Hand Polishing Small Bike Parts?
I've seen / heard of people polishing a few little bling parts on their bike before, but never read any how-tos.  How would I go about doing that without using caustic stripper chemicals?  I assume like a 400 grit sandpaper and water and just take my time.  I'm thinking mostly small bits, like MMX brake clamps, or lock-on grip clamps.  Do I need to put a clear coat on after, or is leaving it raw ok if I don't mind it getting a bit of a haze?  I'm trying to get similar color to Maven Ultimate bodies, or Industry Nine / Chris King silver anodized color.
mrpfp
Cincinnati, OH, USA
12/23/2025 7:10pm
I polished the seat clamp, axle, brake hose ends, and crank arms on my first Ripmo.
I used a bench grinder with a well worn stainless steel wire brush wheel to mechanically strip the black ano from the parts. Time over pressure. Deep scratches greatly increase polishing effort. Built  shine from there with varying grades of both scotch brite and polishing compound.
The better your final finish, the less maintenance required to maintain. No clear coating required.
Still running all of these parts on a Ripmo V2 and they’ve held up well.
IMG 2922 0IMG 2899.jpeg?VersionId=YhJSBI2skQe79DfO.s0IMG 1752 0.jpeg?VersionId=TvVXbStVt
12/29/2025 10:18am
Soaking parts in oven cleaner works well for stripping, and then purple scotch brite pads to further clean it up. Sandpaper away for the polished finish. Mother's auto wax to really make it shine.
Mr. P
Rocklin, CA, USA
12/29/2025 10:30am
Soaking parts in oven cleaner works well for stripping, and then purple scotch brite pads to further clean it up. Sandpaper away for the polished finish...
This. Oven cleaner removes the annodizing (or annodized color) it can make it so easy. But I found some parts fully resisted the oven cleaner. I don't know the why for the resistance.
12/29/2025 10:30am
Cool, maybe I'll go the oven cleaner route.  Some of the parts I was thinking of doing are pretty small and would be hard to get all the nooks & crannies with sandpaper.  Not looking for a mirror / polished finished, just like a satin silver.  So maybe just oven cleaner and scotch brite would do the trick.
12/29/2025 10:37am
AndehM wrote:
Cool, maybe I'll go the oven cleaner route.  Some of the parts I was thinking of doing are pretty small and would be hard to get...
Here's how oven cleaner/scotch brite turned out on my cranks and seatpost clamp.
12/29/2025 10:42am
Perfect, that's just what I'm looking for.
12/29/2025 10:50am
I've used a dremel with a polishing attachment and that's worked pretty well.
Gus J
Plain, WA, USA
12/29/2025 11:17pm
I vote heavy duty oven cleaner, so much easier to polish if you dont scratch it up by grinding the anodizing off. And the only way to get in tight spaces. You can fill thread holes with grease so it doesn't eat away at those, but be sure the surfaces you want to strip are really degreaser.
Spray it, let it sit for 10 minutes and give it a rinse to see what you got. Then dry and repeat as needed. Some stuff with heavier machining marks takes a few more soakings. Scotch brite can finish off stubborn spots, or even just the aluminum polish you finish with. Drano also has the same chemical as the HD oven cleaner, but seems to be more gentle so if you have stubborn spots sometimes a drano soak can finish it off without eating the other bare aluminum. If you dont polish with something like Mothers, it will tarnish to way beyond satin, almost chalky looking. But a little polish will take that away and leave it looking nice.
Wear gloves and dont get the oven cleaner in your eyes Smile
12/30/2025 3:04am
IMG 2079.JPG?VersionId=Q3iM0vIX1.NHLeoVfkoPhdgVrjUp1
SRAM NX Eagle cranks were dipped in a sodium hydroxide solution with hot water for about two minutes, followed by extensive machine sanding and hand polishing, and finished with a final coat of wax.  Use caution when working with sodium hydroxide, as it produces heavy bubbling and hazardous fumes.
12/30/2025 6:41am
Gus J wrote:
I vote heavy duty oven cleaner, so much easier to polish if you dont scratch it up by grinding the anodizing off. And the only way...
That's great info, thanks for the detail on how long to soak and using grease to plug threaded sections.
mickey
Roanoke, VA, USA
12/30/2025 8:22am
I cover shit in oven cleaner all the time.  It IS very caustic.  I will usually make a lean-to out of cardboard outside and spray on a mild, windless day wearing the same elbow length gloves and face shiled I use while glopping aircraft paint stripper onto painted frames.
If i want to strip something like some black ano non-eyeleted rims so I can polish them, I take them to a local anodizer and have them dip to strip the ano, because a part that big is a pain to strip with oven cleaner.  If your local ano spot is nice, they might electro-polish the stripped stuff for ya too. That will significantly reduce the amount of hand work you need to do to get a good mirror finish.
Instead of clear coating your self-polished stuff, be prepared to touch-up/re-polish as needed… You will mess up clear yourself and end up having a crappy, cloudy, hard to fix mess.
Roots_rider
Jackson, WY, USA
12/30/2025 11:10am
Mr. P wrote:
This. Oven cleaner removes the annodizing (or annodized color) it can make it so easy. But I found some parts fully resisted the oven cleaner. I...
7 series vs 6 series. Ran into the same thing on my patrol build. 6 series aluminum strips much easier
Roots_rider
Jackson, WY, USA
12/30/2025 11:17am
AndehM wrote:
I've seen / heard of people polishing a few little bling parts on their bike before, but never read any how-tos.  How would I go about...
I did the oven cleaner route on my patrol build. Definitely recommend, just make sure you have good ventilation or do it outside.
Make sure you’re getting a chemical cleaner with Lye in it and not a citrus cleaner, otherwise nothing will happen. Chemical cleaners seem to be a bit harder to find these days.
I clear coated all my small parts like fork caps and pivot caps, definitely recommend it. Everbrite Protectaclear works incredibly well. Can get small bottles on amazon for reasonable prices. I put a couple coats on the shock linkage, and even after a year of doing frame stands (surfing) it hadn’t rubbed off.
https://www.everbritecoatings.com/protectaclear
12/31/2025 12:34am
Any Europhiles on here that know of a strong oven cleaner available here? Preferably somewhere near Germany.
I’ve tried but the stuff I found is weak sauce. I think I’ve read that there are euro regulations that affect caustic cleaning products available to consumers but can’t quite recall now.
12/31/2025 4:39am
Any Europhiles on here that know of a strong oven cleaner available here? Preferably somewhere near Germany. I’ve tried but the stuff I found is weak sauce...
Can you buy pure NaOH at hardware stores?
1/3/2026 1:35am
There are some people that would be very disappointed in me for not recalling my basic chemistry.
Cheers mate! Just ordered some from Amazon.
Killswitch
Clinton, MI, USA
1/3/2026 8:54am Edited Date/Time 1/3/2026 8:54am
These cranks will get soaked on Monday when my Mothers shows up.
Oven Cleaner , bath, scotch brite clean, easy Mothers and then sanding them with various wet/dry sandpaper, then more light scotch brite.
It's gonna be a beautiful brushed finish, then Im going to re apply new decals and give it 2 or 3 coats of Gtechnique Crystal Ceramic Serum.
Love the polished stuff but brushed if done right looks cool too.
IMG 8582
Killswitch
Clinton, MI, USA
1/3/2026 8:57am Edited Date/Time 1/3/2026 8:58am
I also want to point out and remind everyone that housewives and people so inclined have been using oven cleaner to clean ovens in "un ventilated" kitchens for 75 years...
Be careful but FFS it's not Plutonium.
Killswitch
Clinton, MI, USA
1/5/2026 12:17pm
After 2 soaks.
Look how durable the logos are and that they were white and are now black.....
After this pic I did some preliminary first stage sanding with 180 Aluminum oxide and these are gonna look sick with a brushed finish.Screenshot 2026-01-05 150653.jpg?VersionId=f
Killswitch
Clinton, MI, USA
1/5/2026 5:36pm
Hour and a half start to where they are at.  I have to straighten out some brush strokeage and add decals and 2-3 coats of ceramic sauce.
IMG 8590
Killswitch
Clinton, MI, USA
1/5/2026 5:38pm
I also believe that the logos are laser etched into the surface.  That can not be any sort of decal.
1/6/2026 12:49pm
I got some HD oven cleaner, blue ScotchBrite pads, and various grit polishing heads coming from Amazon.  I'm going to have a go at a spare set of MMX clamps to try and match my Mavens this weekend.  I'll try to get some before and after shots.  Based on some of the photos I've seen in this thread, I'm thinking just the stripping will do the trick to get a good match, without resorting to any polishing/sanding.
1/9/2026 8:31am
Gave the oven cleaner method a try yesterday on some small parts, and it worked great.  Some before & after shots of a pair of SRAM MMX clamps and Ergon GDH lockrings.  I threw the parts in a paint pot, sprayed HD oven cleaner in it until they were covered, and left it for about 10 min.  Then I stirred the parts around with a metallic pick and let soak another 5 min or so.  After that, I removed each part 1 by 1 and gave them a quick scrub with a blue Scotch Brite pad to remove softened paint, then returned to the pot to soak while I scrubbed the other parts.  After that I rinsed off the parts with water.  I'm really happy with how the MMX clamps turned out.  The Ergon lockrings I'm thinking I'll hit with a Dremel polish - on one of them there's a ghost image of some letters that persisted after much scrubbing and soaking, while the other one is completely bare.
IMG 7843.JPG?VersionId=bxX6LgHe2UwejbPoqxfH3AoyKIMG 7846.JPG?VersionId=Jv4pESuJC
Post a reply to: Hand Polishing Small Bike Parts?
