2026 MTB Tech Rumors and Innovation - Longer and Slacker
4/5/2026 10:35pm
Onawalk wrote:
Found it....."The reason facts don't change most people's opinions is because most people don't use facts to form their opinions. They use their opinions to form...
Found it.....
"The reason facts don't change most people's opinions is because most people don't use facts to form their opinions. They use their opinions to form their 'facts'."  — Wayne Gretzky probably
Who knew old mate was a student of Jonathan Swift!
Big Dos
4/6/2026 2:57am
How long until we see the Ochain integrated into the flight attendant system? Seems like a logical step
shreda
4/6/2026 8:58am Edited Date/Time 4/6/2026 8:59am
Reece Wilson testing what looks like a new Dominion (From his IG stories)
IMG 6024
Plus the complete bike
IMG 6026
33
Eae903
Laramie, WY US
4/6/2026 9:23am
shreda wrote:
Reece Wilson testing what looks like a new Dominion (From his IG stories)Plus the complete bike
IMG 6024
IMG 6026
Do we have any details on the Dorado they're running other than the 220mm travel? I'm seriously hoping Manitou updates the damper they run. A Mezzer or Dorado with a pressure tube style damper instead of the bladder would be amazing.
4/6/2026 9:26am
IMG 6024
IMG 6026
Hes fucking crazy and I am here for it.
Slavid666
Santa Rosa, CA US
4/6/2026 9:28am
IMG 6024
IMG 6026
Good spot. That is something that I am actually really interested in. Would be interested to see if they managed to smooth out the power band compared to the original Dominions. The lever looks longer with less hook, I would suspect that they made some improvements to reduce dead stroke allowing you to run levers closer to the bar.
GRM50
Lebanon, NH US
4/6/2026 9:30am
Might have been discussed already but Druid CorE with updated Avinox 4/9/26?Screenshot 2026-04-06 at 12.29.20%E2%80%AFPM.png?VersionId=jXxL3xF5pqc
Eae903
Laramie, WY US
4/6/2026 9:47am
IMG 6024
IMG 6026
Slavid666 wrote:
Good spot. That is something that I am actually really interested in. Would be interested to see if they managed to smooth out the power band...
But the way they deliver their power is one of the best things about the Dominions. We've got enough brakes that build power gradually, give me a lot of bite and a fast ramp up.
4/6/2026 10:30am
Any ideas that this is for?
image 653.png?VersionId=uJmmnA8hmZHC
4/6/2026 10:38am
Kusa wrote:
https://www.cannondale.com/en-us/bikes/mountain/trail-bikes/bad-habit
Is it just me or does this bike a have a classic knolly basement vibes? Obviously the rocker and stays are way different but the seat...
Is it just me or does this bike a have a classic knolly basement vibes? Obviously the rocker and stays are way different but the seat tube visually pointing at the front end of the bb cluster???
You know aside from the carbon, the shock layout, the yoke, the tube diameter, the paint work, the branding, the build, it's pretty much a knolly.
You know aside from the carbon, the shock layout, the yoke, the tube diameter, the paint work, the branding, the build, it's pretty much a knolly. 17754238036233302532414353211564
Fair. Very fair.
Slavid666
Santa Rosa, CA US
4/6/2026 10:39am
IMG 6024
IMG 6026
Eae903 wrote:
But the way they deliver their power is one of the best things about the Dominions. We've got enough brakes that build power gradually, give me...
Let me introduce you to my friend shimano... lol Dominions have kind of the worst of both worlds, lots of lever travel and a short ramp that goes from initial bite to rear tire lockup very quickly. Ride T4V4's and Dominions back-to-back in steep loose over loose conditions and you will appreciate the power and control that the hopes gift you with less lever travel. Don't get me wrong I like my dominions; my 2 primary bikes run both the T4V4's and A4's, but the A4's are not easy to keep from locking up in situations where the hopes have zero issue. The hopes have more power overall too... Hayes has some areas to shore up now that they are pushing almost 8 years with the design.
bcurrancy
Waitsfield, VT US
4/6/2026 11:38am
Slavid666 wrote:
Let me introduce you to my friend shimano... lol Dominions have kind of the worst of both worlds, lots of lever travel and a short ramp...
The lever throw is pretty easily adjustable when you're setting them up... There's a grub screw behind the lever blade. I shortened mine up once, and the start/ bite point is much closer to the grips.... they've remained consistent for years. I personally find the Dominion power much easier to modulate than Shimanos as well, especially given that you could never tell when Shimanos from M8000/81000 series would actually bite.
Slavid666
Santa Rosa, CA US
4/6/2026 11:45am
bcurrancy wrote:
The lever throw is pretty easily adjustable when you're setting them up... There's a grub screw behind the lever blade. I shortened mine up once, and...
You will never get dominions to have as little travel as what you can get out of T4V4's. The little screw is not how you change the bite point of the Dominions and TBH there isnt much you can do about it, the master cylinder piston is as close as you are going to get to the timing port as it is. If bled correctly T4V4's have much less dead stroke, not Kaha dead stroke but not a lot either.
4/6/2026 11:50am
Slavid666 wrote:
You will never get dominions to have as little travel as what you can get out of T4V4's. The little screw is not how you change...
ShapeThings
Oakland, CA US
4/6/2026 11:50am Edited Date/Time 4/6/2026 11:55am
First round of Avinox M2 e-bikes out Thursday. Amflow, Forbidden, Atherton, Mondraker, Propain, Crestline, Pivot and a few more have already soft launched but the drive system(s) will be officially revealed. Head to the ebike thread for more.
bcurrancy
Waitsfield, VT US
4/6/2026 11:51am
There are lots of ways to shorten the dead stroke, especially during the bleed process. I've found the grub screw adjustment to be the easiest way to match each lever, but you can make the dead stroke virtually nothing if you really want.
26aintdead
Rossland, BC CA
4/6/2026 11:57am
I think I disagree with most of what you said. What is the little screw for then if not for bite point adjustment?
Maybe you have a bad bleed. It works like a charm on my brakes and makes the bite point either very close to the bar or further away.
lickmycrinkle
Beverly Hills, CA US
4/6/2026 12:00pm
Sounds like a skill issue.
Anyway, there's a thread for you to whine about brakes in. Your comments add nothing about tech rumors.
Slavid666
Santa Rosa, CA US
4/6/2026 12:17pm
26aintdead wrote:
I think I disagree with most of what you said. What is the little screw for then if not for bite point adjustment?Maybe you have a...
Sounds like you haven't pulled apart the lever and seen what it does? Might be worth your time to check it out if you haven't. If you advance the MC piston much further than where it comes from factory it closes the system off, Its a dead simple system that has little adjustment to decrease the dead stroke. A closes brake system will work for a min but not much more than that. This has all been discussed and beaten to death in the brake thread. You can pressurize the system during the bleed to try and fake it like people have been doing for years with Shimano's to reduce dead stoke but again its a short-term solution.
The dead stroke with the A4's is widely discussed and a known quantity. As are some of the QC caliper leaking issues that have hovered over the years.
My point stands, its a 8+ year old design that was a class leader for a long time. It has not been for many years and there are a number of things that Hayes could improve upon to make it better. Making it more shimano like is not one of them in my opinion.
Sounds like the Hayes fan-boi's see no need in improving on the greatest brake ever made, my mistake lol.
onxx
Laguna Beach, CA US
4/6/2026 1:41pm
Looks like the new master cylinder is mounted at a shallower angle to the bars, like the sram brakes are now. Also looks like a new bar clamp and they moved the door for the bladder to the inside, facing the bars.
4/6/2026 1:50pm
onxx wrote:
Looks like the new master cylinder is mounted at a shallower angle to the bars, like the sram brakes are now. Also looks like a new...
Thanks, I was specifically asking about the little tab-thing at the MC end of the lever, right where the point of of the arrowhead is.
4/6/2026 1:55pm Edited Date/Time 4/6/2026 2:04pm
IMG 6024
IMG 6026
Man that is one ugly bike... Looks to be a new gamux frame? Were they running the potential Manitou coil prototype?
Edit confirmed it is a new gamux from back in october I just didn't see until now. From what is visible on reece's instagram, rear shock appears to be standard.
El Granada, CA US
4/6/2026 2:34pm
Maybe it's just a shield to keep dirt & debris out of the front of the pivot area?
Trocko
Rocky, CO US
4/6/2026 7:00pm
Michelin has some new wild enduros coming
Outlawed
Vancouver Island, BC CA
4/6/2026 9:07pm
Surprised the second part of the promo clip was not posted:
Date stamp was 04-17-2026
123123123
If the chirping birds in Cumberland this weekend are correct, should be E-Dread debut.
TheKaiser
Storrs, CT US
4/6/2026 11:00pm
IMG 6024
IMG 6026
I forget where I heard it, but supposedly these new Dominions are launching at the Sea Otter and are pumping....MINERAL OIL! 😲If true, that is actually a plus for me, but I know it is a very contentious topic and will alienate a lot of existing users and DOT fans.
4/7/2026 1:23am
That leaves only Hope left on the DOT train?
Post a reply to: 2026 MTB Tech Rumors and Innovation - Longer and Slacker
