High vs. Low Tire Pressures: Which Is Faster?
Edited Date/Time 1/24/2025 10:10am
We all know the theory: lower tire pressures mean more grip, and higher pressures roll faster. But when it comes to real-world speed, which one really wins? I set out to answer this with 30 timed runs down the same track.
◾ The Experiment
Two sets of tire pressures were chosen for my 88kg (194lbs) weight: 25/28 psi (front/rear) for the higher pressures and 18/20 psi (front/rear) for the lower pressures. These pressures maintain a consistent 0.9 front-to-rear ratio, with the high pressures aligning with recommendations such as those from E13.
pressure 5
After three warm-up laps, each tire pressure setup was tested over 15 runs, resulting in 30 total laps. The runs were performed in batches of five with high or low pressures selected at random and maintained for the current batch. An automatic timing system, Freelap, was used to time the runs, with a reported system accuracy of 0.02s.
◾ The Track
The upper section of Mondini Downhill, a blue flow trail in the south of Switzerland, was used for testing. It has a rock roll-in followed by three flat to medium banked corners with just the right gradient that your tires begin to break traction if you don't pedal or touch the brakes. This creates the perfect testing playground to consistently push the limits of grip. Testing just the roll in and the first three corners, rather than the whole track, meant the effects that other factors such as mistakes and fitness may have had on the results were reduced.
In other words, the longer the test track, the less sure we could be that the variations in time we saw were due to the changes in tire pressure, and not something else, such as fatigue or mistakes. This approach does come with some downsides. For example, to understand how the tire performs across a range of conditions, many smaller runs would need performing - something we hope to do in future tests.
◾ The Test Rig
The test bike of choice was a Raaw Madonna. At 188cm (6' 2"), I ride the size large. The geometry of this bike feels great, with the high stack and well-proportion chainstays creating intuitive handling that makes placing weight between the front and rear tires effortless.
bike 3.JPG?VersionId=n2mh3BHDvc.Kyx
Dual 29 x 2.4" Michelin Wild Enduro Racing Line tires were chosen for this test. It is a tire I have a lot of experience with, and I believe it is well suited for the terrain frequently found in the south of Switzerland. Inside the tires was a set of Cushcore pro inserts.
tire 2
◾ The Results
Average Performance
Let's just jump straight to the answer you are probably itching to hear: on average, factoring in the accuracy of the timing system of 0.02s, there was no significant difference in performance between the higher (10.81s average) and lower (10.78s average) tire pressures.
graph 1.png?VersionId=yI8E6
However, there is more to the story than just looking at averages. If we overlay the distribution plots for the different pressures from the table (which show how times are spread across all the runs), there is a difference between the high and low pressures.
graph 2.png?VersionId=JPM6 HJLAiNa4SVet4.sDLRb4V
Here, we can see that the highest tire pressures produced not only the fastest times (the left tail of the yellow distribution) but also the slowest times (the right tail of the yellow distribution). The lower pressures, on the other hand, produced more consistent results, as seen by the tighter band of results around the 10.8s mark in the purple distribution. Another way to visualize this is to take the five fastest and slowest runs across all tire pressures and count how many appear in each group. Here we see that eight out of the ten fastest/slowest runs were on the higher tire pressures:
graph 3
These results match my experience during the test. While the lower tire pressures rolled slower, they offered more grip. This made placing them precisely where I wanted easier, and as a result, I could more consistently find the line I wanted. The higher tire pressures, on the other hand, were more likely to slip off line, resulting in mistakes. But when the line was found, they were faster.
◾ Learning Period
Looking at averages and consistency across the whole testing period is important to do as we typically only get to ride a line once, or maybe a handful of times, during a ride or race. So, understanding how the tires perform from the first to the last effort is important. But, for most of us (myself included), there is a learning period as we ride a track. To see the learning period during this test, let's plot the time of each run over the course of testing:
graph 4
We can see that, on average, the times got faster as the testing progressed and then plateaued and became more consistent toward the end of the session. This learning period is probably due to the simple fact that I got better and better at the track the more runs I did. To control for this, let's remove the first ten runs and replot our distributions of times:
graph 5
The story changes! Like before, the lower tire pressures still prove to be more consistent, as shown by the tight band of the purple distribution. But unlike before, a higher number of faster laps, and a lower number of slower laps were observed for the higher pressures. I interpret this to mean that once you have mastered a track, the improved rolling speed of the higher pressures becomes advantageous.
◾ What's The Bottom Line?
My takeaway from this testing is that slower tire pressures offer the advantage of consistency. For the casual racer or weekend warrior, I think this should be an important consideration. Because unless you are Loic Bruni and can hit the perfect line the first time, every time, you often don't have the luxury to hit the same section of track 30 times to find the perfect line. If you do, then great! Rock the higher tire pressures, as there seems to be an advantage in speed.
But take these insights with a pinch of salt. They are specific to the combination of tires, rider, track and conditions. Would the test yield the same results on a wet day down Val di Sole? Possibly. Possibly not. For that, we need more testing. For now, consider how you might use these results to better tune your bike for your next ride.
The code and data are open-source and can be accessed here.
45
Kanista
1/24/2025 3:41am Edited Date/Time 1/24/2025 3:42am
Straight to the low psi settings i go 😅 really good read, thanks alot
az2au
Scottsdale, AZ US
1/24/2025 6:50am
Absolutely excellent post.  Obviously you're correct in that it isn't statistically valid across all variables but I do think it is thorough enough to draw a valid conclusion given the outside testing and holistic work that likely led to the an initial hypothesis of slower being faster as a general rule (because the lack of learning/repeated runs needs to allow for more mistakes).
The other conclusion I drew from it is that you should also ride what you believe in as the differences aren't likely to be that significant either way.  Confidence, and of course competence, likely matters more than either.  I tend to test new products in similar but less colorfully documented way and sadly I find that the only things that make significant differences are those the overwhelming majority of the time.
gigamike
Rancho Cucamonga, CA US
1/24/2025 8:37am
Great post! It would also be very interesting to see the results of low pressures aligned with the average recommendations and the high pressures above that. My observations over the years have seen a lot more riders with pressures higher then what is recommended.
1/24/2025 9:56am
az2au wrote:
Absolutely excellent post.  Obviously you're correct in that it isn't statistically valid across all variables but I do think it is thorough enough to draw a...
In hindsight, my choice of the word "significant" was poor. To statistically validate this claim, we would need to collect a lot more data and then use some inferential statistics (e.g., null hypothesis testing). But I think I agree with you, that there is enough in this exploratory analysis to draw some conclusions.
I also agree that riding what you believe in is a smart choice due to the psychological benefits alone. I think where this type of testing can really shine is for top level riders who are looking for marginal gains. But who knows what more testing will reveal!
1/24/2025 10:01am
gigamike wrote:
Great post! It would also be very interesting to see the results of low pressures aligned with the average recommendations and the high pressures above that...
Yeah I would love to collect some more data across a wider ranger of pressures. Something I will consider alongside other research we have in the pipeline.
I've always struggled to find recommended tire pressures from an "official" source other than this E13 post. Any ideas?
1/24/2025 10:38am
Yeah I would love to collect some more data across a wider ranger of pressures. Something I will consider alongside other research we have in the...
1/24/2025 11:29am
Interesting test, and I think well thought out given the number of variables that can come into play. For the lower pressures did you find yourself having to adapt riding style even with the cushcore? I have heard that xc are running low pressures which would suggest that it's not a rolling speed issue, though maybe this does not apply to heavier tires. Possibly a neutral, straight line roll down a hill would get at this a bit more?
1/24/2025 12:42pm
Good test, I'm same weight/height as OP so it's very interesting to me. I find the front pressure super important, I can go 22psi and no ill effects, just good grip. But in the rear, even with cushcore 28psi is about as low as I'll go before I get flats/rim strikes. I just find the confidence and grip in the front tyre is all I need, the rear can be almost whatever it needs to be to stay inflated. Riding style thing probably.
DServy
Jackson, WY US
1/24/2025 2:39pm
I am a 200 lb man and if I ran 20 PSI in a DH casing I would die. I have no idea what Wolftooth is thinking with those numbers.
https://axs.sram.com/guides/tire/pressure is a pretty decent one.
mtbman99
1/24/2025 3:55pm
I’m in the plus 200lb club and run 20psi front (exo+) and 25psi rear (DH) ( mainly to limit rim strikes and flats)
I think terrain and riding style play a big part in tire pressure. I like to ride more natural terrain with flatter corners. If I was riding park with more high speed bermed corners I would need to go up in pressure.
As for low pressures and drag I seem to remember  paper describing it like a large ship and the larger surface actually reduces drag but of course that probably doesn’t take into account casing deformation and cornering.
RoJo1
1/25/2025 12:34am
Great test. I'm not entirely sure on the assumption that higher pressure = lower rolling resistance for MTB.
Higher pressure can cause your c of g to have to rise/fall more over bumps and dissipate energy.
If you had the appetite then straight line rolling tests over a variety of surface roughnesses would be cool.
1/25/2025 2:52am
RoJo1 wrote:
Great test. I'm not entirely sure on the assumption that higher pressure = lower rolling resistance for MTB.Higher pressure can cause your c of g to...
Good points. Your explanation of higher pressure deflecting more (and being slower) matches the explanation in the Wolf Tooth tire pressure calculator somebody else shared earlier in the thread, and it makes sense. My subjective experience was that the higher pressures rolled faster, but this could be because the trail was not too technical and so there was less deflection, or more likely, that my perception was off and influenced by my prior assumptions.
I like the idea of straight line rolling tests of a variety of surfaces. I will give it some consideration.
1/25/2025 2:56am
Interesting test, and I think well thought out given the number of variables that can come into play. For the lower pressures did you find yourself...
No, I didn't find myself having to adapt to the lower pressures. I had a fair amount of riding time on these pressures previously and so nothing came as a surprise. Combined with the fact that I was on a flow trail with CushCore Pro inserts that provide decent sidewall support, it just felt like a more damped version of the higher pressures with more consistent handling.
1/25/2025 3:02am
brash wrote:
Good test, I'm same weight/height as OP so it's very interesting to me. I find the front pressure super important, I can go 22psi and no...
I relate to this. I too think front tire pressure is the more important variable and often end-up with a similar setup where I just run a higher pressure in the back for security.
b-lec
Denver, CO US
1/25/2025 12:09pm
Good work!  A couple questions that come to kind:
I wonder if there is an intermediate pressure that gives you the best of both worlds?  I think most people are probably in between your pressure brackets.
Seems like take away is higher pressures if you know the lines and lower if you’re still learning the course.
I wonder if the new Schwalbes give you the consistency with the speed since you can run higher pressures and not sacrifice grip?
yzedf
Hebron, CT US
1/25/2025 2:51pm
DServy wrote:
I am a 200 lb man and if I ran 20 PSI in a DH casing I would die. I have no idea what Wolftooth is...
That’s pretty spot on with my enduro riding and dh pressures for Maxxis tires. A bit low for Continental.
Fahzure
Moab, UT US
1/25/2025 7:43pm
*Which is faster on a short section of blue flow trail? A: They are about the same. Q: Which is faster on a loose wet rocky DH course? A: Should be obvious.
1/25/2025 11:22pm
Do I understand this that you only measured something that was 10 seconds long? if so it wouldn't say anything, of you'd do 3min then that's another thing.
Secondly the difference in pressures are enourmous and 18-20psi doesn't seem valid for any racing if your're above 65kg. Why not something reasonable like 3psi lower which is still a lot for racing.
1/25/2025 11:32pm
b-lec wrote:
Good work!  A couple questions that come to kind:I wonder if there is an intermediate pressure that gives you the best of both worlds?  I think...
For sure I think there is a sweet spot. It would be great to do an extended testing protocol with a broader range of pressures at some point in the future. This was just a first test run to even see how feasible the whole process is.
For the new radial casings, I have no idea, but I'm interested to try them.
1/25/2025 11:34pm
Fahzure wrote:
*Which is faster on a short section of blue flow trail? A: They are about the same. Q: Which is faster on a loose wet rocky...
The interesting insight for me was the variability between the two pressure setups. I agree, on a loose wet rocky track, I would like to think the answer is obvious, but I would be interested to see the variability with different pressures.
1/25/2025 11:49pm
I run EXO tires (with a cush core xc in the rear) and run pressures much lower than recommended here - 1,5 bar vs recommended ~1,7 bar.
1/26/2025 3:04am
Do I understand this that you only measured something that was 10 seconds long? if so it wouldn't say anything, of you'd do 3min then that's...
The short section of track was chosen because it allowed me to guarantee that I could find the edge of traction and find the limit of grip on each run. Any longer and it would have been very hard to do this without mistakes and other factors such as fatigue coming into play. As a result, I don't think the findings of this test are transferable to many situations, but I tried to allude to this in the conclusion. I welcome any feedback on how you think I could improve the testing protocol in future tests. Community input here would be much appreciated.
I agree that 18-20 PSI is low (but bear in mind this was with CushCore pro inserts with heavy weighted casings on a flow trail). I choose these pressures to test what I would consider the upper and lower limits of a set up I may run on the type of track I was testing on. I agree, that for most racers for most tracks and conditions, they would likely need to run higher pressures.
Fahzure
Moab, UT US
1/26/2025 4:54pm
The interesting insight for me was the variability between the two pressure setups. I agree, on a loose wet rocky track, I would like to think...
I think the point is: it's hard to tell much difference on a short section of blue flow trail. Imagine testing two skis with different flex patterns over a short section of a blue run. There's not enough information and it is of low applicability for the conditions where the variables matter.
1/27/2025 3:30am
Fahzure wrote:
I think the point is: it's hard to tell much difference on a short section of blue flow trail. Imagine testing two skis with different flex...
This test was just a first attempt at collecting some data to see how feasible the whole testing process was. I agree that the transfer of the findings into other settings are limited (I tried to allude to this in the conclusion), and that we need much more data. I would love feedback on how you think the testing protocol could be improved in the future to make it more relevant to you.
1/27/2025 3:40am
I'd always assumed that the ideal pressure was as low as you can go without hitting the rim (too often), puncturing or rolling the tyre. Unless you're hitting something like Vink Line, in which case rolling speed becomes important. There's probably an interesting test running over a rock garden /root nest with a DH tyre at low pressure Vs a lighter casing at higher pressure (ie both as low as you can go without flatting tyre or rim) to see what the difference is in terms of speed and repeatability
1/27/2025 1:28pm
We all know the theory: lower tire pressures mean more grip, and higher pressures roll faster. But when it comes to real-world speed, which one really...
◾ The Experiment
pressure 5
◾ The Track
◾ The Test Rig
tire 2
◾ The Results
Average Performance
graph 3
◾ Learning Period
graph 4
graph 5
Visualizations look great, love the bike, love the idea, and the write up is really presentable.
I don't see the actual code for the analysis portion in your github, but I see you mention that the "runs were performed in batches of five" "selected at random". I also see the run and lap data, but no other indication of blocking.
Likewise, the data showed in the github does not show configuration. Although you mention random selection previously, the graph displayed in the Learning Period section of the original post shows approximately that the first 5 runs were high pressure, the next 10 runs were low pressure, the following 10 were high pressure, and the last 5 runs were low pressure - this is not randomization lol.
When designing these experiments, its important to stick to the experimental design, stick to the randomization, and apply blocking to account for nuisance factors (i.e. learning period, track speed/conditions on the day, athlete fatigue, etc.). In general, block what you can, randomize what you cannot. When using something like JMP or Minitab, you can specify the design matrix to include blocking and randomization - in R you may have to be a bit more purposeful in specifying a design matrix using something like model.matrix or something from the DoE library. Regardless, sticking to the appropriate design matrix is what makes experimental designs robust and great for inference. Deviations from design turn inference into data analysis. As the joke goes "there are two types of analysts, those who can infer from incomplete data".
This is a great stab at experimentation and you're on a good path. I would take a step back and think about what it is that you want to know about the bike/yourself/etc and formulate a broad set of research questions. Identify the possible factors that you can change, factors that you can measure but not change, and factors that you cannot control wrt some of the key research questions you are interested in. From there, it will be easier to design a 2^k factorial design with blocking, randomization, and an appropriate level of replication for the time that you have to test and the factors that have been identified. It is much easier to design an 'exploratory' experiment from the onset rather than perform a bunch of sequential testing only to find out that, for example, shock pressure is a larger determinant of variance down a timed trail than the tire pressures selected in the previous experiment (and now we need to design a 2^2 design for tire and shock pressure despite the experiment we just completed). If the design matrix grows too large, there are also fractional factorial designs that lets us infer about a chosen subset of interest in the design matrix, cutting down the number of runs that need to be performed to reach desired inference.
There are a ton of texts and support on experimental design out there, Montgomery's book was taught when I was in school but any book on experimental design will give you what you need to take your work to the next step.
p.s. I'm generally pro open source for quantitative work, but software like minitab and jmp are very straight forward and established for DoE. Their visualizations are definitely a blast from the past, but the quality of analysis for DoE from those software is generally top notch.
1/28/2025 12:52am
◾ The Experiment
pressure 5
◾ The Track
◾ The Test Rig
tire 2
◾ The Results
Average Performance
graph 3
◾ Learning Period
graph 4
graph 5
Visualizations look great, love the bike, love the idea, and the write up is really presentable. I don't see the actual code for the analysis portion in...
The whole experiment is published as an R package. The script to generate the visualisations can be found in inst/scripts/images.R.
The data were randomised into batches of five runs before data collection, using random batch assignment. So the order of 5 high, 10 low, 10 high, 5 low is the result of a form of valid randomisation, and my preference for this experiment. I chose not to perform a randomised block design, like you are referring to, because it is very impractical to implement when collecting data (e.g., there is the potential to have to change bike setup between every single run in an entire block which would result in much longer testing times due to setup, and ultimately less data).
1/28/2025 1:08am
The whole experiment is published as an R package. The script to generate the visualisations can be found in inst/scripts/images.R.The data were randomised into batches...
… and would result in a more valid experiment, with quantifiable analysis of variance, avoiding misinterpretation by those unaware.
Finding more inference from less data is a feature, not a bug.
1/28/2025 1:29am
… and would result in a more valid experiment, with quantifiable analysis of variance, avoiding misinterpretation by those unaware. Finding more inference from less data is a...
In my opinion, the cost of collecting less data (due to the practicalities of a randomised block design) is higher than the cost of not using the ideal randomisation design (again, there is some randomisation built into the testing procedure).
Thanks for the discussion and feedback!
RoJo1
1/28/2025 1:56am
In my opinion, the cost of collecting less data (due to the practicalities of a randomised block design) is higher than the cost of not using...
I've got a lot of support for this argument. I've done some of my own tyre testing: https://www.vitalmtb.com/forums/hub/front-dh-tyres-accurately-timed-kryptotal-vs-assegai-vs-magic-mary-vs-vigilante-vs-plus
and the practicalities are hard. Plus you need some learning time, you can't just randomly change bike setup every run and expect to somehow get the most out of it, you need familiarisation time to predict what your tyres will do. The entire subject is difficult and I applaud anyone who attempts to dive into it.
Post a reply to: High vs. Low Tire Pressures: Which Is Faster?
