What does “flickable” mean to you?
seanfisseli
Santa Cruz, CA, USA
2/24/2026 11:18am
Ok so new question: what makes a bike Flickable?
Why the hell is this getting downvoted. I guess maybe I worded this wrong: I meant to ask something like “what design features make a bike flickable?” Is it just wheelbase? Is there a range of geo that you’d call flickable?
storm.racing
Silverton, CO, USA
2/24/2026 11:30am Edited Date/Time 2/24/2026 11:31am
Why the hell is this getting downvoted. I guess maybe I worded this wrong: I meant to ask something like “what design features make a bike...
I mean thats a fair question. there are SO MANY variables we can change to alter the ride characteristics. Id be curious what someone would say about the playfulness of a bike if we were to lets say, increase CS, increase stack a lot, and raise the BB a fair amount. Look at the lets say a medium V10.8 and its F/R ratio and geometry numbers and that bike is considered by most a more playful DH bike than most. Case in point- Jackson Goldstone.
That sucker is only a handful of MM shorter in CS than my XL 29 V10.7 in Long CS! Yet.... it works as a very playful, flickable(idk why that word and phrase is abrasive to me but so be it haha) etc bike. so.... there's just so dang much to the big picture to look at. That is at least what I look at as an XL human and wanting a properly proportioned XL bike that I can still set up to have certain handling characteristics that I am after
seanfisseli
Santa Cruz, CA, USA
2/24/2026 12:05pm
I mean thats a fair question. there are SO MANY variables we can change to alter the ride characteristics. Id be curious what someone would say...
Exactly. If long cs’s make a bike less flickable what can we also change to get flickability back? I think stack is a big one, as it gives us back the leverage that we lost when lengthening the stays. BB is another interesting area. We lowered BBs to get stability but if we are gaining stability back when we are increasing chainstay length then maybe we have room to raise BBs again?!?
I’m curious what other people think.
2/24/2026 5:32pm
Despite the downvotes, I can appreciate your questions on this, as they are inquisitive and are interesting to think about.
People complaining about terms like poppy and playful make wonder why they ride bikes at all. Don’t get me wrong, there’s the challenge aspect for plenty of us, but isn’t riding supposed to also be about having fun? Or did you buy your $5k+ bike just as a form of conspicuous consumption?
Also poppy is not solely a metric of mountain biking. Many snowboard companies actually grade their decks on how poppy they are. Skateboard companies too have experimented with different construction techniques and shapes all with the intent of more pop.
Gator
Saint Paul, MN, USA
2/24/2026 8:05pm
Rob25001 wrote:
Flickable is another BS term used only by mtb dorks. Another term is poppy. No other sport that uses suspension would even have that in their...
Flickable is another BS term used only by mtb dorks. Another term is poppy. No other sport that uses suspension would even have that in their vocabulary. Suspension is supposed to keep you glued to the ground for speed and poppy will kill you.
We use the term in Motocross, and it applies to the ease/quickness with which one can maneuver the bike, while in motion, from one attack position to another, while moving forward and retaining control.
For moto - Some say flick-ability is weight related, and some say the rider triangle is the key, and others say it's engine size or weight distribution, or center mass or weight bias and of course these are accurate, but not all, the variables change - introduce a new one and others may be eliminated, example would be to enlarge the rear sprocket a tooth and shorten the length from axle to countershaft and it changes the suspension tuning, the shift points, the response in corners etc .
IMO, for a bicycle - it's rider triangle - if your bike is dialed, suspension set for your weight and skill AND cockpit set for your size/reach/seat to pedal etc - it's going to "feel" flickable as it "puts" you in position and creates good balance while riding and retains that regardless of speed or conditions giving the pilot confidence -
incorrect tire pressure can affect flick-ability -
You'll know it when it happens - you'll feel like you can do anything on your bike, it's so flick-able.
My opinion.
2/25/2026 7:55pm Edited Date/Time 2/25/2026 7:56pm
I think this is a great valid question. Here's my two cents on how to make a bike flickable/playful/poppy/unstable (four words that mean basically the same thing in MTCool :
1. Shorter chainstays. This has been beaten to death.
2. Higher BB. As others have said, your bike is more stable front to back when your feet are below the axles, and less stable when your feet are above them.
3. Smaller wheels. A mullet is more "flickable" than a 29" bike, and a dual 650 bike is going to be more unstable than a mullet bike. 26" bikes are king here. Remy Morton even has that insane chainless park bike with an old 24" rear wheel #bighit
4. Higher bars/stack. As others have mentioned, if you want to manual, step one is leaning back. Taller bars speed up that process.
5. Firmer compression, air springs, or less travel. All of these achieve the same thing- more bike pushing back against you when you compress the suspension. The first step in bunnyhopping is compressing into the bike, and having the bike sag out underneath you doesn't help. Ditto for pumping, obviously.
6. Steeper head angle. Duh.
7. Shorter reach/shorter wheelbase. Also duh.
8. Higher anti-squat. Surprisingly, higher AS levels will produce a suspension that firms up more when you compress into it to pump or pop. Likewise, a bike with a very low AS will sag out.
9. Forward axle path. A bike that gets longer when you pump is going to feel like doodoo when you want to bunnyhop or pump.
10. More tire pressure. Duh. Also lighter tire casings and faster rolling compounds and tread designs. Hard to "flick" when you're going super slow.
11. A good leverage curve. Anything that's pretty straight and falling rate is good (aka progressive). What's bad? For instance, the old top tube shock VPP bikes had an infamous regressive/linear/progressive hammock-shaped leverage rate that pedaled well in the parking lot but fell into travel when you pumped or popped. Not very "flickable."
12. Stiffer wheels and frame. Flex absorbs body inputs, which doesn't help you pop off things.
13. Make the bike lighter. The Bill Nye TV intro had that female voice that said "Inertia is a property of matter," and I think that applies here.
Put all those things together and you have a BMX bike. Go halfway there and you have a slalom bike. Do the opposite and you've created the new Commencal Supreme.
2/25/2026 8:36pm
Thread can be closed. Robot just clocked the game.
seanfisseli
Santa Cruz, CA, USA
2/26/2026 12:15am
I think this is a great valid question. Here's my two cents on how to make a bike flickable/playful/poppy/unstable (four words that mean basically the same...
That is a LOT of variables. what percentage would you say is chainstays?
A lot of those are attributes of XC bikes, what’s the line between flickable enduro and an XC rig?
Gator
Saint Paul, MN, USA
2/26/2026 5:19am
That is a LOT of variables. what percentage would you say is chainstays?A lot of those are attributes of XC bikes, what’s the line between flickable...
mechanically it's Slack, or lack of it
I rented a Ripmo for the Oregon 24, my daily in MN is a Spot SS steel frame 27.5 -the Ripmo felt heavy, slow, like it was in wet cement until I hit the first long, fast decent and then it came to Life!    I know - 2 completely different bikes with different jobs to do however the Ripmo, for me, was anything but flickable.
owl-x
Shell Beach, CA, USA
2/26/2026 6:56pm
It means it’s time to leave, got some mountain bikers around.
Buckets Up
Hancock, MI, USA
2/26/2026 9:23pm
I’ll probably love flickable bikes when we have ride-by-wireWink
You joke, but that’s the future they’re trying to build for us with flight attendant, live valve, and that patent on abs brakes.
2/26/2026 11:01pm
If you still don’t get it go watch a Dylan Siggers edit.
I personally don’t care for any of this navel gazing though. What makes a bike “flickable”? The rider. Are some bikes more “flickable” than others? Yes. Some people wanna have fun and others wanna pretend racer boi/gal, different strokes.
seanfisseli
Santa Cruz, CA, USA
2/27/2026 12:35am Edited Date/Time 2/27/2026 12:38am
If you still don’t get it go watch a Dylan Siggers edit.I personally don’t care for any of this navel gazing though. What makes a bike...
Ironically he’s on a bike that few would call “flickable” based on certain geo elements…
Edit: but then he loves filming ski edits on those sakuras or whatever the fish tails are…
I think that if people are pretending to be racer bois and girls there are probably just as many pretending to be flickers or whatever they call themselves. People who really see themselves as the Bmx background type but really are just poseurs.
2/27/2026 1:24am
Ironically he’s on a bike that few would call “flickable” based on certain geo elements…Edit: but then he loves filming ski edits on those sakuras or...
Exactly why Dylan is a good example that the bike is almost insignificant.
The difference between the two types of riders I outlined is that racers are actually racing. But fun havers are still just having fun, so there’s no posing Wink
Gator
Saint Paul, MN, USA
2/27/2026 11:52am
this was 6 years ago, this "new definition of flickable" may not apply, but i think it still does : )
Just now looked at this video - he does flick that bike, but his skill level exceeds my ham-n-egg approach by a LARGE margin - he could flick a Schwinn Collegiate.
For the average guy - we have posted some good thoughts on what makes a bike feel good while riding,
Post a reply to: What does “flickable” mean to you?
