10/28/2025 5:27pm
HexonJuan wrote:
OK nerds, have a live one for you. Am I nuts thinking it'd be pretty freaking sweet for sus co's to specify what their stock air...
OK nerds, have a live one for you. Am I nuts thinking it'd be pretty freaking sweet for sus co's to specify what their stock air spring volumes are for forks and dampers? I posit after a bit of a lengthy chat with a pal about why the X2 on his V2 Ripmo isn't the greatest choice for the platform and the bike would be better suited with a smaller spring volume, citing the playfulness of my V3 Rip. Bear in mind he's had the bike since new and never got used to the plow feel, preferring a spunkier ride. I thought it'd be sweet if we had access to that info as well as the piston diameters for those of us who like to do the math so we can better understand and show the rate change effects.
So, silly or no?
Yeah it would be pretty sweet if that kind of data was published, along with a few other specs. Would be useful for picking air shocks and deciding when a Float X or X2  is the better choice. And when Rockshox has 3 different types of air can I still can't keep up with exactly which is supposed to do what. You could see roughly what pressure in an X2 gives equivalent sag in a Float X if you swap it out.
I think you might be right the Float X is probably better for a Ripmo V2 though
10/28/2025 6:25pm
So, silly or no?
Yeah it would be pretty sweet if that kind of data was published, along with a few other specs. Would be useful for picking air shocks...
In my ignorance I had assumed, apropos of nothing, that suspension tuners would have developed an heuristic for that by now, e.g. "above a certain leverage ratio (or other characteristic) = Float X2, below it = Float X", or something along those lines, although I'm sure it isn't that simple.
How difficult is it to measure the chamber volumes when it's already open for service?  I imagine filling each chamber with an appropriate incompressible fluid, but I don't know enough about the insides of an air shock to know whether an "appropriate fluid" exists or if they'd tolerate that kind of thing in general.
Evil96
Portogruaro, VE IT
10/28/2025 10:01pm
So, silly or no?
What are your thoughts about the Hover Monocoque?
comatosegi
Portland, OR US
10/29/2025 1:13am
It's a clever idea, but I take a little bit of issue with the claim of it being  "the only air spring capable of duplicating...
It's a clever idea, but I take a little bit of issue with the claim of it being  "the only air spring capable of duplicating a coil fork spring rate from the vary beginning to the end" when the Vorsprung Secus has been around for 5 years
The secus needed to be outside the fork because of the limited air volume inside, so I guess the lower runt uses very low pressures and the negative coil spring is there to regain some kind of compliance after moving the piston upwards and reducing the negative spring volume. The positive chamber looks smaller, (especially with a runt installed) ie progressive so it seems a bit like robbing peter to pay paul?
The main reason I was excited about it is that Diaz managed to do something productive with the lower leg air volume on the Zeb, which...
The main reason I was excited about it is that Diaz managed to do something productive with the lower leg air volume on the Zeb, which I think really brings down the total performance of that chassis. This is based on my best attempt at interpreting the graphic and the copy, which is highly fallible. But yes, it looks like the coil spring on the negative chamber is a necessary evil to fit everything in there and make up for an undersized air negative chamber at full extension.
If it makes the Zeb less progressive and doesn't feel super whack at full extension, that seems like a decent trade off, to me.
I kinda agree that the Secus already addressed these issues.  There is no replacement for displacement, expanding lower and negative volumes in an external device was pretty innovative engineering.
10/29/2025 2:31am
So, silly or no?
boozed wrote:
In my ignorance I had assumed, apropos of nothing, that suspension tuners would have developed an heuristic for that by now, e.g. "above a certain leverage...
Yeah theres definitely some rough guidelines we pick up, but measuring air springs accurately is tricky so a lot of it comes down to rider feedback and trends as much as measuremements. And part of that for me is not being able to 100% confidently measure the full stroke of an air shock accurately across a range of pressures without a way to validate those tests. Each stroke shock and even trunnion and standard eyelets have different volumes so its a big task to collect data on all of them.
Ive tried measuring a few different ways, all are pretty fiddly - you can fill it with oil or degreaser and weigh the shock before & after bit you still need to work our how much was in each chanber. The inside of the eyelets are awkward shapes so cant be directly measured either. It can be done, its just not always worth the amount of time it would take to work it out. Ive been playing with 3d scanning/photogrammetry and there is potential there for measuring things quite accurately though, so ill look at giving that a try for shock volume soon
10/29/2025 2:37am
So, silly or no?
Not too many sorry - we dont really get any intend product down here so have no direct experience with it apart from bouncing on 1 or 2 of their forks and shocks on tourists bikes. They did feel quite impressively smooth for air suspension though! Ive always been a coil fan so havent looked too closely at them otherwise, they seem really nice its just not my cup of tea
10/29/2025 3:18am Edited Date/Time 10/29/2025 3:20am
Yeah theres definitely some rough guidelines we pick up, but measuring air springs accurately is tricky so a lot of it comes down to rider feedback...
3D scanning might work (likely expensive), photogrammetry probably won't work as you need to look very deep into the air chamber to see the shape of it, it's shiny and usually black, so I doubt you'll get any meaningful results from photogrammetry.
3D scanning is much more likely to work as it also projects (in IR) patterns onto the surface plus looks at the object using two cameras and the part has to be covered with something like TiO2 to be nice and matte to prevent reflections. But you're again back to square zero where you have to measure each and every shock option, it will more or less be a throw-away shock as it will be hard to properly clean the TiO2 from all the surfaces, etc.
It's a very expensive endeavour for something that a) is likely something the manufacturers already have and need to develop the platform correctly and b) would be very easy for the manufacturers to share and c) would not give anything away design wise as those who could realistically benefit from it, easily buy competitor products and analyse them (it's VERY hard to imagine the like of Fox, Rock Shox, Suntour and Manitou don't have 3D scnaning, dynos and other equipment in house and can't afford 20 to 30k to investigate competitor products once those come out).cha
FWIW, if data was shared, starting volumes of both positive and negative chambers, piston surface area and equalisation stroke point is what would be needed to fully model the shock for an enthusiast (spring stiffness wise).
10/29/2025 4:33am
3D scanning might work (likely expensive), photogrammetry probably won't work as you need to look very deep into the air chamber to see the shape of...
Possible (but not at all serious) solution: DIY CT scanner
HexonJuan
WI US
10/29/2025 6:27am
So, silly or no?
ntm95 wrote:
I'd say no.Those ratios can be calculated easily enough by a shockwiz, or anyone with a shock pump and a couple minutes.A "spunkier" ride developed through...
I'd say no.
A "spunkier" ride developed through a higher ratio air spring is typically more detrimental to descending performance as a whole. It simply makes the damping more inconsistent.
Can't say as I've ever heard of a ripmo described as a plow, the dw link is typically the opposite of that on any kind of a fast descent with square edged hits. I had a coil on mine, and it still sucked.
Perhaps plow was the wrong term to use. It is decidedly less poppy in ride feel than the V3, much more eager to keep the back end on the ground.
10/29/2025 6:33am
I’ve always been suspicious that changing shock stroke changed the air volume on my X2.
I extended the stroke from 62.5 to 65 and it felt softer even at the same sag (by distance in mm, not by %). I put a volume spacer in and it felt similar to the prior stroke.
ntm95
Lloydminster, AB CA
10/29/2025 8:09am
So, silly or no?
I'd say no.
HexonJuan wrote:
Perhaps plow was the wrong term to use. It is decidedly less poppy in ride feel than the V3, much more eager to keep the back...
Absolutely, if that's what you are after. Even with a coil though, I thought the v2 was plenty "poppy". It's the nature of the dw link and relatively short chainstay. My terrain here in western canada tends to be higher speed stuff though, so I am definitely bent that way in terms of bike setup.
ntm95
Lloydminster, AB CA
10/29/2025 8:26am
I'd agree that it's going down the rabbit hole to actually measure volumes, shaft displacement, piston area, transfer port locations and attempt to extrapolate a curve.
The layman can suss out 90% of what they need by simply calculating compression ratio. But it's all arbitrary in most cases anyways when we are talking about applying this to a trail bike like a ripmo. An x2 is easy enough to tune, throw some volume spacers in it. Add some lsc, you'll be popping around like Jeff KW in no time.
bikelurker
Bilbao, Vizcaya ES
10/29/2025 8:52am
Just a quick question:
What does 'check tune' mean in Rock Shox rear shocks jargon?
10/29/2025 9:15am
ntm95 wrote:
I'd agree that it's going down the rabbit hole to actually measure volumes, shaft displacement, piston area, transfer port locations and attempt to extrapolate a curve.The...
What exactly does the compression ratio give you?
10/29/2025 10:46am
Unrelated-- how do we feel about there Bartlett? There's a good deal on one. My two riding buddies had the MRP Ribbon and both were disappointing to say the least,  but this was years ago.  IDK if MRP has updated their in house forks ever.
It would be nice to swap my 170mm fork to get 190mm with minimal AtC changes
10/29/2025 11:57am
I wouldn't have mentioned photogrammetry if it wasn't something I was already playing with......this was done with a smartphone and a relatively cheap app....that shaft is supposed to be 14.00mm btw
Jadescreenshot.png?VersionId=rhUbkZ6h5jDghIntunCvgWoW75M6z0
10/29/2025 12:00pm
Unrelated-- how do we feel about there Bartlett? There's a good deal on one. My two riding buddies had the MRP Ribbon and both were disappointing...
I can’t speak for the forks themselves but the MRP ramp control cartridge is the real deal 👌🏻
10/29/2025 12:11pm
The check valve that stops oil flowing through the low speed rebound circuit on compression - either a separate small piston or part of the HBO piston in the recent generations. The old super deluxe had a preloaded shims stack but more recent ones normally aren't. Not sure how much difference it makes (I think they mostly use the same arrangement but list it several times anyway in the manual..)
10/29/2025 12:16pm
I’ve always been suspicious that changing shock stroke changed the air volume on my X2. I extended the stroke from 62.5 to 65 and it felt softer...
Yup thats correct, a volume spacer contains about 5.5g of plastic on my scales and a 2.5mm travel spacer is 4.5g so thats near enough that same thing. Thats often been done intentionally, like RS travel spacers were large plastic discs so that they had a little more progression when you reduced the stroke
ntm95
Lloydminster, AB CA
10/29/2025 12:35pm
Average spring curve.
10/29/2025 12:44pm Edited Date/Time 10/29/2025 12:44pm
I wouldn't have mentioned photogrammetry if it wasn't something I was already playing with......this was done with a smartphone and a relatively cheap app....that shaft is...
This is very different to trying to scan the insides of an aircan (or aircan). The problem is the flare right above the outer sealhead if it's present. And the outside technically doesn't help as you don't know the wall thickness.
Unless you cut it in half.
10/29/2025 12:44pm
How?
10/29/2025 2:04pm
What app is that? All the phone based ones I've messed with have been pretty bad so I gave up on them.
As far as figuring out spring curves, it would probably be easier and more accurate to measure the shock's actual spring curve and then fit it to an equation to approximate the curve at any pressure. If you know shock stroke used and initial positive pressure, you only have to back out initial negative pressure, negative piston area, positive piston area, initial negative air volume, and positive air volume. Pick five data points and that's a system of equations you can solve.
ntm95
Lloydminster, AB CA
10/29/2025 2:29pm
How?
Nothing fancy, or particularly useful. Simply gives you an idea of spring rate progression vs a linear rate progression.
In the context of the OP, they're looking for "pop", as in a higher progression rate/compression ratio. That data might be useful to them in so far as to compare an x2 to something like a float x, in order to isolate spring performance vs having more valving in the x2. Case in point, ibis uses extremely light valving for the most part, I suspect in the OP's case, the tune is the major factor creating a difference between the two bikes, not necessarily the air spring volumes. Likely the v3 ripmo is on an ibis tune, and the v2 is an off the shelf mid tune x2. Comparing the two compression ratios would give him an idea. Of course the sensible thing is to simply compare the tunes.
10/29/2025 4:19pm
So, silly or no?
I think that information is useful, but in a limited sense. Positive air spring volume is one number that's part of several other ratios that determine spring rate, like positive to negative volume ratio (e.g. MegNeg) and positive volume to air shaft displacement ratio (e.g. new Boxxer with a smaller seal head, requiring way higher pressures to create a more linear feel). You could be looking at two shocks with similar positive spring volumes that had very different spring rate curves depending on some of those other factors.
10/29/2025 4:47pm
This is very different to trying to scan the insides of an aircan (or aircan). The problem is the flare right above the outer sealhead if...
Yeah the air can is definitely tough - but at least it is easy to model and revolve in cad and scanned data can supplement the measurements you are able to get manually. Like you mention, the dimple position is super important so it would depend on how well you can determine that measurement too. Either way you would be needing manual drawing and measurements to get a final result, and its mostly inside the eyelet which has weird shapes you can't easily measure or draw with much accuracy. But if you are trying to measure things completely by hand and needing to fudge a bunch of the difficult parts then the end result isn't going to be useful
I'm not saying for sure this is a useful way to do things yet - but I've been playing around with it for a while since I thought it could be handy to make sensor mounts and check clearances in different frames. If I find enough use I might invest in an actual 3d scanner, but I have been dialling in a photogrammetry workflow and fairly impressed with what it can achieve - took some trial and error but there is potential there IMO for what I do. I hadn't really intended it to be used for detailed measurements like this but the accuracy has been better than I expected so I'm exploring it for now.
I'm not gonna lie - a big factor is simply the fact that I'm an adult with ADHD and unsupervised access to a workshop all day - I play around with all kinds of things that may become useful...or might not....but its fun figuring it out
@CascadeComponents - I'm using Kiri engine app and fairly pleased - I tried Polycam and thought that had better results but I ran in to some issues where I paid for the subscription but it didn't let me actually use it and kept getting errors. They fixed it eventually but its more expensive and that kind of made me reluctant to try again. After some persistence I found homemade scanning spray of baby powder & IPA plus a turntable and good lighting (I made 3d printed diffusers to go on cheap desk lamps) has been quite reliable.
I wasn't going to go on but I did actually get a scan from this monarch R which might bring it back on topic......the scan of the positive chamber gave a volume of 79.97cc (actually the threaded part of the air can needs to be subtracted but its a start), and the inside of the air can wasn't much good as expected but the outside is enough that I could model a useable part from it.
20251030 0805542025-10-30 10-582025-10-30 12-06
10/29/2025 4:56pm
What app is that? All the phone based ones I've messed with have been pretty bad so I gave up on them.As far as figuring out...
yeah that is possible - my dyno can only measure 50mm stroke though, plus it is a little awkward to fill a shock to a pressure, equalise the chambers and then mount in the machine (without damaging the shock if the dyno isn't perfectly at BDC), so ideally I would combine that data with accurate volume measurements to fill in the missing pieces. This is also why I haven't really gone too far down the road of measuring air springs, as useful as it might be. A proper spring rater would help - but I'm not sure its useful enough to justify the cost for me personally
10/29/2025 11:24pm Edited Date/Time 10/29/2025 11:24pm
How?
ntm95 wrote:
Nothing fancy, or particularly useful. Simply gives you an idea of spring rate progression vs a linear rate progression.In the context of the OP, they're looking...
The compression ratio would be a very good indicator of shock performance if it only had the positive chamber. With the negative chamber volume, piston area and equalisation point playing a role it doesn't give much usable data by it's own.
The shockwiz measures the compression ratio to know roughly where in the travel it sits by measuring the pressure. The keyword is roughly though.
HexonJuan
WI US
10/30/2025 6:07am
Anti-dive device for the fork...I wonder how this rides. It has to add some harshness under braking, and I'm sure the way the bike reacts under...
Anti-dive device for the fork...I wonder how this rides. It has to add some harshness under braking, and I'm sure the way the bike reacts under braking would take some getting used to as well, but still an interesting experiment:
Giving me U.S.E vibes:
Took way too long to find an image of this!
HexonJuan
WI US
10/30/2025 6:21am
So, silly or no?
I think that information is useful, but in a limited sense. Positive air spring volume is one number that's part of several other ratios that determine...
Right, piston surface area absolutely has a large effect on the system. You can't just take a high volume can and stuff it with spacers to get an equal volume to a smaller can and expect it to behave the same way due to that. That's what my pal with the X2 tried to do but it still didn't give the desired effect.
