Lets talk mullet bikes!
rockchomper
Rancho Cucamonga, CA, USA
I am very stoked on the mullet set up! I spent a lot of time on my friends mullet at summit this season and i'm sold on it! so here lies the problem, I can NOT afford another bike and I love my 27.5 YT TUES but I hate the fork so I want to swap the fork to a 29 and make my bike a Mullet. BUT! while I don't mind the addition of the 29 fork and wheel slackening the bike, I do absolutely hate the Idea of raising the BB. So the question is it possible to add a 29ER wheel and fork to my 27.5 Tues without raising the bottom bracket more than 4-5mm?
SB14
NO
9/30/2020 1:34pm
Offset bushings? I know this has been the solution for alot of other bikes to get around this problem. Others might want to add to this point.
rockchomper
9/30/2020 1:55pm Edited Date/Time 9/30/2020 2:03pm
I don't think those will work because they slacken the head angle as well as dropping the BB. unless I'm not understanding the different types. my bike sits at 63.5 head angle and if I went to the 29er fork and wheel up front it would drop to 62 degrees, then If I added in the shock bushings to drop the BB back to stock those bushings also slacken the head angle somewhere around 61 and I don't want to go lower than 62 degrees.
If those didn't also slacken they'd be perfect.
9/30/2020 2:32pm
it's not a good candidate for mulleting unfortunately.
650B bikes in the 65.5 HA area are the prime candidates.
Besides offset bushings, a quick easy one is going to a narrower/smaller volume tyre in the back, easy way to shave some BB height.
Or if the bike has a kinematic to suit, running closer to 35-40% sag. But H/A gets slacker dynamically.
w4s
Verdi, NV, USA
9/30/2020 2:57pm Edited Date/Time 9/30/2020 3:37pm
I'm thinking about doing the same with my 27.5 Tues, my first choice would be to put on a Dorado at 180mm travel.
rockchomper
9/30/2020 3:48pm
Thanks guys looks like ill be saving my pennies and praying that the price on the canyon sender mullet drops!
9/30/2020 4:17pm
Reality check: Wheel size is 324th on the list of mountain bike variables that affect performance, and it's definitely behind suspension setup, BB height, head angle, and tire size on that list.
9/30/2020 5:40pm
I hear the GT Sensor is the perfect bike for mulleting.
rockchomper
9/30/2020 9:39pm Edited Date/Time 9/30/2020 10:08pm
Reality check: Wheel size is 324th on the list of mountain bike variables that affect performance, and it's definitely behind suspension setup, BB height, head angle...
I like a mullet for more than just it being a fad, I’m way to short for a full 29er but I like the way the bigger front wheel deals with holes and square edge hits. I found that the 29er front wheel on blown out bike park trails with huge bomb holes feels better than a 27.5
So if my fork is dialed, Geometry is up to date, and tires and tire size are the same that world cuppers run. Then am I allowed to look at mulleting my bike? Or do I still need a reality check?
SB14
NO
10/1/2020 1:58am
I don't think those will work because they slacken the head angle as well as dropping the BB. unless I'm not understanding the different types. my...
Yep. You could also get a -2 headset, then you would bring back the HA again. Then it would work?
Eoin
10/1/2020 2:05am
I'm on both sides of the fence:
Mullet'ed my 29er enduro bike with a heavy rear 27.5 wheel: almost no noticeable change in ride feel beyond increased chatter out back.
Mullet'ed my 27.5 e-bike with a 29 fork+wheel (same tyre: MM supergravity). Was worried about the the increased BB height (357mm for a 150mm travel bike), but interested in the -2degree head angle (66->64). Difference is night and day, feels way more stable, beating all my times by a handful of seconds on 1-2minute tracks. Only downside is climbing isn't great.
I wasn't expecting that much from putting the 29 fork and wheel on the 27.5, yet now i've put my 27.5 fork up for sale... Note that I am not a believer in low BBs to begin with after several horrible crashes from rock strikes to the pedals.
rockchomper
10/1/2020 8:26am
Wouldn't it be nice if all bikes were as adjustable as that new Scott Gambler!
Zero Cool
Bristol, GB
10/2/2020 7:16am
A shorter fork?
rockchomper
10/2/2020 8:40am
Zero Cool wrote:
A shorter fork?
For me a shorter fork kinda defeats the purpose of a DH bike. 200mm or bust ! haha
Pedal4life
San Diego, CA, USA
10/2/2020 9:32am
What fork were you gonna use for this mulletization of your TUES & Have you given the folks over at YT a eMail they’ll get ya sorted on this project I honestly want to know more of how this turns out
10/2/2020 9:41am
I like a mullet for more than just it being a fad, I’m way to short for a full 29er but I like the way the...
I think the point is, you don't want to compromise those factors just to go with a mullet setup as the overall handling will suffer. To recognize the marginal benefits of a mullet setup, it needs to be done correctly. I'd suggest looking at a bike designed to be mullet'd - these are a great deal: https://www.commencalusa.com/supreme-dh-27-29-race-2021-c2x31920312
rockchomper
10/2/2020 9:57am Edited Date/Time 10/2/2020 9:58am
Pedal4life wrote:
What fork were you gonna use for this mulletization of your TUES & Have you given the folks over at YT a eMail they’ll get ya...
I was going to use the Marzocchi 58 becuase its relatively inexpensive as far as good forks go and im not a big fan of high speed and low speed adjustments, Im more set and forget. I hadn't thought to give YT a call, I will call them and give an update on what they say.
10/2/2020 1:47pm Edited Date/Time 10/2/2020 1:50pm
Hey Rockchomper, you're allowed to look into whatever bike setup you want, my reality check is just trying to help you draw accurate conclusions on the way. You said you borrowed your friends mullet Capra this summer and loved it. There are about 100 different reasons why you may have preferred his bike to yours, and the 29" front wheel is only one of those reasons. Other potential explanations:
-Fork spring pressure
-More or less tokens than your fork
-Coil vs. air fork
-Rear shock sag
-Better or more recent seal/wiper/oil maintenance
-More compression
-Less compression
-rebound speed
-high speed rebound speed
-Fork model, air spring design, and shim stack tune (these features all vary year to year within manufacturer's models)
-Bar height
-Tire pressure
-Tire size
-Tire casing
-Tire inserts
-Head angle
-Chainstay length
-Stem length
-Grip compound/thickness
-Body position on the bike
-Last but not least the placebo factor, which is real. It affects all human subject tests of every kind, and this is no less true for mountain bikers who are excited to borrow their buddies cool trendy new bike.
There are an unimaginable amount of variables that affect bike performance, and that's why pros and suspension tuners try to minimize variables when testing. I've ridden a lot of different bikes, I've tested bikes for manufacturers, and I've ridden all the wheelsizes in every imaginable scenario. I'm not saying wheelsize doesn't matter, that would be too strong, but based on my experience it's really far down on the list. If you thought your friend's Capra rode through rough terrain better than yours, that's great and useful information, but I don't think it logically and necessarily follows that you would benefit from buying a mullet bike.
rockchomper
10/2/2020 3:46pm
Hey Rockchomper, you're allowed to look into whatever bike setup you want, my reality check is just trying to help you draw accurate conclusions on the...
-Coil vs. air fork
-Rear shock sag
-More compression
-Less compression
-rebound speed
-Bar height
-Tire pressure
-Tire size
-Tire casing
-Tire inserts
-Head angle
-Chainstay length
-Stem length
I agree all those factors do affect bike characteristics but, it was more of an idea of since I don't like my fork I would like to buy a new one and while I am at it I would like to mullet my bike only if I can keep the geo of my bike the same as it currently is , since I would be buying a new fork anyway now would be the time. But unfortunately seeing how much work and money it would take to mullet my bike it looks like I will just be getting a new fork in 27.5
You do have a ton of great points and I am always playing with my bike set up cuz I'm a bike nerd. So I thought it'd be a fun thing to try on my bike since I want a new fork anyways.
Maybe taking your advice I could play with bar height to simulate the higher front end of the mullet although it wont change the feeling of having that 29er front wheel on a bomb holed bike park it should still help with the weight distribution aspect. thanks for the tips and the effort put into that response.
10/3/2020 10:03am Edited Date/Time 10/3/2020 10:24pm
You’re welcome!! Adding 5-10mm of spacers under your bar can make a surprising difference in how a bike rides. If you want to mess around with your current setup, I’d also recommend adding 5 psi to your fork, or even pulling a token and adding 5 psi.
What you’re fighting against on steeper/faster/tougher trails is weight shift. As your front tire hits bumps, it slows down and your body weight shifts forward. This is inherently unnerving and your brain will instinctively slow down to compensate. Slowing down, by the way, compounds the frontward weight shift because now you’re pulling on the brakes. Bar height, 29” front wheels, faster fork rebound, and running a stiffer fork are all ways of combatting frontward weight shift and keeping your bars higher. There are a lot of ways to skin that cat.
Happy puzzling!
Tobyb
Vancouver, WA, USA
10/8/2020 11:08am
I did a mullet conversion with my zerode taniwha, i also put on a 1.5 degree works components headset, it slackens the head angle and drops the front a little while making the seat angle steeper at the same time. First car park ride it felt slack and i thought i had overdone it, but when i rode it the benefits of the 29" grip and roll over were instant and then stability from the relaxed head angle made my ride even more comfortable and stable, the angleset brought my bb around to the same height it previously was.
Suns_PSD
Austin, TX, USA
10/11/2020 6:28am
I tested my Foxy 29 as a mullet, it was a quick and dirty test as all I did was remove my wife's 27.5" rear wheel and install it on my Foxy and go for a 2 hour trail ride.
My bike isn't terribly slack nor low to start with so nothing got to extreme. I did lower my fork travel by 10mm to keep the bike a bit level.
At 5'11" with long limbs it provided no or maybe just 1 advantage but a few disadvantages.
First, done sloppy like this, I didn't like the geo changes for a trail ride at all. The front pushed like mad although I had a fast rolling low grip rear tire installed now (as my wife is more a XC rider), the slackening of the STA was positively unbearable, the rear end was considerably more chattery and rough feeling. I did shove the bike extra hard into a few turns and it felt nice and a few times I was able to do the Pro thing where the rear end pivots around the turn with no brake application and that was really cool. My bike has poor rear tire clearance and this was improved greatly.
In the end, for this application, on this bike on these trails at my height, mullet wasn't worth pursuing imo.
I'd still like to explore it more and I think for a gravity bike, or a shorter person on the right bike it has it's place and very well might be superior to other options. That said, I won't spend money to buy a mullet or convert a bike unless I had lots of testing time beforehand to quantify worthwhile advantages.
6/23/2022 5:09pm
Hello, I wanted to jump in on this with my mullet setup advice. I started with a Rocky Mountain Slayer 27.5 L frame. Dropped a ZEB 180mm 29er fork with the frame already set up for 180mm. The Ride 4 geo adjustment gives good options to slacken or steepen the geo. I set mine to the 3rd position which is one setting down from the steepest.
Recently I took it to Silver Mountain Bike Park and then to some traverse trail riding in the Black Hills of SD the following weekend. This setup was solid on muddy/ peanut butter bike park and only suffered on the rocky terrain of the SD trails by not being very nimble. I appreciate the compromise with this bike to reach into light downhill and still be a very capable trail bike!
6/24/2022 5:34am
I am very stoked on the mullet set up! I spent a lot of time on my friends mullet at summit this season and i'm sold...
You could lace up a 26in rear wheel and have a mullet bike like the free ride guys.
Edthorne
6/24/2022 7:20am
Hello, I wanted to jump in on this with my mullet setup advice. I started with a Rocky Mountain Slayer 27.5 L frame. Dropped a ZEB...
Last season I dropped a 27.5" wheel into the back of my Slayer 29. With the Ride4 in the highest position, it was actually not all that far off the full 29 in the slack full slack setting geometry wise. Felt great out on the trail, particularly in the corners (unsurprisingly).
Post a reply to: Lets talk mullet bikes!
