Let's Build the Most Expensive TRAIL Bike Ever
Edited Date/Time 5/21/2018 2:31pm
Time to build the most expensive custom trail bike.
This time I'm not starting the build at all, so it's all up to you guys to find the goods.
The DH build came out kinda crazy, so let's lay down some rules for the trail bike build:
1. Find a post up a component or frame you think is the most expensive w/ a LINK showing MSRP. Including the
link saves me a lot of time so I'm not tracking down the cost. All prices will be USD.
2. Please check that whatever component you're proposing fits the current build. Shock size, bb, etc...
3. Post only components that are on the build list below. If I left something obvious out, like say tires, feel free to
point that out. This is just so we don't get people submitting gold leaf plated fenders and diamond top-caps.
4. Only components that are likely to be found on a professional's bike will be considered... ie, no bar ends or
crazy road bike saddles // cranks. True trail bike components only.
Here's the evolving build list so far:
Frame: Kingdom The Switch----------------------------------$4,182
Fork: X-Fusion Revel HLR-------------------------------------$1,766
Shock: PUSH ElevenSix (includes Ti Spring)-------------$1,200
Cranks:-------------------------------------------------------------?
Chainring:--------------------------------------------------------- ?
Bottom Bracket:--------------------------------------------------?
Headset:-----------------------------------------------------------?
Wheelset:Alchemist Enduro 27.5----------------------------$2,950
Derailleur:----------------------------------------------------------?
Cassette:-----------------------------------------------------------?
Chain:---------------------------------------------------------------?
Shifter:--------------------------------------------------------------?
Brakes: Tune Kill Hill AM Brakes----------------------------$893
Rotors: X-Rotor Carbon/Ti 180mm------------------------- $176x2
Bar: Thomson Ti Riser Bar (780mm)-----------------------$390
Stem: ENVE Carbon 50mm-----------------------------------$270
Grips:----------------------------------------------------------------?
Post:---------------------------------------------------------------- ?
Saddle:-------------------------------------------------------------?
Pedals: Reset Racing Pedal 3 Ti---------------------------- $669
Tires-----------------------------------------------------------------?
Chainguide:-------------------------------------------------------?
Total: $12,674
How high can we get this baller bike build to get?
Go!
2/5/2016 10:39am
Btw pinner £2500 no shock.
2/5/2016 12:31pm
Gnarnia420 wrote:
Thanks Gnarnia420, frame and fork added to the build. Off to a good start.
2/5/2016 1:14pm Edited Date/Time 2/5/2016 1:14pm
POST LINKS to product claims please.
2/5/2016 2:34pm
Woooo dawgy! Added. Anyone know if any other shocks will fit on the yeti and work properly? I know it'll come up so we should figure...
Woooo dawgy! Added.
Anyone know if any other shocks will fit on the yeti and work properly? I know it'll come up so we should figure that out now.
"The SB6c uses a 2.5” stroke, 8.5” eye-to-eye shock."
As per their FAQ.
2/5/2016 2:46pm
Woooo dawgy! Added.
As per their FAQ.
I was speaking in regard to shock tune w/ the Switch Infinity setup, but that too is answered in the next question in their FAQ.
"Can I put a coil shock on my SB6c?
Yes. The SB6C is designed for use with air or coil shocks."
I think there's a certain high-dollar new shock that just came out that'll fit the bill.
2/5/2016 2:48pm Edited Date/Time 2/5/2016 2:51pm
I was speaking in regard to shock tune w/ the Switch Infinity setup, but that too is answered in the next question in their FAQ. "Can...
http://www.pushindustries.com/collections/rear-shock/products/elevensix…
Oh, you mean one of these (Push Elevensix)? It's listed on their compatible frames. 1200 bucks
2/5/2016 3:18pm Edited Date/Time 2/5/2016 3:24pm
Ohlins RXF 34 Fork according to Vitals review is 1150$ and Santa Cruz Nomad frame with a Vivid R2C Air according to their website is 3662€ (roughly 4085$)
Sesame Seed
Farmington, CT, USA
2/5/2016 3:19pm
Ti-Spring Performance Shock Spring Bearing $36.50
2/5/2016 3:36pm
Ohlins RXF 34 Fork according to Vitals review is 1150$ and Santa Cruz Nomad frame with a Vivid R2C Air according to their website is 3662€...
Santa Cruz's website "Carbon CC Frame & Rockshox Vivid Air R2C: $3249 USD"
2/5/2016 3:40pm
Damn, those import taxes sure are pretty big...
2/5/2016 3:46pm
That'd be the one. Added.
2/5/2016 3:58pm Edited Date/Time 2/5/2016 4:13pm
Ohlins RXF 34 fork is 1150$ according to Vitals review and FOX 36 Talas 160 Factory RC2 is also 1150$ on JensonUSA.
Enve M60 pair of wheels with Chris King hubs goes for 2748$ according to their website.
2/5/2016 5:01pm
Ohlins RXF 34 fork is 1150$ according to Vitals review and FOX 36 Talas 160 Factory RC2 is also 1150$ on [url=http://www.jensonusa.com/Forks/Fox-36-Talas-160-Factory-RC2-275-2016?cs=Black]JensonUSA[/url]. Enve M60 pair of...
Added the Fox.
If you can post links to the rims/hubs w/ MSRP I'll add them. I need individual prices for each component.
2/5/2016 7:25pm
How about a custom ENVE build? M60 HV on DT Swiss 180 hubs, plus a bearing upgrade from Ceramic Speed: total cost $3750, according to WheelBuilder.com.
(I don't think I can share specific builds from their site, but if you plug in all the same options you should see the same prices. $1665 front and $2085 rear. )
WaffleStomp
Everett, WA, USA
2/5/2016 7:52pm Edited Date/Time 2/5/2016 7:53pm
Jesus- this is starting all wrong. 3500 is the best you can do for a frame? Please.
BMC trailfox is 4999 for the frame and shock alone.
https://www.bikeexchange.com/a/mountain-bike-frames/bmc/ca/san-marcos/t…
But that's just for a plebeian air shock, and we want primo coil, right?
Fantaman
NL
2/5/2016 9:31pm Edited Date/Time 2/5/2016 9:37pm
Reset Racing Pedal 3 Ti = $669,54
http://reset-racing.de/product/pedal3/
Tune Kill Hill brakeset with no rotors = $1026,63
https://r2-bike.com/TUNE-Disc-Brake-Kill-Hill-Set
2x CarbonTi X Rotor Steel/Carbon 180mm = $407,30
https://r2-bike.com/CARBON-TI-Disc-Rotor-X-Rotor-SteelCarbon-2-180-mm
Prices are converted to US Dollars
PeteB
La Mesa, CA, USA
2/5/2016 10:02pm
RWC Needle bearings run about $100 a pair, SixC cranks are $500ish msrp.
Greg J
2/5/2016 11:51pm Edited Date/Time 2/6/2016 2:11am
Tune Blackfoot xx1 Cranks $914 USD not including chainring
These bought in Aus would be closer to $2000- due to the Giant island tax.
Not sure if Tune components are considered crazy stuff that will not appear on a pro's bike but Trek is using their bits on their top end road bikes so i'd say that they are in the mass market now.
http://www.tune.de/en/produkt/cranks/black-foot
http://www.bike24.com/p280008.html
Post a reply to: Let's Build the Most Expensive TRAIL Bike Ever
