Tuned Mass Dampers and Mountain Bikes
11/18/2024 4:59pm
Blind test of a mass Vs. Rimpact Tuned Mass Damper:
tdawg
New York, NY, USA
11/25/2024 5:03am
The countercycle is housed within the shell and have some sort or grease or lubricant inside. I like the fact that it’s dead silent. The rimpact...
The countercycle is housed within the shell and have some sort or grease or lubricant inside. I like the fact that it’s dead silent. The rimpact could be noisy also there’s no way to dampen the rebound and in this design
Bought a Countershox/countersycle unit. I haven't ridden it yet so I can't comment on the ride quality, but I have already taken it apart. It appears to have a Brass(?) mass inside which is super tight in the outer tube. I guess this is some sort of friction damping, as the springs are really soft. The marks on the Brass are from when I took it out of the housing.  No oil or lubricant inside the unit apart from grease on the springs. Will put it back together and take it for a ride. PXL 20241125 124328760.jpg?VersionId=rzK3wKClCI9yhgbFM2.2ZBPXL 20241125 124406335.jpg?VersionId=Pa8jBH7F1tC8zCRSbrxu1H6BIOPXL 20241125 124314463.jpg?VersionId=VTVPrDWf1 zfzhT6dXH9V
juliusk
Clausthal-Zellerfeld, DE
11/25/2024 5:46am
tdawg wrote:
Bought a Countershox/countersycle unit. I haven't ridden it yet so I can't comment on the ride quality, but I have already taken it apart. It appears...
Was there any preload on the spring when you took it apart? I am already riding one for a month and until now didn‘t dare to open it.
tdawg
New York, NY, USA
11/25/2024 7:32am
juliusk wrote:
Was there any preload on the spring when you took it apart? I am already riding one for a month and until now didn‘t dare to...
There is some preload but the springs are very soft so it's not a problem opening it up.
11/25/2024 7:42am
That's actually really smart, because I've been wondering how these things don't just feel like a bouncing lead weight, bouncing over and over again ad infinitum. A super tight fit with a malleable metal like brass creates simple mechanical damping for the low speed range. I was picturing really heavy spring rates and no damping.
11/25/2024 12:03pm
Thats cool!, Are there any holes or grooves machined in the piston or chamber wall? A tight fit on the wall might also mean the internal air volume creates a progressive spring rate as well
11/25/2024 12:09pm
That's actually really smart, because I've been wondering how these things don't just feel like a bouncing lead weight, bouncing over and over again ad infinitum...
Great points, as an undamped mass suspended with spring rates for 30-50hz would continue to vibrate the frame after rest.
thresh
San Jose, CA, USA
11/25/2024 1:55pm Edited Date/Time 11/25/2024 1:57pm
So that begs the question - why does damping happen on the "compression" part of the event?
Shouldnt it be more beneficial for it to only happen on the "rebound" ?  I know I'm inventing a poor fork/shock here.
11/25/2024 3:07pm
how Ironic we go to great lengths to have stictionless suspension and yet the countershox relies on stiction for damping.
The big 2 suspension companies were in the wrong game all along it seems.
11/25/2024 4:05pm
brash wrote:
how Ironic we go to great lengths to have stictionless suspension and yet the countershox relies on stiction for damping.The big 2 suspension companies were in...
Stiction in suspension breakaway force is much different.  I have heard from supercross suspension tuners that they have good results from fork fluid that has more friction than other fluids that are more slick.  It gave them a feel they couldn't replicate with shims, pistons or springs
owl-x
Shell Beach, CA, USA
11/26/2024 9:49pm
Dude what did you use to open that thing up? You animal.
11/26/2024 10:11pm
Used his teeth like every other red-blooded American.
tdawg
New York, NY, USA
11/27/2024 12:55am
It looked like it had red loctite holding together, so left it front of a space heater for a while then cracked 'er open with a vice, didn't take much persuasion.
Finkill
5/9/2025 1:37am
Forum regular Jesse Melamed is out at round one of the EDR with what looks a lot like a Rimpact TMD fitted to his race bike, guess he thinks it's good enough to race on, probably some others lurking on bikes that I haven't spotted also. Good luck for the weekend Jesse!
IanP161
Sunderland, GB
5/9/2025 6:03am
Finkill wrote:
Forum regular Jesse Melamed is out at round one of the EDR with what looks a lot like a Rimpact TMD fitted to his race bike...
The Scott DH team are running them also.
I have had one on my bike for a couple of months now.  Initially it felt good, then I felt it was a bit 'chattery' so have gone up to the hard spring to see what difference that makes.  It may have also been the TMD hitting the inside of the steerer so I will check that also
Finkill
5/9/2025 6:11am
IanP161 wrote:
The Scott DH team are running them also.I have had one on my bike for a couple of months now.  Initially it felt good, then I...
Thanks for the insight, be good to hear how you get on with the different springs.
IanP161
Sunderland, GB
5/9/2025 6:16am
I have been riding the same tracks to keep the tests consisten. The chatter I encountered was on one part of the track which was a steep fast chute, the other parts of the track I did not have the same feeling.  Riding on Sunday so will see what the increase to the spring rate does.
5/9/2025 9:56pm
IanP161 wrote:
I have been riding the same tracks to keep the tests consisten. The chatter I encountered was on one part of the track which was a...
I have Rimpact and countershox. With the Rimpact I do find some more noise, but I do like that it’s in the steering tube. Overall the countershox is working better for me on vibration damping and feel to my hands.
5/9/2025 11:19pm
Ronan Dunne running the TMD at the rear wheel in his vlog from May 8th. Interesting to see, for sure!
Screen Shot 2025-05-10 at 1.16.22 AM
IanP161
Sunderland, GB
5/21/2025 7:19am
Still struggling to get along with my Rimpact TMD.  Swapped to the harder springs but still find it really 'chattery'  Going to back to back on the same trail to rule out headset or forks issue.
Noticed in this video https://youtu.be/nYpi-M6LMp8?feature=shared that it looks like Troy is running one.
5/21/2025 5:59pm Edited Date/Time 5/21/2025 6:00pm
IanP161 wrote:
Still struggling to get along with my Rimpact TMD.  Swapped to the harder springs but still find it really 'chattery'  Going to back to back on...
With my riding and bike set up, I thought the lightest spring worked the best.  From most people I’ve spoke to. They are on the lighter spring as well.
I think another thing to remember is that the  aren’t a cure all for chatter. They will work in certain areas, on certain trails reducing, certain frequencies.
IanP161
Sunderland, GB
5/22/2025 2:02am
With my riding and bike set up, I thought the lightest spring worked the best.  From most people I’ve spoke to. They are on the lighter...
Thanks for the advice, I will try the light spring next.  Its one section of trail that the chatter is really noticable
9/3/2025 7:59am
an the TMD in france, did a few back to back runs on Pleney, which is notoriously rough at the end of the season.
With the TMD installed, the bike tracked through the rough corners better, less deflection from the front wheel. Added a chunk of weight (900g) to the underside of the downtube and the bike responded in the same way, also making the bike feel less choppy under brakes.
The racket the TMD makes is quite astonishing, certainly a lot of noise on the big hits. Anyone found the same?
9/3/2025 3:10pm
Sir HC wrote:
an the TMD in france, did a few back to back runs on Pleney, which is notoriously rough at the end of the season.With the TMD...
Are you running the rimpact? Could make sense for the noise, it’s either not perfectly lined up in steering tube and hitting the side or bottoming out. Could try a stiffer spring but then it’s going to change the frequency.  The countershox is self contained and doesn’t bottom out.
9/9/2025 6:01pm
As far as I can tell Jackson Goldstone is no longer using a MD on his bike.
9/9/2025 8:43pm
Looks like CounterShox to me from World Champs
IMG 8118
9/10/2025 12:17am
Are you running the rimpact? Could make sense for the noise, it’s either not perfectly lined up in steering tube and hitting the side or bottoming...
Did check the alignment, and there are no marks on it or inside of the steerer. It only happens on the big square edged hits or repeated braking bumps (morzine). What it wants is a bottom out bumper, winter project...
IanP161
Sunderland, GB
9/10/2025 2:46am
Sir HC wrote:
Did check the alignment, and there are no marks on it or inside of the steerer. It only happens on the big square edged hits or...
I experienced loads of chatter, but no real noise (not at Morzine but in the UK)
9/15/2025 12:43pm
Ronan still on the Seatpost damper
IMG 8151.jpeg?VersionId=KeihOZqyd
Post a reply to: Tuned Mass Dampers and Mountain Bikes
