Damper products that aren’t suspension
thejake
Carnation, WA, USA
I’ve noticed 4 parts available now that seem to all address a similar issue.  The issue being comfort and dampening trail chatter to the rider.  The four I’ve seen are: steering damper, Fasst handlebars with the bushings, O-chain and mass tuned dampers.
I’m curious has anyone tried all of them? Would be super curious if one product is much better for certain bikes/trail types? How do they stack up against getting a custom tune on your fork and shock?
If you’ve tried one chime in.  Maybe Vital can do an article and test all four items individually and then one super dampened bike with all four.
1/28/2025 4:30pm
thejake wrote:
I’ve noticed 4 parts available now that seem to all address a similar issue.  The issue being comfort and dampening trail chatter to the rider.  The...
Great question! I haven't tried the other three products you mentioned, but I have spent a lot of time on the Ochain and I would argue that it is, fundamentally, a suspension product. In effect, it's changing the way your axle path interacts with your drivetrain, in much the same way that changing the actual axle path would. It's like changing your suspension layout to have lower anti-squat values while coasting, then changing your suspension layout to have higher anti-squat values when you are pedaling, all without changing your suspension layout. If there was a movable pivot that accomplished the same thing everytime you pedaled (a la Kona's wild "Magic Link"), it would absolutely be considered a suspension setup.
A few items I'd add to your list: the rotating Rev grips and the new Rali chain magnet. Shoes can make a big difference, too. You could argue Cushcore could be on the list too. Softer compound tires, changing psi, and thicker or thinner tire casing also impact trail chatter, but arguably tire suspension is just another form of suspension.
thejake
Carnation, WA, USA
1/28/2025 5:01pm
Good point about the O-chain and tires and inserts.  I left tires off the list because you need tires to ride and can play with psi.  Inserts should probably be on the list.  You don’t need any of these products to ride but they can add a degree of comfort and control.
I’ll look into those other products.  I have heard of the grips but forgot about them.
ex-ballz
Ouagadougou, EH
1/28/2025 5:15pm
Don't forget about
Review: Cane Creek Thudbuster ST G4 suspension seatpost | road.cc
(or any Reverb - same thing)
1/28/2025 5:54pm
Redshift Shockstop stem? Kind of a suspension gizmo but really just a damper...
What about the Cascade link? Changes the leverage ratio (among other things) to make suspension softer off the top...
I have RevGrips on my hardtail and they're nice, comfy grips but not a game-changer for me. I'll go back to regular lock-ons once they wear out.
1/28/2025 8:33pm
The new schwalbe radial tires offer a very damp ride feel.
I use counter shox mass dampers and ochain on my bike. I’ve also been experimenting with some soft rubber damping material. I’ve tested it in the bars, axles and Seatpost. I believe it does slightly reduce vibrations and high sharp frequencies.
1/29/2025 12:32pm
Mid 90's I used a Girvin Flexstem until manitou SX's were common lol
Elastomer stem with 1inch travel if I remember correct. It worked quite well considering the tech at the time
Girvin 1A
Splayleg
Los Gatos, CA, USA
1/29/2025 5:10pm
Whoa that seems like a wild product. With a fork the whole bike goes down with travel. With this just your bars can pitch down giving the perfect aero tuck for dh domination
1/29/2025 5:45pm
Don’t forget about stfu chain dampers that stop the chain from oscillating and pulling on your cranks. And would you throw a lower guide into this group? Eliminating the derailleur moving with compression.
Splayleg
Los Gatos, CA, USA
1/29/2025 5:54pm
If I put that stem on my 180 zeb can I claim 205 travel? Sic. They have handle bars that do the same im going to have to crunch the numbers now
1/29/2025 6:30pm
I did run it for a bit when I got my Manitou's in 96 I think it was, it gave a real weird feeling from what I can remember, been about 40,0000 beers since then.
Splayleg
Los Gatos, CA, USA
1/30/2025 6:21am Edited Date/Time 1/30/2025 6:36am
https://fasstmtb.com/collections/downhill/products/flexx-dh
Says travel dependent on handlebar length. Thinking of going wider than 680mm for maximum benefit. Anyone know how far my grips will be below fork crown at full bottom out with these technologies?
1/30/2025 7:36am Edited Date/Time 1/30/2025 7:39am
softride stems always looked crazy/cool w/ an actual spring. wasn't their tagline "suspend the rider, not the bike"? when i googled it, this meroca aliexpress thing came up too.
Screen Shot 2025-01-30 at 8.33.50 AM.png?VersionId=65SGCc
ZAKBROWN!
Salt Lake City, UT, USA
1/30/2025 8:02am
also brandon turman, former tech editor here, really dug the fastflexx bars IIRC. his review is here - https://www.vitalmtb.com/product/guide/Handlebars,38/Fasst/Flexx-Enduro,24182 - scroll down a bit.
I dug them too until they snapped on me landing a step down drop in the NAEC race a few years ago.  Luckily it was the alloy wing that pushes into the elastomer so they held together (with like 6” of travel) so I didn’t die in the big g-out and step up that followed.  Ended my race though and any trust I had in them.  They sent me a new set but didn’t seem too concerned with a pretty scary failure.  Sold them and went back to normal bars.
haen
1/30/2025 8:12am
The type of grips you run has a pretty substantial impact from my experience. Pure silicone grips provide more damping than lock-ons.
Cougar797
Bentonville, AR, USA
1/30/2025 8:40am
I have really thought about going to nice squishy slip ons for this reason.
Explodo
Arvada, CO, USA
1/30/2025 9:03am
ex-ballz wrote:
Don't forget about (or any Reverb - same thing)
Don't forget about
Those are a great way to mess up your knees...via my experience in the late 90s.
Blake_Motley
Chula Vista, CA, USA
1/30/2025 9:23am
Slightly embarrassing to admit but I’ve always been intrigued by these because of how much I struggle with hand cramps from trail chatter. Forgot how much Brandon liked them.
ride
Bellinghome, WA, USA
1/30/2025 9:33am
softride stems always looked crazy/cool w/ an actual spring. wasn't their tagline "suspend the rider, not the bike"? when i googled it, this meroca aliexpress thing...
Funny story about these.
In 2003 I got hired to work at Softride here in Bellingham by my good friend Adam. I was chasing a career as a pro mountain biker at that time. As a prank, he ran a print ad for the suspension stem, with a fabricated quote from me endorsing the stem as a 'game changer' for a pro mountain biker. It was actually pretty detailed haha. That was my first industry job, and I think back fondly on my couple years there learning about manufacturing bike frames. We were making them in-house at the time.
Adam now works with us at Transition, full circle.
1/30/2025 9:52am
I guess you could spray a bunch of this into any open tube? Frame, handlebars....
image 174
1/30/2025 10:33am
image 174
The standard spray foam doesn’t have a big effect on vibration. Slightly, but it’s almost too light to dampen.
1/30/2025 10:54am Edited Date/Time 1/30/2025 10:54am
image 174
Maybe we could inject some steel shavings into the foam as it's being sprayed?
Tuned Mass Foamers?
j/k
1/30/2025 1:54pm
thegromit wrote:
Slip on, half waffle, small flange, different compounds, some what affordable, matchy-matchy your fav bar
https://www.rockymountainatvmc.com/parts/renthal-50-50-atv-grips-p
These are great in the Kevlar (softest available) but would be better if renthal made them in super tacky - I actually wrote an email to renthal 🤣.
1/30/2025 2:10pm
image 174
Perhaps unsurprisingly it's been tried!
1/30/2025 2:19pm
bmxconan wrote:
These are great in the Kevlar (softest available) but would be better if renthal made them in super tacky - I actually wrote an email to...
Fox
Durango, CO, USA
2/17/2025 7:45pm
Fun story about Rev Grips.
I've been running them for years. I like em. They help my worn out hands keep goin on long days and rough, rocky tracks.
My 16yo son came home from a ride on one of my bikes raving about the grips and how smooth things felt on the bike. He rides without gloves despite my disapproval; he'll learn the hard way at some point. He was not aware that they are specifically designed to dampen vibration and harshness, but he was very interested in learning more once I explained the clever system Rev grips use.
2/17/2025 7:54pm Edited Date/Time 2/17/2025 7:59pm
image 174
So about the same as vibrocore then?
I use a vibrocore bar (thanks to a combination of curiosity and a CRC sale) and I can't tell the difference in feel between it and the "normal" bar it replaced.  The bar is not very heavy, so the foam itself can't be particularly dense.
I also never found any empirical data that suggests the idea is much more than wishful thinking, but it's been a while since I researched it.
Post a reply to: Damper products that aren’t suspension
