heard on the radials varies greatly, maybe slightly positive overall. It will be interesting to see what other treads they apply the casing...
The feedback I’ve heard on the radials varies greatly, maybe slightly positive overall. It will be interesting to see what other treads they apply the casing to. AFAIK teams were only using the radials in the wet last year.
Overall, the tire landscape is much more competitive. We’re not seeing nearly as many of the top riders riding blacked out tires as even 5 years ago. It’s tough for the tire brands but it’s a good time to be a rider!
Thanks for the reply and your participation in all the forums generally.  Recognize you're in a conflicted position, so understand completely if you ignore.  And I'd...
Thanks for the reply and your participation in all the forums generally.  Recognize you're in a conflicted position, so understand completely if you ignore.  And I'd of course appreciate thoughts from anyone else.
Do you think the wet vs dry choice has to do with the currently available tread patterns?  I'm not familiar with Schwalbe's lineup (I ride your guys' tires).
If it's a choice based on casing support on dry, faster tracks, any guesses on whether it translates down to regular riders?  In other words, I'm going way slower than those guys in general, but both me and them are going slower in the wet than we do in the dry.
You're welcome! Always enjoy the conversations happening here on Vital.
Our theory is it’s more about the casing than the tread patterns. Having a more compliant tire can be a benefit in the wet. Speeds are generally lower in the slop so damping and support are a lower priority. In those conditions more traction is more better.
3/11/2025 10:57am
@iceman2058 just put out a 'First Ride' of Specialized's updated Butcher and Eliminator
https://www.vitalmtb.com/features/first-ride-specialized-butcher-and-eliminator-2025
TLDR: Knob design of both models is a little beefier/deeper/bigger than before. Some slight changes in width/compound/casing options, but still the same casing and compound designs. And they're still a banging deal at $70 USD GridTrail, and $75 USD GridGravity.
I'm sure the Butcher and probably the Eliminator have been discussed in previous pages. But still curious for those who have ridden the tires, are the new changes in the right spot?
Personally, I think the Butcher is a solid all-terrain option. Rolls pretty fast, predictable when leaning over, and decent braking bite. Taller and deeper knobs sounds like a plus to help the tire grip is looser/deeper soil—conditions I don't think the first gen tread wasn't amazing. I've only ever ridden the Eliminator in the rear and it had the tendency to kick out when driving energy into corners, and was not great for trying to slow down on steep or loose trails. So less ramped center knobs and bigger knobs sound like it makes the tire more appropriate for a Stumpy-esque bike.
ballz
Ouagadougou EH
3/11/2025 11:38am
I always wanted the Butcher to be a little meatier in the front and the Eliminator a little faster rolling in the rear. Sounds like that's happening with the Butcher, but the Eliminator is moving in the opposite direction? Also, the article says that Eliminator is available in T7 or T7/T9, but the list of sizes only shows it available in T9 or T7/T9, so perhaps that needs to be fixed.
3/11/2025 12:29pm
ballz wrote:
I always wanted the Butcher to be a little meatier in the front and the Eliminator a little faster rolling in the rear. Sounds like that's...
Good catch! Yep, there was a typo in the spec list in the article (copy-pasted from the press kit we received). The Grid Trail version of the Eliminator is T7 only, while the Grid Gravity version gets the T7/T9 dual-compound.
As for rolling speed, I always felt like the Eliminator rolls on pretty well for such a beefy tread pattern. I've only spent a couple of days on this new model but so far that sensation remains, I feel like it pedals and rolls like the previous version (all very non-scientific, I know...).
ballz
Ouagadougou EH
3/11/2025 1:38pm
Good catch! Yep, there was a typo in the spec list in the article (copy-pasted from the press kit we received). The Grid Trail version of...
I guess I am never happy with the rolling resistance of any tire in the rear, apart from semi slicks, and wished the Eliminator were a slightly grippier and better braking Slaughter. Is the new Butcher really only available as 2.2 in the 27.5 Grid Trail casing? (FU Spesh if so)
andyjr77
3/11/2025 2:25pm
Talking of the Slaughter, I'd love to see that return as a Grid Gravity.
3/11/2025 3:48pm
ballz wrote:
I guess I am never happy with the rolling resistance of any tire in the rear, apart from semi slicks, and wished the Eliminator were a...
I think this is another typo from the press kit. Canadian Specialized website list both grid trail tire available in 27.5x2.4 and no mention of 2.2 option.
sprungmass
Calgary, AB CA
3/18/2025 7:29am Edited Date/Time 3/18/2025 9:29am
Seriously, this might be the most requested tire spec out there. A lightweight rider like myself has no business running a DH casing front tire. I hope this is not just a paper launch because I would love one for my upcoming Arizona trip.
Edit: My Canadian local shop's distributor should be getting these in 6-8 weeks. R2-Bike already has them in stock!
3/21/2025 4:52pm
The old Eliminator is the tire I always wanted the Dissector to be - faster rolling than DHR2 or similar, decent all-arounder, good wear characteristics and good enough cornering traction for the compromises. I always rode it in 2.6 29" T7/9 gravity and never found it lacking in cornering prowess because it has the same side knobs as the old Butcher.
If they beefed it up a bit, while still keeping the spirit of the old one, I'm very excited to try it.
3/29/2025 2:02am
Trail is the Maxxis equivalent of exo, for enduro you need the gravity casing. They also have a DH casing, so a bit confusing to be honest...
3/29/2025 2:47am
FWIW a fairly stout friend of mine destroyed exo casings but is living with the trail (super trail? Not sure) casing with no problems. Not sure which Schwalbe casing best maps to exo+though. Looking at the weight might give some clues too as long as the tread pattern and dimensions are the same.
El Granada, CA US
3/29/2025 7:26am
For the Schwalbe Radials, Trail is akin in thickness and weight to Maxxis EXO+ and Conti Enduro. Their Gravity is more like Maxxis DD or Conti DH thickness, but closer to Maxxis DH weight.
Some actual weights to back this up for tires I've purchased:
 Albert Trail Pro Ultra Soft 29:  1,163g.  Albert Gravity Pro Soft 27.5:  1,289g
Magic Mary Trail Pro Ultra Soft 29:  1,170g.  Magic Mary Gravity Pro Soft 27.5:  1,235g
Conti Kryptotal Front 29 DH SS:  1,263g.  Kryptotal Rear 27.5 DH SS:  1,198g
Maxxis Assegai 29 DD MG:  1,284g.  Maxxis Assegai 29 DH MG:  1,370g.  DHR 27.5 DD MT:  1,118g.  DHR 27.5 DH MG:  1,198g
sprungmass
Calgary, AB CA
4/10/2025 9:14am
Anyone else stoked about the new fast Conti tires? I love fast rolling tires on my short travel trail / Downcountry bike and find Maxxis offerings are a bit on the heavy side. Right now my two favourite combos are Forekaster front / Rekon rear OR DHF DC front and Forekaster rear. These combos are 1,755g and 1,865g respectively (EXO/29x2.4)
When looking at these new Conti tires, a Magnotal Soft front (855g) and Trinotal Grip rear (720g) for a total of 1,575g would be pretty rad.
4/13/2025 8:37pm
Current setup: front - Hillbilly grid trail t9 27.5; Rear - Kryptotal Re enduro soft 26"
This has been a very good pairing, but I'm contemplating changing the front for something more planted on hardpack this spring. I still want it to work as best as possible in the loose.
The Schwalbe Albert has my attention at the moment, because it's the only 27.5 radial that comes in the trail casing. (Yes, I care about the extra ~150g on the gravity casing. I want to keep my mini mullet feeling agile!)
My concern with the Albert is that there might not be enough tread depth to deal well with anything soft or loose, and for the same reason, it might not pair very well with the rear Kryptotal, which is a tall tread with awesome mechanical grip.
Valid concern or am I overthinking it?
4/13/2025 9:57pm
Does anyone have experience with pressures comparing Maxxis EXO tyres vs. Schwalbe Trail casing (non radial)? Running the same 1,5 bar the feeling is that Schwalbe is very stiff and at first feel the grip isn't really overwhelming. I'm on soft Magic Mary front and soft Big Betty rear where I previously ran EXO 3C (maxx terra) Assegai and DHR2.
I've recently ran an Assegai in the rear as well, moved there from the front as I intended to wear it out (replaced a worn DHR2) and put a new Assegai in the front. I feel like the grip was better even with the basically bald (side knobs) Assegai in the rear...
4/13/2025 10:17pm
I would agree the super trail casing feels noticeably stiffer than exo and can probably benefit from a slightly lower pressure if all else is equal. I don't love the orange soft compound as a front tire but am fine with it on the back wheel.
Evil96
Portogruaro, VE IT
4/14/2025 12:53am
Current setup: front - Hillbilly grid trail t9 27.5; Rear - Kryptotal Re enduro soft 26"This has been a very good pairing, but I'm contemplating changing...
overthinking, knobs on the Albert are taller than the ones on the assegai, all of them, but, it's pretty packed so in the softest dirt/mud it can pack, mary is the one you want for softer terrain, Tacky would be sweet but it's not a thing yet
