What does “flickable” mean to you?
seanfisseli
Santa Cruz, CA, USA
Edited Date/Time 2/22/2026 10:28pm
I’m trying to figure out what this flickable thing is. People in the chainstay thread are pissed at me but I just like to address assumptions that I have made (especially if others seem to make those assumptions as well…)
I get what “front wheel grip” is and I get what “easier to manual” means, but Flickable is not only not quantifiable, it’s not even qualified by a description of what/how flickable works or what it feels like to ride a “flickable bike.”
There are a lot of variables that seem like they could contribute to flickability so I’m working to undertake 1) what exactly people mean and 2) where flickability actually originates.
Thanks!
sethimus
2/23/2026 3:58am
circus bike
2/23/2026 5:14am Edited Date/Time 2/23/2026 5:15am
The Scandinavian Flick was used in mid 2000s freeride video segments with Canadians “flicking” their rear wheels any which way but straight while bombing a massive scree field for the boys.
2/23/2026 5:42am
There’s a real art to making a good paper football.
In honesty For me flickable is riding a smaller, lighter, active bike for maneuverability versus a larger bike for stability, grip, durability.  Really meant to jib and play versus shred and push the limits of speed/magnitude.
pinkrobe
Revelstoke, BC, CA
2/23/2026 8:18am
@seanfisseli I can't lie, I have no idea what "flickable" means either. If it's associated with the Scandi Flick, then it seems to indicate pointing the bike wide on a corner, and then aggressively turning to the inside in order to make the turn. You'll get some rear wheel drift as the bike rotates in the opposite direction to the desired turn [i.e. if it's a right turn, the bike rotates slightly to the left]. I'd imagine you'd need to transfer a bunch of weight to the front wheel in order to have any chance of completing the turn.
I think I have done this unintentionally a few times when I came over a rise on the trail and it didn't go in the direction I thought it did. Pure panic, but it felt cool. I have definitely done it in a car and whilst riding a snowboard.
If we extend this to what makes a bike more "flickable", I'd assume reduced swing weight would be a key factor. Shorter rear center, lighter rear end. 🤷
seanfisseli
Santa Cruz, CA, USA
2/23/2026 8:25am
Could it be that “flickable” is a positive way of saying “unstable”?
PhilNZ
Christchurch, NZ
2/23/2026 9:19am
pinkrobe wrote:
@seanfisseli I can't lie, I have no idea what "flickable" means either. If it's associated with the Scandi Flick, then it seems to indicate pointing the...
Shorter rear centre (chain stay) means heavier weight bias over the rear.
Long rear centre will induce naturally occuring oversteer more often than short. Try two of the above in fast flat gravel turns and the difference is immediate.
Flickable comes from the idea that a bikes rear end is more easily manipulated around tight obstacles. With short chain stays, the rear wheel is closer to the riders body so you have more leverage over the back of the bike. In theory it becomes easier, or more intuitive to maneuver the rear around, think of a ski with bindings mounted true centre vs downhill mounting position slightly further back. With the rear closer to underneath you its more inclined to follow what you do with your hips fairly naturally, whereas too much rear can feel like a lot to control in a turn.
Digit Bikes
Irvine, CA, USA
2/23/2026 9:50am Edited Date/Time 2/23/2026 9:53am
Yes. All bike handling exists on a frequency spectrum - even riding in a straight line (because bikes don't even ride in a straight line, they link a series of oscillating falls and corrective turns).
Google's dictionary definition of flick is "a sudden sharp movement". It's AI answer says ""Flickable" describes something that is light, agile, and easy to maneuver or move with a quick, snapping motion. It most commonly refers to motorcycles or vehicles that change lean angles rapidly"
seanfisseli
Santa Cruz, CA, USA
2/23/2026 9:53am
PhilNZ wrote:
Shorter rear centre (chain stay) means heavier weight bias over the rear.Long rear centre will induce naturally occuring oversteer more often than short. Try two of...
So is the rear tire sliding around during these flickable moments initiated from the hips? This is slow speed stuff we’re talking about right? Does flickable mean that we’re literally flicking the rear end around rocks or stumps or something? (Edit: applying what I wrote below to this, I’m wondering if 29ers require some amount of energy from the hips to keep the rear wheel on the inside of the turn. One of the reasons I like mullet bikes is that the rear tire more naturally falls into line in the turns. A flickable bike would enable a rider to manually keep that rear wheel inside on the turns, right?)
I’m confused by what you mean about long chainstays being hard to control in a turn… there is less weight on the rear axle and so it’s really easy to slide them as needed. But lengthening the CS on my bike made cornering so much more intuitive…
Ok wait I’m starting to bring this into focus… if you have a shorter rear end, then input to the bars will have more leverage over the back end of the bike. So turning the bars or “flicking” them will have a more dramatic feeling at the back end of the bike. At first, I thought that the comments about the Scandi flick  a little off base but now I wonder if there is a sensation prior to scandi flicking that originates at the bars, but doesn’t culminate in a full-blown rear tire slide.
I’ve never really enjoyed riding through the  maybe that is why the sensation of flickable never really came through for me. I have always loved riding through the feed and so I mostly notice when my long chain days have improved front wheel grip through corners. Someone who has spent a lot of time riding through their hands, which is what long reach short chain stay bikes require, will immediately notice a longer change day because inputs to the bars, feel a lot slower at the back of the bike.
pinkrobe
Revelstoke, BC, CA
2/23/2026 9:56am
This makes sense. Cheers! 🍻
Buckets Up
Hancock, MI, USA
2/23/2026 10:21am Edited Date/Time 2/23/2026 10:22am
Flick-ability could likely be definable along a spectrum based on the amount of input force needed to change the direction of the bike. How this direction change is defined or quantified would be situation dependent and further define what is flick-ability for each person. However, the concept remains the same. If your goal is to perform a moto-whip in the air, a bike that takes 10N of force to throw the back end sideways would be more flick-able than a bike that takes 100N of force.
You could then assess what variables on the bike affect that required force, i.e., wheel size/mass and gyroscopic effects, chain stay length 😉 and moment of inertia about the bike/rider center of mass and whip axis, etc, etc.
Bottom line, I think a more flick-able bike takes less force to change the bike's direction. How that is applied and where a person assigns value to that characteristic is highly variable and personal preference.
seanfisseli
Santa Cruz, CA, USA
2/23/2026 10:48am
Buckets Up wrote:
Flick-ability could likely be definable along a spectrum based on the amount of input force needed to change the direction of the bike. How this direction...
So you don’t think there are literally “flicking” events in riding?
Buckets Up
Hancock, MI, USA
2/23/2026 11:03am
I think “flick-able” and “flick-ability” are broad terms that get applied to a lot of situations.
Yes, it could be applied when performing a “scandi-flick” cornering maneuver. It could also be applied to folding a table-top out of a quarter pipe at the skatepark or a moto-whip on a fest size jump.
I think most people unconsciously use it as synonym for maneuverable which is ultimately just as ambiguous.
That’s why I think you define “flick-able” as the force required to move the bike’s position. Then each rider can define what task or part of riding to apply that to. It could be cornering or it could be jumping but at least it gives you a jumping off point and allows you to make comparisons between two bikes.
Maybe you are interested in having a “flick-able” bike for riding slower speed janky single-track. One could then look at the type of maneuvers that occur in that riding and start to dissect which bike variables play the biggest role and select from there.
The hard part is that “flick-able” will never apply the a fixed type of maneuver or riding on single type of trail style, thus it will always maintain some level of ambiguity.
seanfisseli
Santa Cruz, CA, USA
2/23/2026 11:12am
I agree with you except so many people use it to describe why short chainstays are better: the impart flickability to the bike, where the inverse is that longer stays make the bike “not flickable.” And people don’t say “more flickable” or “less flickable.” The implication is that it’s flickable or it’s not. It has the ability to be flicked or it’s stable. So I’m trying to understand why so many comments about bikes are so binary in this regard. We say things like “easier to manual” or “harder to manual” but flickable seems like it’s in this other category…
Buckets Up
Hancock, MI, USA
2/23/2026 11:20am
I agree with you except so many people use it to describe why short chainstays are better: the impart flickability to the bike, where the inverse...
I think the use you describe is possibly some weird  artifact of a couple threads here on Vital.
I’ve read a lot of the posts you’re referring to and agree it’s been the modus operandi recently.
However, in my own life and groups of riding friends it’s always been used more how I described. Really used when comparing two bikes, i.e., I liked the Trek Fuel more than the Raaw Jibb because it felt more “flick-able” on Trail A.
My own experience isn’t too helpful here now though I suppose. Hope you can work out a satisfactory answer! Cheers
yeahboiwahoo
Christchurch, NZ
2/23/2026 11:27am
Do you mean less stable? Please don't use absolutes like unstable.
2/23/2026 12:34pm
this was 6 years ago, this "new definition of flickable" may not apply, but i think it still does : )
seanfisseli
Santa Cruz, CA, USA
2/23/2026 2:09pm
Buckets Up wrote:
I think the use you describe is possibly some weird  artifact of a couple threads here on Vital.I’ve read a lot of the posts you’re referring...
I think there is some valuable insight there. I am sad that my asking clarifying questions has been so infuriating for everyone!
2/23/2026 3:56pm
Jasper's riding is as close to a textbook definition as one can get.
PhilNZ
Christchurch, NZ
2/23/2026 4:00pm Edited Date/Time 2/23/2026 4:06pm
So is the rear tire sliding around during these flickable moments initiated from the hips? This is slow speed stuff we’re talking about right? Does flickable...
When I say that long chainstays can feel like “a lot to turn,” I’m using colloquial language based on how they are often described by non‑Cahal believers. What I actually mean is slightly more specific.
If we treat the head tube as a pivot point and assume identical front centres, then comparing two bikes: one with a short rear centre and one with a long rear centre, the input force required at the pedal or bottom bracket to rotate the bike about that pivot is greater with the longer rear centre than with the shorter one.
Consider a scenario where rider input induces rear‑wheel loss of traction. When attempting to counteract the forces acting on the rear wheel, less energy is required with a shorter rear centre than with a longer one, because the lever arm acting about the pivot is shorter.
A bike is a complex system with many interacting variables and forces, as Buckets Up explained. To me “whipping” or “flicking” a bike, whether endo turns, in the air, or through corners, are all fundamentally variations of a lever rotating about a pivot, whether that pivot is the head tube or a point on the ground etc
Additionally, consider the same bike offered with two rear‑centre lengths. In a situation where the rider passes an obstacle and must initiate a turn immediately afterward, if both bikes are the same perpendicular distance from the obstacle, the longer‑rear‑centre bike must travel farther past the obstacle before turning to avoid a collision. This is just a simple explainer of the classic long bike versus short bike manoeuvrability argument, but is applicable with two identical bikes with long vs short rearends. Of course it doesn't account for the arguably superior control offered by the longer rear.
seanfisseli
Santa Cruz, CA, USA
2/23/2026 5:13pm
PhilNZ wrote:
When I say that long chainstays can feel like “a lot to turn,” I’m using colloquial language based on how they are often described by non‑Cahal...
Ok I really like the idea that on short chainstay bikes the head tube is considered the pivot point. I think that for me I don’t ride a bike swinging off of the back, pivoting around the head tube. I’m sure that if I did I would find myself noticing “flickability.” I find that the BB is the pivot point for my riding and so long chainstays dont really change my “flicks” all that much.
 as far as I understand it people liked the little bikes from 10-15 years ago but those bikes were inherently unstable and threw people over the bars constantly. We made the bikes longer lower and slacker, but they lost their applicable quality when the front end got longer. It seems like the short chain day thing was a combination of trying to minimize the negative impacts of the moved to 29 inch rear wheels as well as the change to longer lower slacker geometry.
I remember hearing about all of these Enduro guys switching to a  that was a size smaller than recommended by the manufacturers and I just thought that they could go faster on smaller bikes, but I think it just further emphasizes the flickable nature of a Bike. This whole flickable research project is based on trying to assess whether or not we could just size down a lot of these bikes to appease the people looking for flickable. If the front ends are really long now, and the rear ends are starting to grow maybe we can size the whole bike down a little and find a happy medium for people.
seanfisseli
Santa Cruz, CA, USA
2/23/2026 5:14pm
is this riding that much harder with a chain stay that’s 15 mm longer?
PhilNZ
Christchurch, NZ
2/23/2026 5:19pm
The answer has to be no. Its all personal preference, what you're comfortable with and that which you are accustomed to.
seanfisseli
Santa Cruz, CA, USA
2/23/2026 6:40pm
I think we used to call that feeling “twitchy” but marketing people got ahold of it and decided “flickable” could sell those bikes
Buckets Up
Hancock, MI, USA
2/23/2026 7:05pm Edited Date/Time 2/23/2026 7:07pm
I was going to make a statement on this. Haha
I actually think ‘twitchy’ might be attributes of ‘flickable’ gone too far. It’s all a continuum.
I think of bmx bikes. I can’t ride the modern street frames because their HTAs are too steep and CS are too short. These bikes are ‘twitchy’ to me. For the bmx I do ride, the frames I prefer are considered hogs by modern riders.
I do think highly skilled riders can overcome deficiencies in stability and tracking better than average riders and thus can consider other aspects of handling such as ‘flickability’ more. Basically what is ‘twitchy or negative’ to me is ‘flickable or positive’ to someone better.
As an example, many pros ride frames with sub 13” rear ends and 75.5 degree HTAs. They boost these bikes and hit large street features at high speeds. I would be so sketched even rolling into some of these features on their bikes. They are willing to compromise some stability for other attributes they prefer, which could probably be classified as ‘flickable’ to them.
Now I’m not commenting on anyone here and their riding ability at all, but, in MTB I’d bet there is some analogy. Some individuals who prefer longer CS do so because they ‘need’ the extra stability. Others who may be more skilled prefer shorter CS because it lets them perform certain maneuvers better and they can deal with the negatives that show up elsewhere in handling easy enough.
It’s fun to discuss all this, but we all need to realize it’s a bit pedantic and there is no one right answer.
And for reference, both sides would probably laugh at my bikes current geo and component selection, but I enjoy it immensely.
2/23/2026 7:33pm
The term “flickable” was first used back in the 80s to characterize roadracing or sport bikes that could quickly transition cornering directions. It was in the 80s that engineering, manufacturing, and tire technology improved to the point that roadracing bikes, especially GP machines could be ridden with sudden extreme force of input without the bike trying to spit the rider off. This was accomplished with ultra-rigid frames, steep head angles, and well damped suspension.  This tech trickled down to street bikes and soon bikes like the Kawasaki GPz-550 were deemed flickable.
The true test was a near violent transition from full lean in one direction to full lean in another in as little time and space as possible. Soon larger more powerful bikes also became “flickable”.
Of course the term can mean other things now, but that was the original application of the term to two wheels.
seanfisseli
Santa Cruz, CA, USA
2/23/2026 10:26pm
Buckets Up wrote:
I was going to make a statement on this. HahaI actually think ‘twitchy’ might be attributes of ‘flickable’ gone too far. It’s all a continuum.I think...
I don’t think Jackson Goldstone is compensating for lack of skill… I know that’s not exactly how far you would take your statement but I think that the majority of people talking about Flickable as a positive trait see themselves as better than the average rider for being able to ride bikes that are inherently unstable.
I also don’t even really care that much what pros ride because pros 15 yeas ago were riding geo that we would NEVER ride today, so what is “acceptable” or even loved at any given moment really is just a pile of shit waiting to be improved upon from the future’s perspective.
fartsack
咸興市, KP
2/24/2026 12:35am
jibberish BS
2/24/2026 7:36am
Yes.  But there is also another factor in maneuverability.  Which can be a lot of fun.  And is even more of a factor for shorter and/or less skilled riders.  I have a throttle and a spire both in medium and I’m pretty sure the throttle is some 70-90mm shorter in wheelbase and is much lower to the ground.  Sure I can’t get close to the traction I can on my spire but I can maneuver that throttle anyway I want to.  Where as I’m stuck in a very neutral riding position on the spire or I’m going to eat a tire in my butt.  Also no rear suspension and an extremely stiff fork means the bike is far more reactive.  Again less traction but more control of the inputs on the bike.  Especially at the medium speeds those more traditional mtb geo bikes excel at versus a more contemporary geometry.
seanfisseli
Santa Cruz, CA, USA
2/24/2026 7:59am
Ok so new question: what makes a bike Flickable?
Rob25001
Hamilton, NZ
2/24/2026 11:02am
Flickable is another BS term used only by mtb dorks. Another term is poppy. No other sport that uses suspension would even have that in their vocabulary. Suspension is supposed to keep you glued to the ground for speed and poppy will kill you.
Post a reply to: What does “flickable” mean to you?
