The flex stay discussion thread
6/23/2025 8:57am
nsp234 wrote:
I think you nailed it, that was what @seanfisseli tried to convey. I agree on your "bad design" theory. The only thing that comes to...
I think you nailed it, that was what @seanfisseli tried to convey. I agree on your "bad design" theory. The only thing that comes to mind is that in theory there could be a higher probability of "bad design" with flex stay designs, but I doubt it. At best, there could a few initial issues when the concept was new to frame designers?
Regarding compliant rear ends, does anyone remember those ugly "Zertz" seatstays Spesh did a while for some of their roadbikes? At least, the layout kind of interrupted the straight line of the stay and created something that looked like a defined deformation zone. While I have zero technical insight into that thing, I doubt that it did much...zertz.png?VersionId=is.cDJaJkWV28hySJhxBysAVePVy2
I was working in the engineering department at Specialized during the whole "zertz" thing. They did absolutely nothing. We tested frames with them and without them on an MTS test bed as well as having strain gauges/etc and DAQ systems on for riding. They did not damp or mute anything, zero difference. The shape of the carbon stay itself did change how the rear end behaved when compared to a "normal" seat stay, but the zertz did nothing. It even got to the point where Specialized was ordering field test frames without them as the cost was a bit lower. Zertz was pure marketing. Same goes for the seat posts and forks with them.
I was also tasked with making the first flex stay mules for Specialized. I took 2 alloy Epic frames and removed the bearings from the Horst link and then welded the pivots solid and heat treated the frames. One was welded to be "relaxed" at top out, and the other at sag. So there was either an inflection point at sag, or it just acted as another spring for the entirety of travel. I believe they went with the sag version, and this is where the whole negative spring thing came from. The flex stay is basically trying to pull the frame into sag, then after sag it adds to the spring force.
I'll also add that FEA, even today, does not necessarily give you the same results as the real world. I saw this countless times, many hours of setting up FEA simulations and designing off of them, only to have the actual product not behave as predicted. It was used at a design tool, but also verified through lots of real world testing with DAQ and rider feedback.
A good example of this involves the press fit BBs on road bikes. When Specialized was moving from co-molded alloy cups that the bearings were pressed into (BB30), to having a carbon BB shell that bearing and plastic cup were pressed into (PF30), FEA was run and the results were basically the same. However, if you test rode two identical bikes (one being BB30 and the other PF30), you could instantly tell which one you were on. Very noticeable difference. Similar situation with Zertz; FEA showed that they did help damp the system, but this could not never be measured or verified in the real world with instrumentation or rider feedback.
seanfisseli
Santa Cruz, CA, USA
6/23/2025 10:02am
I was working in the engineering department at Specialized during the whole "zertz" thing. They did absolutely nothing. We tested frames with them and without them...
This is some great intel. Thanks for sharing!
6/23/2025 2:03pm
xy9ine wrote:
at 9" travel, this is the most extreme implementation of a flex stay i've seen. not that there were enough examples to generate meaningful durability data...
at 9" travel, this is the most extreme implementation of a flex stay i've seen. not that there were enough examples to generate meaningful durability data, but by all accounts i'm aware of, these were bomber. this one saw 10 years of regular use, and is still intact 18yrs later (only dusted off for the occasional nostalgic retro ride these days). super stiff laterally, silly supple vertically. as a proof of concept, it certainly succeeded.
20220830 173442 %281%29 0.jpg?VersionId=pS167DkvpmLGXmr8lJYQIj
Wynn Masterd delaminated the chainstay back in the day, and at one point had a tube wrapped tightly around one side to keep it together.
6/24/2025 7:13am
sprungmass wrote:
Granted this forum is mostly geared towards all-mountain and Enduro side of things. Riders who are primarily Enduro riders and like to smash into things tend...
Granted this forum is mostly geared towards all-mountain and Enduro side of things. Riders who are primarily Enduro riders and like to smash into things tend to dislike these flex stay or XC style bikes. In XC, we don't smash into things like a big Enduro bike. It requires finesse, lots of active riding by unweighting/hopping over obstacles instead of plowing through them. You also have to compromise some of that downhill smashing ability for uphill and out of saddle performance which is where these races are won. Being an XC guy at core who now does equal part Enduro riding, I love them. They can be fast too but you just need be in that mindset.
I had the Epic Evo then got Transition Smuggler C and finally settled on the Stumpjumper Flexstay. For context I am 165lb that exclusively rode and raced XC for most of my riding years then moved to the mountains. Epic Evo geometry felt a bit lackluster for our local trails so I decided to build a light weight trail bike i.e. Smuggler. The horst link design excelled on the descents but left me wanting that "zing" and sharpness of my previous XC bikes. So I sold the Smuggler and built a Stumpy Flex which got me what I wanted. Better geo for our terrain, direct feeling acceleration and good downhill performance if you are willing to ride it like a XC bike. Now this bike is unique as it delivers 130mm travel which caused Specialized some flex stay spring back issues hence the very specific RX tune. See "Suspension Design" section here: https://nsmb.com/articles/2021-specialized-stumpjumper/ I just raced a local virtual enduro on blue trails using my Stumpy and placed near the top against folks with 160+mm bikes.
This is a great point. I used to break shit all the time, mainly wheels, until I began racing XC and riding a single speed exclusively. While I no longer race, that experience still informs my trail/enduro riding style which I would describe as aggressively smooth. For the past 10 years or so my bikes were all longer travel trail or enduro bikes. A couple years back I got one of the flex stay Stumpjumpers after I bought an alloy Stumpy EVO. Both bikes are great in their own right, but more often than not, I am reaching for the flex stay bike. It's way lighter and way livelier, so to me, it's more fun to ride on my local trails. The trails have plenty of tech so like @sprungmass said you learn to hop and unweight through these parts. The EVO is now reserved for big backcountry rides or park days where it really shines.
Great discussion in here!
6/25/2025 8:58am Edited Date/Time 6/25/2025 8:59am
This will be my last attempt at explaining why rebound damping at the shock will control the flex stay. If you take the blur rear triangle...
This will be my last attempt at explaining why rebound damping at the shock will control the flex stay. If you take the blur rear triangle and attach the upper pivot to the lower pivot with a rigid member, you are forming a triangle and locking out the flex stay. If the shock were to be locked at any given position, it’s effectively doing the same thing. As such, for the flex stay to move the shock just move and therefore the damping at the shock is controlling rebound of the flex stay.
IMG 9995 0
This is two rigid bars(the chainstay  and  the main pivot to shock link-your orange line) connected with a pivot. The chainstay and your orange line will move at the pivot and compress or extend the seatstay. The flex stay acts as a spring that can compress or extend to allow the axle to move.
This would flex, the axle will move and that motion will be undamped. I don't think that affects the ride but this set up would move like an undamped bike unless I'm missing something.
6/25/2025 9:09am
This is two rigid bars(the chainstay  and  the main pivot to shock link-your orange line) connected with a pivot. The chainstay and your orange line will...
Again, flex stays are not flexible in all directions. It is not able to extend or compress axially any more than any other frame member including the chainstay.
6/25/2025 9:41am
Again, flex stays are not flexible in all directions. It is not able to extend or compress axially any more than any other frame member including...
I'm not sure what you mean. So you mean rotate? Because it does.that's why it replaced a pivot.
6/25/2025 9:45am
So imagine replacing it with a pivot and then driving the shock all the way to bottom of travel. Can the axle move beyond that point?
6/25/2025 9:55am
"extend or compress axially" means along its axis. So stretch or compress inline with its long axis. Likewise it won't buckle/bend under compression (which is what I thought was happening).
6/25/2025 9:56am
Yeah because the length of the bar(flex stay) changes.
There's no Side Side congruency theorem for triangles.
6/25/2025 10:07am
I think @Sheppy Wong is aiming at the picture with the banana seatstay. That would tend to bend like a bow a bit and give some more (undamped) travel.
You could make the rear triangle vertically compliant, but doing so would bring you jn a heap of problems elsewhere ride dynamics wise.
6/25/2025 10:08am
I think @Sheppy Wong is aiming at the picture with the banana seatstay. That would tend to bend like a bow a bit and give some...
That would make more sense, but that's not how anyone does flex stays.
6/25/2025 10:11am
Here is a 2D representation of a Blur rear triangle where the flex stay is converted to standard pivot. The dimensions are meaningless because I didn't scale the image to match anything real. In one image, the shock length is not dimensioned. Because it is not dimensioned, the lines are blue because the sketch isn't fully constrained. In the second image, the shock has a length dimension associated with it. This fully constrains the sketch and nothing will move.
Unconstrained.png?VersionId=w4xgKmjConstrained.png?VersionId=NpjiDlS1xABXb.xYrARYHJH
6/25/2025 12:36pm
I think the point that @seanfisseli is trying to get across is:
In the video you can clearly see the Santa Cruz seatstays flexing up and down. This is probably because the flex stay is more flexible, by design, than most other chainstays out there that aren't intended to flex. That wobbbling up and down may or may not actually lead to the seatstay compressing meaningfully, but either way that wobble/flex/vibration is clearly there.
Sean is hypothesizing that this wobble/flex/vibration can be felt on the trail, even it if doesn't lead to meaningful compression of the seatstays, and this degrades the bike's performance.
I am skeptical, but I don't think the question is stupid (even if the question did "evolve" over time)
6/25/2025 12:46pm
Of course not, thus the bad design I mentioned. But this is what @seanfisseli was trying to get across with the undamped talk.
@hamncheez2003 adding a pivot will cause it to shake even more. As I said before, it's not a flex-stay thing, it's a triangular construction with compression loaded sections thing.
6/25/2025 1:22pm
I think the point that @seanfisseli is trying to get across is: In the video you can clearly see the Santa Cruz seatstays flexing up and...
This has somehow morphed from talking about undamped spring force and rebound from a flex stay to transmission of vibrations. Very different things. Any frame will transmit vibrations to varying degrees. To figure that out you have to look at natural frequency and then also the frequency of impacts on whatever trail you're riding. I would guess that most flex stay frames have a higher natural frequency.
Santa Cruz chose to design the Blur with a very thing seat stay. This is not something that is a requirement for the functionality of a flexure. In the huck to flat video it would appear the seat stay actually nearly buckled. You could do away with the flex stay and it would still nearly buckle. Actually might require increased strength from the seat stay since a beam pinned on both ends buckles at a lower force than a beam that's fixed at one end and pinned at the other. @Primoz posted a picture a little bit back that depicts this.
6/25/2025 1:39pm Edited Date/Time 6/25/2025 1:40pm
Im assuming that any flex of the stay changes its length. Unless I'm missing something obvious I can't picture a flex system that doesn't change lengths wihout a pivot. That's why pivots work, they put the bar in straight compression or tension between the pivots.
6/25/2025 1:51pm Edited Date/Time 6/25/2025 1:52pm
Im assuming that any flex of the stay changes its length. Unless I'm missing something obvious I can't picture a flex system that doesn't change lengths...
the key word was "meaningfully"
seanfisseli
Santa Cruz, CA, USA
6/25/2025 2:43pm Edited Date/Time 6/25/2025 2:44pm
If the amount of force needed to compress the shock is more than the amount of force needed to flex the seat stay, I still think there is a chance that the SS flexes instead of compressing the shock. I know that’s not in accordance with the axle path, but the axle path is attempting to redirect the forces exerted on the rear wheel into the shock, and if something interrupts that (shock getting stiffer than a member of the linkage) the force may not follow the engineered path. God I love this thread.
seanfisseli
Santa Cruz, CA, USA
6/25/2025 2:46pm
If the amount of force needed to compress the shock is more than the amount of force needed to flex the seat stay, I still think...
Also, if the direction of the force is especially rearward then these flex stay bikes (with their forward axle paths) might have more trouble converting that force into linkage movement, again opening up seat stay flex as a place for the energy to move into.
seanfisseli
Santa Cruz, CA, USA
6/25/2025 2:47pm
These are hypotheses btw, and yelling and people on the internet is not a valid scientific way to prove or disprove their hypothesis. Some of y’all are acting like science on your side with ZERO experiments demonstrating your own hypothesis is more valid that what I am positing.
seanfisseli
Santa Cruz, CA, USA
6/25/2025 2:49pm
Here is a 2D representation of a Blur rear triangle where the flex stay is converted to standard pivot. The dimensions are meaningless because I didn't...
This is a nothingburger. What are you trying to say here?
seanfisseli
Santa Cruz, CA, USA
6/25/2025 4:36pm
This has somehow morphed from talking about undamped spring force and rebound from a flex stay to transmission of vibrations. Very different things. Any frame will...
I said it’s an undamped spring. If a spring is oscillating and vibrating without anything to damp said vibrations/oscillations, it is an undamped spring, no? This was always a major point of mine. How much said spring compresses and extends is another story entirely, but a story I’m still open to exploring!!!
6/25/2025 7:29pm
Your tires are an undamped spring, your handlebar is an undamped spring. Your dropper post fully raised flexing forward and backward while pedaling is an undamped spring.
For the flex in a flexstay design to be undamped would mean that the force required to move vertically the wheel a significant amount of travelis higher than the stiction force of the seal of the air spring. Otherwise it's just one part of a series of spring from your tires, rim, spoke, wheel axle, rear triangle, linkage and shock. And since the shock is at the end of this and is damped than the full series of spring is damped.
Also carbon fiber don't really lose energy as heat when it flex so most of the energy accumulated by the rear triangle flexing is transferred back further to the shock which damp it all.
But as other have mentioned, a flexstay design will require a higher force at the wheel axle for the system to move vertically instead of a 4bar setup they typically replace since a bearing require much less force to rotate than a seatstay/chainstay to flex. So your suspension damping tune must account for those higher forces.
seanfisseli
Santa Cruz, CA, USA
6/25/2025 9:20pm
It’s funny how many of us have zero evidence. It’s all theory/conjecture/conventional thinking. I love coming up with ideas!
6/25/2025 11:00pm
If it is a bar with two pivot points and all the loads going into the two pivots (so faux bar seatstay), yes. If you have three pivots (faux bar chainstay, Horst link seatstay, etc.) or have a brake mounted to it, no. You went from a bar to a truss which is also loaded by side loads and torque (moment) loads and the dimensioning and calculation of it becomes completely different.
6/25/2025 11:01pm
No. Time and and time again it has been explained to you that the flex does not mean additional axle travel.
6/25/2025 11:02pm
Also, if the direction of the force is especially rearward then these flex stay bikes (with their forward axle paths) might have more trouble converting that...
Add a pivot. It will be EXACTLY the same.
6/25/2025 11:03pm
These are hypotheses btw, and yelling and people on the internet is not a valid scientific way to prove or disprove their hypothesis. Some of y’all...
Some of us have years of education and experience from the field...
6/25/2025 11:24pm
1llumA wrote:
Your tires are an undamped spring, your handlebar is an undamped spring. Your dropper post fully raised flexing forward and backward while pedaling is an undamped...
FWIW carbon fibre damps a lot more than metals. And a handlebar can also be somewhat damped 😉
Aaaand I'm out. I think we ran the course of the debate and are spinning in circles.
Post a reply to: The flex stay discussion thread
This forum thread has been locked.
