Have We Been Measuring Sag Wrong? (and how to fix it...)
Edited Date/Time 6/15/2025 9:48am
Dave Cerutti from Rulezman Suspension is at it again, this time he has some observations and opinions on how we measure sag, and how we SHOULD be doing it. He is also getting involved with distributing a new product to help us do it the right way. Check out the video below to learn more.
Slacker MTB Pro Kit is available from 15th June from getslacker.com in the US and Rulezman.com in the EU/UK area. MSRP: $374.95 USD.
2 96 39 1.jpg?VersionId=GYxDTkELsr984zr7ov2xMhCiqOFOJ10 0
easton
Squamish, BC, CA
6/15/2025 10:13am Edited Date/Time 6/15/2025 10:16am
Pedantic critique: a measurement error from 25% sag to 29% sag is not 4%, it's 4 percentage points. The actual difference is 4/25=0.16, actually a 16% difference.
Also I couldn't make it through this very long video and the product is wildly expensive for what it is.
Blake_Motley
Chula Vista, CA, USA
6/15/2025 10:39am
Dave Cerutti from Rulezman Suspension is at it again, this time he has some observations and opinions on how we measure sag, and how we SHOULD...
This strikes me as excessive. Sag is a relative measurement anyway, there’s very little value in actually knowing the number. I guess you can get a little more precision out of it, and it could be cool to have as a team or a shop, but it’s pretty expensive for an individual
6/15/2025 10:40am
Sag is one thing, weight distribution is another. I think this is a component that varies quite considerably between people and isn’t taken account of at the moment. When you stick on a new stem that is 10mm shorter you’re changing your front wheel weight by as much as a couple of kg. His bar height no. 111-113cm is interesting, I need to check his theory - I am 5’7” and have landed at 110cm - again a 1-2cm change from my old setup has made a difference (positive).
6/15/2025 11:08am
Id have no idea what sag im running. other than a starting point, thats all its good for - in the rear i'd guess closer to 20% than 30%(based on shock stroke)
my bikes ride sick since I stopped caring about "but im about 30/20% sag"
Buckets Up
Hancock, MI, USA
6/15/2025 11:14am
Unless you have a bike with a very specific leverage curve designed around a specific sag point (old Santa Cruz?) sag seems almost completely irrelevant. Set up your suspension to your preferences for how it behaves dynamically on the trail not a single static value.
6/15/2025 11:22am
No, we haven’t been measuring sag wrong. Any method of measuring sag that is repeatable is an acceptable way to measure sag. As it is something that must be tuned as opposed to setting to a specific percentage, being able to repeatably measure sag is the most important thing. You can do this seated and measuring at the shock just fine. If someone wants to measure it with a whole bunch of kit that’s fine, but telling everyone they are wrong and do it wrong is silly. It is definitely worth noting that on more progressive bikes you shouldn’t be surprised if you run under 30% sag at the shock, though.
As an aside, I find it comical that there’s all this accuracy and yet wheel travel is being measured by eyeballing a ruler in the frame and the measurement is impacted by horizontal wheel travel as well.
6/15/2025 11:55am
Back at it again creating his own hype by saying "don't believe the hype" and saying that he's going to change the mtb world. Not quite....
Setting sag is not that deep, I've done this with measuring the shock sag and just looking up what sag that is at the axle using a linkage model on the computer (cost 0€).
6/15/2025 12:11pm
It’s not important how accurate your sag measurement is, what is important is that you measure it the same way consistently. Most air gauges and weight scales are not all exactly accurate or calibrated but who cares!?
As long as you are measuring the same way consistently then you can find the sag that works for you, even if it’s 31,5%
The fact is that sag as a measurement is a subjective number because we all have different tastes in how our suspension should ride and feel, it isn’t about hitting some exact specifically accurate measurement of sag that is defined by science as being the perfect setting…
Shinook
Asheville, NC, USA
6/15/2025 1:01pm
I was under the impression that kinematics were created such that various figures/values (antisquat, progression, axle distance, etc) are designed and created to be set values at a given point in the shocks length when sagged (e.g. you have x antisquat at 30% of the shock stroke), not the wheel travel. So this would cause it to deviate from the intended values if you set sag based on wheel travel instead of shock length when weighted, no? Is my understanding mistaken?
6/15/2025 1:11pm
I always new Dave was an avid MBAction reader - https://mbaction.com/garage-files-how-to-set-suspension-sag-using-motools-slacker-digital-sag-scale/8/
I like how he assumes none of us ever heard of that tool or read the Motorcycle Suspension Bible....but apparently we are all morons?
I don't normally get to caught up in everyones theories since there are many ways to do it, and each is fine as long as its vaguely repeatable, but this is claiming an awful lot of precision for measuring the sag without any way of checking the weight distribution which can introduce just as much error!
6/15/2025 1:39pm Edited Date/Time 6/15/2025 1:41pm
A lot of good thoughts here, but just to play devil's advocate, have we considered the possibility that he's right and we're all stupid and everyone in the bike industry has collectively been doing it wrong for 30-40 years and he alone can tell us the answer and it requires buying this expensive new product from his webstore?
I mean at least consider it, is what I'm saying.
6/15/2025 3:22pm
A lot of good thoughts here, but just to play devil's advocate, have we considered the possibility that he's right and we're all stupid and everyone...
Your onto something, but I just refuse to believe that someone wearing an all white kit, googles and half shelf, with a hip pack, on a DH bikes, knows much of fuck all.
Jokes and fashion aside, Rulezman is a knowledgeable dude, and I appreciate what he brings to the sport, but this is just totally unnecessary.
The absolute best way to measure sag, is to use a telemetry system like BYB and look at dynamic ride height.
Second to that, seated on level ground, cos its free and repeatable, and tune from there.
6/15/2025 3:41pm
Sag is a reference point.
Do yourself a favor, cut your sag O-rings off and live free! This was actual advise from Mr Vorsprung himself in a Gondola in Queenstown.
It's even more irrelevant on a moto with the whole tape measure and sharpie mark on the rear fender that anyone can do for free.
6/15/2025 3:43pm
ioni
Villa De Alvarez, Col., MX
6/15/2025 3:56pm
I’m certain Dave is really good at what he does (I’d love some pro ride his tuned suspension vs. stock and see what they say).
My favorite part tho is his good ole Italian attitude aka very strong and confident about himself 😁
rbsack
Taoa, NM, USA
6/15/2025 5:57pm
The line between having fun on a bike and totally geeking out is OFFICIALLY BLURRED!
marzbomber888
Vancouver, WA, USA
6/15/2025 6:01pm
No, we haven’t been measuring sag wrong. Any method of measuring sag that is repeatable is an acceptable way to measure sag. As it is something...
That guys is silly as they come.  Again another rider trying to fix talent with gimmicks
6/15/2025 9:33pm
Hard to take a guy serious that rides Kendas.
23
LePigPen
Harbor City, CA, USA
6/15/2025 11:19pm
brash wrote:
Eoin
6/16/2025 12:52am
"It is definitely worth noting that on more progressive bikes you shouldn’t be surprised if you run under 30% sag at the shock, though. "
Wait what, maybe the language used is wrong, but more progressive bikes would likely need more than (over) 30% sag, while linear bikes can be run well under/less than 30% sag.
As others have said, I roughly check the sag on my first setup to know the rough number of psi I need, then it's all about feel. My last 2 bikes have been a battle to setup due to overly low BB height.
6/16/2025 1:02am
Nico_Ofner wrote:
Back at it again creating his own hype by saying "don't believe the hype" and saying that he's going to change the mtb world. Not quite....Setting...
This is what I was going to put on his IG POST.. old school plot reading , like in my college days.. get your mm of shock strike and go to the leverage curve of the bike and voila you read your wheel travel.. i guess these days people are back to selling snake oil as the population gets dumber and dumber ( in a different way, too busy scrolling, zombies)
Jakub_G
SK
6/16/2025 3:25am
Jeeeesus, just buy tape measure and measure distance between rear axle and rear edge of the saddle if you want to be moto. Or go ahead and buy sag master from racetech for 10bucks, moto AF. This is just dumb.
6/16/2025 3:41am
Eoin wrote:
"It is definitely worth noting that on more progressive bikes you shouldn’t be surprised if you run under 30% sag at the shock, though. "Wait...
This is where the argument for measuring at the wheel comes from - you are correct when looking at % sag at the wheel, but the change in rate through the stroke means you have an inversion of % shock stroke used vs % of wheel travel used. Ie on a progressive bike, 25% shock sag might equal 30% wheel travel and 75% at the shock is 70% at the wheel. But on a more linear bike 30% at the shock might be 25% at the wheel.
sprungmass
Calgary, AB, CA
6/16/2025 8:36am
Typical Dave with his absolute claims. Things like 15mm stems are the only way and anything else is too flexy and unusable. Using XC tires on his "enduro" bike. Claiming everyone should have a bike 2 sizes up with 1300mm+ wheelbase and any bike with pedal kickback is completely useless etc etc.
Granted he has some interesting theories but the way he dismisses everyone in the industry gets old real fast. This rebranded product is the perfect example of his attitude. He's numero uno and we're all plebs.
WillijPDX
Portland, OR, USA
6/16/2025 8:40am
🤨 I get the nerding out on sag, but the kit is as expensive as a shock wiz, with the shock wiz being way more useful to dial in your suspension to riding style, compliance, and terrain. Strikes me as some obsessivness getting way out of control.
yzedf
Hebron, CT, USA
6/16/2025 9:48am
WillijPDX wrote:
🤨 I get the nerding out on sag, but the kit is as expensive as a shock wiz, with the shock wiz being way more useful...
The wiz only works if you run air, which this guy is a big coil advocate.
This video did get me to check my shock for the first time in a month, so that’s good I guess.
6/16/2025 9:48am
This is an example of percent wheel travel as a function of percent shock travel. In this example, all have 160 mm of travel and a perfectly linear (in the mathematical sense ie. in the form mx+b) leverage curve. The green line is 50%, the blue line is 30%, and the orange line is 10%. The largest difference in percentage is at 50% shock travel. This is the point at which the aforementioned leverage curves converge. Running more sag on a more progressive bike can result in the ratio of up travel to down travel from the sag point being thrown off.
Screenshot 2025-06-16 094741
WillijPDX
Portland, OR, USA
6/16/2025 10:24am
yzedf wrote:
The wiz only works if you run air, which this guy is a big coil advocate. This video did get me to check my shock for the...
I agree with you but that wasn’t my point. I am saying the cost is as expensive as a tool that is better for the vast majority riders. Fine if a shop or fitter buys it to help people for their initial set ups. Just not a price point for an individual for what the kit actually does.
NoahColorado
Fruita, CO, USA
6/16/2025 10:27am Edited Date/Time 6/16/2025 10:28am
WE'VE BEEN MEASURING CRANKS COMPLETELY WRONG! THEY SHOULD BE MEASURED FROM THE GROUND!
yzedf
Hebron, CT, USA
6/16/2025 10:47am
WillijPDX wrote:
I agree with you but that wasn’t my point. I am saying the cost is as expensive as a tool that is better for the vast...
Duck tape, a stick and a helper with a tape measure will be good enough.
Post a reply to: Have We Been Measuring Sag Wrong? (and how to fix it...)
