120-130mm forks
veg wizard
NorCal, CA, USA
I'm building up a hardtail for light duty trail and XC use (downcountry, if you will) and can't really decide which direction to go for the fork. All of my modern front suspension experience has been with forks in the 150-170mm range and I don't know what to prioritize. Is this just a case of simple performance to weight tradeoff? Will I be unhappy with anything less than a lowered 36 or Lyrik? I am 185 pounds geared up. This bike won't see big hits but I'm capable of riding like a moron on any bicycle. I also value home serviceability.
I'm considering all of the usual candidates and would love to hear experiences. From most capable to lightest duty it seems like:
  • Pike Ultimate
  • 36 SL
  • 34SL/SID (non SL)
Any good options from other brands? It seems like Rockshox and Fox dominate this space.
9/9/2026 9:51am
I've been very happy with regular chassis Fox 34's with Grip X and Grip X2 dampers on my "down country" hardtail and short travel bikes. I never really feel the need for for a chassis upgrade to 36. If you go Fox, avoid the Fit4 damper as it is not usefully adjustable, under damped and "Unfit4 aggressive riding". Grip X seems to be the sweet spot of having lockout and good damping. Just need to keep an eye on where the HSC knob is at as a couple of clicks makes a big difference and it's easily displaced from an accidental brush up or bump. I drew a line where I like it set for quick reference after using the lockout.
veg wizard
NorCal, CA, USA
9/9/2026 10:03am
On Fox's website it seems like they're only advertising the 34 in "SL" with the "GRIP SL" damper, something I'd never even heard of (obviously I don't pay attention to forks like this. But Jenson and others have a 34 SL with a Grip X damper. Any experience with the SL damper vs the X?
9/9/2026 10:09am
Could not be happier with my 130mm Rockshox Pike Ultimate. (Charger 3.1 damper). I have had the past 2 generations of Pike and this one is a massive step up in performance and ride feel. The Charger 2 damper of the previous gen fork was good, but the chassis was really the draw back. The newest version is incredible! Extremely tunable but very simple both in service and in setup! I just wish they still had the silver lowers!!!
bigbrett
Salt Lake City, UT, USA
9/9/2026 7:57pm Edited Date/Time 9/9/2026 7:57pm
Huge recommendation for the manitou mattoc pro. I love mine. Haven’t tried the latest pike or 34SL but it is far superior to the previous generations of both those forks IMO.
9/10/2026 12:54am
One of the Best forks I rode in recent times was the DT SWISS F535 One with the CoilPair super sensitive and do through the travel dependent damping it’s always high in the travel what is super comfortabel on Hardtails. Love that fork so much I sold my Öhlins RXF36. That F535 is available from 120-160mm. Not the lightest but perfomance over weight.
veg wizard
NorCal, CA, USA
9/10/2026 9:16am
Those are some interesting options. I've never seen a DT Swiss fork in the wild. How is home serviceability?
onxx
Laguna Beach, CA, USA
9/10/2026 11:32am
What travel length are you going for? There isn't really overlap between a SID 35 and a lyrik, is there?
I think it depends on how sensitive you are and where you are riding, what the terrain is like.
Going from a sid 35, 34sl, to a pike is a noticeable benefit in stiffness, overall control, and smoothness/predictability.  That extra pound in the fork does beef it up quite a bit. But if you're riding like soft, loamy trails, it's not going to matter nearly as much versus riding bumpy AF hardpack.
Regardless, its going to be way different than a 170mm fork, even if you downstroke a lyrik or 36.
9/10/2026 5:09pm
The 34SL is a really great fork with GripX.
The chassis is fairly stiff, and the weight is really impressive. It really suits xc-light trail, but it’s not the same as a stiffer trail fork.
If you wanted stiffer you have lots of options, the 36SL is going to be really amazing if you want to point and shoot. The Helm is a great fork for this too.
I was on the fence between 34SL and 36SL when sorting my singlespeed to be more racy (had a helm coil). I went 34SL, and it’s great. I occasionally wish I had the 36, but that’s normally when I’m making bad life decisions.
Big Dos
9/10/2026 8:44pm
Hey mate. I weigh about the same as you and have a Grip2 34 on my hardtail. It's fine from my experience, I don't notice much flex or anything negative. The bike itself limits how hard you can smash into stuff compared to a dual sus bike so going a bit lighter on the fork isn't a drama. On the other hand I have a Lyrik on my SJ Evo and I don't think the chassis is stiff enough for me.
AgrAde
., BV
9/11/2026 1:27am
I think the main question is, are you being realistic about not riding the bike hard?
I realised when I tried to build some nice light efficient bikes that I can't switch off the thing in my brain telling me to find the limit. Which is why my hardtail has drop bars to slow me down and a pike because the drop bars didn't really help. And my 125mm trail bike has a DVO Diamond 36 which feels to me maybe a little burlier than a lyrik. No regrets with either, if you are used to riding bigger bikes and not caring, and think you might carry that through to the hardtail, you'll probably prefer something stout.
If you're able to chill, or you will be riding it in a different place with low-key trails and don't expect to cross over to the trails that you ride on your big bike, then lighter forks made for the purpose will feel great.
veg wizard
NorCal, CA, USA
9/11/2026 10:25am Edited Date/Time 9/11/2026 10:27am
AgrAde wrote:
I think the main question is, are you being realistic about not riding the bike hard?I realised when I tried to build some nice light efficient...
That’s a good question and one I’m struggling to figure out. I will definitely be avoiding bigger stuff on this bike but still like riding reasonably fast. This hardtail will compliment a 160-travel enduro bike and is replacing a long-travel hardtail with a 160mm fork that ended up being my de facto XC bike, and just wasn’t really perfect for that use case. I think I can definitely step down from the 36 on terms of stiffness and composure, especially at shorter travel, I’m just not sure how far to go.
veg wizard
NorCal, CA, USA
9/11/2026 10:28am
The 34SL is a really great fork with GripX. The chassis is fairly stiff, and the weight is really impressive. It really suits xc-light trail, but it’s...
Thanks! I had a first gen Helm for a while and it was pretty solid, if overdamped. Had mentally classed it as a step above what I’m looking for now but maybe I should consider it. The internal travel adjustment is really nice.
aaronufl
Poulsbo, WA, USA
9/11/2026 3:42pm
veg wizard wrote:
Thanks! I had a first gen Helm for a while and it was pretty solid, if overdamped. Had mentally classed it as a step above what...
I enjoyed my Helm MKII but developed a CSU creak right outside of the warranty window. My experience with Cane Creek customer service has been great, but their suspension products do seem a bit finicky and require more frequent maintenance.
LePigPen
Harbor City, CA, USA
9/11/2026 4:59pm
If I downfork my bike, it's definitely getting a 36 SL. Very intrigued by the weight and performance balance of that fork. Big fellaz like trail riding tooo
9/12/2026 3:21am
We did a 140mm fork test comparing 34 to 36 a while ago that seems relevant to this discussion: https://www.vitalmtb.com/videos/member/trail-bike-fork-selection-34-vs-36
TLDR: the Fox 36SL is certainly stiffer than the 34, but it also rides significantly harsher. I could never quite get it to the point where I was happy with the comfort/support tradeoff (I always ended up with a slightly less forgiving fork over small, square-edge trails). For me, the Öhlins RXF36 was the clear winner (as an older guy, I appreciate just how comfortable that fork is able to remain, even when running a fair bit more damping and higher spring pressure), while my son (the other tester in this review) prefers the 34 - he wants less comfort and more direct feedback for his trail bikes.
9/12/2026 4:57am
Really hard to beat the dollar per performance you get for a used Charger 3/3.1 Pike or Lyrik. Very easy to do a lowers service upon arrival and you might have to anyway if you want to change the travel. I managed to score a Charger 3.1 Lyrik Ultimate in green for $300 on PB recently.
9/12/2026 5:49am
Depending on how much you care about weight, I still reckon a 36 with a Smashpot is the single best right side up fork I’ve ever ridden. Just buttery, supportive, controlled, and the HBO is glorious on a hardtail. I remember hitting things super hard and the hbo would kick in like the hand of almighty god to hold me up.
veg wizard
NorCal, CA, USA
9/12/2026 8:03am
We did a 140mm fork test comparing 34 to 36 a while ago that seems relevant to this discussion: https://www.vitalmtb.com/videos/member/trail-bike-fork-selection-34-vs-36TLDR: the Fox 36SL is certainly...
This is really great, thank you
onxx
9/12/2026 10:36am
Keep in mind that test is with the old 34, which was quite good. The new 34SL looks like a step cast. In the past the step cast 34 had crazy spring ramp because of the reduced volume of the lower legs. I'm sure they worked on that with the new one, they said as much, but it could still be a noticeable difference between the forks. Just something to look into/demo/whatever.
280driver
Richmond, VA, USA
9/12/2026 11:20am
I really like the 130mm 34SL with Grip X   Not flexy at all and excellent dampening.  Mine came with some air in lowers that caused it to ramp up at the end of the stroke.  Once I bled that out, I’ve had no complaints.
9/12/2026 11:48am
Manitou Mattock Pro. Easily maintained at home, easy to do damper changes, stiff enough for a trail bike and I bet lighter than all those other options.
I find the best way to limit myself from taking the smaller bike over its head is tires. Put on some fast rolling and slightly sketchy tires and you won’t be tempted to drop into the loose and gnarly stuff, even with burly suspension. Bonus is being shocked with how much faster it is when climbing compared with the big bike. Resist the urge to accidentally make a heavy, slow trail bike!
Big Dos
9/12/2026 3:25pm Edited Date/Time 9/12/2026 3:25pm
^ yeah this re tyres. Couldn't agree more
9/12/2026 3:34pm
If it matters, a 34SL is 200g lighter than a mattoc.
The new SL is not a step cast design.
amanitas
Bellingham, WA, USA
9/12/2026 5:37pm
Also having this debate. I don’t have first hand experience, but The Radavist review said the 36SL sounded like Macho Man Randy Savage inhaling repeatedly. I had an MRP Ribbon that sounded the same and while it rode fine I couldn’t stand the constant noise.
9/14/2026 7:05am
280driver wrote:
I really like the 130mm 34SL with Grip X   Not flexy at all and excellent dampening.  Mine came with some air in lowers that caused...
Zip tie seal poke lower equalization is part of my preride checks for any non-vented FOX lowers. Air in the spring and tires, air out of the lowers.
There really should be vent ports in the smaller chassis forks IMO but the smalll zip tie poke works well and does not seem to cause damage if done carefully.
280driver
Richmond, VA, USA
9/14/2026 7:14am
Zip tie seal poke lower equalization is part of my preride checks for any non-vented FOX lowers. Air in the spring and tires, air out of...
Any concern about damaging the seals?
9/14/2026 7:42am
Sort of, as long as you use the tip of a small nylon zip tie without burrs and pinch/pull the seal away a bit with your fingers it should be fine. Never really had a problem with damage. Frequently have a problem with the fork feeling harsh and then feeling like new after a lower seal burp. Kind of crazy how much it effects the ride feel.
280driver
Richmond, VA, USA
9/14/2026 7:56am
Sort of, as long as you use the tip of a small nylon zip tie without burrs and pinch/pull the seal away a bit with your...
Cool.  Agree with you on how harsh it can make the fork feel.  How often do you to the bleed?
9/14/2026 8:08am
That’s….kinda insane. Not that you do it, but that it’s a required step to make the very expensive piece of equipment work properly. This should not be a thing. You should not have to do a non-approved and potentially seal ruining procedure on the regular.
Post a reply to: 120-130mm forks
