Tire chat (nerds only)
aaronufl
Poulsbo, WA, USA
7/25/2026 7:39am
aaronufl wrote:
AndehM wrote:
Must have been an error posting early because link is broken now.
I was wondering.
What I can remember:
New DHX is a dry conditions bikepark tire. It will initially be released in August in their new downhill casing only. Other casings like EXO plus will pop up in October and December respectively. The author thought it worked great in the dry but not so well in wet or slick conditions (makes sense).
KylerOnBikes
Vernon, BC, CA
7/25/2026 9:19am
aaronufl wrote:
aaronufl wrote:
I was wondering.What I can remember:New DHX is a dry conditions bikepark tire. It will initially be released in August in their new downhill casing only...
I was wondering.
Is it meant to replace the Assegai or is it meant for drier conditions?
I'm in central BC, so dry and dusty most of the time. Assegai works great until the dust gets deep, then the High Roller is my go-to.
The DHX looks like the perfect tire for my use.
KylerOnBikes
Vernon, BC, CA
7/25/2026 9:25am
I did some digging and found a nice summary
Maxxis Minion DHX — new gravity/DH tread aimed at dry, hardpack conditions:
Bigger, blockier lugs than before for support and braking power at speed
Tighter-spaced center tread for faster rolling on hardpack; bigger shoulder lugs for off-camber grip
New L-shaped center-to-shoulder transition
Positioned as a fast, dry/hardpack-focused tire — sits alongside the Assegai and DHR II, not replacing them
New DH casing — reworked construction across the DH lineup:
More rigid butyl bead insert (pinch-flat resistance)
Wider casing overlap under the tread
New sidewall cut-resistance material
Claimed 20%+ gains in cornering support, sidewall/tread puncture resistance, and pinch-flat protection — at similar weight to the old DH casing
Riding impressions (tester rode it at Leogang and Czech/Polish bikeparks): fast-rolling and stable in dry/hardpack corners and berms, reliable braking; ran pressures as low as 22psi with the new casing without losing control even in slightly wet conditions — but it struggled on a genuinely slick, rooty wet trail, confirming it's a dry-conditions tire. No flats after ~2 months of riding despite visible cuts/scrapes.
Availability:
August: DHX in New DH + 3C MaxxGrip, 27.5" and 29", 2.5" widths
October: more DHX options (New DH or EXO+ casing, MaxxTerra or 29er-only EXO+/MaxxGrip combos)
End of year: Double Down casing versions
New DH casing also rolling out on Assegai (29x2.5 only), DHR II (27.5/29, 2.4 & 2.5), and HighRoller (2.4) — notably not on the DHF
Pricing expected similar to current tires
CptObius
Hauenstein, DE
7/25/2026 10:16am
Re: Hutchinsons
Installed a pair of hutchinson wyrms rlab in 29×2,4. Weighed in both at 850g.
Install was easy, the sidewall feel much more substantial than exo+ and whatever kenda is using. Measures 66mm at the knobs and 62mm at the sidewall. Very round profile, bot bad imho.
Recommended Pressure in the sidewall 1,5bar/22psi. Legit!1000046957 01000046956 01000046955 01000046954
7/25/2026 2:41pm
CptObius wrote:
Re: HutchinsonsInstalled a pair of hutchinson wyrms rlab in 29×2,4. Weighed in both at 850g.Install was easy, the sidewall feel much more substantial than exo+ and...
Re: Hutchinsons
I tried a Wyrm as a rear tyre about two years ago. I tore it off after the first ride and sold it. In retrospect I think i should have given it a couple of rides to wear in a bit. It's just my own theory but i've learned that Specializeds tyres tend to need a couple of rides before they perform their best.
7/27/2026 9:59am
Idk whats going on in this forum lately.  Amaury: I'm using radials. Schwalbe: our riders are all using radials.  Us: no one's using radials.   My personal experience, riding them in...
My personal experience, riding them in every condition imaginable, including snow: the biggest improvement in mountain bike technology since we figured out 64 degree HTA could apply to non DH bikes.
VINDICATED
1000019818.jpg?VersionId=C
HarryMudd
Manassas, VA, USA
7/28/2026 1:59pm
Love my 29 dhf max Terra on my all mountain / trail bike here in the mid Atlantic. I love it less than the 26 in downhill casing dhf I had way back when. It's fast, it corners, yes I've washed out. It works great in dry and hero dirt and I can ride through mud and it sheds. What's so different about the dhx that it's just a dry tire?
pejzaż
Phoenix, AZ, USA
7/28/2026 4:12pm
I did some digging and found a nice summary Maxxis Minion DHX — new gravity/DH tread aimed at dry, hardpack conditions:Bigger, blockier lugs than before for support...
Availability:
Now why would the new Maxxis DH casing be more stiff/supportive if radials are purportedly the way to go for DH?
seanfisseli
Santa Cruz, CA, USA
7/28/2026 4:27pm
Availability:
You might want stiffer side walls, but more supple tread zone.
ColinL
7/28/2026 4:45pm
Availability:
my first guess would be rider feedback, particularly from dh and ews pros, regarding cuts and punctures. possibly about stability as well. but you make a tire heavier and more durable for reasons other than traction.
pejzaż
Phoenix, AZ, USA
7/28/2026 6:57pm
"Wider casing overlap under the tread" to me sounds like a less supple tread area. Isn't this also what Schwalbe did with the updated radial gravity casing in order to dial back some of the lack of support? I don't think its as easy as having 2 zones you can independently control that don't influence eachother much. My takeaway from radials is that there is no escaping the support/suppleness tradeoff
ColinL
7/29/2026 6:42am
pejzaż wrote:
"Wider casing overlap under the tread" to me sounds like a less supple tread area. Isn't this also what Schwalbe did with the updated radial gravity...
I haven't ridden E13 radials yet but that is exactly what they depict, multiple types of reinforcements that do not extend into the tread area.
image 765.png?VersionId=0.ua7C9JdMIrA
7/29/2026 8:31am Edited Date/Time 7/30/2026 10:31am
Yeah some interesting choices. my read on the changes is as-follows:
  • 60TPI > 120 TPI: smaller threads = thinner tire cross section meaning it's more flexible, faster rebounding, less puncture resistance
  • More overlap over tread: thicker cross section over tread for more puncture resistance, less flexible on tread, slower rebounding tread area
  • Additional sidewall protection: like EXO+ added sidewall layer helps prevent punctures, insignificant change to sidewall support but thicker cross section means slower rebounding too.
  • new casing material: no idea on details but likely stronger fabric to help prevent punctures, tears
  • different butyl insert: better protection against snakebite punctures but less flexible near bead
Shooting from the hip it looks like they mostly moved sliders around to get largely similar performance but with a more flexible sidewall. Seems that they think DD is enough casing support but needs more flat protection for DH racing.
EDIT: After going through some of the media from the launch it sounds like the new butyl / apex is adding a fair amount of support to the sidewalls which I find interesting.
7/29/2026 8:57am
New DH looks interesting to me even if I don't need that much puncture protection most of the time.  My biggest hangups using radials so far seem to be related to the high rebound (from higher pressure).  The New DH layup is similar to what I was dreaming of after trying radials and not loving them - seems to tick all the boxes for me personally.
I recall that earlier this year Jesse Melamed had a video about riding in the wet where he said he preferred the feel of DD, but needed DH puncture protection racing.  Then he said he was riding new Maxxis DH casing that he couldn't get into the details but it felt similar to the DD when running lower pressures but still kept the puncture protection.
I'm kind of surprised how much the early DHX reviews point to it being a dry conditions only tire.  I've felt like in the past the DHF did ok in moderately wet/loose conditions - better than the DHR which I feel clogged up a bit easier.  Assegai definitely can get overwhelmed in wet/muddy conditions because of knob density.  I want to try the DHX, but have a pile of front tires I gotta wear through first.  I suspect that the HR3 will be better for my conditions though.
seanfisseli
Santa Cruz, CA, USA
7/29/2026 9:18am
AndehM wrote:
New DH looks interesting to me even if I don't need that much puncture protection most of the time.  My biggest hangups using radials so far...
I mean, compared to the HR3…
notseanday
cumming, GA, USA
7/29/2026 10:17am
Any questions about the DHX or updated DH casing let me know, both were my projects.
In general the DHX does everything our current dry tires do, but has more capability for high load high speed conditions. I designed it to excel in the bike park oriented World Cup tracks but still not give up performance in soft or natural sections compared to current dry tires. Ideally I wanted to simply the racers’ tire choice: if it’s dry and fast- DHX, if it’s soft or mixed- HR3, if it’s wet- mud spike.
The updated DH casing is pretty well explained in the press release. The goal is soft contact patch and high support sidelwalls. Lowering the pressure also helps the rebound and damping characteristics. This is the casing that pros have been using for the 25-26 season in the dry, so the average person can see what the pros want out of a casing.
jalopyj
Concord, CA, USA
7/29/2026 10:20am
Thanks @notseanday.
1. Are any pros running DHX front and rear vs. DHX F / DHRII R?
2. When are folks deciding to run an Assegai vs. DHX?
3. Any indication if the casing technology will filter down to EXO+/DD?
HarryMudd
Manassas, VA, USA
7/29/2026 10:24am Edited Date/Time 7/29/2026 10:25am
notseanday wrote:
Any questions about the DHX or updated DH casing let me know, both were my projects. In general the DHX does everything our current dry tires do...
When Maxxis releases more trail friendly versions, how does this tire compare to a dhf exo that does great over most of the terrain I ride? Would it just clog a little easier comparatively and roll faster?
notseanday
cumming, GA, USA
7/29/2026 10:42am Edited Date/Time 7/29/2026 10:53am
jalopyj wrote:
Thanks @notseanday.1. Are any pros running DHX front and rear vs. DHX F / DHRII R?2. When are folks deciding to run an Assegai vs...
Thanks @notseanday.
1- Some pros like the 2.4 DHR for looser conditions on the rear.
2- Most that have time on the DHX end up running it for most conditions. Some have very particular terrain conditions when they would go for Assegai, mostly when it’s really loose. Some just choose the Assegai because they don’t want to recalibrate tire feel.
3- DD and EXO+ should be in before the end of the year.*
*Edit- misread this. We are looking at touching up EXO+ and DD, but no definitive timeline. The end of the year estimates are for DHX in EXO+ and DD
notseanday
cumming, GA, USA
7/29/2026 10:46am
HarryMudd wrote:
When Maxxis releases more trail friendly versions, how does this tire compare to a dhf exo that does great over most of the terrain I ride...
Basically if you struggle with side knob roll the DHX is for you. If you don’t and the DHF works for you, keep enjoying the classics. The DHF is still a super fun tire in the right conditions, the DHX just delivers more consistency at high loads and high speeds, so if you don’t have these conditions the difference between the DHX and DHF would primarily be the smaller transition to the side knobs and a bit better braking for the DHX
7/29/2026 11:02am
I'd be curious to hear more on comparison of HR3 & DHX.  Before the DHX, I noticed a lot of pros had switched to running HR3 up front for the blown out conditions.  Now they seem to be only running HR3 a little bit.  I'm sure HR3 does better when the track is a mix of dry and mud just due to wider spacing.  I've basically switched to running HR3 full time for California conditions (very little moisture) because I feel like it does way better in moon dust and loose sand than Assegai-style treads.  Has the DHX kind of poached HR3 territory a bit, moving it into a tight band slot next to the Shorty/Wet Scream?
notseanday
cumming, GA, USA
7/29/2026 11:17am
AndehM wrote:
I'd be curious to hear more on comparison of HR3 & DHX.  Before the DHX, I noticed a lot of pros had switched to running HR3...
The HR3 is still a great choice if it’s super loose like you see in California. Some riders will chose the DHX is even heinous conditions just because the confidence in the hard or high load sections is so good for them. It’s always a trade off when hunting for .1 seconds at the top of the sport with tire choice. If the HR 3 is good for the majority of your riding it may be the best choice. The rule of thumb is that if the Assegai struggles with knob engagement in your terrain, the DHX will as well.
Tustin, CA, USA
7/29/2026 11:24am
related to the dhx release... I want to give a shoutout to the new 3c maxx terra that maxxis released.  I just tried it for the first time on a 2.5 dh dhr2 as a rear tire and the longevity/wear is significantly improved.  Previously, this same tire as a rear would be looking pretty shot after 5-6 full park days... but the new compound only just started to show wear ever so slightly after day 3.  Suffice to say, it seems to me that it will last somewhere around 2x longer... maybe a bit less than that.  Conditions were too blown out for me to comment on increased grip however.
johann377
Mosfellsbaer, IS
7/30/2026 8:39am
Don't have enough time on them to do a full write up on them, but this is something you really feel coming from the old Schwalbe radials. The tread feel is similar but corner support is way different.
7/30/2026 11:17am Edited Date/Time 7/30/2026 1:55pm
Yeah, I can't tell how much of the hype around the DHX as a "dry conditions tire" (whatever that means) is an accurate description of its performance window vs. talking points from Maxxis to create clear product differentiation within their lineup. Mammoth is dry, but it's so dry you want to run HR3's or full mud spikes. So what does "dry conditions" even mean?
I'm excited to try this tire at some point, because I live in the land of actual dry conditions year round. Can't tell if this will be a front Assegai replacement for me, a front HR3 replacement, or a great fast rolling and braking rear tire. Or some combination of the three, or none of the above, or something else entirely.
I will add, in sympathy to the journalists, that writing about the finer points of comparative tire performance is extremely difficult. It's easy for those descriptions to either be too vague to be helpful, too specific to be accurate, the result of placebo effect and/or confirmation bias, or just boring.
7/30/2026 1:02pm Edited Date/Time 7/31/2026 6:21am
I would also add, after spending most of my last rides thinking specifically about my tires feel, subtelties in conditions, rider's energy and mindset can change how a tire feels.
For example, using the gen 1 Schwalbe Albert Gravity 2.5 US front/rear, mostly dry rides. Early in the season, not in the best shape, I was cautious but gaining confidence in the tires. I settled on the best pressure after 5-6 rides and just enjoyed them afterwards. Then I reached one ride where I was tired and the tires seemed skittish and less predictable. The ride after, they felt great again and I found the confidence back (I was less tired I guess).
So riding a tire only a few times doesn't give all the traits. I guess when you tests parts for a living you end up taking this in consideration when doing a "first ride" review.
As a side note, I still wish that the side knobs were bigger on the Albert 2.5, but after 15-ish 1.5-2h rides, they show almost no wear and are still some of my favorite tires ever.
notseanday
cumming, GA, USA
7/30/2026 1:30pm Edited Date/Time 7/30/2026 2:49pm
Yeah, I can't tell how much of the hype around the DHX as a "dry conditions tire" (whatever that means) is an accurate description of its...
in conditions where the Assegai does well, this tire will do well and has the added benefit of better stability in high speed, high load conditions. Essentially no downsides compared to Assegai. It rolls a bit faster as well. If you have a bunch of high load sections, DHX front and rear can be beneficial as at times a DHR rear will lose stability and step out.
In times when it’s dusty or muddy enough for the Assegai to be overwhelmed, the DHX will be overwhelmed as well. It’s not a HR3 replacement by any means.
