Matching Brand Suspension
It seems like most people tend to run matching brand front and rear suspension; is there any real advantage to this? Is it mostly just an aesthetics thing? Or is there a legit reason like damping methods between brands differing enough to cause some level of imbalance?
4/3/2026 10:07pm Edited Date/Time 4/3/2026 10:10pm
MoldyMTB wrote:
It seems like most people tend to run matching brand front and rear suspension; is there any real advantage to this? Is it mostly just an...
I think it's just a "the bike came like this and I have no reason to change it" thing in most cases.  However I'd guess if you're in the market for new suspension, any reasons you might choose Brand XYZ for the fork probably apply to the shock too, or vice-versa.
One of my bikes has a RS SDU Coil in place of a blown-up Fox X2, but there was no reason to replace the Fox fork.  They both contain Vorsprung parts, though, so maybe I still have matched suspension.
4/3/2026 10:43pm
Different brands do have different suspension feels but that’s really getting off into the weeds and most riders won’t be able to tell or care. You can sometimes run into some weird combos but thats pretty rare.
4/4/2026 6:25am
I mix suspension brands; (currently on a  Lyrik w/ MRP damper and a Cane Creek shock w/ an Ohlins spring) because I'm chasing a particular feel.
(Not tire brands though, what kind of monster does that?)
owl-x
Shell Beach, CA US
4/4/2026 8:21am
dolface wrote:
I mix suspension brands; (currently on a  Lyrik w/ MRP damper and a Cane Creek shock w/ an Ohlins spring) because I'm chasing a particular feel.(Not...
aaronufl
Poulsbo, WA US
4/4/2026 8:47am
I think you may notice slight differences if you're doing back to back runs on different combos of fork/shocks. But like most things on the bike it eventually fades into the background, you adjust, and then stop thinking about it.
El Granada, CA US
4/4/2026 12:15pm
Trying to get a pretty overdamped shock like EXT to match normal retail suspension is hard, but other than that you can usually dial them in to feel pretty balanced.  I find setting up matching brands to feel balanced is a bit easier/quicker though.
4/4/2026 4:16pm
I run which ever works best. In my opinion I do not think there’s one brand with the best fork and shock on the market. Different brands that make the best shock and best fork.
4/6/2026 10:37am
I run which ever works best. In my opinion I do not think there’s one brand with the best fork and shock on the market. Different...
Just out of curiosity what do you think the best shock and fork?
4/6/2026 10:51am
probably aesthetic reasons. I've had the same bike going on 4 years, between a 24' Float X2, 24' DHX2, and 26' Float X2, and Intend Hover; the fox shocks felt the most dramatically different. while the intend felt most like a fox coil shock.
so yeah.... whatever works best @carlinojoevideo
4/6/2026 11:12am
Mixing tire brands is a red line I will never cross. Yes, that's completely irrational. 😂
4/6/2026 11:38am
To add to what’s already been said, I think most ride feel differences between two different suspension brands on a bike would be over shadowed by maintenance intervals.
In other words, servicing suspension often is going to make a bigger ride feel difference than having a different brand fork vs shock.
rtclark
Vail, CO US
4/6/2026 12:42pm
It's a known known that your bike will underperform if you mismatch front and rear suspension, just like with tires.
astrizzle
Moscow, ID US
4/6/2026 1:19pm
For myself I'd like to think it's a performance thing but it is ALSO an "looks" thing. Matched tires and suspension just feels and looks right to me.
That's why I never understood when big companies like Santa Cruz mix suspension brands on their stock builds, ugly!!
Roy
Nashua, NH US
4/6/2026 1:49pm Edited Date/Time 4/6/2026 7:31pm
With my current DH bike, I run an Ohlins coil shock and Dorado fork. And it's been the best set up I've ever used.
Falcon
Menifee, CA US
4/6/2026 2:35pm
For the same reason I run the same tire brand F/R, the same brand jersey and shorts, the same brand of stem, bars and grips, and always put my pants on left-foot first, I would never run two different brands of suspension. The reason is I'm psychotic. That's the reason. No actual performance measurement, just psychosis.
4/6/2026 2:47pm
Until Fast makes an actual fork, I guess i'm shit out of luck ! I dont really care about mixing suspension, as long as the colour scheme isnt terrible
Mixing tires brands feels wrong, but i'm too cheap to not use the tires I already have
4/6/2026 3:10pm
My Hightower V2 has a RS SDU W/MegNeg and a Fox Factory 36.
4/6/2026 4:10pm
Lol my '26 Fox 36 and Vivid Ultimate are a great combo on my Gen 5 Sight. Also Assegai Maxxgrip DD on the front and the Kryptotal Front Soft on the rear, very solid tire combo that will give you some good miles
Digit Bikes
Irvine, CA US
4/6/2026 8:46pm Edited Date/Time 4/6/2026 11:08pm
In no particular order:
1: Most people ride whatever suspension came stock on their bike. It's easier for factories/brands to buy both front and rear suspension parts from the same vendor.
ii: The stickers can match.
thirdly: People like to pick a thing and be a d!ck about it. If you've picked a favorite suspension brand you'd want it on the front and the rear.
IV: People like to pretend they're pro, and pros have one suspension sponsor who provides them both forks and shocks.
E: Bike companies custom tune rear shocks to work with their suspension linkage. To some degree OEM rear shocks are a starter kit from which the optimum tune can be developed. Though not all OEM shocks are the same, the end goal, and hopefully the result after tuning may be somewhat similar, regardless of which brand is on the rear.
Outlawed
Vancouver Island, BC CA
4/6/2026 10:47pm
I run whatever the bike comes with and when a good enough deal comes across my radar, if it makes sense to upgrade, I do it.
Enduro bike is currently z1 coil grip2 fork with a ohlins ttx2 shock
Trail bike is z1 coil fork with float x shock.
Picked up both Z1 coils on sale for $500 bucks each, the grip2 was out of an old 36 with a roached CSU that fox wanted nearly $500 bucks to change out for me. The Ohlins was a take off deal from a bike manufacture ($400 bucks and it was tuned for my bike already) and the Float X was a never used take off from a buddy that was also tuned for my trail bike.
Pretty agnostic as most modern suspension is pretty damn good, but I will say the Ohlins rear shock is considerably better then the fox/rock shox stuff I have ridden thus far.
4/7/2026 12:53am
Mostly a preference thing. Matching brands looks clean and the damping “language” is similar, so it’s easier to tune both ends to feel the same... but tons of people mix and match with zero issues. As long as you can dial in sag, rebound, and support, the bike rides fine. Aesthetics + convenience more than anything.
4/7/2026 1:28am
I run RS front and back exclusively mostly for servicing reasons, i.e. it's much easier to service RS stuff than it is Fox stuff.
On the other hand the idea of mixing and matching does give me the heeby jeebies. Mixed tyres, suspension, mix and match drivetrain. Different front to back brakes, hell, mixing rims and hubs? 😬
selliott
Mission Viejo, CA US
4/7/2026 9:10am Edited Date/Time 4/7/2026 9:10am
I don’t know I think yall are sleeping on the mismatched tires. I’m running an assegai in the front and a kryptotal in the rear (mainly for its wear characteristics). You can pry both from my cold dead hands. I’m loyal to whoever makes the best gear aesthetics be damned.
storm.racing
Silverton, CO US
4/7/2026 9:20am Edited Date/Time 4/7/2026 9:21am
what does this classify as? IMG 6894 0IMG 6892 0
4/7/2026 3:59pm
Places for Vanilla/chocolate swirl soft serve? : r/Calgary
4/7/2026 6:50pm
For my riding style, personally, I like the Ohlins DH38, with factory airspring, and I have the damping adjusted to be slightly softer HSC and faster rebound.  The Fox DHX2 shock has a great free feeling, out of the box for me. They come a hair on the slow side for rebound, but it's not hard to get that sped up.   I have Telum on my ebike, which is very, very good, and the adjustment range can basically reach all levels and speeds of riders. Really amazing free feel that is offers.
Going into 2026 season, I'm very interested to try the new Boxxer and Fox40.  I think they both made the changes that I struggled with. Boxxer, the air spring ramped up like crazy.  The Fox 40 chassis was much too rigid for my liking.
thejake
Carnation, WA US
4/8/2026 7:35am
If you really want to mess with people get different color brake lever.
storm.racing
Silverton, CO US
4/8/2026 8:23am
hahahahahah thank you for this
storm.racing
Silverton, CO US
4/8/2026 8:24am
different brakes. dont stop now (puns not intended)
Eae903
Laramie, WY US
4/8/2026 2:27pm
I find that running matching suspension can lead to bikes feeling predictable and consistent front and rear since different brands will have different damping philosophies. I find fox to be supportive but a little firm off the top and rs to be more supple initially but moves through travel easier. That being said, I'm running rs front and rear on the DH bike (came stock) and Manitou front and Cane Creek rear on the trail bike, and the trail bike feels great and consistent. I'll run what ever works best, or what ever I'm the most interested in at the time. Ohlins is next on my list, probably for the DH bike.
Post a reply to: Matching Brand Suspension
