New EVIL Offering - Forum Hot Seat with Evil Bikes
Edited Date/Time 11/6/2025 6:01pm
Today Evil launches the new Offering and they join us here to answer all your questions!
Fire your queries to the Evil Bikes crew below.
EvilOfferingOrange
New Offering Highlights
YOU WIN - IT'S NOT SUPERBOOST! (more on that below)
29-inch wheels
151mm travel, up 10mm from previous
Latest generation of DELTA + Geometry + Kinematics
Three different fork lengths - 160mm optimized but can run 150 or 170mm forks
EvilOfferingRipChips
Two Rip Chip positions (High/Low) to get:
Head Tube Angle Range of 63.5 deg to 65.2 deg.
Seat Tube Angle Range of 77.9 deg to 79.3 deg
Only requires removal and loosening of two bolts to change chip positions
EvilOfferingDelta
Geometry compared to previous Offering
0.5 deg slacker HT angle – 64.7 to 64.2 degrees
5mm longer Chain Stay
20mm longer front center
2 degree steeper ST Angle – 77 deg to 79 deg
Virtual Top tube lost 33mm (size LG)
Reach is nearly identical
EvilOffering12x148BoostRearEnd
Boost 148 Rear Spacing with 55mm Chain Line
Boost Mode. The dust has settled, and the market has spoken. Evil-0, Industry-1. We’re back to Boost, baby! We’ve enlisted a Boost 148mm rear hub with 55mm chain line to maximize compatibility and provide a smoother, more compliant ride.
Reason for the change
Super Boost 56.5mm chain line allowed Evil to gain significant tire clearance as compared to an old style 52mm chain line.
Old style 52mm chain line combined with boost 148 rear end caused chain to skate down the cassette at even a slight hint of a back pedal from the rider. 56.5mm chain line and 157 Super Boost Rear end fixed this inherent boost chain line drivetrain performance issue.
New chain line standard is 55mm which allows for all the tire clearance we need.
New generation drivetrain designs are based off the 55mm chain line which vastly improves drivetrain performance
EvilOfferingChainguide.jpg?VersionId=
Hardware
Large main pivot, all other pivots forward of the seat tube result in minimal flex at each pivot
Longer lasting pivot bearings
8x30 lower shock hardware and longer lower shock bolt with a deeper broach
6mm fastener Trunnion bolts
Linkage bolts go from hollow to solid
Rear Axle
Lighter weight
6mm fastener head for added durability
174mm x 12mm size, 1.0 Thread Pitch
EvilOfferingFrames
Frame Details
Cleaner silhouette, smoother cable routing
Lunchbox downtube storage with waterproof bag
Water bottle mount
Piggyback shock compatible
One piece rear triangle with significant rear-to-front triangle overlap
Updated sag indicator
New DELTA Links and Bone Links
Inside voice protection package
Side mount seat collar split
Evil Offering Lunch Box Clear.jpg?VersionId=7sABRZSLsl W5ZIHQeitdV9YNcL
What didn’t change?
Bearing size
Main Pivot width
Main Pivot Spacers
Lower shock bolt expanding collet
Headset Spec – It is still angle headset compatible, though we believe the Head Tube is slack enough to not warrant use of an angle headset
Seat Collar 34.9mm collar for 30.9mm seat post diameter
Seat Post Diameter – 30.9mm
Carbon Internal guide tubes for super easy housing routing through the frame
2-Bolt ISCG Chain Guide and Bash Guard Tabs
73mm Threaded BSA Bottom Bracket
180mm Post Mount Rear Brake Mount
UDH Rear Hanger and Transmission Rear Derailleur compatible
Geometry Chart with 160 or 170mm fork
EvilOfferingGeometry
Build Options & Pricing
The Offering can be purchased as a frame-only or in a variety of build combos with RockShox suspension, SRAM drivetrains and brakes, Industry 9 wheels and Maxxis tires.
Frame - $3,999.00
Eagle 90 - $6,699.00
Eagle 90 w/ I9 Carbon Wheel upgrade - $7,999.00
X0 AXS - $7,999.00
X0 AXS w/ I9 Carbon Wheel upgrade - $9,299.00
XX AXS - $9,299.00
XX AXS w/ I9 Carbon Wheel upgrade - $10,599.00
Buy online at evil-bikes.com, at The Landing in Bellingham or at your local Evil dealer
View key specs, compare bikes, and review the new Evil Offering in the Vital MTB Product section.
https://youtu.be/r5EQqjCyuM4
https://youtu.be/m7AbZlIH5aE
Have questions? Ask the Evil crew right here!
11/4/2025 10:10am
$4k frames in 2025: Are you comfortable being DOA?
jsray
Gilbert, AZ, USA
11/4/2025 10:15am
i am slowly being priced out of MTB.
11/4/2025 10:15am
Man that's clean! Hoping something's down the road for mixed wheels!
piggy
Compton, CA, USA
11/4/2025 10:41am
They fixed the seat tube angle! As a tall guy, I would finally consider an Evil!
As for the pricing - please stop whining. This is pretty standard now, for better or worse. It’s less an an equivalent Santa Cruz. Go buy a YT.
Tustin, CA, USA
11/4/2025 10:42am Edited Date/Time 11/4/2025 10:44am
I'd love to try one... in a field of crab links, faux crab links and imitation crab link look alikes, this does stand out as different and interesting.
As a 6'3" ish rider, I'm interested in the design/validation process that lead to a fixed chainstay size.  I'm a longer chainstay type of guy, but I can admit when I jump on a pivot, I'm not thinking of how short the chainstays are the whole time.  I feel like there is a riding style that is central to evil bikes that jives with slapping the back end in and out of things and that works with shorter chainstays.  That being said, this bike has a much longer front center then the last one, and the chainstays did not grow proportionally, so I'm interested in how that played out in the design process.
Also, as a serial rear brake dragger, I'm interested to know as much as I can about the anti-dive kinematics of this bike.  I will admit that I felt like the previous evil bikes I've ridden rewarded a very advanced, off the brakes riding style and the suspension performance benefited from that.  Have they done rider testing with a wide range of riding styles/skillsets for this bike? I'm not sure it's truly important, Evil's brand and rider follwership was more of a, "if you know you know" and an advanced riding style.  Maybe this isn't that critical for their identity or target customer.
Lastly, overall I think it's a good design update and I would (as noted above me) not take the bait on pricing criticism.  The writing is on the wall that if you want something that is under 3k for a carbon frame, you need to buy name brand, off the shelf crab.  If you want the limited run, fresh off the shell crab, you're going to need to pay in the 4k range for a frame.  Seems reasonable to be riding something different, that is going to sell less volume then Specialized.
11/4/2025 10:57am
I suppose we can't be everyone's cup of tea - our goal is to make the best bikes we possibly can & yes, that price is competitive. Thanks!
sethimus
11/4/2025 11:04am
I suppose we can't be everyone's cup of tea - our goal is to make the best bikes we possibly can & yes, that price is...
why do you think everyone should have the same length rear center but a size specific front center and do you believe every size rides exactly the same?
11/4/2025 11:17am
Is there kinematic charts we can see?
jftoha
Washington, DC, USA
11/4/2025 11:21am
Bet
Please let there be a short travel MX wheel "play bike" with shorter chainstays, pleeeease!! A new mullet Calling!! I assume the eventual new Insurgent will be a 180-200mm Mullet too.
11/4/2025 11:23am
Can you run it mullet?  Just eyeballing it, it looks possible in some of the high setups, like high/170.
11/4/2025 11:23am
Appreciate you guys (Evil) releasing a bike and being present on the forums to chat about it.
11/4/2025 11:26am
ebruner wrote:
I'd love to try one... in a field of crab links, faux crab links and imitation crab link look alikes, this does stand out as different...
Thanks & great question - it's a longer answer than we can reasonably sum up here, but we'll do our best.
Your assessment is correct - an "agile" ride character has always been somewhat of a hallmark here at Evil. We try to walk the line between agile/fun, and stable/confident. Short stays make for fun wheelies & jumps, thus, we've always stayed on the shorter side. There's a great argument for size-specific chainstay lengths - that much, we do not debate.
Our rear triangles are a relatively complex mold. Molds are quite expensive. Introducing another rear triangle mold increases total up-front investment significantly. Considering the bike industry as a whole is not doing so hot right now, we really had to take a hard look at cost/benefit.
All other variables held constant, increasing chainstay length would output more travel and throw off the leverage rate. To maintain travel and ride character, this would require alternative links, alternative shock tunes, and/or an alternative front triangle altogether. It gets complicated quickly.
Front center did grow significantly. You are correct in the sense that CS did not grow in quite the same proportion. That said, when you consider that the seat tube angle is considerably steeper, the rider's weight in the pedaling position is shifted significantly forward. Seated - the effect is much more tangible than the 5mm growth in CS length. Standing - the bike still likes to wheelie & jump. Trying to strike the best balance of uphill efficiency, while maintaining the lively, agile character synonymous with Evil.
Braking - we hear you, although we've never found it to be much of a bother. Our DELTA linkage is a linkage driven single pivot design. The rear axle operating in a perfect arc around the main pivot. Within this design, there is no way to isolate braking forces, shy of a floating brake. We're always looking to improve, but we really like the ride character of our DELTA linkage & I don't think we're terribly excited about floating brakes. Big fans of "less is more" from a mechanical complexity perspective. We want working on bikes to be easy. To answer your question directly - yes, we test with a wide variety of styles & skillsets.
Thanks for the kind words & we appreciate the sentiments around pricing. To touch on that from my perspective (hi, Dylan here), we went out of our way to ensure this bike was not only competitive, but actually priced less than many comparable models from other brands. While we do aim to produce & sell a top-tier product, we are not really interested in playing the Louis, Gucci, Fendi, Prada game like some brands. There's always a lot to consider here, but the market isn't doing so hot right now & we want our bikes to strike somewhat of an attainable luxury balance. We put all this effort in so people can ride them, not just dream of riding them.
Anywhoo, hope this babble was at least insightful & thanks again for your comment!
11/4/2025 11:29am
sethimus wrote:
why do you think everyone should have the same length rear center but a size specific front center and do you believe every size rides exactly...
Thank you for your comment - this is addressed in another comment/reply within this thread. And no - of course every size does not ride exactly the same.
11/4/2025 11:31am
This is something that we have not historically shared. Of course these can be reverse-engineered to a relatively accurate degree, although our engineering team prefers to keep the secret sauce a secret.
11/4/2025 11:33am
Not by design, although you absolutely can. There's plenty of folks out there who have mulleted any one of our 29" models. Considering the steep seat tube angle on this one, a smaller wheel won't pose a huge detriment to STA, although it will lower the BB height, so that's something to watch out for.
11/4/2025 11:34am
Hell yeah brother! Rules : r/Hell_Yeah_BrotherThanks!
11/4/2025 11:49am
Bike looks great, well done Evil. When does the new DH bike drop!? 🤘😵
Evil96
Portogruaro, VE, IT
11/4/2025 11:50am
Can run older eagle drivetrain with the stated spacing in the Faq?
11/4/2025 11:53am
I think everyone here agrees that we would absolutely love to see the Undead rise again. I mean, it is in the name after all...
That said, for a small company like us, a DH bike is a passion project much more than it would be a smart business decision. Perhaps someday, although it's going to take the market recovering, and us sitting comfortably before that's going to happen.
11/4/2025 11:54am
Yes, but you might need a new crankset to achieve that 55mm chainline.
Goupil
Rennes, FR
11/4/2025 12:03pm
I like how it looks. I didnt even try to think how that suspension work 🙃
theweaz
Victor, ID, USA
11/4/2025 12:10pm
Whats the timeline for the rest of the product line to get updated?
These updates on the following would make me very interested in owning one
jsray
Gilbert, AZ, USA
11/4/2025 12:17pm
I second this, safe to assume the rest of the bikes will get similar treatment. following will be 🔥
11/4/2025 12:39pm
Going to be a bit. We're a small team and the industry is not doing so hot. Development is slow these days.
Tustin, CA, USA
11/4/2025 1:08pm
Do you guys mind sharing a frame weight for a Large?  (sorry if this is posted in your faq videos, i'm at work and can't watch them)
I've been in the market for a new trail bike and I've been looking for a 140/150 travel frame.  I have a hunch that this bike could be slightly heavier then other options I'm looking at... however I recently played around with adding some weight to my nomad and I find that additional weight around the bottom bracket is nothing to be feared, if anything it's helpful.
h20-50
San Antonio, TX, USA
11/4/2025 1:15pm
Love to see it EVIL!  I had  V1 Insurgent and still own my  2017 Calling and 21' Insurgent MX.  Questions?
Any hints on the new Insurgent?  At least tell me we will get some colorful options outside of shades of black and grey?
Any word on the Calling?!?!  I'm going to need a replacement sometime, and the Calling is still the best riding bike I have ever thrown a leg over!
11/4/2025 1:35pm
This is something that we have not historically shared. Of course these can be reverse-engineered to a relatively accurate degree, although our engineering team prefers to...
This is something that is very useful to know and I appreciate the companies that make it easy to access. A lot of people want to either upgrade the shock or bring over a high end damper they already own. So this makes it much easier to get that person set up properly if the bike company hasn't already supplied detailed settings and spring rates for that shock
afreak
Big Sky, MT, USA
11/4/2025 1:48pm
The Freehub review makes it sound very “poppy” and not stable, super fun probably! Would a coil shock rein it in a little and allow it to track through the rocks better? What’s the size large frame weight without shock?
Evil96
Portogruaro, VE, IT
11/4/2025 1:51pm
what are the frame weights?
Post a reply to: New EVIL Offering - Forum Hot Seat with Evil Bikes
