The great Headset Debate
Right, this came up on a ride the other day and im curious what the superior site thinks,
Ill add a poll and we can discuss
IS - the bearings sits direct into the frame with a Mated surface, Common being IS41 and now common IS52(ICR etc)
Pressfit cups - Cups are pressed into the Frame With Bearings Pre fitted or removable bearings. such as the common zs44/zs56
Theres Zero Stack(zs) cups or External cups(EC, Bearing is outside of the headtube)
Which is best, why and does it influence your Bike decision?
Poll
Headset type
Choices
ex-ballz
Ouagadougou, EH
1/12/2025 4:28pm
I have bikes with both headset types, they all work just fine, and they play no role in my bike decisions.
1/12/2025 4:38pm
Voted cups because it simplifies frame manufacturing and gives you some recourse if you end up running a loose headset and beating up your bearing.seats, but agree with the above...both work fine its not a purchasing decision.
1/12/2025 5:08pm
Whatever standard allows me to use angle adjustable headsets if I ever wanted to. That's the standard I would want. Otherwise, I never think about my headsets.
Splayleg
Los Gatos, CA, USA
1/12/2025 6:18pm
What ever style distributes the stress over the largest area, is adjustable and also the standard that is not smoking crack
Digit Bikes
Irvine, CA, USA
1/12/2025 6:52pm Edited Date/Time 1/14/2025 6:29pm
It wouldn’t affect my buying decision.
Here are some factors I consider when designing for a frame:
IS head tubes have existed for about 20 years I’ve never seen a cracked one, whereas I have seen cracked press fit head tubes. This seems more important than angleset compatibility especially if I get to design the HT angle.
This crack resistance is because with IS the highest stresses areas are recessed inboard from the head tube opening*, and there’s no press-fit-hoop-stress**.
Both IS and ZS allow the down and top tubes to be further separated than EC; and the head tube to be longer for equivalent stack (this is particularly important for small frames with 29” wheel and long travel forks).
For welded frames the 46ish millimeter OD of an IS head tube typically delivers a nice long welds*** as the DT and TT junctions wrap almost 180 degrees around the HT.
For carbon frames ZS can be the better choice because often an IS frame insert negates the , * and ** advantages, and there are no *** welds to envelop the head tube.
Often on carbon frames IS headsets are basically ZS headsets but molded/bonded in place. Molding/bonding the insert into frame is advantageous over press-fit.
Head tube surfaces really don’t wear, but if the head tube did wear with IS, simply retensioning the headset would move the bearing deeper into its conical bore. With ZS or EC a wallowed out head tube is hard to fix (and probably it’s a sign that it’s time to retire a frame).
1/13/2025 9:47am
I see all this as a big downgrade in products in recent years, I have a Santa Cruz V10 2024 and I haven't had any problems yet, but I've seen many friends with the parts causing looseness and noises in the parts that fit with looseness, and not with pressure. I've seen the same thing a lot in the Canyons Sender.
1/13/2025 11:38am
For me the average rider, if the bars turn, there is no creaking and i only need to regrease every year or so i couldn't care less what it is.  Don;t overthink it. Very few of us actually benefit greatly from top end tech. Waste of money
1/13/2025 1:07pm Edited Date/Time 1/13/2025 1:58pm
I had zero stack headsets for years and years and still have a pile of them in my bike bin, but I've been on IS on my Santa Cruz bikes for the last 5 years. I've never had a problem with an IS headset so far, but they scare the hell out of me and given the choice I'd take a press-in ZS headset 7 days a week.
First, it seems to me the IS headset requires waaaaaay higher manufacturing tolerances. Again, I've never had a problem with this on my Santa Cruz CC frames (disclaimer: SCB sponsored rider), but I can imagine this being a problem in an industry that has a mixed track record of delivering on tight tolerances.
Second, shipping! Whenever I packed my frame up for shipping in a standard bike box, I prayed to God the bike would arrive with a functional head tube. The thinnest part of the head tube, the outer lip of the IS interface, is the part that's exposed against the top and side of a cardboard bike box. YIKES. My best idea was to ship the frame with the headset bearings and top cap in the frame, and to use zip ties on both sides to try to keep the bearings in place in the IS cups, but this solution sucks. With ZS cups press-fit into the frame, there's a much more substantial structure to reinforce and protect this vulnerable spot on the frame.
Lastly, maintenance and problem sleuthing. If I have any issues whatsoever with a ZS headset, I can knock out the cups and start from scratch. If I have problems with my IS, if I pulled and cleaned everything and regreased it before assembly and still have problems, I have to worry about my head tube now? That's crazy. Who wants to have "check to make sure your front triangle isn't ruined" as part of their standard headset checklist?
I'm guessing the aluminum ZS cups weigh 20-40 grams more. Yeah, I'm cool with that.
1/13/2025 1:21pm
I had zero stack headsets for years and years and still have a pile of them in my bike bin, but I've been on IS on...
I think Digit Bikes Kinda coverd the part about the frame damage/wear on an IS headset, where as if a Press-fit frame was to wear it bsically ruin the frame.
Most of my bikes have been IS or brands own special ones for adjustable headsets with the odd zs44/56 frame in there.
IS52 headsets, which are common on Ebikes and ICR bikes are very frustrating as they use such a large compression ring, if made from alloy brands are using plastic headset covers that flex an cause headsets to always be loose(canyon, looking at your 21+ spectral/torque here)
I see some brands, such as commencal have moved to press-fit zs66 uppers, but use a large plastic compression ring.
A side note to the ebikes & ICR bikes(or canyon/merida/commencal) Acros now make a thin Alloy version similar to the plastic ones.
1/13/2025 2:04pm
I think Digit Bikes Kinda coverd the part about the frame damage/wear on an IS headset, where as if a Press-fit frame was to wear it...
Regarding wallowing out from excessive/careless headset installation or removal, I've done horrible things to ZS headtubes and never had a problem. Lots of "here's your new team frame the night before a race" headset installs with wooden blocks, mallets, etc and never had a problem. Not saying you can't wallow out a headtube, just saying I've never seen it. A robust ZS headtube is made out of very thick aluminum or carbon. It's not a pop can.
And regarding impacts, I can't imagine an impact that would ovalize or crack a robust ZS headtube and not crack or wallow out an IS. But I don't build bikes for a living like Digitbikes, so I accept that I'm just another idiot with an opinion.
1/13/2025 2:39pm
Both type of headsets are fine and have their positives and negatives.
The main reason i would say cups are far superior, is that it allows oversized/oval headtubes for reach adjust and angle sets. (you can do it with IS headsets but its less common).
But IS on a XC bike would be my preffered, and cups with reach adjust on a DH bike.
1/13/2025 3:16pm
Press in cups for me. The surface only has to be a tiny bit worn or out of shape to cuse all kinds of creaking and lossening problems. Even a slighlty loose headset will start to wear the bearing surface quickly, and a lot of people don't preload headset bearings enough (as evidenced by the wear marks from the collet eating in to the steerer) so once its started the frame is pretty much ruined. Some companies are a lot better - Santa Cruz, as mentioned really knows how to design an interface like that strong enough and with decent tolerances that its unlikely to be a problem.
Wouldn't change my bike purchasing though - IS is too common that you would be cutting out a huge chunk of options if I decided it must be ZS
vetprowanab
Longmont, CO, USA
1/13/2025 3:20pm
Another vote here for cups due to the ease of adjustability regarding reach and angle.
However, my number one criteria is that cartridge bearing headsets have split or slotted crown races.  I have several from FSA, Hope and Works Components...haven't found a downside yet.
iforte312
Minneapolis, MN, USA
1/13/2025 4:06pm Edited Date/Time 1/17/2025 7:04am
9point8 released an adjustable head angle kit for IS style bikes, I haven't tried it
Edit: After reading below about the reliability of this system, it seems like a bad option
notthatbryan
Acworth, GA, USA
1/13/2025 4:37pm Edited Date/Time 1/13/2025 4:38pm
The integrated headset on my Propain Hugene lasted less than 2 months before destroying itself. I took the fork off chasing a creak and inner race and bearings came out with the fork. Getting the outer bearing race out without damaging the carbon head tube took a lot of creativity and swearing.
There is a greater chance of damage to the frame with an integrated headset if something goes wrong.
It's not a factor in my buying decision though.
Prophet26
Quakertown, PA, USA
1/13/2025 6:59pm
I'm  not rich enough for a nice modern bike  so a few years ago I bought a Cannondale Prophet frame and began building it up. (See my bike check) I modernized it and with its 1.5 headtube I'm able to run a modern tapered fork. I couldn't do thar with an IS headset.
1/13/2025 10:12pm
iforte312 wrote:
9point8 released an adjustable head angle kit for IS style bikes, I haven't tried it Edit: After reading below about the reliability of this system, it seems...
Did they? I can't find it on their website or their IG page. Asking because that sounds super sketchy (lots of leverage in a very shallow IS cup) and I wanted to see how they did it. Can't find any evidence.
1/13/2025 10:19pm
Did they? I can't find it on their website or their IG page. Asking because that sounds super sketchy (lots of leverage in a very...
Jakub_G
SK
1/13/2025 10:49pm
While the idea is great, buddy has one installed on his SC nomad and bottom cup always rotates over time (over time not as in months, but rather few bike park days at best). At least it doesn't creak, but it's not perfect.
Eoin
1/14/2025 4:37am
Ever so slight off-topic:
My new bike came with adjustable head angle via headset cup, sounded great! But it also comes with headset routing, luckily not the worst implementation and can mostly be ignored. Except of course if you would like to rotate those fancy headset cups, suddenly I need to take out all my cables and disconnect my brake lever. Maybe there is a fancy tool and procedure that doesn't require dismantling all my components, but it certainly seems like those "convenient" headset cups are never realistically getting flipped.
amaranth
Nutley, NJ, USA
1/14/2025 7:30am
Tried that one, it's just not good imo. It always migrates and creaks. You can use all the carbon paste and retaining compound you like. I tried it on my yeti sb130 before ultimately selling that frame, friend tried it on the SC 5010, you'd get 1-2 rides creak free then it'll start creaking, and eventually when you have high torque applications such as trying to go down (turn in) an off camber rockface it WILL migrate. Also for that reason I choose cups over IS - there's a lot of adjustability afforded with cups that's just not possible with IS.
Cougar797
Bentonville, AR, USA
1/14/2025 7:50am
Voted press in cups cause it works well, has never failed me, and means lots of options for adjustable HTA. Its an if its not broke dont fix it item.
1/14/2025 4:47pm
Well executed IS is fine if the geometry is where you want it to be, but I'd prefer ZS for the option of running anglesets without fucking up stack (like the 9p8 does).  I know what head angle I like for my local trails, but I can totally see that someone in BC might like the same bike but want a slacker HTA, or someone in CO/AZ might want something a bit steeper.  IS/ZS bearings in adjustable cups (like Specialized does/GG did) are ok - easy to install/align, but prone to creaking in my experience.  It just seems to me that frame designers would make their bikes more appealing to a wider audience by spec'ing ZS.
FilipK
SK
1/15/2025 2:57am
It's the same story as Bottom Bracket.
From a pure design perspective, INTEGRATED is better because of the lower stack up of tolerances more direct load path with fewer interfaces to rub/loosen/... Fewer parts to manufacture as well.
From an experience and reality of poor manufacturing standards. EXTERNAL CUP seems like the best option. An indirect load path through the EC (housing) might allow for some separation between the poorly machined frame landing and the actual bearing seat. Fixing a problem is probably easier with ZS/EC.
Personally, next time I buy a frame I will make sure it uses a common bearing type with plenty of options. I never gave it a thought when choosing a gravel bike and it bit me recently when trying to identify and source the obscure bearing type. Searching for an upgrade or stainless steel option - no luck yet.
1/15/2025 2:18pm Edited Date/Time 1/16/2025 7:55am
I recently got bit buying a new headset for my Megatower. I like to buy stuff used whenever I can, so I was buying an IS41/52 headset off a guy, taken out of a Yeti IIRC. Well, it shows up and the top headset bearing doesn't fit into my upper IS cup in my frame. Too big. I take out the headset and the side of the bearing says "41.8mm," but googling that headset size gets me nowhere.
Turns out IS42 headsets actually measure 41.8mm in diameter, but apparently "41.8" is too confusing when there's already a 41mm size. So 41mm is called "IS41" and 41.8mm is called "IS42." Ugghh. Homie just read the number on the side of the bearing and assumed 41.8mm meant IS41 when he posted his ad.
In a related story, if anyone wants to buy a lightly used Cane Creek Hellbender 70 Headset IS42/52 headset for tapered steerer tubes, let me know!
1/15/2025 11:22pm
External cups might not be ideal, but I'd go with ZS cups if possible. Hell, it would kinda make sense for pivot bearings too.
Reaming out a bore to dimension through and through (or a tapered headtube for that matter) is easy. Machining in steps is a bit more cumbersome. It's an operation best left for a lathe (easy to make a headtube from round stock, but welding it will deform it) and cups are precisely that. Ream the hole and press in precisely turned cups and put/press bearings into them.
Digit Bikes
Irvine, CA, USA
1/16/2025 10:01am
Reaming/facing for IS is no harder than for press-fit. These tools are common:
Amazon.com : Cyclone Bicycle Park Tool ...
IS's conical bearings and seats are more tolerant of imprecision than press-fit, so in some cases reaming for IS is unnecessary.
1/16/2025 4:05pm
FilipK wrote:
It's the same story as Bottom Bracket.From a pure design perspective, INTEGRATED is better because of the lower stack up of tolerances more direct load path...
Out of curiosity, was it a Canyon or something else with a Acros headset?
FilipK
SK
1/21/2025 4:11am
@TheSuspensionLabNZ
haha! During my research Canyon and Acros came up as offenders on a lot of occasions.
But it was a Cannondale Topstone Al with a 41.8x30.2x6.3 45x45° bearing.
For example, Enduro Bearings doesn't even make this one.
I found PRO, M-wave, AIRE VELO. None are reputable bearing brand in my mind.
OEM headset maker Tange Seiki is unavailable in my region.
Post a reply to: The great Headset Debate
