Suspension Data Acquisition
1/17/2026 10:52pm
thegromit wrote:
https://www.vitalmx.com/features/vital-mx-pit-bits-2026-anaheim-1-supercross More picture here. Looks like the have a mount off the case.
A1PitBits-070.jpg?VersionId=cfjpzhttps://www.vitalmx.com/features/vital-mx-pit-bits-2026-anaheim-1-supercross
Such a cool design and idea. I’ve used a motion instruments kit on motocross bike and the shock sensor set up took like half a day and I still ended up breaking the pot after a few weeks. Hhaha
1/18/2026 5:47am
Surprised that you don’t see a rotary pot and a link arm being used, far cheaper and more robust.
Been using string pots a lot recently as I can’t trust the guys using them to not bash them off. I’d like to back to back them with linear pots to see the response difference.
1/18/2026 6:48am
Such a cool design and idea. I’ve used a motion instruments kit on motocross bike and the shock sensor set up took like half a day...
I kind of wish I got sensors for my moto.... maybe another year. The moto feels so good that its hard for me to know if I am that far off but I would still be interested in the data.
1/18/2026 11:33am
Sir HC wrote:
Surprised that you don’t see a rotary pot and a link arm being used, far cheaper and more robust.Been using string pots a lot recently as...
I bought a couple of these sensors years ago - they are ride height sensors used by GM, super cheap and pretty much bomb proof. A bit bulky and they run on 5v so I haven't been able to use them on a bike yet, but I still think are a good option. V8 supercars do/did use them on racecars, plus Motec sells the exact same thing for about 5x the price. You can buy/make different length arms and brackets to mount on different bikes
https://www.ebay.com/itm/177392721144?_skw=Delphi+Right+ER10031+Suspension+Ride+Height+Sensor+for+08-11+Cadillac+CTS&itmmeta=01KF994E16FQD5Q7BV6WYHYF0B&hash=item294d6e1cf8:g:W9UAAeSwYyhovDQS
20260119 082510.jpg?VersionId=vyXcpHLDjVYtpM6g6NU120260119 082519
1/18/2026 12:11pm Edited Date/Time 1/18/2026 12:11pm
FWIW you could probably make something identical with a rotary potentiometer and some 3D printing. Granted, it won't be weather sealed like this one is...
1/19/2026 11:14am
Yeah rotary pots can work, I've seen people make angle sensors and even a type of string pot from a basic Rotary potentiometer, something like the Motec steering sensor here. You lose a little bit of resolution if its only working in a small portion of its range (a 1 turn Pot with 260ish degrees of working range and a 12 bit ADC/4096 values measuring a link with 45 degrees of rotation and a 65mm stroke shock is roughly 0.1mm) vs a 75mm linear pot that gets about 0.02mm on the same system. It's probably the easiest one to integrate with any system though, I've looked at throttle position sensors that are non-contact magnetic sensors which look very tidy but again seem to all use a 5V output
2026-01-20 07-57.png?VersionId=ed RkqO.iUt5PynE3EnB1qclk
Treloid
Biberstein, CH
1/19/2026 12:33pm
Funny to read here about string potentiometers and link driven potentiometers too 😅 A few days ago I noticed a pretty big flaw in my system. The rear sensor is mounted on a pivot of the rear linkage system, similar to Motion Instruments. zero position and max position are calibrated, the rest between is handled completely linear between the two points. But pretty much no pivot on a bike moves linear through the travel (I don't know how I didn't notice that till now)
Because of that and because of the annoying mounting differences between each bike I'm currently redesigning the rear sensor and currently exploring exactly those two options (Still using an AS5600 rotary encoder though).
The new version will probably use a rear wheel travel > sensor travel calibration to get the best and most precise result possible.
Will let you know once I have more to share :-)
1/19/2026 1:07pm
FWIW Suss My Bike also used the rolled up string in their concept. They were an early shockwiz competitor.
Treloid
Biberstein, CH
1/20/2026 6:15am
Yeah rotary pots can work, I've seen people make angle sensors and even a type of string pot from a basic Rotary potentiometer, something like the...
You could use a level converter to use it with a 3.3V microcontroller. But this adds another layer of complexity. Maybe they even have limitations in regard to updatespeeds (I have no experience with them, just as an idea)
1/21/2026 11:42am
Treloid wrote:
You could use a level converter to use it with a 3.3V microcontroller. But this adds another layer of complexity. Maybe they even have limitations in...
Yeah I experimented with a voltage divider and it seemed to work OK, but felt like it would need too much extra work to integrate with the system. As in adding an extra 5v power supply then either making a small board or maybe an inline connector/adapter with the extra circuitry....so kept look for other sensors.
There could be a way of making a small module that "breaks out" the 5v sensors and houses a small battery too? Maybe it doesn't need to be that complicated but I've been keen to try adapting the Sram AXS batteries to power a logger since they are pretty small and commonly available now....
1/22/2026 5:40am
Hi all,
I would like to try the BYB on different Bikes.
- Supernought Forbidden
- V10.8 Santa Cruz
The Bikes are not yet here any mounting experiences with these bikes?
Best regards 🙏
1/22/2026 8:40pm
I've been doing some more testing and slowly have inched up in air pressure in the fork. I did try full open compression and full open rebound for a few laps as that is what the auto tune was telling me to do. I can say it was very active but felt uncontrolled and I found my self wanting more support or getting offline easier than I wanted.  I slowly crept up in pressure and compression but didn't want to loose to much front end feel. I tried to then get the rear to have similar compression speeds but could never get it as slow as the front. I found a spring that I had laying around and thought it would be interesting to see what would happen if I dropped about 100# and get something closer to 30% sag. I figured I would have to run more compression and faster rebound to not use travel to easily. I was expecting to have faster compression speeds and slower rebound speeds which I did but not as much as I expected. I'd like to try a spring between my 343 and 325  and a shim stack with more HSC and lighter rebound tune. Both were completely ride able although the softer rear setup did get the faster time for the day. I also felt like I wasn't being pushed forward/riding as high up with more rear bias sag which helped but I was also feeling that I was using travel easier.  The duration of the run is about 2 mins and I was able to put a start/stop in to compare runs and times which is a nice feature to trim everything down.
Screenshot 2026-01-22 at 6.47.52%E2%80%AFPM 0Screenshot 2026-01-22 at 7.08.43%E2%80%AFPM 0Screenshot 2026-01-22 at 7.09.35%E2%80%AFPMScreenshot 2026-01-21 at 11.48.06%E2%80%AFAM
Treloid
Biberstein, CH
1/23/2026 2:36pm
1000113740
First prototype of the new rear sensor is on the bike! :-) The sensorarm is waaay too long but I did that on purpose to test different positons for the ballhead.
1/26/2026 12:31pm
manny.bike wrote:
Hi all, I would like to try the BYB on different Bikes.- Supernought Forbidden- V10.8 Santa CruzThe Bikes are not yet here any mounting experiences with these...
Hi all,
- V10.8 Santa Cruz
Best regards 🙏
The V10 is pretty easy, the forbidden you have to get creative with because that shock tunnel. Also depends which shock you are using.
Treloid
Biberstein, CH
2/1/2026 12:31pm Edited Date/Time 2/1/2026 2:19pm
Update from the Thinker Garage ;-)
The new sensor and calibration are finally implemented. While calibrating the system, I now create a map between rear sensor data (the link arm sensor) and the rear wheel vertical travel (the fishing rod looking sensor). This map is then used while logging to know which sensor value means how much rear wheel travel.
Main advantage: No leverage curve needed anymore unless you want to reverse calculate the shock movement. But honestly I haven't seen a use case for that yet in terms of bike setup. Do you guys use raw shock movement data?
First testride, without the "fishing rod" of course, is yet to be done.
1000114350
2/3/2026 6:09pm Edited Date/Time 2/4/2026 6:59am
Here are some of the earliest known data acquisition photos I have seen in mountain biking.  These are posted by @vintage mountain bike podcast.  An interview they said that Greg Minar was riding this Honda. Very heavy and dangerous to with data on because the covers it would get caught in cross winds.  We have come a long way!
IMG 0489IMG 0490IMG 0491
trexyz
RO
2/5/2026 4:07am
@enricorodella22 Is it possible to train an AI model using this data and have it provide insights or recommendations? That would be a really nice feature. I’m not a data scientist, but maybe someone with more expertise in this area could weigh in. The sensors already collect a lot of information but I find it difficult to interpret and use it to make adjustments.
2/5/2026 7:38am
trexyz wrote:
@enricorodella22 Is it possible to train an AI model using this data and have it provide insights or recommendations? That would be a really nice feature...
BYB already has a page that suggests how to tune your suspension based on the data.
IMG 0520
DServy
Jackson, WY, USA
2/5/2026 8:07am
AI isn't amazing at providing insights or recommendations for "novel" things. It's great at historical pattern recognition and replaying patterns into the future. The problem with trying to train an AI model with the tooling we have now is kind of twofold.
First, wholistic system data. To recognize patterns that would be meaningful, the model would have to know more than what the position sensors can provide. It would have to take into consideration things like terrain (which you could in theory get from gforce data) but also rider body position and dynamics. It would have to know (from historical context) how you would respond to various terrain features (like if you tend to land nose heavy or crumple in g-outs) for it to start providing any real insight in a meaningful way. The more variables a system has the more quality data it needs on each of those variables to make a decision.
Second, model targeting and outcomes. Models are trained by coming up with solutions deemed "good." We've done this for Large Language Models by giving it a book and saying "this is a good book" or an image saying "this is a good image." This is kind of in conjunction with the wholistic system data point above, as not only do you need a LOT of data, but that data also needs to be flagged as "good" in some capacity. What is good suspension? What is a good setup? Not to sound too philosophical on that but the fact that so many different setups can produce similar outcomes (like lap times) makes this a very hard problem to solve.
Also, I'm not convinced (at this point) that pumping all this data through an LLM would give you any different/better insights than the algorithmic based approach BYB and Vorsprung's Tuning Hub provide. Those work by having target values and either comparing that against positional measurements (BYCool or by doing some math (expected force at shock based on rider weight, rear suspension kinematics and "rider aggression special sauce"). So I don't think you'll see any improvements to what those things provide by giving the raw data to the LLMs.
However, I am in the AI space for my job and working on various processes/tooling to help deal with physical AI and robotics stuff and I desperately want to get a BYB system that gives me the raw access to the data to start doing some cool stuff around plugging data into models and producing outcomes. But just asking to chuck AI at it is similar to how "everything needs an app" felt when smartphones came out, AI is a hammer but not every problem is a nail.
With all that being said, I think someone like BYB could use AI to help explain conceptually what's going on and why its advocating for the recommendations that it is. But honestly you could do that yourself as is by just taking some screen shots and having a chat with Claude.ai.
Also all of ChatGPT are trash and I cannot wait till the world is free from that pile of garbage. What shit models.
2/13/2026 6:31am
crisotop wrote:
I'm aware of that and am usually doing that in Linkagedesign to get proper rear wheel readings for my BYB kit. But if you use sort...
I'm aware of that and am usually doing that in Linkagedesign to get proper rear wheel readings for my BYB kit. But if you use sort of "random" points between your rear and front triangle (as pictured above on that crestline), you get (at least in my mind) superfunky sensor displacement that has nothing to do with the shock movement. But I guess you could take the same approach in linkagedsign and use a high-res picture in order to get ~10 points of real wheel travel and corresponding sensor length and interpolate.
Which software are you using to upload your photo to? I searched around a bit and didnt really find what I was looking for.
Treloid
Biberstein, CH
2/13/2026 12:36pm
It's probably the linkage X3 software, I don't know about many others that can stuff like this (The syn bike software maybe too)
https://www.bikechecker.com/
2/15/2026 1:21pm
benconnor
Gooseberry Hill, WA, AU
2/15/2026 11:15pm
Hey folks, thought I'd share my DIY data acquisition project. It's been about 6 months in the making (so far) and is up and running. My intention, once it's cleaned up and a few more of the wrinkles are worked out, is to open-source this.
Hardware-wise, it's based on an ESP32 dev board on a custom PCB that breaks out the connectors and does some simple analog signal processing. It supports 4 analog channels and digital sensors on I2C. It has a small OLED screen and keypad, and optional handlebar-mounted switch for starting and stopping logs and marking events of interest.
 PXL 20260216 062832896 0.jpg?VersionId=hoeJAO
Apart from logging data (obviously) the logger runs some simple quality-of-life functions like sensor calibration, turning sensors on and off, and setting the sample rate (I've tested with 2 sensors up to 500Hz and have nice clean signals, at least to my eyes). The logger also supports wifi access for more detailed setup and downloading files. Optionally, you can apply transformations at the source (e.g. shock travel to wheel travel) either as a lookup table or polynomial. The firmware is designed to be extendable to other types of sensors but for now it's limited to analog inputs.
Sampling and recording sensor data is simply (ha!) an engineering problem; deciding what it means is of course the hard part. With this project I'm aiming for somewhere between a black-box “just trust the result” tool and dumping the raw data on the user: the goal isn’t to provide instant answers for everyone but rather to build an extendable set of tools that are useful straight away and provide a platform for "power users" to take further.
To that end, I've built a data pre-processing pipeline and some general-purpose widgets for browsing and analyzing the outputs. These are Python-based and run on Jupyter Lab, a free and open source interactive computing environment.
Session browser
Signals histogram 0.png?VersionId=jS1VR1event browser 0Metric histogram 0
One aspect of the analysis pipeline I'm particularly pleased with is 'event detection from schema'. Users can specify in a configuration file particular things they are looking for in the data - deep compressions, say - and what they want to know about them from the available data series. This is a work in progress but is already quite flexible and powerful.
I've been running the system on my Stumpjumper Evo with a couple of AliExpress linear potentiometers and 3d printed mountings:
PXL 20250928 040235432PXL 20250928 040303453
I'm conscious I'm jumping into the middle of a thread that is 12 pages deep, so if you think this belongs somewhere else, feel free to let me know. Otherwise, any thoughts, feedback or questions would be appreciated. I'm also on the hunt for people who would like to have a go at building one. It's not a beginner project as such, but none of it is actually rocket science either.
If you've made it this far, thanks for reading :-)
2/16/2026 6:26am
benconnor wrote:
Hey folks, thought I'd share my DIY data acquisition project. It's been about 6 months in the making (so far) and is up and running. My...
Session browser
Awesome project! The data box is a clean look! Keep us posted on your development
Mr.Nally
AS
2/16/2026 7:04am
Here are some of the earliest known data acquisition photos I have seen in mountain biking.  These are posted by @vintage mountain bike podcast.  An interview...
Sunn and Voullioz were earlier than that. Images below are 1998 And I imagine someone/team tried even before that? Nico and Bruni's mechanic Jack would be the guys to ask. Cool we are now at a point in DH MTB that we can chat about the "history of Data acq". It's certainly come a long way. I'm also old enough to remember Volvo-Cannondale team using data acq at some stage in the late 90s, but can't remember for sure (part of old age).
image 588
image 589.png?VersionId=hlOWL
https://www.instagram.com/p/C2b1kqJxNAO/
Mr.Nally
AS
2/16/2026 7:44am
Seems to be a DAQ box of some kind on this Cannondale? But no sensors visible?
image 590.png?VersionId=DG7kRJPPdqtq
2/16/2026 8:07am
Session browser
I think this is the correct place for this. What's the sampling rate you can go to? Does it stop at 500 Hz?
2/16/2026 8:46am
Session browser
Who made that mount for the SJ link?
