Tire chat (nerds only)
Skalman
Kullarna, SE
8/27/2026 6:51am
aaronufl wrote:
You know, I wonder if the excessive wear has to do with the amount of siping on some of the side knobs. Starting to notice a...
You know, I wonder if the excessive wear has to do with the amount of siping on some of the side knobs. Starting to notice a bit of wear on mine, mainly on the side knobs with the long central sipe, although it still has life left. I wonder if the amount of siping causes more squirm of/or force onto the base of the knob causing the undercutting.
After mine bites the dust I think I'll put a dissector on.
Skalman wrote:
Usually if a beam is more flexible at the far end from a rigid connection it will cause less stress at the connection.
I don't know whether sipes can contribute to tire wear at the base of tire knobs, but I don't think your beam example applies here.The point...
The point of sipes on a tire knob is to generate more mechanical friction with the ground, with the goal of creating more traction and transmitting greater forces between the ground and the knob.
I think your beam example assumes that forces being applied through the knob are held constant, and so the beam that flexes at one end will apply less stress to the rigid connection compared to a beam that's inflexible (or much less flexible) at both ends.
If the tire is ridden on an inclined frictionless plane in vacuum ;-)
ColinL
8/27/2026 6:57am
aaronufl wrote:
So what would you suspect is causing premature wear?
we're talking about the Romy, right?
riding conditions and style would be my first guess, but the pics of other tires you've posted don't seem to be as severe rapid wear.
manufacturing defect would be my first guess as to why some have very different wear than others. bad batch of rubber compound?
aaronufl
Poulsbo, WA, USA
8/27/2026 7:29am
ColinL wrote:
we're talking about the Romy, right?riding conditions and style would be my first guess, but the pics of other tires you've posted don't seem to be...
Sounds like he and I are riding in the same conditions - the PNW isn't known to be hard on tires. If we're experiencing undercutting that quickly I doubt it's just a "bad batch".
ColinL
8/27/2026 7:45am
aaronufl wrote:
Sounds like he and I are riding in the same conditions - the PNW isn't known to be hard on tires. If we're experiencing undercutting that...
plus it's happened to you (and I think at least one other poster) that both mid and soft compounds are wearing excessively fast.
I didn't want to go immediately to 'bad tire design / construction' but that has to be on the bingo chart.
Goupil
Rennes, FR
8/27/2026 11:42am
Really liking the Michelin DH22 so far, but it lost the fight with one on the many volcanic rocks of the bike park Sad Thankfully happened not long before the end of the last day. Might try an insert next time.
Starting to understand some people here, the wear is only 3 days worth of riding, at home I can get 2000km out of an enduro tire ! (longer than any bearing...)
IMG 20260826 171120 0
rpearce1475
Bremerton, WA, USA
8/28/2026 5:37am Edited Date/Time 8/28/2026 5:39am
ColinL wrote:
plus it's happened to you (and I think at least one other poster) that both mid and soft compounds are wearing excessively fast.I didn't want to...
I have run two trail casing mid rears and one gravity casing soft rear. This latest trail casing mid rear is definitely wearing the fastest. The gravity casing showed some feathering of the side knobs at around 25 miles but no tears like the latest one. The first trail mid casing showed feathering around 50 miles and started tearing knobs around 80 miles and was done just past 100. These were ordered in May, July, and now August. If I was able to get acceptable (not asking for Conti level wear, just like 400-500 miles) wear rates out of them I'd never run anything else because performance wise it's my favorite trail rear tire I've ever used. But I can't justify having to replace a rear tire every 75-100 miles.
JVP
Bellingham, WA, USA
8/28/2026 8:57am
Goupil wrote:
Really liking the Michelin DH22 so far, but it lost the fight with one on the many volcanic rocks of the bike park :( Thankfully happened...
Patch that tire from the inside. Use a heavy duty or moto version of the old-school Rema kind that uses rubber cement. Gotta clean it, and a little heat helps, but it's not hard. Or even just throw a large Dynaplug in there (bacon strips aren't sufficient). It's not dead.
Fox
Durango, CO, USA
8/28/2026 10:52am
Agree with JVP- that cut looks fixable.
I use the Slime automotive strips/plugs cut in half (cuz they are like 3" long) on heavier casing tires and they work really well. They don't work so well on XC casings as the thinner casing doesn't seem to hold them in place.
storm.racing
Silverton, CO, USA
8/28/2026 11:59am Edited Date/Time 8/28/2026 12:05pm
Currently running through a tire a week so have a pretty good feel of Maxxis tires from new through clapped out. Finally got a batch of 'New DH' casing tires in. Wowza. Alright, that was more noticeable of a change than I was expecting! BIG FAN
8/28/2026 12:33pm
Currently running through a tire a week so have a pretty good feel of Maxxis tires from new through clapped out. Finally got a batch of...
Just out of curiosity, what did you like about the new casing?
storm.racing
Silverton, CO, USA
8/28/2026 12:54pm
I truly feel like I gained the sidewall support I wanted more of AND still felt a slight increase in traction. I say this with no bias of care either. I wasn't expecting anything or caring much either. I just go through tires and know the patterns I like and it is what it is. So, I was pleasantly surprised.
I only went 1-2 psi lower so far. Still feels more supportive than the old at higher (25F/30R). It feels more damped in the feedback. Noticing less/almost no dings on rocks I usually ding on. I did notice a slight increase in the traction in those really fighting for something spots of off camber, rocks/roots, etc. It was marginal on the traction department but was noticeable with the more supple top on the tire.
8/28/2026 1:40pm
Holy hell, a tire a week!
Who has some extra cash they can loan me I'm starting a mtb retreading company
8/28/2026 3:00pm
DH tire torture from world champs today. the double-bouncing is pretty nuts. (instagram only for now, sorry)
8/28/2026 8:15pm
poor Dak lost his chain silencer
ColinL
8/28/2026 8:54pm
I'm assuming he lives local to a bike park, but yeah, I would be riding maxxis DC or Conti soft. if you ride enough to go through one of those in a week, you hopefully are paid to ride. 💸
8/28/2026 11:51pm
No, Front is an Albert 2.5 soft radial that's been on since May and is showing ever so slight feathering of the side knobs but otherwise...
No, Front is an Albert 2.5 soft radial that's been on since May and is showing ever so slight feathering of the side knobs but otherwise looks great. This is the third Romy (2 trail mid, 1 gravity soft) I've had on since May. Riding this bike 2-3 times a week. Every rear tire I've run before these in this area has lasted 6+ months
Rubber behaves differently than solid materials and maybe the knob deforming loads the outer edge a lot more, stretches it and tears it... Thus starting the undercut.
8/29/2026 12:01am
JVP wrote:
Patch that tire from the inside. Use a heavy duty or moto version of the old-school Rema kind that uses rubber cement. Gotta clean it, and...
Blue rema patches and blue SC-BL cement. Works a treat. There are very few tyres over the last... 10 years that I wore out without having to patch.
aaronufl
Poulsbo, WA, USA
8/31/2026 4:02pm
I have run two trail casing mid rears and one gravity casing soft rear. This latest trail casing mid rear is definitely wearing the fastest. The...
I experienced the same - mid exhibited quicker undercutting than soft which is surprising.
I picked up a standard tacky chan super trail soft and I'm going put it on the rear and keep the TC radial on the front. Curious to see if it lasts any longer.
8/31/2026 4:22pm
This video was cool because it showed how separate the rear shock and tire are from each other, despite working in series. These are the most sophisticated full suspension bikes on the planet, and it's still a shitshow back there, with everything moving at a different time in the sequence and at a different speed.
I need to watch this video ten more times to figure out the exact sequence of what's moving in what order, how fast, and how far.
bicycle019
Denver, CO, USA
9/9/2026 10:21am
On Schwalbe, been running a variety of their radials since they came out, early adopter as they were a big improvement in just about every aspect.  One thing I've noticed now running their radial Trail and Gravity Soft vs. same casings in Ultrasoft - the Soft does seem to wear faster.
Most recent experience on my trail bike I switched from Trail U-soft Alber rear to Trail Soft Albert to pick up some speed as the draggy feel of radials plus the U-Soft compound really was noticeable.  The Soft rolls faster as a harder compound should but it's wearing faster which is surprising.  I'd say that it's seems to be wearing twice as fast as the U-soft.  Still rides great and has solid grip wet or dry so I'm happy with the performance just disappointed in the wear rate.
One thing about the U-soft that's really impressed me has been it's tread life - it's way exceeded expectations for something that grips amazing in the wet or dry.  Looking to try a Romy Trail Soft in the rear vs. Albert to try and roll a bit faster but not excited to drop the $$ and see short tread life.
ColinL
9/9/2026 10:52am
bicycle019 wrote:
On Schwalbe, been running a variety of their radials since they came out, early adopter as they were a big improvement in just about every aspect...
that is pretty unexpected. was your ultrasoft albert recent, or from last year+? the main reason I ask is that ultrasoft just changed for 2026. it's a new formula, but it's still the only tread compound that doesn't include recycled materials, I believe.
soft didn't change afaik. and I thought that mid was just a name change from speedgrip, same rubber.
bicycle019
Denver, CO, USA
9/9/2026 2:37pm
ColinL wrote:
that is pretty unexpected. was your ultrasoft albert recent, or from last year+? the main reason I ask is that ultrasoft just changed for 2026. it's...
Older stock, I've had maybe a half dozen Usoft Alberts and all of them were produced in '25.  Same for my Soft compound Alberts, both Trail and V1 Gravity casings.
9/9/2026 6:25pm
image 81720260909 075013.jpg?VersionId=Piy5wKZp5ENolMOVNPxCuothJR
The new Romys came in last night, mounted them up by hand, no lever (with insert in the rear too!). Set the bead with a normal floor pump as well, no tank or compressor.
First ride on them this morning, 2.5 Soft front, 2.4 Medium rear. 26 PSI, which felt much more stiff with the thumb test. The knobs and lugs look about the same size as a DHRII, but these roll noticably faster (at least at 26 PSI).
The same benefits I found on my ebike with Radial Albert + MM: Much, much slower rebound. You can feel it when climbing! On the descents it is gripper than my Assegai + DHRII combo, while (same as climbing) rolling faster. This is an amazing tire for my 135mm/150mm trail bike. The only complaint so far is that I expected more climbing traction in the rear. Maybe I should have gone for double Soft, but I'll definitely play around with tire pressure. See if that improves things.
Its probably in my head, but on the descents (I did about 1800 feet of climbing/descending) I felt like the tires were so damped that I could speed up my rebound on my Cane Creek IL rear shock if I wanted. Like tire pressure, I will experiment more.
Anyways, first impressions after one ride.
Evil96
Portogruaro, VE, IT
9/9/2026 11:58pm
 The new Romys came in last night, mounted them up by hand, no lever (with insert in the rear too!). Set the bead with a normal...
should've gone for the radial rear to get that traction you're chasing
ColinL
9/10/2026 6:48am
maybe. he did comment that maybe he should've gone with soft. he picked the fastest rolling Romy for rear use so yeah he could've gotten radial, soft, or both for more traction.
I'm going with a Romy radial trail soft on the rear because I don't love mid/speedgrip in the wet, and this blown-out dry summer is going to end sooner or later. I do my best not to ride actual mud, but I had a Nobby Nic speedgrip several years ago and it wasn't great on damp roots and rocks.
9/10/2026 8:59am
Another ride this morning, confirmed the lack of climbing traction. It's actually kinda poor (but the rear still feels awesome on the decent, even with a simple single pivot! ).
1000020898 0
So I retract my previous statement about suspension rebound, I don't want to speed it up.  Also, I come here to post, and see that someone pointed out that I accidentally ordered the non radial rear!  This really bums me out, I was hoping to experiment with radial rolling Speed on not- an-ebike. Still, this non radial Romy is at the very least comparable to a DHR II exo+ 3C in downhill performance, but rolls faster.
I'm not comparing these to bald, torn up old tires.  My outgoing assegai and dhrii have plenty of life left,  except for a snake bite I couldn't fix,  which triggered this whole thing
9/10/2026 9:06am
I got my hands on a DHX and DHR2, both in the New DH casing, and have some first ride thoughts.  Two words:  holy shit!  The gist of it is, the feel of this casing is what I wanted from radial but couldn't get.  I weigh ~150 lbs, and am on a ~49 lb ebike, riding totally dry and blown out trails about an hour north of Santa Cruz.  I started with lower pressure than what I run with DH, but kind of hedging a bit - 18 front, 20 rear.  With old Maxxis DH or Conti, I usually run about 19/22 locally, and add 1-2 psi if I'm riding somewhere really rocky.  Things felt decent but a bit pingy after first lap so I checked pressures, and they'd gone up 2 psi since I left my house due to it being 94* out.  Dropped back down to 18/20 - better, more compliance & grip but no squirm.  Dropped 0.5 psi next lap to 17.5/19.5 - still improving with no downside.  After that dropped to 17/19 (!!!) and had crazy good grip, nice damp feeling.  By the end of the ride at that pressure, I still wasn't getting the X marks on sidewalls, even after hitting some high speed, steep berms and big compressions.  Compliance over roots and rocks was excellent.  Traction on flat corners was on par with Gravity Radials, without any squirm.  There's one flat corner at the top of our hill that I can hit without braking when I trust grip - I get it about 20% of the time on regular tires, 80% of the time on radials, and was 4/4 yesterday on NDH.  And that's with conditions about as bad as they possibly can get.  The DHX up front rolls noticeably faster than the HR3 that it replaced, and still hooks up in steep loose chutes where an Assegai/Kryptotal Front tend to float.  Even at those silly low pressures, I was overshooting landings because I was carrying so much more speed into them.  As someone who never really gelled with the radials, this is the feel I was looking for.  Part of it is the incredible sidewall stability, but part of it is really good tread patterns and knobs.
Now, the downside is these are freaking heavy.  My 29x2.5 DHX clocked in at 1,534g.  My 27.5x2.5 DHR II (NDH) is 1,340g.  In the future when new casings become available, I'll consider dropping the DHX down to DD casing (depending on what the actual weight savings is) but keep the NDH in the rear (just with MaxxTerra v2 once that's available).  On my enduro bike, I definitely can't stomach pedaling a 1500g tire, so will probably stick with DD/DD or EXO+/DD.  I'll probably switch back to my stash of HR3s for the front once the rain starts in a month or two, but I plan on running DHX front for the majority of the year here.  Even if the DHX runs heavy in DD / EXO+, it's damn good and worth the penalty.
ntm95
Lloydminster, AB, CA
9/10/2026 9:17am
AndehM wrote:
I got my hands on a DHX and DHR2, both in the New DH casing, and have some first ride thoughts.  Two words:  holy shit!  The...
It'll be interesting to see if the dhx translates well to a dd or exo+.
I suspect the magic there is 95% new dh casing. I've been running them on my dh bike and my e-dreadnought for half the summer, and agree that they are better than the other brand's radials. Feels like you have the sidewall support in corners of a cushcore insert, but with the traction of a radial.
They were great in western canada's dry conditions this year. Kind of unique conditions in that there's the usual loose over hardpack, but certain corners were full on deep moon dust. So you wanted to run something like a magic mary or hr3, but it would get squirmy in high load corners on hardpack. The dhx's bridged those conditions nicely, and roll relatively quickly for what they are.
