Dumb Bike Problems
5/7/2026 12:42pm
I think backwards in the sense of the direction of wrapping it around the mounting bolt. Most times I deal with shimano stuff I'm not quite sure...
Most times I deal with shimano stuff I'm not quite sure how to route the cable to be honest...
Yeah that will be it - some of the shimano mechs were definitely routed in a way that isn't intuitive!  But it made a big difference
5/7/2026 3:47pm
Yeah after reading it again - if this is a sram brake I definitely think it wasn't tightened enough. The olive should be crimped on to...
Yeah after reading it again - if this is a sram brake I definitely think it wasn't tightened enough. The olive should be crimped on to the hose so they are pretty much impossible to separate. And because the barb threads in to the olive, thats why it snaps off. I guess its tight enough to press against the housing, but hasn't squashed down on to the hose properly. Older brakes (and I guess shimano) could pop the line out completely if the hose wasn't clamped enough, like @HexonJuan described but the more recent threaded inserts prevent that (I say recent but I think they've been around over 10 years now.....)
There was a run of sram xx brakes in about 2010 with the super light lever bodies that were known to occasionally shatter when tightening. They had a composite filament kind of structure, and were so expensive they weren’t common.
I recall having a major discussion with the sram team rep when two did it on a weekend before a race and both athlete’s bikes had front ends covered in DOT fluid.
HexonJuan
5/9/2026 1:18pm
Dammit. One on me today. Why is my 12sp XT shifting like garbage on the dirt? Totally helps when you put the 2nd position cog in the right orientation. Lesson: if you need glasses/readers, wear em when aligning your cogs. It really helps to connect the goddamn (alignment) dots on the cogs....
5/10/2026 5:45am Edited Date/Time 5/10/2026 5:45am
HexonJuan wrote:
Dammit. One on me today. Why is my 12sp XT shifting like garbage on the dirt? Totally helps when you put the 2nd position cog in...
I just swapped in a pair of stupid-cheap new Code RSC's for an extraordinary well-used pair (to the point where I was having a hard time reviving one of the lever bearings, and replacing those things is a PITA - at least with the bearing tools I have).  TIps from you and Jono seemed to make a difference on install.  Eventual removal will tell the full tale.
To the extent I was under-tightening the barb and barrel nut, I'm going to look at the positive.  Been doing almost all of my own wrenching for a couple of decades, and I think that'd be the first time I didn't forget to fully torque something and the problem wasn't overtightening it.  I'm maturing.
Riding by myself the other day, I snapped an X01 chain for the first time in ages.  Riding with an EDC pump and my minimalist hip pack on a bike without internal storage.  Hip pack was new and somehow the tiny readers I keep in all my packs weren't in it.  Had a hell of a time getting a quick link installed and going again.
It's frustrating to know that you can carry around a vast array of tools, but if you don't have your glasses, you're screwed.  I've long maintained there's a market for steerer-tube readers that pop out like OneUp's multitool.
5/10/2026 6:59pm
I removed one of the brake caliper post mount bolts on the weekend and failed to catch one of the cone washers before it bounced across the tiles and down a ducted heating vent.
Pro tip: close the vents before working on your bike.  Or put some mesh backing on them.
5/11/2026 4:36am
boozed wrote:
I removed one of the brake caliper post mount bolts on the weekend and failed to catch one of the cone washers before it bounced across...
Been there.  They also make magnetic covers for vents.  I have one on the floor vent near my work stand.
I looked one time for the little bent c-clips SRAM uses on their pad retaining bolts.  I wanted to buy a 100 so I could drop them and not even bother looking for them.  Actually hard to find in that small of a size.
Do people just say screw it and not bother with those clips?  I've forgotten to tighten a pad retaining bolt once.  It's not like a I remember the clip but forget to tighten the bolt.  I've never had a tightened pad retaining bolt back out (knock on wood).
HexonJuan
5/11/2026 6:09am
This matters. Worked with a guy who was how you say Very Proud of His Excellent Mech Skills. Watched him struggle with a front derailleur for over a half hour before he asked me to take a look at it. Cable was on the wrong side of the pinch bolt.  Not even 2 minutes to correct his installation error. That right there is why I spent extra time reading up and watching vids of Sram and Shimano's newer style front d's when they came out. A good mech knows they don't know everything, terra incognita means you study the map before embarking.
HexonJuan
5/11/2026 6:11am
I just swapped in a pair of stupid-cheap new Code RSC's for an extraordinary well-used pair (to the point where I was having a hard time...
"....and the problem wasn't overtightening it.  I'm maturing." YUUUUUP! Thanks to you I nabbed a pir of readers to stash in my downtube permanently. That is an excellent idea!
Dogboy
Chapel Hill, NC, USA
5/11/2026 6:30am
You can always remove the cable fixing bolt and find the groove/path that Shimano wants you to orient the cable in. That or si.shimano.com and look at the docs.
5/11/2026 9:16pm
Been there.  They also make magnetic covers for vents.  I have one on the floor vent near my work stand.  I looked one time for the...
The clips often fall off during riding anyway. I've ran multiple brakes over the years for years without a clip and never had a problem. The bolt bakes into the threads anyway.
5/11/2026 10:19pm
The clips often fall off during riding anyway. I've ran multiple brakes over the years for years without a clip and never had a problem. The...
The clip is probably an effective reminder to tighten the bolt on its own... In my experience they don't fall off Shimano calipers, but maybe that means I don't ride hard enough.
On the lower grade Shimano brakes that use split pins to retain the pads, I did once have a bike shop mechanic insert the pin and then forget to bend it.  I didn't notice until I lifted the bike off my car at the bike park.
5/12/2026 5:59am
Here's a new one from this past weekend - catching up on maintenance doing a brake bleed. Need to clean the pads off so I go to my shelf of flammable /aerosol cans in my garage. Brain is on autopilot, I thought I grabbed the brake cleaner and sprayed a set of pads was confused by the smell. Turns out I grabbed penetrating oil.
codahale
Fort Collins, CO, USA
5/12/2026 2:07pm
“Why do these new grips feel like crap?” weeks pass “Why does my right grip have a big L on the end? … Oohhhhh”
I also found myself the other day mistaking the ft-lb scale on my new torque wrench for the Nm scale so now I’m wondering what bolts on my bike are fighting for their lives rn.
5/13/2026 10:33am
Carbon nerd thread reminded me of one:
My friend cracked the seat tube of his brand new hardtail by accidentally knocking it over into a shelf corner in his garage. He fixed it with a repair kit and rode it for years but that's about as bad as it gets.
HexonJuan
5/13/2026 1:19pm
codahale wrote:
“Why do these new grips feel like crap?” weeks pass “Why does my right grip have a big L on the end? … Oohhhhh”I also found myself...
Rode my only set of Ergon GE's on the wrong sides and didn't care for em. Switched em over to the correct side and still didn't care for em. Fine on the cruiser however.
SylentK
5/14/2026 2:28am
I guess it was my turn for Waterloo Quackery. Knock block and pressfit BB. You freakin kidding me?! No wonder why it was on super sale. But for that price, what could go wrong? See above. You guys probably already knew this.
5/14/2026 10:03am
HexonJuan wrote:
"....and the problem wasn't overtightening it.  I'm maturing." YUUUUUP! Thanks to you I nabbed a pir of readers to stash in my downtube permanently. That is...
Old man/ old eyes hack. If you have presbyopia( the loss of the ability for your eyes to focus on close objects) you most likely have your fix with you. Curl your index finger tightly until there is only a small gap.  Bring this close to your eye and look through it at what you’re trying to focus on. This small aperture is the same thing a camera lens uses to increase depth of field. It’s not perfect, but it may get you by. I have a 2.0 diopter close up correction and this works for me if I don’t have my readers.
IMG 5970.jpeg?VersionId=e5VM IpUKivr.F6C.kFVmtFOg
5/15/2026 4:18pm
63expert wrote:
Old man/ old eyes hack. If you have presbyopia( the loss of the ability for your eyes to focus on close objects) you most likely have...
I did enough years in middle school to worry about getting my face bopped when it tried it. I would not trust this advice in person lol.
5/19/2026 12:13am
Just tried this, Holy Shit! Great tip.
Don't worry Bobs_is_better_than_A-line, I'm alone in the house, and still sane enough to not bop myself.
5/19/2026 5:27pm
I did enough years in middle school to worry about getting my face bopped when it tried it. I would not trust this advice in person...
I immediately googled it to make sure he wasn't f'ing with us.  Imagine having been able to do that in middle school.
What does it say about you if you're old enough to need to do this but one of the first thing that occurs to you is making a joke about looking at your dick?  I guess it's true that youth is fleeting, but immaturity can last a lifetime.
owl-x
Shell Beach, CA, USA
5/19/2026 5:49pm
IMG 1360 0
5/20/2026 12:25pm
Ongoing / unresolved "me problem":  I like my brake levers' bite point to feel the same left/right.  Of course, my left arm is weaker than my right due to being right handed, so the right lever always feels easier than left.  I tend to progressively wind out my right brake levers' contact point, since that makes the bite point feel sharper.  Over time, the measured bite distance discrepancy builds up - the other day I measured my right's to be a full 1cm further out than the left.  Then my OCD for making things matchy-matchy kicks in, so I reset the contact adjuster to match distances.  But you can bet that I'll be winding it out again next ride, and the cycle will continue.
5/22/2026 6:48am
AndehM wrote:
Ongoing / unresolved "me problem":  I like my brake levers' bite point to feel the same left/right.  Of course, my left arm is weaker than my...
I always set up my levers for equal bite point instead of resting distance from bar.  Sometimes my are very visibly different as pads wear.  As long as they feel the same when I give em a squeeze I'm happy.
HexonJuan
5/26/2026 1:47pm
Tried it this past weekend and I'll be damned. It worked. Kept me from running upstairs for the readers when centering a caliper. This was one of those tips that was the reason for the innernuts creation.
Falcon
Menifee, CA, USA
5/29/2026 12:48pm
Don't get me started on "matchy-matchy." I have been known to consume hours when putting stickers on my helmet, making sure they are straight and symmetrical with other logos. You know you have a real problem when you are aware that sometimes you have a to put a sticker on slightly crooked so it will appear straight.
Back to the levers: How does anybody ride without their levers being exactly the same? I mean, that's probably what causes Hantavirus or something.
5/30/2026 10:44am
I have a “fun” one. Got an ultrasonic cleaner last week to go with my new waxing regime, time to clean everything! I had a couple hours and figured I could settle in for some meditative bike maintenance. I’d pulled my cassette (Garbaruk XD 12 speed) and the cleaning cycle was almost done when my wife was home early from some cancelled plans- and now my available time evaporated. Pulled the now sparkling cassette out (ziplock with purple Simple Green, half hour at 70C, chefs kiss) and was rushing to reassemble everything (with a new waxed chain on too.) Cassette went on but didn’t feel quite the same (tight but not that hard stop) and I assumed it was the grease making it feel different. Throw the wheel in and it’s freewheeling fine, go to pedal and the resistance is massive. No problem I thought- it’s just the freshly waxed chain that needs to loosen up. I had also swapped the housing entry angle into the derailleur (Madrone) for better routing and figured I’d need to adjust shifting, so wasn’t concerned about the absolutely horrendous shifts up to the top of the cassette. I was finally able to get it turning with difficulty in the easiest gear and thought “man, this chain is way harder to break in than my other waxed chain,” when I started looking at the cassette as it spun. Massive wobble.
I pulled the wheel and realized what I’d done- cross threaded the cassette onto the freehub. I was able to pull it off and was greeted by a bunch of thin aluminum shavings from the cassette driver and the freehub. After keeping myself from screaming curse words at the top of my lungs, a shower and a calm down, later I came back to it, cleaned out all the shavings and was able to get it threaded on and seated properly.
I now recognize that it was the universe telling me that I hate i9 hubs and really should rebuild the wheel with a Sidekick hub when they’re back in stock. In other news- if you’re out of time and it’s not absolutely critical to finish your bike maintenance, just walk away and finish when you have enough time. Learn from my experience. And also, if anyone wants a slightly questionable Garbaruk cassette that’s perfectly matched with an i9 freehub please let me know- I’d be willing to let them go for very reasonable rates.
5/30/2026 5:58pm
Why is there so much drag and what is that awful noise?  Oh.
What is the purpose of this feature on Shimano Mx100 derailleurs?  It isn't structural and it forces you to break the chain again if you accidentally route it the wrong side.
image 720
5/30/2026 10:34pm
boozed wrote:
Why is there so much drag and what is that awful noise?  Oh.What is the purpose of this feature on Shimano Mx100 derailleurs?  It isn't...
image 720
Just open up the cage via the pulley bolt and fix it that way?
5/30/2026 10:42pm
image 720
Dumb problem #2: I didn't consider that
5/31/2026 5:15am
I think the purpose of that little tab is to be a mini chain guide for the upper pulley in big chain slap moments.  Pull the cage forward by hand and imagine the chain slapping and flopping around.  Seems like it'd be easy for the chain to jump off the upper pulley if that tab wasn't there.  I just checked a couple of X01 derailleurs in the old parts bin because the clutches started to wear out, and you can clearly see that the chain has hit that tab.
Post a reply to: Dumb Bike Problems
