One, tire levers matter. Best ones I've come across are from SuperB. They have a heat treated steel core so don't bend like every other steel core. They have a great contour along the working faces so don't hang up on the bead too Two, a toe strap is dumb handy when working with DH casings and cushcores. Press one section of the bead into the rim drop zone, preferbly near but not on the valve area, with the above tire lever and cinch down the strap hard to hold the bead in place, then work around the tire, pushing bead in with one lever, popping the next section over, just a couple inches at a time. Once I figured this out it made me rue dh skins/cushcore inserts far less. Bought the first set of levers on a lark, bought two additional sets in case they stop making em.
$2.99 at Home Depot. Clamp like a vise & force either 1 or both beads into the center channel. Tire cannot come out of the rim. I've used at most 2 before. Just swallows the tire & rim as one. Can disconnect & ratchet back down on the next section of tire harder than a grown man. It's like having 2 buddies latched onto the tire & rim as you work on the bead.
Drop the tire bead into the center recess of the rim as you walk it around. This allows you to pull the tire over the side wall of the rim with your hands. Yes, even with Conti's. If your rim is asymmetric, install the side with the flat section first.
For all you non compressor having people, I made one of these... ten years ago and it still works. Works better then a compressor, the joe blow charger pump, etc. Its higher flow and as a bonus you look like the unibomber
A really good floor pump is the Topeak Joeblow Mountain II which inflates 722 cm3 of air per stroke. Floor pumps usually inflates about 150-250 cm3...
A really good floor pump is the Topeak Joeblow Mountain II which inflates 722 cm3 of air per stroke. Floor pumps usually inflates about 150-250 cm3 of air per stroke, and other brands mtb specific pumps rarely exceeds 400 cm3 per stroke. I have zero problems getting tires to pop into place with the previous model (683 cm3).
That is awesome! I have an old Lezyne that is the same, very high volume and max 60psi but they havent made them for ages and this one is starting to feel its age... Do you know if the gauge is pretty accurate? The lezyne one is spot on with my digital pressure gague.
Always drop bead into center of rim. This creates slack and makes the job so much easier. #1 rule for installing tires. I just installed Maxxis DH casing with no tire levers.
After the tire is installed you can use soap and water around rim bed and tire bead to reduce friction for an easier tubeless inflation if not working otherwise.
If #2 is not working, install new rim tape.
White (painters) Gorilla Tape does not leave residue on your rim (like the black one does). Word of caution: Gorilla tape is thicker than normal tubeless tape and rims with shallow bed depths will be noticeably harder to install tires, especially if you double wrap
If struggling to install, always revert back to #1. You can install almost any tire without levers if you are patient and massage the bead into the center of the rim. I have noticed deeper rim beds are easier than shallower rim beds, especially with cushcore.
Reading this thread I thought I’d travelled back in time to 2012! Can’t remember the last time I struggled to get a tyre inflated with just a track pump and maybe the valve core removed. But as mentioned elsewhere, never buy anything mucoff, it will be by far the crappest version of what’s available. And the specialized rim strips work really well and are mega cheap and faff free, amazed more brands don’t make them (don’t get any ideas, mucoff)
Pedro’s tire levers are the only lever I will use. Cheap, strong, and just the right shape.
For super stuck beads (tire removal) you can put the wheel down on a soft surface to protect the end cap/hub and step with your heel onto the sidewall of the tire. Works great and saves your hands, especially when sealant has glued the bead on.
If you have trouble getting the tire to fully seat around the bead, put your wheel and tire out in the sun and it will pop in.
Finish the bead install at the valve. That gives you the most slack on the bead when it is dropped into the center.
Installing the tire without sealant at all will make sure you don’t have a big mess if things go sideways.
A lot of good advice mention so far. Only thing I haven't seen that helps a ton is to constantly make sure the bead is dropped...
A lot of good advice mention so far. Only thing I haven't seen that helps a ton is to constantly make sure the bead is dropped into the center of the rim when installing the tire. Makes it so much easier no matter the brand or casing type.
This is everything.
No levers for install, you're just gonna mess up your tape or sidewall.
Being a wheel-smashing connoisseur, I have found myself changing tires far more frequently than desired. My biggest piece of advice is to have the right tools for the job. My second piece of advice would be to follow a standard procedure for every tire install rather than just swearing and getting frustrated. Meat hands are also a plus but not required.
Every tire I mount (in the shop), I use the following items:
Park Tools Multi-Position Wheel Holder (WH-1) - gives you an extra set of hands and keeps you from working on the ground
Pedros Downhill Tire Lever II - Get the leverage you need; don't fight the tire
Crank Brothers Speedier Tire Lever - Use the install end to pin one end of the bead while you work the other side with your Pedros lever
GLASS CLEARER (MUST BE AMMONIA FREE) - Spray the bead and get it nice and slick
Use Kapton tape for rim tape. It’s cheaper, stronger, stickier, and most importantly much thinner than regular rim tape. The less space you give up to tape the more room you have to mount your tire.
Use Kapton tape for rim tape. It’s cheaper, stronger, stickier, and most importantly much thinner than regular rim tape. The less space you give up to...
What thickness? I haven't used that stuff much, but I thought it was more like foil with adhesive.
It’s less than 1mm thick but it’s plenty durable and has no issue being stretched. I’ve been harping on about this stuff for a while and it’s recently been brought to my attention that absolute black is selling rebranded kapton tape at a 500% markup.
But if you do use levers for install, the lever should be oriented the same way as when you take the tire off. Meaning the lever hook is facing up, so it's less likely to mess up the rim tape.
That is awesome! I have an old Lezyne that is the same, very high volume and max 60psi but they havent made them for ages and...
I have a Topeak smartgauge D2 which shows the same pressure as the ǵauge on the floor pump. How accurate they are I don't know, i'm satisfied that it's consistent in measuring and that's enough for my needs. I only have mtb's so I never go above 35 psi. The Joeblow mountain is mainly plastic but it holds up well.
Tips for getting a DH casing schwalbe or conti tire onto a Bontrager rim:Throw away bontrager wheelBuy a different wheelMounting tires on Bontrager rims is total...
Mounting tires on Bontrager rims is total bullshit. Avoid at all costs.
I havnt had the balls to try and take this thing across the border for whistler trips.
Half the kids probably haven't seen this in a while. Post a video of it working. I always wanted to build one of those but I fail at blowing things up cleanly so avoided.
Buy one of these, connect the valve, press the little flat tire button, and run away! If it explodes, no problem, you're far away! Impossible to get covered in a cloud of sealant!
Whilst this is more for taking them off - a black round trash can or large flower pot where you can rest the spokes on the...
Whilst this is more for taking them off - a black round trash can or large flower pot where you can rest the spokes on the edge and then really reef on the tire is the best way to break the bead....
My family has a lot of bikes and this method (used by almost every bike shops I'd guess) has sped things up considerably.
I use the trash can trick (learned it for installing inserts) on every enduro or DH casing tire installation and removal. It makes life considerably less sucky. I don't have to resort to any other ridiculous tricks when mounting or removing pain-in-the-arse tires 95% of the time.
You don't need a fancy air compressor nozzle to seat an annoying tire. The cheap brass air blower nozzle that most of them come with seals good enough when placed on an open valve core to give it a shot of air to set the bead.
Buying a compressor is worth it for the annoying tires that won't set. I spent too many hours of my life hacking tires in the early tubeless days. It's a false economy to hack around, and you will always find other uses for an air compressor if you're DIY inclined.
It’s less than 1mm thick but it’s plenty durable and has no issue being stretched. I’ve been harping on about this stuff for a while and...
AbsoluteBlack do go out of their way to deny that this is off the shelf Kapton tape but color me skeptical of their AI generated explanation.
Interesting, I'll check it out when I need new tape. 1 mil is 25 microns, so it's 1/4 the thickness of absolute black. Most manufacturers don't list tape thickness, but ai is saying 4-6mil is average.
Interesting, I'll check it out when I need new tape. 1 mil is 25 microns, so it's 1/4 the thickness of absolute black. Most manufacturers don't...
Please put down the AI tools and think critically about what 2 layers of 5mm thick rim tape would do to a wheel lmao
Man, I didn't realize that this was still an issue until I saw this thread. Pretty quickly after I started mountain biking, I invested in a small air compressor - that makes setting beads of even stiff tires easy. I've always used good quality tape (prefer Reserve or DT), which while expensive, it bonds better and lasts longer between retaping (and doesn't require trimming to width). Prior to Filmore valves, I learned to remove valve cores when seating beads (or adding sealant). I've been running durable carbon rims for years (WAO and Reserve), and am able to mount Maxxis DH casings on them by hand without a lever. Brand new Conti DH I can do without a lever but if my hands are tired or I'm in a hurry a Pedro's lever works nicely. After they've been mounted once they go on easily without a lever subsequently. The latest Schwalbe Gravity casings are tricky because they don't want to stay in the rim channel until you get about 80% of the bead in, so a rubber OneUp/Voile strap helps act as a third hand. When trying to get a stubborn bead to pop with tighter tires, I do a little spritz of isopropyl alcohol between the tire bead and rim lip to lubricate the tape surface. (I use iso because it will evaporate quickly afterwards for no mess.) I guess since I change tires often I learned pretty quickly through trial and error what works and doesn't to do it quickly and efficiently.
Hyper cleaning the rim & old tire beads will make things go much easier.
https://www.vitalmtb.com/forums/The-Hub,2/Joe-Barnes-DIY-Coke-Bottle-Tubeless-Compressor-Hack,8450
This is everything.
$20 for 33ft
Vs
$10 for 100ft
no issues here if you tape the rim?
Safety first! 😂
Use the meat of your palm, not your thumbs.
This guy doesn't know mil and mm are different lmao
Damn. Today I learned.
Post a reply to: Tips for Changing Tires
