1/8/2026 4:06am
Nobble wrote:
I had T4V4’s on my Enduro with standard lines, my friend had T4V4 with braided on his Patrol. Same pads and rotors.They basically felt the same...
They basically felt the same, the only real upside is durability. Hope even says the same thing themselves.
The steel braid isn’t tensioned, it isn’t going to do anything significant to resist expansion.
Yep, that's been my experience too, the Hope braided lines do nothing for lever feel, the external steel braiding is just there for additional protection. Additionally, installing them is a huge faff, the steel braiding splits open real easy and then getting it all into the olive is a royal pain. They are also thicker and thus may not play nice will every frame out there in regards to cable ports and internal guide hoses. TL/DR "these are not the hoses you are looking for."
I'd be very intrigued by running HEL lines on other brakes to see what difference they make in stiffness/bite point feel. Don't know if they are available to purchase separately.
mtbjoe
Leawood, KS, USA
1/8/2026 5:06am
Yep, that's been my experience too, the Hope braided lines do nothing for lever feel, the external steel braiding is just there for additional protection. Additionally...
Disagree about the braided lines. Maybe placebo but I think they are firmer
1/8/2026 5:10am
I've see several first hand accounts of the silver calipers swapping directly for Shimano calipers.  I have not done it personally, but I wouldn't worry about trying it.  If I were to swap I would use the bronze calipers just because its easy to get a big roll of bulk hose and add the ends.
I'm very interested to feel these brakes but I'm so happy with the TRP's I'm currently running that I just can't bring myself to pull them off.  I just really enjoy them.
I have swapped TRP calipers in place of Shimanos and not had a problem.  I think alot of the banjo diameters are the same.  I just wonder if the caliper comes with the banjo bolt.
1/8/2026 9:50am
RE: braided lines, I'm working with Maven Ultimates, so I'll need a version that deals with banjos unfortunately.  I mean I guess I could buy a Bronze caliper but that adds quite a bit to the whole experiment.  I'd consider trying some variation of a Kevlar line too, if someone else could point to a kit that was compatible with Maven banjos and was actually stiffer.
On the other hand, when I ran Dominions, I know they had a braided line that was actually slightly larger (to the point of being an issue on certain frames like gen 3 Levo), but it actually visibly flexed when I squeezed the lever.
Evil96
Portogruaro, VE, IT
1/8/2026 10:20am
if you think the Hope ones is a huge faff and they split open try to install the raw Goodridge on Trickstuff good luck
1/9/2026 11:03am
I finally wrapped up my XT vs. XT brake test, here for your viewing pleasure - https://www.vitalmtb.com/features/comparing-shimano-xt-brake-performance-m8100-vs-m8200
The TLDR:
- New brakes worked much more consistently. Never had any wandering bite point issues and the lever feel stayed solid in varying conditions. When I tested the new XTR brakes last year, I had a similar experience. I think the new oil/seals play a huge part in this, and the 'stiffer caliper' probably has some effect too. Don't @ me about
- New reach adjust dial is a pain to turn IMO. I like the grip of the old one and the ability to barely turn it and change the lever position. The new adjuster has preset detents.
- You can do the bleed with just hex wrenches now thanks to the new bleeding port. Not a huge deal, but I always misplace my 7mm wrench so saved me some time.
- The new lever pivot point/lever blade path: could not tell a difference (good or bad). I like the tiny lever feel of Shimano brakes, and you keep that with the new XTs. But all the marketing around the new ErgoFlow pivot location didn't amount to a difference in feel to me.
- The new finned pad design is quieter than the old ones. It's not absolute silent, and you still get some classic Shimano pad knock under heavy braking or rolling over really chattery sections. I did a day testing with new pads, old pads, velcro under the fins, flexing the pad spring out, and fin-less pads. The best setup was finless pads and flexed pad spring.
- Shimano says the new caliper is stiffer, and power transfer at the lever is more efficient, which = a bit more power. Riding back to back with the brakes, and one of each at the same time, I was struggling to say one felt more powerful. I did some testing with BrakeAce sensors, and those showed that I did brake for less time with the new brakes, and on average was riding faster. I also was able to generate some higher peak power out of the new rear brake. All of that to say—I'd say the new brakes are a touch more powerful, and I felt this most in the ability to modulate that power more precisely. They didn't feel so on-off like the old models.
1/9/2026 11:06am
I'll add that the new brakes still didn't give me the immediate stopping power of other brakes. I went back to Mavens last week and it was instant how much harder I could brake, and how much easier it was to generate that power. Not to say XTs don't work great for like 95% of trails I ride. I just think Shimano is holding out until that new Saint brake is released to compete power-wise with other brands.
StilPhone
Channel Islands, JE
1/9/2026 11:11am
You mention in the review that the new M8200 aren't as powerful as the TRP Evo Pros - how do they compare to the DHR-Evo 9non Pro)?
1/9/2026 11:26am
StilPhone wrote:
You mention in the review that the new M8200 aren't as powerful as the TRP Evo Pros - how do they compare to the DHR-Evo 9non...
I'd say similar story—the DHR Evo's still offer more power readily available at your finger tips.
Evwan
Sunnyvale, CA, USA
1/9/2026 1:08pm Edited Date/Time 1/9/2026 1:09pm
I'll add that the new brakes still didn't give me the immediate stopping power of other brakes. I went back to Mavens last week and it...
It's crazy to me that Shimano didn't update the XT and XTR with larger caliper pistons. They've really fallen behind the standard for braking power.
I'm pretty sure every other manufacturer offers more power at this point: maven, maven base, TRP DHR Evo/pro, Lewis LHP/LHT, Trickstuff, Hayes dominion, Hope, Magura, Intend, Radic.
I agree with you that XT is good enough for 95% of situations, but that other 5% is pretty important.
I just hope they release the new saint brakes this year with larger caliper pistons. Until then, Shaven is the move.
Nice review btw - always interesting to hear your thoughts.
AgrAde
., BV
1/9/2026 5:16pm Edited Date/Time 1/9/2026 5:18pm
Limiting power on a higher end 4 piston brake so that the DH brake can be even more powerful is such a stupid idea. Cheap/light/powerful, pick none of those things and buy some XTs... Now with added cable rattle and handlebar scuffing.
1/10/2026 1:02am
Evwan wrote:
It's crazy to me that Shimano didn't update the XT and XTR with larger caliper pistons. They've really fallen behind the standard for braking power. I'm pretty...
But it’s not really that fair to compare XT vs maven (or other big ones) anyway, XT is basically a trail brake and maven is full on gravity. Lets see what they are doing with that new Saint model when it comes, my guess is that pistons are bigger but not maven size.
mtbjoe
Leawood, KS, USA
1/12/2026 5:50am
Anyone run their hope brakes without the phenolic insert? Seems like they could have the potential to deform and be less uniform than just the steel pistons
mtbjoe
Leawood, KS, USA
1/12/2026 10:17am
Melting? They are hollow and could deform easier than the steel pistons for sure
Finkill
1/12/2026 10:34am
What is the up side to taking the inserts out, wasn't clear on this the last time it was discussed. Is it just because, or is there a functional reason for wanting to try it?
Kapolczer
1/12/2026 8:27pm
The signature Hope squeal existed on the tech3 brakes as well, correct? If so, and given these brakes used strictly phenolic pistons, with a similar design to the inserts on the tech4 brakes, it seems possible that they are the common denominator causing the squealing. Now what the compounding factors could be that cause that in these brakes is beyond my knowledge base.
Will the Hopes work without the inserts? Probably. Given that the TS maxima’s use the same pad shape and no inserts in their SS hollow pistons. Do the inserts improve heat resistance? Probably.  But I’d say a good majority of riders are out here regularly fading these brakes, so that’s just something that would need to be tested individually. I’m planning on doing some messing around with brakes these year (have some HEL Advocates on route, and might swap calipers and levers with the Hopes for fun), so might give it a try myself, as in the summer the squeal makes POV video content hard to watch/listen to.
Its worth noting the HEL Advocates also use hollow SS pistons, but with more wall thickness. Although, the pistons are castellated which they note improves heat dissipations (allowing air to move from the centre of the pistons or less contact area with the pads?)IMG 9907
AgrAde
., BV
1/12/2026 9:59pm
There's an idea for boutique brake manufacturers. Ducted ventilation for the back of the pads.
mtbjoe
Leawood, KS, USA
1/13/2026 4:30am
Radic has near identical pistons with no insert. Trick stuff as well. If there’s flex with the phenolic insert, might get crisper action without
1/13/2026 9:01am
Water cooling!
17683233164861349664866330926136.jpg?VersionId=1QM88c8D3B3JRuNhft
Wait this is a real thing!
1000014081
1/14/2026 8:03am
Incorrect material choice is part of the design.
It's not sharp edges. The piston is flat where it is pressing on the backplate but where the hole is, where the wear material is anchored in, it creates a bulge. To me it looks like it gets hot enough to become soft and thus deforms.
Curiously filing it off it looks looks to be very hard (it creates fine particle dust) and possibly glass filled. Why this happens is beyond my knowledge, but I can 100 percent confirm it happens through use. And is more severe in the back than the front.
Nobble
Lakewood, CO, USA
1/14/2026 8:13am
I believe phenolic resins are a thermoset not a thermoplastic.
That means they do not melt at high temperatures. You have to get them hot enough to actually damage the polymer chain for them to do anything.
Slavid666
Santa Rosa, CA, USA
1/14/2026 10:57am
Correct they are thermosets, most are very, very stiff in compressive loading situations, >30ksi. Just as stiff as the aluminum caliper under similar compressive loadings. The only reason there would be impressions and deformations in the phenolic piston blocks is due to poor design leading to stress raisers that allow for point loading putting the material into a plastic deformation condition above typical elastic conditions. I personally have never seen such issues with the phenolic inserts in my Hopes, and I have yet to ever hear of anyone mention it before.
I don't have a stress-strain curve for Bakelite or any other phenolic resin, but I feel pretty confident that its going to be quite steep, as most thermoset resins are, that's why they crack so easily. I believe you guys are thinking that our brakes are capable of generating significantly more clamping force than they actually are.
The enduro mtb mag brake shootout has what I would assume are line pressures measured during the brake dyno testing of the brake systems. If that is correct at ~800 psi of fluid pressure you are going to be hard pressed to start flexing anything in those pistons. Using the total caliper piston surface area of a maven for instance, ~1106mm^2 with a line pressure of 56bar you are generating about 1392lb/f total, or about 350 each thereabouts.
If anyone has a spare insert I can pop it on our Instron and see how much deflection is actually happening at 350lb/f. I have a 5kN load cell for the short fame system.
1/14/2026 3:28pm
I have tested stainless castellated pistons with a 1.5mm wall thickness back to back with phenolic. If your goal is to insulate the calipers from heat, the phenolic is better. No contest. Pretty much instantly 10% lower caliper temp in comparison.
From a manufacturing standpoint, stainless is easier to deal with. All you need is a mill or lathe and you’re good to go. Phenolic pistons have additives to increase max temp and strength. They are compression molded and then ground to their final OD.
Brake pressures can get quite high. I’ve seen 3500psi from a code lever. That’s a fair bit of force through each piston, but when you look at stress levels, you could get away with a thinner wall than what you’d be comfortable with really.
Slavid666
Santa Rosa, CA, USA
1/14/2026 6:32pm
I have tested stainless castellated pistons with a 1.5mm wall thickness back to back with phenolic. If your goal is to insulate the calipers from heat...
How much lever force was required to obtain that pressure? I could probably do the hand calcs but don’t really feel that motivated lol.
1/14/2026 6:59pm
Don’t remember off the top of my head since that was a while ago. It was a fair but though. Only possible with a stoppie on pavement or just squeezing the levers hard just because. Although I do remember that 3500 psi was not as much as what was possible just squeezing the levers as hard as you could. If I remember right 0-1000psi was the real world range.
1/15/2026 2:00am Edited Date/Time 1/15/2026 2:06am
Slavid666 wrote:
Correct they are thermosets, most are very, very stiff in compressive loading situations, >30ksi. Just as stiff as the aluminum caliper under similar compressive loadings. The...
I understand the basics behind it. On the other hand, if you have a new brake with flat (or as designed) pistons, that grow bulges on the surface after you go through a few sets of pads, bulges that prevent the bleed block from being inserted unless filed down, those have to come from somewhere.
I think my brakes were not the only ones I saw this on, but other than heat generated during use, I do not see a single reason for these on my brakes. It's not a special piston or something like that, the brakes were serviced, inspected, used by me and only me all the time.
I'll have a look if my current ones have the same problem and I don't think I have any pictures from when the issue was most pronounced, so typing it out is all I have at the moment.
EDIT: hot damn, I have pics. Not of my bike, but all the same.
1000008333.jpg?VersionId=LQgXjPk5YmnbW1000008332
rugbyred
1/15/2026 5:48am
Primoz, could that be a build up or dust, dirt, brake pad material ?
1/15/2026 6:01am
Nope. You can see the castleation in one of these bulges and nowhere else on the piston where they should be. Also this was very hard, I used a file to file them off on my brakes to be able to put the bleedblock in the caliper. The stuff was hard.
Digit Bikes
Irvine, CA, USA
1/15/2026 2:34pm
image 554
The Base is fundamentally quite a different brake to the others. In addition to the swinglink delete:
Base also has 4 x 18mm pistons vs 2 x 18 + 2 x 19.5mm on the others.
Base doesn't not have a hose banjo at the caliper.
The Bronze, Silver, Ultimate designations are levels of premium, The oversimplified explanation is that Bronze has bushing pivots, Silver adds bearings, Ultimate has titanium
1/15/2026 6:23pm
Bronze also lacks the contact adjuster, and no banjo fitting.  SLV/ULT both have that.
