Shock servicing at home
12/13/2024 12:54pm
DServy wrote:
Thanks again for everyone's help! For those who have tested things in dyno, is there any correlation to Fox's tune codes to RockShocks? E.g is the...
Thanks again for everyone's help! For those who have tested things in dyno, is there any correlation to Fox's tune codes to RockShocks? E.g is the light compression code for Fox similar to the c26 compression code and so on. Be curious on where each of the companies "tunes" land in comparison to each other.
Short answer, I don't think it's a neat translation from Fox tunes to RS or vice versa. There was a great discussion in one of these forums (can't remember which) about the new standardized RS tuning nomenclature, which makes a lot of sense. It used to me L, M, or H, but sometimes the H was actually softer than the M, etc etc and oftentimes employees deep inside RS couldn't remember when tunes were created, how much damping force they generated, and more. Now it's linear and standardized, so 31 is always more damping than 27, and so on, and those tunes are transferable across platforms, like a Vivid to a SDLX. My understanding for Fox is that they're still using a L/M/H tune system akin to the old RS system, which does not translate neatly across platforms.
DServy
Jackson, WY, USA
12/13/2024 2:55pm Edited Date/Time 12/13/2024 2:57pm
Short answer, I don't think it's a neat translation from Fox tunes to RS or vice versa. There was a great discussion in one of these...
Yeah, I remember reading that, I think @Dave_Camp was the one who was commenting on the RS nomenclature being consistent throughout the shocks. I have a few folks I know looking to jump ship from X2s to Vivids and I wanted to see if I could help them figure out a decent base tune based on Fox's L/M/H to RS's numbers between Vivid and X2.
Also, I guess when we are down the path of talking about shock tuning. When have folks decided that a re-shim is needed vs just fiddling with the adjusters. I know a shimstack creates the shape of the force curve and the adjusters are more just moving that shape around, but when is it worth changing the stack vs adjusters. I know there's probably a lot of "tuner magic" that goes into answering that question, I'm more just curious on what people are willing to share on this process.
12/15/2024 3:34pm
DServy wrote:
Yeah, I remember reading that, I think @Dave_Camp was the one who was commenting on the RS nomenclature being consistent throughout the shocks. I have a...
A lot of it is due to rider ability and preference and existing bike setup (i.e native tune of the shock).
In my opinion, broadly speaking a fast rider on a 140+ bike that likes moderate to high damping (and you should) will benefit from re-tuning a shock to a firmer overall settings.
As on Rockshox and more to the point fox products, most fast riders are close to maximising the usable damping range before they hit a LSC wall and can't reallt use the end range of clicks without it losing early travel grip and responsiveness.
Its why so many people love Ohlins and it's a totally different feeling, it's just much more damping overall than the standard RS and fox tunes.
Having said that, 2 times a week strength training will yield more benefits in speed than a custom $1000 shock anyway, so take away what you will.
12/16/2024 11:05am
I don't have full sweeps of the latest tunes from Fox and Rockshox but this plot is a rough approximation of where the tunes sit - generally there isn't really a nice match between the 2 brands, Fox shocks also vary wildly from year to year and each models also has very different characteristics. Rockshox has had fairly similar damping profiles (at least on compression) since the super deluxe launched, and even the Monarch Plus wasn't too different. They were slightly digressive, with the adjuster mostly changing the overall force but the newer 2025 shocks seem to be more linear with a lower threshold at low speeds. As seen comparing the super deluxe C40 tune with the vivid C30 - the SDLX has a steeper gradient and more high speed damping but significantly softer at low speed. Although its not on here, most of the tunes from the 2021 Float X2 would have been firmer than all of these, even fully open. The "C" labelled super deluxe tunes (opposed to L, M, H) are all using the new piston
Adjuster range and function is super important when comparing tunes - each brands "low speed" and "high speed" dial can have more or less affect on the entire range of speeds, as well as more or less resolution between each click. So most shocks have a sweet spot in the range they work best while others are pretty useful for different people across the whole range. So I would normally compare tunes at specific points people would use (as opposed to just middle, open or closed) but these tests were mostly run separate so aren't designed to match. The closest match though would be between the current Float X2 "CX2" tune to the Rockshox Super Deluxe C40 which is interesting because CX2 is the second softest tune while C40 is the stiffest for RS.
Also the Rockshox settings are the absolute position from fully closed (as is the convention for literally everybody) and not the +/- labelled on the adjuster which is confusing as heck. Therefore -2 is the middle and -4 is fully open
*final note: please don't use this plot to infer anything other than what I've tried to quickly explain here - they are standard "PVP" plots which give an overall impression of the damping rates but there are a lot of layers to comparing damping including adjuster range, spring design and hysteresis, so even 2 shocks that look quite similar will have a very different feel on the trail
RS vs Fox with labels
12/16/2024 11:22am
Oh yeah I also mean to talk about adjusters vs reshimming - you should always exhaust the full range of the adjusters you have first, which comes after bracketing your spring rates/air pressures. A lot of people get led down the wrong path of making some assumption with spring rate and volume spacers (ie soft spring + too many tokens or vise versa) so if its too soft they will never get the damper rebounding fast enough and think they need a faster rebound tune, or maybe stiffer compression tune. Where if the spring was set better you might not need to touch the damper, or even go completely the opposite direction. But usually I would work through a kind of flow chart, finding the upper and lower limit of spring pressure, then volume spacers and if you reach a point that the air spring is as high as you can manage while having OK grip, but the support is lacking then try closing the compression and if that improves support (but reduces grip) then its a good sign the high speed tune should be stiffer. With rebound, I would make sure spring and compression are good first, then run through the range of rebound adjustment - if you need it to be right at the extremes then its time to change. Deciding if you need softer compression is maybe harder to describe - if the spring is too soft it can feel very harsh but not necessarily bottom out, so again I would make sure your spring rate has been throughly bracketed and then bracket the full range of compression damping. If fully open feels the best then you can probably go with a retune.
I always come back to bracketing because people often don't realise how much higher in pressure they can go - a bike can still be "functional" at 40psi or more below the ideal setting, but if they add 20psi and it feels better they just assume thats as good as it gets because it was such a big step. You really need to keep going up to find the point where it starts getting worse, and then come back a little from there.
12/18/2024 4:20am Edited Date/Time 12/19/2024 4:23am
I've always wanted to play around with the ReSacker program for shimming.  Every time I do though I get confused and aggregated.  I believe once you...
I've always wanted to play around with the ReSacker program for shimming.  Every time I do though I get confused and aggregated.  I believe once you figured out that program it could be really useful.
It's not. The results arent even close to the real world but even in you spend hours getting perfect measurements of your damper it still doesn't...
It's not. The results arent even close to the real world but even in you spend hours getting perfect measurements of your damper it still doesn't give you anything useful. It promotes itself as replacing a dyno but it really isn't, you are better off with trial and error as restackor will just confuse you. You would think it might be useful to iterate shim stacks before dyno testing them but it isn't, I'm pretty sure it would be cheaper and easier to teach yourself CAD and CFD with some of the free and open source software tools out there instead. I don't know anyone who uses it once they own an actual dyno
Maybe play with the free version to get an idea of how things work but definitely take it with a grain of salt
I've only played around with the free version, initially by plugging in my existing LSC shim-stack and then aiming for something stiffer.
Most recently, I asked chatGPT for a (stiffer than what I put in) shim-stack recommendation. I then used restackor to confirm and adjust to confirm a stiffer shim stack.
Full disclosure:
I have no skin in this game, I just like tinkering/messing around with suspension (Diy runt, piston mods, coil conversions). But I must say, my fork is definitely better because of the shim-stack mods.
12/18/2024 5:33am
DIY runt?
dirty booger
7200', CO, USA
12/19/2024 5:21am
Johnboy wrote:
Screenshot 20241219-232228Screenshot 20241219-232205.jpg?VersionId=GdSAJ4mX0doVlkZp
Nice!
What do you have going on with the piston?
I have been playing with the stock RUNT +10mm extended piston. I bored it out and was able to increase the internal volume by close to 10% with the goal being to reduce the progression. I also swapped out the o-ring for a quad ring and a few other things.
Seems to be working well, improvement over stock for sure.
PXL 20241204 210727602
12/19/2024 5:40am Edited Date/Time 12/19/2024 5:45am
I think Chickadeehill has this style of floating piston?
One possible reason is to have more volume at full compression in the secondary chamber but drill being able to assemble the whole assembly in the given length.
dirty booger
7200', CO, USA
12/19/2024 5:42pm
That was the idea, increase volume for less progression near bottom out.
I have a Chickadeehill in a Boxxer. It is a well thought out version of a second positive air chamber system. Modular design, very light weight, the piston is bored out and it uses a quad ring to seal. For sure German....😉
chicadee Boxxer.jpg?VersionId=5stcdRMcjSU8TnXnOoQfAV5Wmhv
12/19/2024 6:33pm
Nice!What do you have going on with the piston?I have been playing with the stock RUNT +10mm extended piston. I bored it out and was able...
Nice!
Similar set-up with a hole drilled in the bottom for exta volume. I went with 2 o-rings so stop any chance of the piston cocking in the bore. The second o-ring doesn't do any sealing, it is just a guide.
I also trialled a piston with double u-cup seals. But I tested the breakaway force needed to get it moving and it was not as good as the 2 o-ring setup.
10000207471000020746
dirty booger
7200', CO, USA
12/26/2024 8:23am
The Vorsprung Telum needs some mention here. The fact that you can change the tune it in 5 minutes w/o a rebuild is amazing.
Externally adjustable clamp shim diameter plus a massive tuning database will forever change the suspension game, no more hand jobs for @TEAMROBOT
https://www.youtube.com/watch?v=C5RomAga7qs&t=38s&ab_channel=VorsprungSuspension
https://www.youtube.com/watch?v=xx5-vHt-mVo&t=235s&ab_channel=VorsprungSuspension
ex-ballz
Ouagadougou, EH
12/26/2024 2:14pm
As much as I like the Telum and the clamp shim adjustment, I don't think it can match performance and tunability of a custom shim stack. IMO a properly tuned Avy will still come with fever performance trade-offs than a properly set up Telum.
DServy
Jackson, WY, USA
12/26/2024 4:51pm
ex-ballz wrote:
As much as I like the Telum and the clamp shim adjustment, I don't think it can match performance and tunability of a custom shim stack...
Actually, my time spent on a Telum is kinda what prompted this whole can of worms in my life, and I think to Vorsprungs credit, they pretty much nail it.
here comes complete speculation, I could be probably way off
As far as I've been able to understand, when it comes to a shim stack, pretty much every shim past the main face shim is to help control the flex of the face shim, basically customizing the flex property of that shim to respond in set ways during load. So in that respect, any sort of of system that directly changes the flex of the shim is equivalent to "re-stacking" a shim stack. That's what VVC was attempting to do, and thats what the Telum does. The Telum does this by actually making contact with the shim in a set way depending on the amount of turns set on a worm screw. Which means its less prone to the tolerance issues that the VVC had (and, because its physically touching) probably acts even more like a re-shim.
I'll conceded that there is probably a touch less "fidelity" in the Telum system than maybe a custom shim stack, but If I were a betting man, I'd say that Vorsprung would probably argue that the "next level" of customization in damper curves using complex shim stacks could provide are just not useful for the mountain bike application (or at least not as useful as the breath of tune curves the telum can produce with its setup). And frankly, damper forces on a mountain bike are probably not nearly as high as they are in other applications because there just isn't the raw sprung and unsprung mass.
12/26/2024 10:49pm
Mountain bike shocks are fairly unique actually because of the breadth of damping they need to do - they need to handle fairly high speed hits in high speed compression events (nothing too dramatic), but at the same time the low speed performance (platforms, bobbing prevention, etc.) is much farther away from the high speed stuff than most other applications. Or at least the shock is the only thing handling that. With cars for example you have the sway bars to handle side to side low speed suspension events.
dirty booger
7200', CO, USA
12/28/2024 9:58am
Changing the shim stack allows you to change the shape of the damping curve. Steep/shallow nose, linear, progressive, etc. The clamp shim makes the whole stack stiffer or softer, the basic "shape" remains the same. One of the assets Vorsprung has is a massive tuning database they've developed over the past 10+ years, so they should have the damper curve shapes pretty dialed for each application.
I have an Avalanche tuned Bomber CR, Fluid Focus Bomber CR (with their mid valve piston/tune and mods), stock RS Super Deluxe, and soon a Telum. All the same size, all tuned for the same bike.
I'll drive out to Bootleg Canyon if @Vital MTB  can cover lodging and shuttles. Some real world test sessions with the same tires.😉
DServy
Jackson, WY, USA
12/28/2024 1:01pm
Changing the shim stack allows you to change the shape of the damping curve. Steep/shallow nose, linear, progressive, etc. The clamp shim makes the whole stack...
@sspomer How can we make this happen? I'll pitch in 5 bucks!
Whattheheel
Spearfish, SD, USA
12/28/2024 1:28pm
Like the rap group Luniz said “I got five on it!” Also!
1/1/2025 10:39am
DServy wrote:
Actually, my time spent on a Telum is kinda what prompted this whole can of worms in my life, and I think to Vorsprungs credit, they...
Yup thats pretty bang on - the telum system is dang close to re-shimming the piston and in actual fact probably behaves more like what you think reshimming a shock does. The Telum makes a clear change to the gradient of the curve, and only that where as changing shims often has multiple changes in the force and speed that the shims open. VVC is frustratingly sensitive to tolerance - the tiniest change in preload on the leaf spring has a massive effect on damping. If you set it up with close to zero preload the adjuster does almost nothing, and once you have a small amount of preload, that gets increased as you shorten the lever on the adjuster plate so it behaves as much like a preloaded spring.
The fidelity of adjustment from the Telum is about as good as you would ever want - The idea that a "properly" tuned custom shim stack has infinite tuning possibility and is the only way to get a perfect damping curve is a myth - there are so many more factors to shock performance that are baked in like friction levels, piston size, port geometry, shaft size and gas pressure. Even if you are attempting to optimise all of those for each application, the final result needs to decide on a compromise for it to work across the widest range of input frequencies and speeds. Thats why external adjustment is always needed to fine tune the damper for each unique person. Trying to make the perfect tune just with shims is a waste of time, when the end result would be literally indistinguishable from one that used a combination of internal tuning with external adjusters. Personally I think the Telum is currently the best balance of being able to get the most ideal set up in the widest range of bikes from a single shock.
dirty booger
7200', CO, USA
1/1/2025 12:52pm
Yup thats pretty bang on - the telum system is dang close to re-shimming the piston and in actual fact probably behaves more like what you...
Have you folks run a Telum yet? What do you think about the lack of a mid valve?
I thought that one of the functions of a shimmed mid valve was to counter the slight delay between piston movement, and when oil pressure through the base valve generates damping.
Maybe different on a twin tube design?
1/4/2025 12:37pm
Have you folks run a Telum yet? What do you think about the lack of a mid valve? I thought that one of the functions of a...
I've had it through the shop and dyno'd but not personally ridden on the trail yet. I like the solid main piston (its not a mid valve on a shock) because it helps the damping to respond faster and balance the pressures more predictably. I think mixing a shimmed main piston in a twin tube is either to help it move faster (reducing low speed damping) or combined with preload as a high speed "blow off". The downside is if the shims are too soft the adjusters are very ineffective, the lag in damper response can increase harshness/knocking and if you need lots of damping the internal pressure becomes insanely high, because you are relying on the pressure acting on the small area of the shaft . A stiffer tune is a little better but the blow off effect makes bottom out control tough if you don't have a good bump stop or HBO (like the first DHX2 had super harsh bottom outs). the CCDB did a pretty good job of mixing the designs but generally I prefer manufacturers to pick a lane and go full twin tube with a solid piston or stick with a traditional monotube
DServy
Jackson, WY, USA
1/13/2025 6:54pm
Follow up:
Cracked open a vivid air I have laying around and the process went super smoothly until i got to the point where I needed to replace the nylon bleed ball.
Does anyone know what size nylon bleed ball sram is using? @TheSuspensionLabNZ ?
1/13/2025 11:01pm
DServy wrote:
Follow up:Cracked open a vivid air I have laying around and the process went super smoothly until i got to the point where I needed to...
Follow up:
3.15mm or 1/8"
DServy
Jackson, WY, USA
1/14/2025 5:24am
Follow up:
3.15mm or 1/8"
You're a wizard! I owe you a beer!
1/14/2025 8:41am
Follow up:
3.15mm or 1/8"
What on earth is a nylon bleed ball?
TimBud
1/14/2025 11:00am
Is that just the little white (normally) ball that is pressed into the allen bolt to stop inadvertent loosening?
1/14/2025 11:09am
It's the little white ball that's in the bleed hole of Monarch (non-Plus) and Deluxe (non-Super) shocks on the sealhead to close off the damper. It's held in place with a grub screw.
Not sure where it is on the Vivids.
The ball in the allen bolt is a Fox thing for the nitrogen port on inline shocks.
DServy
Jackson, WY, USA
1/14/2025 1:47pm
It's the little white ball that's in the bleed hole of Monarch (non-Plus) and Deluxe (non-Super) shocks on the sealhead to close off the damper. It's...
Its on the countermeasure/bumpstop plate. Yeah, sucks to get to the point were you are bleeding the shock and realize that you actually need to remove/replace that nylon ball to set the IFP.
I will say, up until that point, I was "shocked" with how easy everything was. Only misstacked the shim stack once!
MrDuck
3/16/2025 8:46pm
So just before I got the doctors to take me out for a while, I shimmed my previous gen SDLXA. The exact stack doesn't matter I suppose, result feels good, but being a nerd on a mend I'm overthinking whether my stack would contribute to cavitation in some situations.
Instead of the typical pyramid-ish shape, I added a set of something like
18x0.1
11x0.1
18x0.15
In other words I added 2 larger shims with a spacer shim in between, in order to have the first shim bend freely until it contacts the next one. It's nothing special, I just don't know the nomenculature. I haven't really seen this setup used in OEM suspension that I recall, but also most people seem to like less progressive suspension than me so I wonder if it has significant downsides?
Cheers!
Post a reply to: Shock servicing at home
