DT Swiss DEG DF
4/26/2026 5:03pm
ex-ballz wrote:
I've just placed an order for the base Sidekick. The price is too tempting, thank you for the note.
Another benefit is the new hub is that it has damn near zero drag similar to the WRP kit. Seems like a win win.
sweaman22
Calgary, AB, CA
5/12/2026 8:48pm
Just fitted a DF hub to my Patrol. It's in the 10deg setting and it's made a noticable difference through some of the rough trails we have here (Canadian Rockies).  My previous bike was a V1 Druid and whilst I didn't miss too many things from it when I moved to the Patrol I did notice the increased feedback at the pedals. I think the DF hub has certainly helped in that regard.
I debated Sidekick but my LBS had this already in stock and I had DT wheels. I can see myself ordering a Sidekick for my better halfs Bronson.
No ochain as we're both running 28 front chainrings as we're old :0)
5/12/2026 9:50pm
Jakowitz wrote:
Had my first ride on the EX 1700 today, DT Swiss’ new alu wheel that comes with the chain device installed. It cost £400 for the...
Had my first ride on the EX 1700 today, DT Swiss’ new alu wheel that comes with the chain device installed. It cost £400 for the full wheel at RRP which feels like quite a fair price.
It felt really great, the bike almost felt like it floated under me, my friend noted that my rolling speed seemed high. It’s quite a chain slappy bike and the device has definately reduced that on the small chunk, but it still slaps on proper hits.
One odd thing that may be unrelated is that the suspension felt too soft, I even had a couple of unexpected bottom outs. I guess the chain was providing some compression damping force that has now been reduced?
Will report back after a few more rides but initial impressions are that it’s made a difference for sure and since it came on a wheel that id happily buy anyway, it’s good value for money.
"One odd thing that may be unrelated is that the suspension felt too soft, I even had a couple of unexpected bottom outs. I guess the chain was providing some compression damping force that has now been reduced?"
This is something I remember being reported by other folks who have tested these sorts of devices. Their suspension was moving more freely which meant it more freely got to the bottom of the travel.
I think you're probably right; I'd imagine adding more compression damping would help.
Simcik
Loma, CO, USA
5/13/2026 6:18am
Simcik wrote:
I have it in a few bikes. I WORK AT DT SWISS. I have not ridden o-chain. I live in Western Colorado and basically ride in the...
I live in Western Colorado and basically ride in the 10 degree setting all the time. When I go to the bike park, then I swap to the 20. On my e-bike, it is always in the 10 setting. On my PNW trip last year I swapped depending on where I would ride.
Around here, trying the 20 degree at our techy trails, you do get a bit of a thud when riding technical terrain on the analog bike. I haven't noticed that as much on my e-bike.
DubC wrote:
What is the thinking for choosing the 10 deg setting in your EMTB? Wouldn't you want to run the larger 20 deg setting since the motor...
What is the thinking for choosing the 10 deg setting in your EMTB? Wouldn't you want to run the larger 20 deg setting since the motor activating quickly takes up the freeplay so engagement speed is much less of a concern than on the MTB?
Sorry, just saw your message. I have the Hybrid DEG DF on my e-bike, which only has the 0/10 settings. To your point, no need to ever run it in the 0 setting. Should have clarified that.
I have DEG DF on my other bikes which also have the 20 setting but I only find myself running that in the bike park and on climb/plunge trails.
Jakowitz
Lichfield, GB
5/13/2026 6:27am
"One odd thing that may be unrelated is that the suspension felt too soft, I even had a couple of unexpected bottom outs. I guess the...
Yep I’ve settled on a couple of extra HSC clicks and nothing on low speed, perhaps need one there too though.
sweaman22
Calgary, AB, CA
5/18/2026 7:17pm
Few more days now on the Deg DF including a couple of days shuttling. I like it and it's made a noticable difference to the ride. The DEG hubs are noisy and for some reason they seem to have got louder with the DF installed. I don't know if it's that other stuff is quieter or just fresh service but.... If quiet hubs is on your wishlist e-13 might be the way to go....
5/18/2026 9:08pm
When do you feel they are loud? When coasting or when the hub engages?
5/18/2026 10:39pm
Both for me. They get louder as they break in when coasting as well as make a little thud noise when engaging.
Jakowitz
Lichfield, GB
5/18/2026 11:13pm
I thought it was the quietest hub ever initially- nope when it breaks in it gets more noisy. It’s not hope levels of noise though.
5/19/2026 6:49am
I'd agree - I haven't ridden them, but have noticed that my buddy's very new (~1 month old) 350 DEG set to normal hub mode is much louder than my old style 350 ratchet.
Simcik
Loma, CO, USA
5/19/2026 6:59am Edited Date/Time 5/19/2026 10:47am
AndehM wrote:
I'd agree - I haven't ridden them, but have noticed that my buddy's very new (~1 month old) 350 DEG set to normal hub mode is...
Bigger ratchets, more teeth, more surface area. I would agree they are louder than standard ratchet hubs. I think that is all DEG hubs. I hadn't noticed if DF ratchets being louder while coasting than non DF DEG ratchets.
sweaman22
Calgary, AB, CA
5/19/2026 10:01am
It's whilst coasting in my case. A lot of the time I'm riding rough rocky trails where I'm not super fast and there's often some background noise of loose rubble etc so the noise wasn't that noticeable. This past weekend I was on some smooth high speed jump trails and I really noticed it.
5/20/2026 11:29am
Is there a preference to the E*thirteen Sidekicks or the DT Swiss DEG DF? I may be building up a rear wheel soon.
ex-ballz
Ouagadougou, EH
5/21/2026 4:47am
I've been riding my Megatower with a Sidekick hub on our trails so far, no trips to bike parks yet. I started with the smallest dead band and I just don't think it's a great hub for technical trail riding, especially if you're used to instant engagement hub like Onyx. The bike is now also way louder on the downs. The chain slaps massively on bigger hits, or perhaps it's the hub clunking when the chain pulls on it hard? I have not been able to pinpoint the source of the metallic clunk just yet, but it's no bueno. Next step - STFU, let's see if it helps quieting this loud pig down.
Simcik
Loma, CO, USA
5/21/2026 6:02am
I used to work at DT and I have not ridden Sidekick so obviously I have a preference. What I like about the DF system is that it can be turned off in seconds. I live in Grand Junction and for Lunch Loops, there is a lot of ratcheting you will do. For climbing there I run it in 0. Every once in a while I will change it for a descent there. Otherwise I mostly run it in 10 around here. You can put it to the 0 setting which is 4-5 degree engagement (72 or 90T) super fast. Then swapping to 10 or 20 is super easy. It functions and requires the standard maintenance that any DT ratchet hub requires. It is pretty darn robust and reliable.
5/21/2026 6:56am
ex-ballz wrote:
I've been riding my Megatower with a Sidekick hub on our trails so far, no trips to bike parks yet. I started with the smallest dead...
The chainstay protector on the Megatower (both v1 & 2) is not great.  I replaced the stock one on my Nomad 6 with a Bronson 5 CS protector which has taller, softer fins and that helped a lot with the chainslap noise.  I'm sure the STFU or VHS fin tape would work even better, particularly on the underside.  I wasn't able to get an STFU loop device to work on the Nomad or Bronson without rubbing in some gears.  On other little trick I found that helped a bit was putting a bit of mastic tape on the underside of my right crank, as I descend right foot back, and there are marks from the chain slapping the end of the crank.  Biggest upgrade for quietness was putting an Ochain on, which takes out everything but full compression slap.
ex-ballz
Ouagadougou, EH
5/21/2026 8:01am
AndehM wrote:
The chainstay protector on the Megatower (both v1 & 2) is not great.  I replaced the stock one on my Nomad 6 with a Bronson 5...
Thank you. I have STFU on V5 Bronson and it works very well for me, but I also have 11sp SRAM drive train on my bikes which makes its setup easier. I have a feeling that any freehub with a dead band and without some damping feature is just going to be clanging when the chain yanks on it hard, hopefully the STFU will damped the chain oscillations enough.
5/21/2026 5:51pm Edited Date/Time 5/22/2026 5:48pm
Simcik wrote:
I used to work at DT and I have not ridden Sidekick so obviously I have a preference. What I like about the DF system is...
In seconds?! Both systems require the wheel to be removed from the bike and then the cassette from the hub before you can adjust them.
Sidekick has the advantage of single point pawl contact while it isn't engaged, so probably has noticeably less freewheel drag (and noise, if that's of value to you), b̶u̶t̶ ̶i̶t̶ ̶i̶s̶n̶'̶t̶ ̶c̶l̶e̶a̶r̶ ̶t̶o̶ ̶m̶e̶ ̶w̶h̶e̶t̶h̶e̶r̶ ̶i̶t̶ ̶h̶a̶s̶ ̶a̶ ̶f̶u̶l̶l̶y̶ ̶d̶i̶s̶a̶b̶l̶e̶d̶ ̶(̶z̶e̶r̶o̶ ̶a̶d̶d̶i̶t̶i̶o̶n̶a̶l̶ ̶f̶l̶o̶a̶t̶)̶ ̶s̶e̶t̶t̶i̶n̶g̶ ̶–̶ ̶i̶f̶ ̶i̶t̶ ̶d̶o̶e̶s̶ ̶t̶h̶e̶n̶ ̶t̶h̶a̶t̶ ̶m̶e̶a̶n̶s̶ ̶i̶t̶'̶s̶ ̶o̶n̶l̶y̶ ̶4̶0̶ ̶P̶O̶E̶.  DEG DF has the advantage of more POE (90), so it's genuinely high engagement when disabled and its float is more constrained, while it also has a wider range of float settings (I think they measure them differently, i.e. i̶f̶ ̶I̶'̶m̶ ̶c̶o̶r̶r̶e̶c̶t̶ ̶a̶b̶o̶u̶t̶ ̶S̶i̶d̶e̶k̶i̶c̶k̶ ̶b̶e̶i̶n̶g̶ ̶4̶0̶ ̶P̶O̶E̶ ̶t̶h̶a̶t̶ ̶m̶e̶a̶n̶s̶ ̶e̶1̶3̶'̶s̶ ̶"̶1̶8̶°̶"̶ ̶i̶s̶ ̶a̶c̶t̶u̶a̶l̶l̶y̶ ̶9̶-̶1̶8̶°̶ (edit: seems to be 60 POE. I still think e13 quotes the maximum total float, if so "18°" would mean 6-18°.), while DT's "20°" is 4-24°).
Edit: corrections per ballz and sweaman22 below.
Simcik
Loma, CO, USA
5/22/2026 6:37am
boozed wrote:
In seconds?! Both systems require the wheel to be removed from the bike and then the cassette from the hub before you can adjust them.Sidekick has...
Yes, you have to remove the wheel on both. DT hubs you can remove the cassette and FHB without any tools, just lift up on it and the FHB/cassette pop off. Adjust the DF ratchet and reassemble. That is seconds. Pulling the wheel takes longer than making the adjustment.
ex-ballz
Ouagadougou, EH
5/22/2026 7:06am
There's no 0 deg deadband setting in Sidekick, which I am starting to regret. The pawls retract when coasting and require the full deadband travel to re-engage so the 9 deg setting results in 9 deg + whatever the engagement of the pawls is of float.
sweaman22
Calgary, AB, CA
5/22/2026 10:28am
If I'm reading the e-13 website correctly the sidekick 2 is 60POE.  Which is 6deg. So it's 9-15deg?
DT DF in 10deg is 10-14? (10 degrees of float + 0-4 for the 90POE cassette.  Although I have read arguments that it's more like 5-9 because the DF points sit in the middle of the 10 when coasting.
My math might be way off here....
I have a DT350 36 tooth on a different wheel and it feels very similar to my DF in the 10deg setting although I've not done actual back to back style comparisons.
5/22/2026 4:23pm Edited Date/Time 5/22/2026 5:58pm
sweaman22 wrote:
If I'm reading the e-13 website correctly the sidekick 2 is 60POE.  Which is 6deg. So it's 9-15deg?DT DF in 10deg is 10-14? (10 degrees of...
That's my understanding of how it works, although I don't know whether the number e13 quotes is additive (as DT's must be, since it has a 0° setting) or the maximum in that setting. I'm much less certain about that now that I know the minimum setting isn't an effective zero.
I think freewheeling drag should be enough to hold the DF ring at the far end of its float range. At the end of the day the numbers themselves probably don't matter as much as the feel, though.
To answer FrontRangeFriend's original question, IMO all of this makes DT the clear choice, at least on paper. Once you can buy the hub with the DF ring preinstalled.
sweaman22
Calgary, AB, CA
5/22/2026 7:08pm
Unless you really value a quieter hub...
5/22/2026 10:02pm
I 100% guarantee what you are hearing is the metallic clank of the hub engaging. When you get used to the soft engagement of the onyx, a classic style and slower hub is jarringly loud. The slower/less POE means there is more momentum going into the hub engaging, therefore louder.
if you pack it full of grease it will be marginally quieter but it will only last a few rides. When I had a raceface vault hub, the extra large construction amplified the sound. I wrapped the hub in mastic tape and it muted it a bit.
Heatwave
., AZ, USA
5/23/2026 6:14am
Has anyone packed more grease in the DF system to quiet down the noise?
sprungmass
Calgary, AB, CA
5/23/2026 6:18am
There is only so much grease you can pack before the rachets start binding up. Even if you do, it only lasts a few rides.
paddydigital
San Luis Obispo, CA, USA
6/1/2026 12:28pm
Just had my first ride on a sidekick hub.
Pending any big differences in reliability, I think the answer basically comes down to your feelings on high engagement hubs. I’ve never really liked or sought out high engagement hubs (broke boy symptom?), so I don’t care about the lack of 0deg setting, nor was I bothered by the low engagement while riding.
However, the low drag of the sidekick was super noticeable and very welcome. I would take low drag over high engagement in a heartbeat. But for high engagement enjoyers, the dt deg df system wins hands down. Up to you whether drag or engagement is more important to your riding style.
Also, re: changing the settings trailside. Voluntarily opening any hub trailside is lowkey insane. However, any ratchet-style hub’s springs are more likely to spew their innards when you pull it apart than a pawl hub, so advantage to the sidekick here. But, again, don’t do this for either hub. Why tempt fate?
aaronufl
Poulsbo, WA, USA
8/22/2026 12:34pm
The DEG DF came on a new set of Reserve wheels I purchased a few months ago. I've played around with it on back to back laps and it does what it says it does, although I'm not sure it impacts my trail speeds that much. But over repeated hits the suspension feels calmer and similar to others I actually had to bump up the HSC a tad. The downsides are the lovely "clunk" it makes on the first pedal stroke and having to remove the wheel to adjust. I definitely wouldn't ride the 20 degree setting on a bike I pedaled regularly, but the 10 degree setting is enough of a difference that I'm fine running it as long as a lot of tech climbing isn't on the menu.
snowsnakes
Anchorage, AK, USA
8/24/2026 12:44pm
Interestingly, I haven’t been bothered in the slightest by the 20 degree setting on my REEB SST. That said, I’ve never cared much for high engagement hubs - I think because I ride flats and try to use momentum to my advantage a bit more than ratcheting.
The SST is one of those bikes that already feels insanely smooth for 120mm of rear travel, and I’ve found the DF hub makes it almost feel like a reverse hardtail - the back end is just absolutely planted through everything, without losing the innate pop from the air shock. Very impressed, personally.
CNutt
Morristown, NJ, USA
8/24/2026 4:09pm
Has anyone who has used the DEG DF or similar devices noticed an increase in rear wheel lifespan?
Post a reply to: DT Swiss DEG DF
