Suspension Data Acquisition
32x20
Salida, CO, USA
4/5/2026 7:25am
If you really want to go forward with measuring suspension movement with accelerometers, besides having a really good DAQ (think Dewesoft or NI grade of equipment)...
If you really want to go forward with measuring suspension movement with accelerometers, besides having a really good DAQ (think Dewesoft or NI grade of equipment) the best way to do it is to have single axis accelerometers with the working axis aligned AS CLOSE AS POSSIBLE with the shock/fork axis of travel and have each mounted on either end of the two moving parts. The alternative is to have three axis accelerometers and align two of the axes, but that will just give you general noise on the other two axes and complicate the acquiring part (you need 6 instead of 2 channels per bike end).
The thing is that even measuring these two positions you will still get A LOT of noise from the bike moving around. That's why you need two and to compare the two (hence why you need the two channels synced). The difference between the two measured points is actually what the shock (or fork) is doing.
If you're measuring or comparing the BB vs. the axle, you really need a three axis accelerometer on either end as the movement is not linear, if you assume it is, you need to mount the two according to how you linearize the rear axle movement, the accelerometer on the rear axle will still rotate in the travel giving you skewed readings, if you're using a 3-axis accelerometer you have the above problems PLUS you need to incorporate how the axle is moving into your analysis, the bike is still moving around, etc. etc. etc.
All that and measuring accelerometer requires some more specialized equipment even if using just one accelerometer channel. Accelerometer work on an electric charge principle and you have to measure that and then transform it into voltage and so on. It's not as simple as measuring resistance (voltage drop) or voltage which is fairly simple even for the home gamer making DIY DAQ equipment.
TL;DR: just use linear pots for the suspension movement and be done with it.
Appreciate the points you've made. I canceled my order and it was refunded by the sensor company. You're right, it doesn't make any sense with a single sensor. I just need to order the Raspberry Pi and start down that road.
4/5/2026 9:49am Edited Date/Time 4/5/2026 9:57am
Interesting post on IG from @Downamics . It’s a great visual diagram of how each part on the bike set up affects the other. It can also remind us how in the weeds we can get by making a change.
“This diagram is an overview of the scope for using DAQ as a holistic and specific analysis tool. It is not a comprehensive guide to the vehicle system or DAQ methodology.“
IMG 1348
You can view and use the diagram here:
Downamics Framework
descendnow
Marbelka, León, ES
4/7/2026 10:05pm
Anyone had any experiences with BYB using MacBook or Windows? Loading times etc
4/8/2026 9:34am
Yes, I have used BYB, with pretty fast loading times.  What other info are you interested in?
benconnor
Gooseberry Hill, WA, AU
4/13/2026 12:06am Edited Date/Time 4/13/2026 12:14am
So I sacrificed a string pot on the altar of science. TL;DR: So far, the results are encouraging.
DSC 8305
I used a lathe to drive the pot via an offset crankpin, allowing me to calculate the theoretical string trajectory exactly, and the maximum velocities and accelerations at different lathe speeds. The downside of this arrangement is secondary vibration: because the string oscillates vertically, its inertia introduces an error that gets larger as the speed of rotation grows. The good news is that, because it isn’t something the pot will experience in real use and occurs at mid-stroke, I think it can be ignored: the ends of the stroke, where the accelerations are the highest, are where we expect any problems of the string overrunning the spool to occur.
RPM       Peak velocity (m/s)     Peak acceleration (m/s²)
 530        3.78                            247.6
 750        5.35                            495.8
1060       7.57                            990.4
1500       10.71                          1983.4
For reference, most of my ride files have max transient accelerations in the 200-300 m/s² range. I'm sure harder-hitting riders see higher accelerations but I think 1000 m/s² is a decent upper bound for design. That's 100g, folks.
The pot ran without any mechanical issues at the first three speeds. At 1500 RPM it failed after about 5 seconds (so even then, it got more than 100 cycles in). The mode of failure appears to have been loss of tracking of the string on the spool, possibly contributed to by  wear in the grooves. I had a connecting piece of 40lb fishing line in the string which broke as intended. The string also chewed itself a new exit channel due to a minor alignment issue. In other respects the unit appears to have survived intact.
At 1000rpm the pot is tracking ideal movement pretty well - although not perfectly. The secondary vibration effects are visible in the mid stroke, along with the occasional minor bobble - cause unknown.
Screenshot 2026-04-13 143046
At 1500rpm I didn't manage to get the logger turned on before the string pot failed. But from what the string was doing, I would expect it to be ugly.
My conclusion is that this design comes pretty close to meeting the mechanical requirements. It tracks well - but not perfectly - under some very demanding test conditions - I'd expect the results to be perfectly acceptable for a fork in normal use, and better for a shock (where displacement, speed and acceleration are reduced by 2-3x). Having said that, there is scope for further reduction of both physical size and the inertia of the moving components. I have a revised version that I'll be testing shortly.
Durability is unproven at this point. The main issue I'm looking at is friction of the string at the exit point and resultant wear. I'm looking at fishing rod hardware to address this. Other longer-term issues will probably emerge.
Integration is another issue. Ideally the pot would work as a plug-in replacement for a traditional resistive linear pot. The AS5600 encoder I use does indeed have an analog output option, and can be used that way if the analog supply rail runs at a voltage that works for the AS5600, and if the logger's analog input doesn't  load the AS5600 excessively. The AS5600 can also be read via a digital data bus, if your logger has one.
Because the pot is multi-turn, there is also the need to 'unwrap' the raw encoder results. Unless the analysis software happens to deal with that already (or the logger does it onboard), the results are going to look very strange. The requirement to unwrap also puts a theoretical lower limit on the sampling rate that can be used.
Screenshot 2026-04-13 143233
Various misfortunes have prevented me getting a successful side-by-side comparison to a linear pot, but that will be along soon.
Shinook
Asheville, NC, USA
4/13/2026 10:15am
benconnor wrote:
String pot update... next iteration done and ready to ride. Testing duties will be delegated as I'm recovering from shoulder surgery but hopefully will have some...
String pot update... next iteration done and ready to ride. Testing duties will be delegated as I'm recovering from shoulder surgery but hopefully will have some results to share soon.
PXL 20260401 115851273.jpg?VersionId=ckuPc4zUHClj6L3ubgzqGhbCPXL 20260401 115945121Screenshot 2026-04-01 201222.png?VersionId=7V9MScreenshot 2026-04-01 201308
There was a product called SussMyBike Flow that did something similar to this. The issue was the app sucked and eventually fell out of support, but it gave you some data ranges to work with using a similar mechanism IIRC. I have one laying around here somewhere...
4/14/2026 2:41am
benconnor wrote:
So I sacrificed a string pot on the altar of science. TL;DR: So far, the results are encouraging.I used a lathe to drive the pot via...
DSC 8305
 530        3.78                            247.6
 750        5.35                            495.8
1060       7.57                            990.4
1500       10.71                          1983.4
You could try supporting the string near the lathe in both vertical directions to prevent these oscilations.
benconnor
4/14/2026 3:43am
Yep, I'll try that for sure. There is a trade-off: as the support point gets closer, the magnitude of the secondary vibration gets larger (like short conrods in a car engine), but reduced oscillating mass ought to help. The main thing I will do is use lighter string. I have some high-tech fishing line that is 20% the weight of the stuff I'm using now so I expect that to help a lot.
benconnor
4/16/2026 11:47pm
few pics of the new string pot design. It ate up 1000rpm in testing and even ran at 1500 briefly. Unlike the last time however, this time the failure was friction at the string support (thanks @Primoz, worked great) causing the connecting string to break. The pot itself survived intact and tracked the theoretical path well until the failure.
That's it for bench testing. We'll see how it performs in the wild.
1DSC 8324 resized.JPG?VersionId=zu2V0m3sqo4ky.ig3k2DSC 8320 resized.JPG?VersionId=blaERTAqE5vjaaYfq34DSC 8314 resized
4/17/2026 3:01am
I was thinking about using two bearings for support to prevent friction over the in going edge. Or at least a very rounded hole entrance.
benconnor
4/17/2026 4:56am
Yeah, my solution (hole in a piece of delrin) was pretty basic, it could definitely be better.
descendnow
Marbelka, León, ES
4/21/2026 1:12am
Wondering how people interpret the 95th valve and whether it’s one of the main valves you analyse.
benconnor
4/22/2026 4:34pm
My $0.02: its a more consistent measurement of suspension use than the maximum, which is prone to distortion by one big event.
4/23/2026 8:04am Edited Date/Time 4/23/2026 8:06am
From what Enrico at byb told me is averages are mostly LSC and 95th/Max HSC but depending on what numbers you see it can pull your averages up. I could be wrong but this is how I interpreted what he said. Also agree with ben c on 95th being less of an outlier.
4/26/2026 10:29am
My "old" style BYB front linear pot got a bit noisy over the winter -- has any of you successfully opened and cleaned / revived such a thing?
4/26/2026 1:35pm
crisotop wrote:
My "old" style BYB front linear pot got a bit noisy over the winter -- has any of you successfully opened and cleaned / revived such...
I haven't opened my byb pots but they can usually be pryed open and you will find wipers on the end of the shaft, which contact the resistive surface on the outer tube. Clean these up with contact cleaner, and you might want to gently bend the wipers out slightly so they make better contact too.
To get it apart, there might be a grub screw to remove first. My aim ones where pressed together which needed careful gripping to pull apart. Ill have a look at my BYB ones tomorrow though, pretty sure they need it too
4/26/2026 2:08pm
These are old photos but hopefully you can figure out whats going on inside them! They are all constructed in a similar way
168F467D-CE42-4B79-ACCE-DF7C3EB1E4690A094363-284D-46CF-AB68-5137431965E4
4/27/2026 6:50am
thegromit wrote:
From what Enrico at byb told me is averages are mostly LSC and 95th/Max HSC but depending on what numbers you see it can pull your...
Depending on how your suspension valving works, most of the time LSC largely affects HSC as it sort of acts as a "threshold" at which speed oil is forced through the high speed circuit. For example when running very little low speed damping most of the oil will (can freely) flow fast enough through the LSC orifice, no matter how fast the shaft speeds might be (you'll see very fast hs speeds when measuring). As soon as the low speed needle is closed off enough, oil has to flow through the high speed stack, as the orifice simply can't pass enough fluid fast enough.
I went down the rabbit hole once of trying to get high speed events down by shimming the high speed stack stiffer and stiffer, without any significant changes is the measured values – all while running very little low speed compression. Only to realise all that would have been needed are a couple of clicks low speed compression.
Of course that also works the other way around -- if your high speed stack is super soft, you can run as much lsc as you want, the oil will be able to freely pass through the hsc stack even at slower shaft speeds.
4/29/2026 5:46pm
I like using 95th, I find it's a great, quick number to look at to balance the shaft speeds.  I think you can get used to any number, i just started with that so know its an easy one to compare with the years of data I have.
moridinbg
Sofia, BG
4/30/2026 3:09am
I love the DIWhy vibes from the last few pages 😍
I have been working a lot on the App and the Firmware  for the mast month or so. I have made a lot of progress into packaging it into end to end usable, both on desktop and mobile.
image 685.png?VersionId=5Hvdu1 kE1w5fJgb2a
Major changes
  • Live data! Now you can stream the sensor readings from a connected DAQ in more or less real time (20-30ms delay). You can set the time on the DAQ and you can edit and replace the configuration, without dealing with memory cards and text files! You can also change recording sampling rate (and soon recorded sensors) without recompiling the firmware.
You can also record live sessions.
The spring rate/damping/balance are recalculated every 1.5 seconds, while the graphs are real time. It works with two sensors and two IMUs at 1000Hz, but can be taxing on the phone.
When you hit save, it is stored locally as a session, same as the ones imported from the DAQ.
The bike editor can have a:
  • Hardtail - fork only
  • Linkage - BikeLinkage-like setup that calculates kinematics - very useful for the rotational sensors, less so for linear sensors
    • I have also added wheels to the original @sghctoma linkage setup, which calculate head tube angle. I was surprised how off mine was from calculations. Front travel calculations take head angle into account, so make sure it is roughly correct.
  • Leverage ratio - drop a CSV table with shock travel/leverage ratio. Mostly for linear sensors
Minor quality of life improvements:
  • Graphs (travel, velocity, etc) are synced to each other and to the map too - what you zoom and see on the graph is what segment of the track you see zoomed in on the map and vice versa. Also, you can add custom map sources.
  • You can delete multiple sessions/setups/bikes and undo any of them (within 5 seconds after a deletion)
  • You can import/export bikes via JSON and Setups (which includes the bike the setup applies too).
Mobile changes
Confirmed to be working on Android. I have not tried it myself, so I do not have setup instructions, but another dude tried it.
Working on iPhone. Right now it is somewhat tricky - you have to have a (free) Apple Developer program and do minor setup in Xcode and change the identifier.
If the project takes off I might consider setting up paid dev programs and upload it to Google Play/Apple App Store. They are $99/year so this will rely on some sort of donations.
  • The sync between mobile and desktop (pair from the sidebar menu) should be much improved with more robust conflict resolution - if you change something both on desktop & mobile, the latest change wins, no merges.
  • Other than that it supports the same Live data and Live session features
  • Recorded sessions now have the same travel/velocity/imu graphs and a map synced to them
Firmware changes:
  • The firmware can now create a WiFi network - There is a WiFi mode in the CONFIG, that can either be AP (creates a network) or STA (joins existing network).
  • The firmware uses mDNS local auto-discovery, so in general, you shouldn't have to configure anything, the DAQ should automatically appear in the Live browser. There are some issues with IPv6.
  • The supported GPS modules now include Ublox M8N (widely cloned, I am using a BN-880 clone) and LC76.
  • IMUs remain at MPU6050 & LSM6DSO
As things finally start to settle down code-wise I will start publishing ready to use app and firmware builds. For Android it should be straightforward to have an APK for side loading, for iOS will have to see what to do without a paid program - Apple has been loosening the rules recently.
My goal over the past few months was mainly to package everything that @sghctoma has created into a usable complete package. Massive hats off to him - the travel statistics and suspension kinematics he has done are incredible.
Most of the featured I had in mind - wifi access point on the go with daq management over wifi and better parity between mobile & desktop are complete.
There are some bugs and UI inconsistencies that I will be resolving as I get annoyed enough by them or enough people complain.
Now that things are more stable I will be riding more and see what else can be done to the kinematics stuff and calculations.
If you try this out and notice something is off or can be improved, please, please, please, write an issue in the App repo or the Firmware repo
moridinbg
Sofia, BG
4/30/2026 3:32am Edited Date/Time 4/30/2026 7:37am
My setup is linkage driven with bearings and cheap rotational sensors ($3 each)
IMG 0684
The kinematics setup in the app then translates the angle of rotation of the sensor into shock/wheel travel.
The firmware/app also support linear sensors.
I have compiled extensive documentation on both the firmware architecture, hardware build and daq operation.
There is another architecture document for the app which explains the telemetry and kinematics calculations.
benconnor
4/30/2026 6:38am
Looking real slick! I'm off for a hunt around in your repo 😉
4/30/2026 12:43pm
moridinbg wrote:
I love the DIWhy vibes from the last few pages 😍I have been working a lot on the App and the Firmware  for the mast month...
Major changes
Mobile changes
Firmware changes:
Damn that is looking cool! well done on all the impressive work here - I've followed that project since the early days and love to see how far its come!
4/30/2026 12:59pm
I opened up my BYB fork sensor to clean it up - was a little easier than the AIM ones were - its a snug fit but not as tight since the screws hold it in place, so can be carefully pryed apart with a metal spudger or blade. The wipers looked pretty good, a tiny bit of dirt in there so I'll clean it out, replace the o-rings and add a tiny amount of thin super lube grease to the contact points to reduce friction and give smoother contact for the wipers. It had quite a lot of play in the shaft too so I would like to tighten that up a tiny bit if possible to reduce rattle. In the past I lathed a new sealhead with a tighter fit in smaller pots, and these look like a standard linear bearing but I haven't found one online yet
20260428 09103520260428 091247.jpg?VersionId=HeVy96
benconnor
4/30/2026 10:54pm Edited Date/Time 4/30/2026 10:56pm
DSC 8346Another DIY datalogger update. I have three main things to report, and an invitation.
 - The project has a build website: www.bodaqs.net has sourcing and build guides for the hardware, a user guide for the logger, and a software guide, as well as an overview of the project.
 - syn.bike compatibility. The logger can output files for direct upload to data.syn.bike, which is a simple, clean option that will satisfy most users. I'm still working on my own software, but that is going to take time and I don't want to reinvent the wheel (more than I have already).
 - Another iteration of the hardware. Same basic functionality but better power management and works around an ADC issue.
If you fancy taking a look at the build website - even if you don't think you'll be building a data logger - any feedback would be appreciated. If you take a look and decide you want to give it a go, I'm looking for beta testers - hit me up.
Treloid
Biberstein, CH
5/1/2026 1:02am
moridinbg wrote:
My setup is linkage driven with bearings and cheap rotational sensors ($3 each)The kinematics setup in the app then translates the angle of rotation of the...
IMG 0684
Yes yes yes, love this so much! Finally somebody else trying to use rotational sensors for the rear. Probably due to the same "Santa Cruz Shock Tunnel Syndrome" that caused my preference for those sensors 😉
Will definitely look around in your repo and maybe try the app (I'm an Android User as well). As far as I remember, my files probably should be compatible with the sufni project.
The software looks awesome as well as the mounting idea for the sensor!
moridinbg
Sofia, BG
5/18/2026 10:17am Edited Date/Time 5/18/2026 10:18am
Credit goes to sghctoma who originally did the rotational sensors. I have ordered some linear sensors, but I don't think I can fit anything in the SC tunnel...
I got tired of the cave look, so now with light mode! Also - lots of quality of live improvements for the sessions.
  • The telemetry plots can be reordered, minimized and embedded in one another. They are also scrollable and resizable with dividers
  • Holding down Option/Alt while zooming in/out of the plots makes it much slower and precise.
  • Holding Shift while scrolling in the plot area will skip zooming the plot under the mouse and will scroll the plots
  • Tooltips for statistics values
  • Average temperature for the ride, if an IMU with a thermometer was used. Rebound is very sensitive to cold usually
  •  Holding shift and dragging over a plot will select only that segment from the session and recalculate the statics over the segment, instead of the entire session
Something that I have enjoyed a lot implementing - automatically matching a selected segment from a session against all other recorded sessions and showing a statistics comparison. Strava segments, but for telemetry! I will not be releasing this in the public repo at this point.
image 741
5/18/2026 1:02pm
Go the light mode! I thought I was in the minority with everything coming in dark mode these days
benconnor
5/20/2026 12:24pm
That's very slick. Well done!
descendnow
Marbelka, León, ES
6/7/2026 3:55am Edited Date/Time 6/7/2026 3:57am
HI 0.png?VersionId=jOTLrsqEfcO
2 different position vs velocity charts, different riders, different tracks. Top image is a boxxer with 3.2 damper and second is with 3.1 damper. Obvious from the second image that the rebound in the rear could do with speeding up, average is -253mm/s and max at -1327mm/s.
First image average rebound is -390mm/s and max at -2697mm/s.
