Damper products that aren’t suspension
2/17/2025 8:36pm
I guess you could spray a bunch of this into any open tube? Frame, handlebars....
image 174
The standard spray foam doesn’t have a big effect on vibration. Slightly, but it’s almost too light to dampen.
boozed wrote:
So about the same as vibrocore then?I use a vibrocore bar (thanks to a combination of curiosity and a CRC sale) and I can't tell the...
I use a vibrocore bar (thanks to a combination of curiosity and a CRC sale) and I can't tell the difference in feel between it and the "normal" bar it replaced.  The bar is not very heavy, so the foam itself can't be particularly dense.
I also never found any empirical data that suggests the idea is much more than wishful thinking, but it's been a while since I researched it.
The stuff I use is more dense/heavier than viborcore.  I’ve been looking into something that can measure vibration at the bar, but I don’t have any data to support that’s better or worse.
3/14/2025 1:19pm
thejake wrote:
I’ve noticed 4 parts available now that seem to all address a similar issue.  The issue being comfort and dampening trail chatter to the rider.  The...
I’ve noticed 4 parts available now that seem to all address a similar issue.  The issue being comfort and dampening trail chatter to the rider.  The four I’ve seen are: steering damper, Fasst handlebars with the bushings, O-chain and mass tuned dampers.
I’m curious has anyone tried all of them? Would be super curious if one product is much better for certain bikes/trail types? How do they stack up against getting a custom tune on your fork and shock?
If you’ve tried one chime in.  Maybe Vital can do an article and test all four items individually and then one super dampened bike with all four.
Late to the party. Nevertheless. Not exactly Fasst bars, but I had the chance to ride some REALLY flexy bars and comfort wise it's good. I also noticed that the hand trying to roll over the grip effect is lessened with a softer bar (which is flexy fore-aft besides up-down). My wrist was hurting less with a softer bar than with a stiffer bar after a longer day of riding. One side effect though was that the fork felt like it doesn't work. Going to a stiff bar the initial impression was 'oooooh, so the fork DOES work!'. Only for the wrist to start screaming of pain by the end of the trail.
3/14/2025 3:27pm
I have used the vibrocore bars.  I find them better to use use on my steel bikes or hardtails.  For me, it helps with dulling the chatter. But I also run larger grips, silicone or other materials.  I do think the vibrocore rims have a more pronounced effect.  Dulls the trail a bit, which is the point I guess. Better for trails with a lot of small roots/rocks in the trail. Not as effective for say braking bumps or larger hits.
3/14/2025 9:36pm
I have a little note about Leatt grips, the idea of them on paper looked great, they say “maximum vibration damping”.
The plastic is cut out and has a material in there which I thought would work great. The grip material itself is pretty stiff.  Unfortunately I thought they added more vibration to my bike and bar set compared to OneUp grips or the Diety soft large grip.
IMG 5788.jpeg?VersionId=3z6IMG 5917.jpeg?VersionId=vK39iVrpet95Yp6cKkCpl
And in other news, I’m trying the Rimpact TMD vs countershox.  My first impression is that Countershox made a bigger change and much easier to install. Total weight is similar, but rimpact isn’t damped is just free floating weight and spring. Right now I’m on the soft spring.
IMG 5889IMG 5812
billdelong
Georgetown, TX US
3/28/2025 12:41pm
Splayleg wrote:
https://fasstmtb.com/collections/downhill/products/flexx-dhSays travel dependent on handlebar length. Thinking of going wider than 680mm for maximum benefit. Anyone know how far my grips will be below fork...
Says travel dependent on handlebar length. Thinking of going wider than 680mm for maximum benefit. Anyone know how far my grips will be below fork crown at full bottom out with these technologies?
Anyone with experience to talk about these bars?
I just placed an order for carbon bars and if they don't solve my issue with getting a sore shoulder on long technical rides, then I might give these flexx bars a try!
thejake
Carnation, WA US
3/28/2025 2:10pm
billdelong wrote:
Anyone with experience to talk about these bars? I just placed an order for carbon bars and if they don't solve my issue with getting a sore...
My buddy has some on his dirt bike.  He says they are nice for long days.  Keeps you feeling less fatigued even after several hours.
haen
3/29/2025 2:25pm
Your soreness might be an issue of bike fit. Your bars could be too low (or far away), and as a result, you’re supporting too much of your bodyweight through your upper body.
There’s a separate thread on this: https://www.vitalmtb.com/forums/hub/general-cockpitcontact-point-discussion
3/29/2025 11:30pm
Or the bars could be too stiff. As I said above softer bars cause less problems for my wrist...
ballz
Ouagadougou EH
3/31/2025 10:00am
I've returned to RevGrips with my niggling hand injury and the latest version is much better than the original one. It is the only grip that makes real difference for me, in the most-comfy configuration. Order the heavily discounted blem issue if you like bright pink/orange colorways, lol.
4/2/2025 9:26am Edited Date/Time 4/2/2025 9:29am
Interested in Tuned Mass Dampers? Here's more info on that from the founder of Rimpact:
8/31/2025 8:41am
A random O chain thought:
I enjoy my O chain and feel like it works as advertised. However, the resistance of the elastomers is enough to engage my hub (dt350). This gives a tapping feeling before the feeling of bottoming out the elastomer in the free throw of the ochain. It’s a two stage tap which is kind of annoying.
Sound/sensation aside, wouldn’t the ochain work better if there was actual free play between the hub and pedals? I’d say the elastomers engage the hub in the first quarter of movement.
8/31/2025 11:19am
A random O chain thought:I enjoy my O chain and feel like it works as advertised. However, the resistance of the elastomers is enough to engage...
What degree are you using in ochain, what engagement hub?
8/31/2025 10:20pm
12* 90% of the time. 9* if I’m feeling adventurous.
it’s a dt 350 on a xm1700 wheels set. I’d say it’s the 36 tooth by the amount of slop.
comatosegi
Portland, OR US
9/2/2025 11:30am
I have both O-Chain and Sidekick on two different bikes.  The elastomers on the O-Chain seem to do a better job at reducing some pedal feedback.  Also when you engage a Sidekick quickly, going to flat or casing, there is noticeable thunk, when the pawls engage.
Also there is some movement before the elastomers engage, there are three very light springs inside.  Somebody correct me if I am wrong.
9/2/2025 11:54am
comatosegi wrote:
I have both O-Chain and Sidekick on two different bikes.  The elastomers on the O-Chain seem to do a better job at reducing some pedal feedback...
You are correct. I'm spitballing here but I'd imagine whatever deadband you have the ochain set to most of it occurs BEFORE contacting the elastomer. For example, set at 9 degrees, 8 degrees occurs before touching the elastomer and the last 1 degree is elastomer compression? The elastomers really don't seem to have that much compression in them.
The ochain engages a bit more naturally because of the elastomer compression. The sidekick is more of a clunk metal on metal, bc it is I guess.
9/2/2025 7:05pm Edited Date/Time 9/2/2025 7:17pm
You are correct. I'm spitballing here but I'd imagine whatever deadband you have the ochain set to most of it occurs BEFORE contacting the elastomer. For...
My O chain does not move at all without pulling the chain forward until the hub engages.  Immediately, there is enough resistance to pull the chain and engage the hub. After the hub engages, the pedal then travels the full of 12* without pulling the chain. Once you bottom out the 12*, it will the pedal normally, of course.
I’m not sure if the initial chain pull is from resistance from the springs or the elastomer. I think it’s the springs.  The thud at the bottom of the 12* is harder than I’d like. Ochain told me you can’t get softer elastomers to make that bottom out softer.
I made a video but you can’t post video here.
Edit: to clarify… when pedalling, the crank and chainring move forward normally until the hub engages (because of the spring resistance), then the crank travels the 12* of float until the Elastomers engage. So that’s 2 taps for the price of one. My friend has an Onyx hub and the entire system is much smoother and quieter.
I believe the sales pitch is wrong. People always say “it’s different than a low engagement hub because you always get 12*, rather than whatever free play is left in your hub.”
That is incorrect, you actually get the 12* PLUS what ever free play is left in your hub.
I think this product is substantially better with a high POE hub, despite everyone saying that set up is contradictory.
comatosegi
Portland, OR US
9/2/2025 9:15pm
My O chain does not move at all without pulling the chain forward until the hub engages.  Immediately, there is enough resistance to pull the chain...
Atherton team was running the high POE Stans mag hub with the O-Chain.  B/C you get a consistent degree of movement from the O-Chain, you don’t need to have extra degrees from the freehub. There was also less drag with that hub, so not sure where their priorities were.
I am not sure how you would design an O-Chain to be lower friction than the freehub.  Those are very light springs inside already.  Any chance that your O-Chain needs a service, maybe have excess friction in the device?  I never felt my freehub engage separately from the O-Chain.
DT Swiss is ratchet system with two sets of unidirectional teeth interfacing each other.  Spring is just there to keep the ratchets meshed together. I believe that is why the DT system has lower drag.
9/3/2025 6:28am
comatosegi wrote:
Atherton team was running the high POE Stans mag hub with the O-Chain.  B/C you get a consistent degree of movement from the O-Chain, you don’t...
If I'm understanding what you're saying something does seem off with your ochain, ebikepartyshirt. Might be worth a rebuild? I also get what you mean, the deadband of the Ochain is more resistance than the dead-end between the POE. I mostly ran my ochain on a Hydra so I didn't experience that. For a few weeks between frames I ran the ochain WITH a sidekick and yeah, that had "2 taps" as you explained it.
Post a reply to: Damper products that aren’t suspension
