How Much Reach is Too Much Reach?
2/13/2019 1:37pm
Last year my bike had 500mm reatch, was nice and all but my core would gett tyerd on longer +10min runs, so when my frame cracked i went down to a 485 reatch and feels alot more balanced.
Both with a 40mm stem.
Im on a G16-GPI so CS are long at 445.
77SA is steep, but moved my seat back a tad on the rails so its not so far forward.
And im around 183cm tal.
For me i think a 475-480 reatch with a 50mm stem, 440 CS and a 76 SA would be spot on.
The way i see it, YT have probably nailed the cizing on ther new Jeffsy. I shuld be on a large cize bike, and ther number match almost perfect.
But if everyone just could stop making seattubes so damn long we culd all just pick and shose more easly. An XL bike shuld never have more then 460mm seat tubes!
Craw
2/13/2019 1:47pm
Last year my bike had 500mm reatch, was nice and all but my core would gett tyerd on longer +10min runs, so when my frame cracked...
That doesn't make any sense. I have a 36" inseam, which is a fair length for my height. I have a 590mm seat tube on my XL G16 and I have to run my 185mm Revive 6mm beyond the minimum insertion line to get proper extension. A 560mm seat tube wouldn't work. There is really only one longer post. So as much as I would also prefer shorter seat tubes for XLs they actually don't work, at least until dropper seatpost brands start offering longer static lengths (which would be awesome).
Unless you're talking DH and slope bikes in which case make them as short as you want.
2/13/2019 2:19pm
Craw wrote:
That doesn't make any sense. I have a 36" inseam, which is a fair length for my height. I have a 590mm seat tube on my...
Agree in that case.
For me it was more the other way around, had to almost slam my 150mm e-13 dropper post in my old medium frame with a 460 seat tube.
The smal i have now is a 440mm so now i consider getting a 185mm dropper instead..
Longer post options would be the best tho.
Shorter ST and lower standovers is always good.
GetSoMesy
Santa Barbara, CA, USA
2/13/2019 2:20pm
36" inseam + 1" for shoe and pedal = 939mm
939-175(crank)= 764mm 30"
764-560 (seat tube)= 204mm 8"
revive 185 min exposed while extended is 226.7mm + seat = ~250mm seat stack.
so 204mm left and your seat takes up 250mm more, that would mean your seattube is too long.
i bet you pedal with your toes down, run short cranks, wear padded shorts and or roll your hips side to side while pedaling, cause it sounds like youve added a lot of stack to your pedal stroke.
the other way:
inseam + 1/2 Pedal + shoe sole = seat top to pedal spindle length (S-P)
S-P minus Crank arm length = seat to bb length (S-BCool
S-BB minus Seat tube length (STL) = amount of space that needs filled by exposed post, dropper travel, and seat thickness(~40mm)
revive 185 is 334 max travel extension minimum inserted. plus 40mm saddle stack height =374
200mm dropper is 260+40mm seat so 300mm stack
940mmSeat to pedal length, minus 374 seat and post max stack, minus 175 crank equals 391MM MINIMUM SEAT TUBE LENGTH. (this is assuming a seattube that protrudes directly from bb where effective and actual STA are the same)
Zaf
2/13/2019 4:43pm
Reach is a stupid number that doesn't properly represent the actual length of a cockpit. I think Chris Porter said it best, "It'd be helpful if people were shaped like a set-square".
My old SB-66c in XL had a 455mm reach on it. My current bike, a Large Nicolai Ion G15 GPI, is sitting at 515mm. However I had to switch the Nicolai from a 35mm to a 50mm stem to make my cockpit feel comfortable and "uncramped" again whereas the SB66c I was on the limits of fitting the XL with the stumpy little 35mm (I stand at 187cm for reference).
It will give you a reasonable comparison of how a cockpit feels if every other number you're comparing between bikes is the same, but it otherwise doesn't properly represent the cockpit.
One of the distances that is almost identical on all my bikes is that between the middle of my saddle clamp and the middle of my handlebar, which makes a whole lot of sense.
2/13/2019 6:52pm
crisotop wrote:
I'm about to decide the frame size for my next bike and found some interesting points in that discussion. I'm 175cm (5'9) tall with a 82cm...
I'm about to decide the frame size for my next bike and found some interesting points in that discussion. I'm 175cm (5'9) tall with a 82cm (32') inseam and 184cm (6'05) wingspan, which means I've got fairly long arms & legs for my height.
My current trailbike has a 432mm reach paired with a 50mm stem and feels smallish for me and my regular riding terrain. The downhill bike feels spot on with 445mm and a 45mm stem, although it's hard to compare because of the different front- and rear-centre measurement. A significantly slacker head angle and/or longer chainstays will change the ride characteristics even if the riders "space" between the bb and handlebars stays roughly the same.
I've ridden a slightly larger bike (460+40) for a couple of weeks and was struggling in corners to keep the front weighted and ride a smooth arc (no matter if it was a berm, or open corner).
Anybody else in the same height department with monkey arms and a clear preference for longer bikes? Do I just have to re-learn cornering and adapt my riding style to a longer frame?
I am also 5'9", but different proportions (long torso, 5'9" wingspan, short legs). That said, I think I can provide a bit of insight for you.
I ride a Transition Sentinel with a 450mm reach and a degree head angle. Initially, when I demo'd the bike, I had the same issue as you, I struggled to weight the front end in corners. I wasn't initially sure if it was caused by the slack HA or the longer reach, or something else (brake angle, etc). This was with a 40mm stem. However, as soon as I swapped to a 50mm, I instantly felt central between the axles and had more cornering confidence than on any other bike (literally from the first carve I made in the parking lot). The difference was night and day. I went from feeling as if I had to fight to constantly pull my weight forwards to weight the front wheel, to feeling as if weighting it was perfectly natural and effortless. In my view, minor differences in stem length make a huge difference in the riders weight distribution, and therefore in how a bike corners.
Similarly, I am currently demoing a large Santa Cruz Nomad (460mm reach, 65 degree HA). Initially, I struggled with weighting the front end until I removed all the spacers from under the stem. As soon as I lowered the bars, I got that same neutral, confident feeling in the corners, where I didn't have to shift my body around to weight the bike properly, meaning the bike felt very easy to corner and didn't require a whole lot of body english.
My takeaway? Weight distribution on the bike is the most critical factor in how a bike corners. For me, it was impossible to achieve that neutral, balanced cornering feel before I got on bikes with ~450mm reaches. The reach seems to be far and away the most important factor here. That said, even bikes that fit me with appropriate reach numbers don't corner well until I am able to find that neutral feeling where my weight is between the axles. Stem length, brake lever angle, and bar height all play a role here, as does suspension set up.
I would recommend trying that 460mm reach bike again, but going to a 50mm stem. It might sound like a minor change, but for me it made a major difference. Lots of people seem to think stem length is just a tool to fine tune reach numbers, but for me 10mm in stem length seems to have a way bigger impact on ride characteristics than 10mm of reach. It is likely you don't need to "re-learn cornering" or adapt your riding style to the bike so much as you need to get the bike to adapt to you.The 460/40mm bike you tried probably requires a more forward biased riding position with the shorter stem, so to get a similar feel, go for a longer stem and try and ensure other factors like bar height are as similar as possible.
Hope that helps!
2/13/2019 7:25pm
I read somewhere that Sam Hill just uses a BB to Bar reach measurement for his setup. Can anyone verify ?
GetSoMesy
2/13/2019 7:59pm
no way in hell one of the fastest guys ever on a mtb JUST bases fit for ALL HIS BIKES on the same measurment!!
GetSoMesy
2/13/2019 8:05pm Edited Date/Time 2/13/2019 8:36pm
Zaf wrote:
Reach is a stupid number that doesn't properly represent the actual length of a cockpit. I think Chris Porter said it best, "It'd be helpful if...
same seat to bar only makes sense if you only ride on kind of bike! for example downhill or dj bikes are typically going to have a much shorter saddle to handlebar distance for agility or rearward position, compared to something like an xc bike where the rider wants to be laid over chest down for aerodynamics and power. the seat position should be the same relative to the crank on all performance bicycles, although bikes such as all mountain bikes should present a 73 STA while climbing, sagged to with incline % counting against STA
reach is one important isolated piece of geometric angle to discern fit. all parts the same ie same stem bar etc. variable and/or numerical reach paired with, headtube height, stack, axle to crown can tell you a lot about a hypothetical bikes weight distribution and cockpit feel.
Axle to crown + headtube length - sag @ headtube angle = will give you a horizontal length, probably somewhere between 220mm(xc) to 320mm (29er dh) this horizontal distance, plus reach and fork offset, is your front center length! something like ~730mm. your front center divided by rear center (450mm) will give you a % of weight distribution standing on pedals without weight on hands on flat ground ie, 730/450=1.62 = 162% weight on rear wheel. this number will be smaller with bike pitched downhill, on brakes, leaning forward & weighting handlebars. the % weight on rear wheel number will be bigger when climbing, accelerating, leaning/ hanging back, frequently hitting all weight on rear wheel when you wheelie, loop out, or get in the back seat cause your a scared squid and loose control of the front wheel. personally im shooting for 150-160% weight on rear whee on flat ground, based on my experience on many many bikes.
you cant have traction without ground pressure, no matter the tire. if your bike is a xl process 153 with 425 chainstays 510 reach 66ha and 834 fc youll have a 196% as much weight on the rear as the front... that sucks. your gonna have to work hard to get that front wheel to lead the way! thats why they put the motor in motorcycles, sportbikes and dirtbikes alike, as close to the front and low as possible, to weight the front wheel!
UpDawg
MX
2/13/2019 10:10pm
This might be a reach but I think getsomesy just set a new vital essay record.
GetSoMesy
2/14/2019 12:05am
what are your body proportions, build, years riding and best race result?
GetSoMesy
2/14/2019 12:15am
sorry to be longwinded but mtb fit is a very variable due to terrain, intent, and biodiversity, with constant kinesioligic parameters; which mus be addressed as a whole rather than such grossly monochromatic lone number.
2/14/2019 4:38am
Im around 183cm and 82-85kg with a monky index of 185 or so and normal long legs. Been racing for 20 years and have a few podiums from my younger years..
Consider myself a fairly good and fast rider.
Why your asking?
Fred_Pop
2/14/2019 6:10am
Reach is a useful number to know how your bike will fit when you are standing on the pedals rather than sitting on the saddle. A short reach bike with a slack seat angle can feel the same as a long reach bike with a steep seat angle when the rider is seated. I personally don't like the seated and standing positions to feel too different which is why I prefer long reach bikes, +500mm. I feel a cramped standing position makes it necessary to ride off the back which isn't ideal.
Fred_Pop
2/14/2019 6:18am
I also prefer shorter seat tubes as I like to run my saddle as low as possible. I actually cut my frame seat tube down from 480mm to 450mm. Ideally I'd like a 430mm seat post.
I currently have a 150mm KS dropper which is 440mm long (the shortest out there as far as I know) but at minimum insertion the saddle isn't high enough. I end up running a quick release seat collar to compensate. I would love to get a 180 or even 200mm post but then the post is way to long to insert into my interrupted seat tube.
2/14/2019 4:36pm
Fred_Pop wrote:
I also prefer shorter seat tubes as I like to run my saddle as low as possible. I actually cut my frame seat tube down from...
Have you looked at BikeYokes post? They have one with 185mm dropp.
Its 226.7mm to rails when slamed.
SharpieMTB
Boiling Springs, PA, USA
2/15/2019 5:57am
Reach tends to be a little extreme when i can't reach the bars no more.
rtclark
Vail, CO, USA
2/15/2019 7:27am
I've noticed as reach becomes longer, it becomes harder to compresss the rear suspension because you're weight is being pulled away from the pivot point.
Fred_Pop
2/15/2019 11:07am
At 485mm overall length it is too long. When slammed the saddle height would be even higher than my current KS (which I already fine annoying). I need to get me a Geometron with a straight seat tube to solve my current problem. 430mm seat tube with a 200mm dropper would be sweet!
2/16/2019 7:37am
Agree. On my last bike with 500mm reatch i had to work hard to gett enoth higth when popping of roots and smaler thing. It was damn fast, but feelt like to mutch at times.
2/16/2019 7:38am Edited Date/Time 2/16/2019 7:39am
2/18/2019 4:58am
taldfind wrote:
I have an unproven theory that the proper reach for a person on a given category and style of bike can be found by an arm...
I have an unproven theory that the proper reach for a person on a given category and style of bike can be found by an arm measurement and some math. This theory is based loosely on snowboard sizing, where you Measure to a certain points on your body to find the lengths of board that will fit you. This method is similar, and takes into account changes in the head angle.
Measure from inside the armpit to the tip of the longest finger. For me this is about 720mm. Then take the average head angle for the category of bike you want to ride, i.e., 67 or 66 for a trail bike, and divide that by 100. I Then multiply the arm measurement by one hundredth of the head angle, which for me looks like 720X0.66=475.2. If I want a more stable bike I add one percent of the arm measurement to the reach, in my case that is about 7mm, I would take that 7mm off the reach for a more agile or climb oriented bike. This process will also work for XC, Enduro, Park, and DH bikes. It struggles with DJ bikes, unless you take 10 degrees off the standard head angle before dividing by one hundred, i.e., (69-10)/100=0.59, this gets me much closer to reach numbers seen on DJ and Slopestyle bikes, especially if they have multiple sizes for the given model.
Anyway, I have not yet tested it by riding bikes on the trails with reach numbers close to what this method tells me I should ride, to see if i really like it better than the 430-440 reach numbers my current bikes have. But it does get me close to the reach numbers many manufactures are recommending to people of my height with their latest bikes, or in Kona's case, what they have become red to me for a few years now, so it may have some merit.
I tried your theory with my measurements and I can't see how it would work for me! Glad you found something that works in theory for you, but I come out with a reach of 315 mm! I am by no means a pro - very recreational here! What I find makes the most difference to me is the rise of the stem for comfort. I can comfortably ride things with a reach from 390-420 depending on how high the bars fall and the type of riding being done. I mainly do XC and just started getting into single track
3/12/2019 12:03pm Edited Date/Time 3/12/2019 1:32pm
So, while I have made some posts (on first page), I sadly haven't read the majority of this thread since making my last post (over a year ago!). Maybe I will get to it after posting this, but I just want to share my findings. I've been drinking the long reach Kool-Aid. And I’m loving it.
Starting off, I have gone from - to:
-2015 Giant Reign 1, Large - Bird Aeris AM9, XL
- 27,5" - 29"
- 458 mm reach - 522 mm reach
- 1217 mm wheelbase - 1292 mm wheelbase
- 160 mm travel - 150 mm travel
- 125 mm seatpost travel - 170 mm seatpost travel (it's important)
- 50 mm stem - 40 mm stem
Me:
-190 cm (or 6'3" in the weird units that don't make sense)
-91 cm inseam
-I think a bit over 190 cm of arm span
Yes, I am tall. Yes, this puts things i will be saying below into a different context and changes some stuff, massively. Yes, I’ve been saying steep actual seat tubes are a must on the internets for a while now. And yes, this is true for the XL squad and less so for the M/L squad (given the way virtual seat tube angles are measured, people with an inseam around 10 cm over the stack height get the advertised seat position). This is because the height of the seat we XL guys need and the amount of it getting over the stack height, which changes the actual seat position massively.
Giant facts:
-Yes, the large Giant was too small. But:
.-my previous bike was also a (too small) Large (I found the L Giant comfortable at the time of purchase)
.-I tried an XL Reign before buying my L and I didn't like the cockpit (less so than the L)
.-It took a while before I got to the conclusion that I don't like slack seat tubes and/or the L Giant
.-riding the Bird for two weeks now going back (after preparing it to sell) I still don't like the cockpit of the Giant.
-The seatpost is a limiting factor descending because the seat gets in the way being dropped down. I figured this out in the past year and wasn't prepared to swap it out given I was about to buy a new bike.
Now, like I mentioned, the difference in reach between the two bikes is a massive 64 mm. Given the opening post in this thread, this is about three frame sizes. Granted, accounting for the stems this difference does get taken down by 10 mm. But what do you think the difference in cockpit length, from centre of the bar to the point where the seatpost pierces the seat (which is what I’ve been saying matters) is? Less than 30 mm but definitely more than 25 mm. So where did the massive 64 mm in reach difference go? Taken out by the seat tube angle, the actual one.
Seat tube angles: from Giant - to Bird:
Virtual: 73° - 76°
Actual: 69° - 71° (Giant's is taken off a press photo, could be even slacker comparing the two bikes. Bird's is official)
Effective: 72,07° - 75,02° -> at seat height! (calculated given above two angles, stack height and needed seat height)
This is what over 800 mm of seat height gives you, it's a territory most designers don't think about (I can understand them, given the volume of XL frames) and most people don't experience. Those who do, mostly don't care or don't know what they are missing.
Bird - going up:
Why does the effective seat tube angle at seat height matter? Climbing performance. The bike climbs like a champ. I had problems and I never actually succeeded in clearing a relatively long (for the grade), very steep, rocky and rooty climb with the Giant. I cleared the same climb with not a single problem, issue or wobble, never got hung up or had a skid of the rear tyre, in my first try on the Bird. And I tried many times with the Giant, looking for the optimal line (took the final, most optimal line with the Bird), tried it in multiple surface conditions, but always got hung up on stuff, lost traction, etc. Granted, I took three pauses to catch my breath (lacking in cardio fitness), but this was the same as on the Giant, I also took pauses there, even more of them if anything.
The grade? Over 30 % average grade on the steep part, ~15 % average over the 1,7 km of climbing with a height difference of 244 m. Nothing world class, but definitely not easy.
Now, my shape was largely the same in all cases. I had a new Aggressor on the rear of the Bird with a not new, but definitely not worn out High Roller II on the Giant in all cases. The tires are then are not a factor here. A benefit for the Bird was that I knew the optimal line, but I attempted the same line multiple times with the Giant.
Technically a benefit of the Bird is the fact that it's a 29er. The rollover performance is insane. But the main factor? The seat tube angle. I was relaxed in an upright position much longer and had to move forwards on the seat and bend over the bars much later than on the Giant to weigh the front, when the climb got really steep. While the 10 mm longer chainstay has an effect here as well, the effect of it is much less than the seat tube angle. I was pedalling comfortably, unlike on the Giant, where I felt like I was kicking the doors down (pedalling 'forwards', not down) because of the slacker angle.
Bird - going down:
Descents? You’d think the extra 75 mm of wheelbase would show itself. That the reach would be too long. That the bike would be lazy with the 29er wheels. Only the last part was true. Only on the first ride. I even excitedly told how smooth, calm and grippy the bike is but that it's lazy going into the air to a 29er fan, who's a friend of mine. He was surprised. I took the laziness comment back after another ride or two. Since then, I’ve been popping roots and rocks and other small fun, even popping it right before and into turns, which I didn't do before. I rail turns (berms or off camber nasty stuff) confidently where I was awkward before. With like a flick of a switch, overnight (by changing the bike) I’m much faster, more confident, have a better position on the bike. A friend of mine was amazed at my 'progress', which is caused by the bike. A lower seat is most definitely the main factor here, WideTrail tires probably account for quite some confidence by providing more grip and giving tons of confidence. But...
Regardless, the bike just motors down the trail. It's calm, confidence inspiring, I feel completely at one with it. I fit in it. I've actually missed my PB/KOM on a local trail by only 4 second on my third ride with the bike while passing a hiker (slowly and carefully on the high speed, loose section), going for the slow, but fun route (instead of the faster Strava line) and generally just cruising about, learning the reactions of the bike, evading the effects of the forestry on the lower part of the trail, etc. The KOM was set 2 months before in prime grip conditions while clearing my head from the stress of work both going up and going down, where I was in a perfect state of flow and aggressiveness, genuinely enjoying myself while setting the KOM.
Tight turns where you have to front pivot (I still can't do that properly anyways) or jack-knife yourself? It's about the same as with the Giant or maybe even less awkward. Maybe due to an increased confidence from the new bike. Generally the three sizes larger reach is NOT an issue and is not something I noticed. The same goes for the 75 mm longer wheelbase.
64 mm more reach is not too much reach:
So, 64 mm longer reach, a much steeper seat tube angle and I’m loving it. Would I go longer or steeper? Steeper definitely, longer I don't know. Maybe. I was looking at Pole's Machine, but it was around 1000 € too expensive to justify the purchase, regardless of me having the money to spare or not. But having finally ridden a bike with a steep seat tube angle, finally drinking the Kool-Aid I’ve been spewing on the internet for so long, I can confidently with no doubts say that this is it.
I am fully aware of the fact that I am in a special, small part of the population, but given this fact, there are 6 frames I would be thinking about buying if I had to buy a new bike. Given that I’m a 29er convert (and I was playing the 'I want a fun, poppy bike, not a freight train' record before trying the 29er, plus I can't be helped with my size), realistically there are 5 frames I would buy. that I would buy. These are:
-Bird Aeris AM9 (29")
-RAAW Madonna (29" - the minus is a relatively short cockpit, even more so given the steeper seat tube angle than my Bird)
-Nicolai G1 (in 29" of course - but there is no water bottle, so a minus here. It can be bodged together though)
-Pole Machine (€€€...)
-Pole Stamina (€€€€ and I kind of prefer the looks of the Machine. Plus 180 mm of travel could be a bit much?)
-Custom geometry MDE Damper (29" of course - there is also no water bottle option)
The sixth would be Bird's Aeris AM145, which is a 27,5" bike. The seat tube on the 145 is actually even steeper than on the AM9, by about half a degree for my height. I would have to take a closer look at Yeti's SB150 regarding the actual seat tube angle, but it does also look a bit short in the cockpit area, though longer than the RAAW.
Conclusion:
Given the above list, I’d go for the AM9 again. It's right on the border regarding the seat tube angle and I’d prefer a steeper one, but it ticks all the other boxes, mostly the price one (and their online configurator with an excellent choice of parts, given my preferences). Given unlimited finances or 'you can get anything you want', I'd go for one of the machined Poles. Third option would be a custom geometry MDE Damper 29", that also has an actual, effective, seat tube angle of around 76°. But I want the option of the water bottle.
And, to clarify again, I’m talking about XL frames for riders of around and mostly above 190 cm. This is an area I’m most familiar with and feel the issues of the most. If you're thinking I’m talking shit, I’ve had three other people tall enough for an XL frame (one of them is riding a Large Meta V4) commenting how nice the Bird feels in a parking lot test. That it's not big at all. Another (not so tall) friend contemplating the same AM9, but deciding between their Medium-long and a Large tried mine and instantly decided to go Large.
Steeper seat tube with a much longer reach is better, at least for me. But this is a perfect example showing how utterly useless the reach number is for the feel of the bike.
andyjr77
3/17/2019 1:29am
Alex1 wrote:
Is a longer reach addressed to all levels of riders? I certainly don't think so. I believe that a longer reach suits a taller rider (or...
I believe that a longer reach suits a taller rider (or one with a longer tosro than inseam) or a physically stronger person than average (stronger back/core).
As bikes get better, and riders get stronger and more aggressive, it is unavoidable to match the geometry to their needs.
You raise a couple of really good points here!
I'm 5'9" with long body/arms and short legs (29" inseam) and have found my Stumpjumper Evo S3 fits better than anything before it (with a 35mm stem fitted). But I've also found that while I'm faster by a good margin (up and down), my upper body has definitely felt more tired, and I've always been strong after years of competitive swimming.
A few weeks of a new kettlebell programme and I seem to be improving, but it's a consideration many wouldn't think of. A dramatically longer bike needs more "work" or else you can feel like a passenger..
3/27/2019 6:26am
Back in 2014 I mainly rode a Ragley Bagger 288 which I really liked. The only thing I didn't like was the way I sat on it. It felt short. So I ended up with a 70mm stem (760mm bars). I liked the length, but not the handling.
So I convinced myself that I need a longer bike to sit comfortably, using a 50mm stem.
I did a lot of measuring and calculated that I should have a frame with 460mm of reach. So I got a custom hardtail frame built with that exact reach number. I loved it, rode it a lot, but ended up not liking it anymore.
After that I got a Production Privee Oka. I wanted a size large, but got an XL frame, as the previous owner did not know exactly what frame size he had bought...I had to chop off 20mm of the seat tube to fit my dropper post and convinced myself that this is exactly what I needed. It was not.
I ended up buying a Production Privee Shan size large, which has around 30mm less reach. And I finally can ride it the way I want to ride a hardtail.
Besides that I got a 2015 Mondraker Foxy XR (carbon frame) with 483mm of reach and it's pretty good overall. Feels appropriate on 90% of trails for me.
Apparently there is the theory that you can go with 30-40mm more reach on full-sus bikes as the reach gets shorter with sag. And it's the other way round on hardtails. They get longer with reach.
I did not read this whole thread, so sorry if this has been discussed before.
3/28/2019 8:27am
So, while I have made some posts (on first page), I sadly haven't read the majority of this thread since making my last post (over a...
- 27,5" - 29"
Me:
-91 cm inseam
Giant facts:
Virtual: 73° - 76°
Bird - going up:
Bird - going down:
Conclusion:
Good post. I'm 188cm & ride an XL RAAW Madonna.
I've been on a 29er for a few years now, my other bike is still current, which is a 19.5" Trek Fuel EX 9.9. prior to that, funnily enough I was on a Reign Advanced 0 for years.
Reason I went for a big 29er was, i've raced enduro & regional DH on the same bike for probably the last 7 or 8 years now (last DH bike was an IH Sunday). My poor Fuel was taking an absolute battering, I had long shocked it so it was just shy of 140mm rear travel & ran a 150mm fork, it was surprisingly good but the frame was too light for what I was putting it through & it cracked. Trek replaced it & i've since built it back up to a 26lb trail bike, for which is absolutely rips at. Seriously it might be the best bike i've ever owned in it's current setup.
Sizing wise, it's probably whats considered about average these days, but it is considerably slacker than Trek advertise. it's still my go to bike for 90% of my riding & will still be used for local enduro races where the RAAW is just far too big & cumbersome.
With the RAAW I run a 170mm fork on it & a 65mm stroke rear shock which takes it to just over 170mm travel on the back. It's not light, and when it's lent up with other bikes, it almost looks like a comedy thing, it's so big. Reach between the two is quite a bit different but due to the steep SA the saddle to bars numbers are almost identical. Much like the recent PB review, it does climb well for its size, but that's the geometry doing it's thing - I get a lot less front wheel lift & wandering than I do with the Fuel, but that makes up for it by being ~8lbs lighter.
They are very different bikes though. The Fuel is light, nimble, playful & a bit of a handful when it gets fast & rough. It's an easy bike to ride. The Madonna by comparison, is an absolute monster truck & you really need the terrain & speed to make it work. The long stays & low BB can make it hard to throw it around, but like everything, it's a trade off for outright speed & stability - it just wants to go hard & fast everywhere.
If I could only have one bike, it would be no contest - the Fuel wins hands down for the vast majority of my riding, and does double as a surprisingly competent race bike for the UK. But, i'm racing a few EWS's again this year, doing a month in Whistler & a few weeks in Finale Ligure later in the season & for those, the RAAW makes perfect sense.
For me, i've found the limit, I can't imagine I would ever need something bigger. I would prefer it to be lighter, but i'll trade reliability for a bit of extra weight, given it's intended use.
7/9/2019 12:52pm
Would you use reach judge fit between a trail bike and a DH bike? For example, the reach of the newly released 2020 demo in S2 to S4 sizing seems down right tiny right? Reach on the S3 sizing is almost the same as most medium trail bikes at 445mm. S2 Evo 27.5 is 465mm reach and S2 Demo is 425mm! I'm 170cm.
Skerby
Ellensburg, WA, USA
7/30/2019 9:18am
Has anyone downsized for back pain reasons? Im 5'10" riding an old XL patrol, 1245 WB, reasonably short ETT. I love it but my back is messed up. I have been riding this bike for about a year, stepped up from a large frame, and I can go really really fast on it but my back is killing me.
I go to phys therapy and I do a lot of stretches/workouts but still not really sure what I need to do / what actually works. I've had back pain since i was around 16, almost 30 now. I have my seat slammed forward and I roll the bars back in a 40mm stem to get them close as possible for climbing.
My goal is to ride everyday, I've been trying to achieve this for 3 years now, average ride is 1000-3000 ft. Last week my back finally felt good, like didnt hurt at all, I hit the bikes so hard and rode perfectly for 7 straight days. Come day 8, Im inexplicably destroyed and I haven't been able to really ride for 3 days, bummed! Im in the best shape of my life and not overweight, Im sure i have massive muscle imbalances though.
TL;DR: Will a shorter frame make my back hurt less often? It's hard to ride with back pain, it tightens everything and limits my movement.
