2026 Predictions
Evwan
Sunnyvale, CA, USA
12/31/2025 5:34pm
image 83
1/1/2026 10:03am
piggy wrote:
I'll give you a 2027 predition - motor gearbox units (possibly some CVT) will go mainstream on ebikes.
If this happens we’ll see the full fat segment morph into 55lb full power e-bikes with motor gearboxes. Then, the SL e-bikes as we know them (42lbs with Exo tires and 400wh battery) will fade into the bushes and be replaced by 45lb DJI powered bikes with 600wh batteries. 400wh just isn’t enough to not take your analog 120-140 bike out now that they’re fashionable again.
1/1/2026 10:27am
We carry on to ride bikes for the reason we started  as it’s funEnduro dies at a local level it becomes like gran fondo- participation event...
Enduro dies at a local level it becomes like gran fondo- participation event but there’s less races
Festival style events with bikes, some racing and partying get bigger
More e-bikes
Brands reduce making 160/170/180mm bikes (enduro) as e-bikes fill this gap
120/130 bikes more popular if you ride a non motorised bike
Less dh riders able to get a ride and rightly so if they aren’t good enough
Less Instagram “ambassadors” with industry cuts
Riding bikes will still be fun
I’m down with the 120/130 stuff but I really want to see brands move away from flex stay and back into higher performing suspension designs on...
I’m down with the 120/130 stuff but I really want to see brands move away from flex stay and back into higher performing suspension designs on these short travel bikes. It’s interesting that Giant explicitly called out other flex stay bikes having excessive flex in their stays and I think there is something to that. The short travel bikes can be incredible but I just hope 2026 finds them freed from the XC limitations…
There’s some good alternatives already (SB120, Tallboy, Trailcat Sl, to name a few). They’re just not that light, which kind of defeats the purpose of a short travel bike IMO. Why not have 130 or 140 rear travel, if your bike is going to be 32lbs.
I think they are getting closer to blending both into one (trail performance + XC weight). Salsa Spearfish seams to be leading the charge, but I’m sure better options are coming. Should be an exciting Sea Otter for this category.
iRider
DK
1/1/2026 10:46am
If this happens we’ll see the full fat segment morph into 55lb full power e-bikes with motor gearboxes. Then, the SL e-bikes as we know them...
You guys know that light e-motos are already available, or? 😉
MikeyMT
Bozeman, MT, USA
1/1/2026 11:46am
1. Loic wins the overall
2. Vali goes undefeated
3. e-bike hate will increase
4. The new demo will be made into an e-bike version - the 2 chain mechanism will be swapped for a new motor from Spec.
5. Bikes wont change much
6. Gates still pushes the nonsense purse to no avail
7. Reece Wilson will do something even more weird with his bike and still not make it through in Q1.
JamesB
1/1/2026 12:15pm
Trek finally releases the Ticket S that every pro has been on for the last 8 years.
Aluminum becomes the hot material for MTBs.
Warner Bros continues to announce record breaking viewership, even though nobody believes them, and pro level enduro continues to be more of a feeding series to downhill rather than the end-goal. (Maes, Harnden, Rude, etc)
2.25 clearance on all new gravel bikes. That's the line in the sand that divides MTB from Gravel.
sweaman22
Calgary, AB, CA
1/1/2026 1:00pm
Not perhaps a 2026 but more long term. Bike brands are going to aim for much simpler line ups.  Right now it's 1-2 ebikes and 4(ish, very ish) normal bikes (showing my bias). Hardtail. Race, Trail, Enduro.
But I don't think we'll see 4 ebikes from a brand? So then is it going to be economic to still carry all the pedal bikes or do you go for just a couple??
1/1/2026 2:58pm
MikeyMT wrote:
1. Loic wins the overall2. Vali goes undefeated3. e-bike hate will increase4. The new demo will be made into an e-bike version - the 2 chain...
I'll double down on your #4 and predict that the e-Demo will not have a physical connection between the cranks and the motor output, ala Also TM-B.
Ahab
Brooklyn, NY, USA
1/1/2026 4:08pm Edited Date/Time 1/1/2026 4:21pm
Rob Warner does a genealogy test, figures out he's actually one of the Warner Brothers, saves World Cup DH from itself
28
1/1/2026 4:40pm
sweaman22 wrote:
Not perhaps a 2026 but more long term. Bike brands are going to aim for much simpler line ups.  Right now it's 1-2 ebikes and 4(ish...
While I think for some brands that will go that route.  And Others will go the route of the new trek with multiple roles engineered into one platform.  I think most the premium brands will continue to offer specifically engineered bike for most travel ranges.  Sometimes even multiple bikes with diffirent tasks or wheel sizes in those travel ranges.  However the product cycle for those bikes (especially the niche ones) will be much longer.  Like specialized with the enduro.  We may see 2-3 stumpy cycles or variations while the enduro only is updated once a decade.  Transition for another example will likely continue to have a diverse lineup with seemingly quite a lot of overlap.  Allowing customers to really pick that “perfect for me” or “perfect for this role” bike.  But rather than introduce a full or nearly full lineup of bikes with all the same features, design language, etc they will continue to run longer product cycles even if some of the line up is getting a bit “old”.  6 even 7 year product cycles as opposed to two to three.  And some more niche models like the pbj, spur, bottle rocket going even longer.
It’s going to be even more competitive to get a sale going forward.  The economy is getting harder for people to get into the sport and the quality of product means those who are in it are less in the habit of buying a bike every season.  I don’t think there is such a high level of efficiency to be found to outweigh the value of a genuinely good addition to your product lineup.  However brands will need to really think about what value their r and d budgets are returning and what they are really offering to a customer.  Cause the days of just pushing new bikes out the door just because it’s new are gone in general.
1/1/2026 7:01pm
1. Vali and Gracey are neck and neck all year. My CDN heart wants Gracey to win, but Vali doesn't fold and wins again.
2. It's not even close. Jackson smokes the field.
3. Very few new bikes are sold. Tell me how you convince a guy with a 22 Hightower (just an example), that a new bike is going to change his world.
seanfisseli
Santa Cruz, CA, USA
1/1/2026 10:06pm
1. Vali and Gracey are neck and neck all year. My CDN heart wants Gracey to win, but Vali doesn't fold and wins again.2. It's not...
His chainstays are too short, bike is unrideable. Stack is too low, unrideable. Seat tube too slack, unclimbable.
MikeyMT
Bozeman, MT, USA
1/2/2026 7:04am
While I think for some brands that will go that route.  And Others will go the route of the new trek with multiple roles engineered into...
Id love to see the big brands offer after sale support. Imagine buying a Stumpy, then having a direct line to all Spec parts - wheels, saddles, etc.
1/2/2026 7:12am
- Amflow stays popular despite “real” brands dropping DJI bikes. They lower their prices/build spec to compete. Teewing is too late and fails to get its footing against the “real” brands and Amflow.
- Bosch bikes go on sale at the end of the year.
- Bikes on sale remains the new normal. Everyone has a great bike with a lifetime warranty. New riders continue to get insane deals on used bikes. Low prices are the only way these 2 groups will be convinced buy a new bike even sans rampant inflation.
- YT makes a better comeback than we’d hoped for. Compromises build spec a little to maintain their low prices.
- Nukeproof comeback flops because they set prices too high. The Nukeproof of ole was a great value in that it’s nicer than Marin/Polygon/Vitus but less expensive than a Transition or Santa Cruz. (this is how the brand is perceived in the US at least)
- More park/free ride bikes released
- Continental radial tires. Maxxis ignores radial and continues to fall off from its once dominance.
- Tires stay way too expensive
- Ric is finally kicked out of the commentary booth
- Gravel and XC begin to merge as gravel riders want 32” and aero XCM continues.
Clownshoe
Whistler, BC, CA
1/2/2026 7:18am
Hardline British Columbia
Moreno Valley, CA, USA
1/2/2026 7:20am
I know this deal is expected to take up to 18 months to close, but, Netflix/WBD deal is something to keep an eye on. The future...
I know this deal is expected to take up to 18 months to close, but, Netflix/WBD deal is something to keep an eye on. The future of seeing live MTB racing is in oligarchs hands.
I don’t think you know what that word means.
1/2/2026 7:30am Edited Date/Time 1/2/2026 7:31am
More excited about this than pretty much anything else in 2026. I hope they announce it soon so I can book it off. Probably more excited about that than the World Cup stop in Whistler...
Clownshoe
Whistler, BC, CA
1/2/2026 7:34am
saskskier wrote:
More excited about this than pretty much anything else in 2026. I hope they announce it soon so I can book it off. Probably more excited...
Crankworx DH, World Cup DH, and (hopefully) Hardline BC would make for an all time summer of race viewing in southern BC
1/2/2026 7:59am
I think that only works with forum nerds and I think they are less than 10% of the MTB public.
MikeyMT
Bozeman, MT, USA
1/2/2026 8:24am
Nothing like crankworx DH watching a bunch of randoms get beat by the 1 real WC racer…maybe will pull more people this year given same track as WC…
ntm95
Lloydminster, AB, CA
1/2/2026 8:50am
- Amflow stays popular despite “real” brands dropping DJI bikes. They lower their prices/build spec to compete. Teewing is too late and fails to get its...
I highly doubt amflow will stay popular unless they release a different bike soon. The motor/battery is good, but the bike itself is a stumpjumper knockoff from temu. I was not impressed with the one I tried. It's laughable that they're priced higher than a forbidden e druid (which is a much, much better bike). The teewing flux also looks vastly superior in terms of geo and kinematics to the amflow, but we will see how their production quality and detail work gets on.
seanfisseli
Santa Cruz, CA, USA
1/2/2026 9:47am
My comment was regarding how the industry will justify new bikes, not whether or not riders are on board with that reasoning currently. But to your point, the fc/rc ratio and stack equation is gaining a lot of momentum and it’s not just forum nerds. What’s wild is that over on bikepacking the gravel people are having the same discussions about chainstay length, and now the 32” trend will also push CS lengths out into the 450s.
MTBs have been in a constant state of refinement but there is always a possibility for major advancements when it comes to basic tenets of bike design. It’s not always an industry conspiracy, things like 27.5+ really have huge benefits, and longer+slacker saved countless collar bones. It’s hard to predict what will drive the next revolution but to say there is no need for a new bike is silly, there are lots of issues with the current lineup.
seanfisseli
Santa Cruz, CA, USA
1/2/2026 10:51am
More e-bikes
There’s some good alternatives already (SB120, Tallboy, Trailcat Sl, to name a few). They’re just not that light, which kind of defeats the purpose of a...
tallboy is on my shortlist of bikes to ride. i was a huge fan of the stumpy carbon, but the flex stay was noticeably more chattery than the alloy four bar version. the epic evo was even worse and so my hypothesis coming off of those three bikes was that a 130 four bar lightweight trail bike would be my ideal bike. unfortunately i am long CS-pilled and so the current offerings leave me concerned for handling.
1/2/2026 11:06am Edited Date/Time 1/2/2026 7:17pm
My comment was regarding how the industry will justify new bikes, not whether or not riders are on board with that reasoning currently. But to your...
I think head tube angle, handlebar width, and dropper post length are as far down the rabbit hole as much mountain bikers go. Now that head tube angle has been sorted out and they can run a long dropper, they will be satisfied to spend their time colour matching parts instead of a new bike.
earleb
North Vancouver, BC, CA
1/2/2026 1:49pm
No dates yet...but lots of local talk of it being at Cypress. So dig around for North Van accommodations.
1/2/2026 9:56pm
Some serious names in XC will get Gravel Curious and start to dabble. The "spirit of gravel" is on life support, if not dead already. Pit stops have crews, domestiques are hiding out in the open, and money is flowing in.
1/3/2026 12:08am Edited Date/Time 1/3/2026 12:10am
I think you're right on the 120-130mm bikes. I think bikes are going to divide into short travel bikes, ebikes, and DH bikes. Maybe not 2026...
I think you're right on the 120-130mm bikes. I think bikes are going to divide into short travel bikes, ebikes, and DH bikes. Maybe not 2026 but at some point.
And I bring this up because some folks don't know (literally a friend of mine was telling me how much they miss parmigiano reggiano but they haven't had it since they've become lactose intolerant): Aged hard cheeses have less lactose than younger and/or softer cheeses. If a person is intolerant, they might still be able to have parmesan, Romano, Manchego, and other aged hard cheeses. The aging process in cheese denatures some of that lactose that would be in younger cheese. Something that I thought was obvious changed my friend's lactose intolerant life because they tried and could tolerate hard cheeses after thinking that had to give up cheese completely. So now I bring it up every time someone mentions cheese and lactose intolerance.
Cheese sidebar over. Bikes are sick.
On top of the fact that most aged cheese has bugger all lactose, you can readily purchase tablets which contain the enzymes needed to break down lactose. You literally just pop one before your cheese orgy and you’re all g.
The lady is actually lactose intolerant and does this on the regs.
I actually had a cheese hangover going into 2026, was brutal.
Mr.Nally
AS
1/3/2026 4:31am
I heard it's the weekend before Whistler WC though. Which is dumb. Cos a lot of faster racers probably won't do it
MikeyMT
Bozeman, MT, USA
1/3/2026 8:46am
I predict Jackson won’t do it again…overall is the real deal Hardline is still just a glorified crank works.
1/3/2026 9:34am
I predict there is zero chance Jackson doesn't race BC Hardline unless he's injured.
Post a reply to: 2026 Predictions
