Sea Otter Classic - 2026
Edited Date/Time 4/20/2026 10:05am
This is the place for all things Sea Otter Classic in 2026. Vital staffers will update this thread with photos and product details throughout the weekend, and you can add your finds, too!
Vital product coverage in alphabetical order (this list will grow throughout the days!)
Bikes
Components
Gear
Weird/Misc Stuff
4/16/2026 10:52am Edited Date/Time 4/19/2026 3:52am
Frameworks 32-Inch Testing
Neko Mulally is racing a Frameworks with a 32" front wheel and 29" rear wheel for Sea Otter downhill. He says he's been riding a bit back at home and had to purchase the front tire online (1 of 2 that he could find). He's surprised by the traction but did indicate that if it broke free, it broke free without warning. He was able to cram in a 29" rear wheel despite the rear triangle being made for 27.5. His philosophy is that it's worth the experiment to figure out if there's something more to pursue and he'll let the results speak before judgment. Sea Otter's DH track is a good place to test the idea, and he hinted that there may be more to come in the future, too.
neko1
neko2.jpg?VersionId=Wg9wmY3Xr0dJQQFbFp7
Is the guy in the background having the same reaction as you?
4/16/2026 11:07am Edited Date/Time 4/17/2026 2:34am
Cane Creek Invert
Cane Creek showed off their new upside down enduro fork, dubbed The Invert.
Price is $1,599, it features 160, 170 or180mm of travel via different air springs, comes stock with 15mm axle but can also run 20mm available separately.
  • 160, 170 or 180mm travel
  • Air spring only
  • High-speed Compression, Low-speed Compression, Low-speed Rebound
  • 45mm upper tubes
  • 38mm stanchions
  • Bleed screw in top cap
  • 586.5mm axle-to-crown height (170mm)
  • 200mm brake mount, 220mm adaptor available
  • Claimed weight: 2795g (180mm travel mode with guards, hardware and full steer tube)
  • $1,599
Development started 3 years ago and they're currently taking deposits which will give early adopters a $100 discount. Their goal was to make inverted forks more affordable. Learn more at https://www.canecreek.com/products/invert-enduro-deposit
SeaOtter2026-6.jpg?VersionId=ODv02UARREH6itYZq LA
Cane Creek Invert mounted to a Significant Other
SeaOtter2026-16
SeaOtter2026-14
SeaOtter2026-15
SideSwipe guards provide protection but still allow the fork to be seen from the front.
SeaOtter2026-13
SeaOtter2026-12
SeaOtter2026-11
SeaOtter2026-10
15mm axle stock, but 20mm axle is available.
SeaOtter2026-8.jpg?VersionId=vrl0xtTYSbb
Kitsuma and eeWings on a Norco
SeaOtter2026-7
Tigon on the Significant Other.
4/16/2026 11:13am Edited Date/Time 4/17/2026 2:34am
Bosch Motors
Bosch had ebikes showcasing their 4 different motor configurations. A Norco with the new, affordable PX, a new Kona with an SX motor, the new Ibis with the CX motor and a Pivot with the CX-R.
SeaOtter2026-17
SeaOtter2026-19 0
SeaOtter2026-22
SeaOtter2026-18
SeaOtter2026-21.jpg?VersionId=J18 Hd67aLMYQIW.Mhnxb38AsuVt5A.
SeaOtter2026-20
j0lsrud
NO
4/16/2026 11:19am
Follow.
4/16/2026 11:21am
I thought that Frameworks bike was some whacky trail bike at first. Then i zoomed in and got stink face.
4/16/2026 12:48pm Edited Date/Time 4/16/2026 12:48pm
Frameworks is the only bike there without a motor
4/16/2026 12:59pm
 I hope he looked over the warranty information, not sure if he is covered for that.
Finkill
4/16/2026 1:40pm
It's a little scary how small the 29er rear wheel looks on that frameworks bike, in comparison to the 32" front.
4/16/2026 2:31pm
Man that tyre looks like it would get dangerously close to the downtube on full compression!
vetprowanab
Longmont, CO, USA
4/16/2026 2:41pm
Cane Creek InvertCane Creek showed off their new upside down enduro fork, dubbed The Invert.Price is $1,599, it features 160, 170 or180mm of travel via different...
Cane Creek Invert
  • Air spring only
  • 45mm upper tubes
  • 38mm stanchions
  • $1,599
SeaOtter2026-16
SeaOtter2026-14
SeaOtter2026-15
SeaOtter2026-13
SeaOtter2026-12
SeaOtter2026-11
SeaOtter2026-10
SeaOtter2026-7
Came here for the Sig O.  Thank you.
4/16/2026 2:52pm
What is Bosch, like, some Avinox wanna be?
4/16/2026 3:11pm
who?
4/16/2026 3:19pm Edited Date/Time 4/16/2026 3:21pm
Frameworks 32-Inch TestingNeko Mulally is racing a Frameworks with a 32" front wheel and 29" rear wheel for Sea Otter downhill. He says he's been riding...
neko1
That frameworks looks sketchy as hell with the travelled podium (120mm or something?), the tire so close to the downtube, the tire choice.
Maybe an advantage at that flow trail, but the real test needs to be done on a real downhill track where it’s not only about rolling speed
crunat
Durango, CO, USA
4/16/2026 3:50pm
I literally thought this was a frameworks slalom bike at first before I read the 32” bit. Wow that big wheel skews the perspective
One Ghost
Tacoma, WA, USA
4/16/2026 3:54pm Edited Date/Time 4/16/2026 4:27pm
eden-ext-1 copyEden-mo-parking lot-copy.jpg?VersionId=LtAb4KKa1
The Shredline Eden. Full details coming next week. I'll try to answer questions each evening as I'm at the show and have zero service there. If you are at the show stop by EXT, Spank or Gates to see one or find us walking around. This variant is set up at 164mm rear (170 front) using a 230x60 stroke.
The Eden can be set up in six different travel modes, two wheel sizes and high/low settings.
63expert
Beaver, WV, USA
4/16/2026 3:57pm
neko1
The black ano rocker is unobtanium
4/16/2026 4:17pm
who?
Neko.
One Ghost
Tacoma, WA, USA
4/16/2026 4:23pm Edited Date/Time 4/16/2026 4:24pm
Bike park mode for the Eden over at the Spank booth.
This one is set with 188mm back (190mm front) using a 250x70 stroke shock set up in Mx wheel configuration.
IMG 2777IMG 2772IMG 2776
4/16/2026 6:02pm Edited Date/Time 4/17/2026 2:35am
Kona Remote 160 CR
Kona's Bosch-powered Remote 160 CR with SX motor
Untitled-83 0
Untitled-77
Untitled-78
Untitled-79.jpg?VersionId=G
Untitled-80.jpg?VersionId=SRf5pxNdQvDwnGZW03KdHBQUgGfM
Untitled-81
Untitled-82.jpg?VersionId=1XMIHgQF8IGh
Kona Process 246 for the groms
Untitled-76
4/16/2026 6:07pm Edited Date/Time 4/17/2026 2:36am
Telepathy
Telepathy steel high-pivot rig with rearward axle path that matches fork axle path for a consistent wheel base regardless of travel.
Untitled-3.jpg?VersionId=SUIh09E O2MbofvD2dNoKw2L
Untitled-5
Untitled-2.jpg?VersionId=zNa00HYNFwAx5JMK4z
Untitled-4
Untitled 2
4/16/2026 6:10pm Edited Date/Time 4/17/2026 2:36am
SDG
SDG had a preview of a soon-to-be-released I-Beam version of their Tellis dropper and sneakily hiding a carbon Slater kids bar, that lands in the near future, too.
Untitled-6
Untitled-7
Untitled-8.jpg?VersionId=CcfSZkunhworxt8r3NTkp
Untitled-9
Untitled-10.jpg?VersionId= CKPvZ EPxHf
Untitled-11
4/16/2026 6:14pm Edited Date/Time 4/17/2026 1:12am
CushCore Tire Installation Tool
CushCore's miracle-working tire-install tool. It's only Thursday and they've performed the demo a billion times. Thankfully though, plenty of on-lookers come through and said, "we've seen the video." Watching it in person, there is some muscle required and their tire lever helps makes quick work of the initial bead pop before the tool can go in.
Untitled-12
Untitled-13.jpg?VersionId=3f6evnq v yO
Untitled-14
Untitled-15
4/16/2026 6:15pm Edited Date/Time 4/16/2026 6:38pm
Our new favorite ebike, hands down.
Untitled-69.jpg?VersionId=Cv6
4/16/2026 6:17pm Edited Date/Time 4/17/2026 1:13am
Fairdale Elevator
Taj's Fairdale Elevator. A breath of fresh air among the never-ending display of electronic tech.
Untitled-70.jpg?VersionId=GLJL
Untitled-71
Untitled-72
Untitled-73.jpg?VersionId=fBJvk38QD6.s.eJUiyqUA
4/16/2026 6:25pm Edited Date/Time 4/17/2026 1:14am
Stablead
Stablead showing off their suspension. The frames are for display only and aren't planning on being released. Tom Rogers is the man behind the squish with consultation from guys like Brian Lopes. Besides the product, the most surprising thing in their booth was none other than the infamous Sanjay Sanbhag who hadn't been to Sea Otter since he was "hitting the dirt jumps on a road bike."
Untitled-27.jpg?VersionId=q4C9tSxw8bMYwHjfPslTdI.YTv
Untitled-28
Untitled-29
Untitled-30.jpg?VersionId=jInH3PT8rdhbMcqj7qsQELrx8VnlWJ
Untitled-31
Untitled-32.jpg?VersionId=YgqarrJB7e
Untitled-33
Untitled-34
Untitled-35.jpg?VersionId=XoBsu1UawmxtEuoo6KIbyKb17UGV
Untitled-36.jpg?VersionId=DRvovieK9HpFv2dSd4N4Wf18u7xX58m
Untitled-37
4/16/2026 6:28pm Edited Date/Time 4/17/2026 1:15am
Psychosis Welding Class Project
Not bad for a welding class project! 60-degree static head angle is the play with the philosophy of it living at around 62-63 degrees at sag and cruising up to 66 at bottom out. "I welded the rear end, but my friend, who's a way better welder than me did the headtube. I didn't want that to fail."
Untitled-24
Untitled-25
Untitled-26.jpg?VersionId=4IhiBXxeVghyZfMoUNeGub
4/16/2026 7:21pm Edited Date/Time 4/17/2026 1:17am
Brembo GR-PRO
I got to see the new Brembo GR-PRO brakes in real life, and while the master cylinder is larger, and the red doesn't help hide their size, the brakes do look incredibly clean.
DSC09935
DSC09929.jpg?VersionId=3DewQaa Y33K5tuPg1WQp9NxmXv
Quick hit notes from chatting with them:
There are three lever adjustments: reach adjust is tool-free, and then you have tooled lever ratio (3 positions) and dead stroke adjustments.
DSC09926
DSC09928
The leverage ratio affects how quickly the power engages during the initial lever stroke, but power builds consistently throughout the stroke in each position. They found that Specialized Gravity riders all run slightly different lever ratios, and surprisingly, none of them run the 'hard', quick-hitting ratio. If I had to guess, it's because braking makes you go slower, and softer hitting brakes keeps you from braking as much.
IMG 2153.jpeg?VersionId=1t15qqB.o7rTuu2X wnW1
IMG 2154
DSC09931
Caliper uses 4x18mm pistons, which is the same as the latest SRAM Maven Update.
DSC09934
They only have one pad material—semi-metallic. Brakes come with an extra set of pads.
Funny enough, none of the display brakes had oil in them, so I couldn't actually see what the lever felt like. But Brembo did develop its own low-viscosity mineral oil for the brakes, intended to offer similar benefits to other LV oils—improved consistency at higher temps.
They are only making 200 and 220mm rotors. 2.3mm thick.
DSC09937
Other color ways are planned but haven't been chosen yet. You can vote for your favorite color here
Availability in the U.S. won't be until ~September. They're still sorting out distribution. European availability is slated for ~July. @iceman2058 will definitely be getting a set to test #vitalbrakeguru and hopefully I'll get my mitts on a set later this year.
4/16/2026 7:59pm
StableadStablead showing off their suspension. The frames are for display only and aren't planning on being released. Tom Rogers is the man behind the squish with...
Stablead
Untitled-28
Untitled-29
Untitled-31
Untitled-33
Untitled-34
Untitled-37
TR, Lopes, and Sanjay mentioned all in one post... Shut it down... You can't top that...
Post a reply to: Sea Otter Classic - 2026
