Frame Design
7/23/2025 5:32pm
Definitely avoid single shear bolts as much as you can - I'm sure the vorsprung best practises document has already been mentioned here but he specifically...
Definitely avoid single shear bolts as much as you can - I'm sure the vorsprung best practises document has already been mentioned here but he specifically singles them out-
8. Do not use single-shear bolts under bending loads unless absolutely necessary.
These see much higher stresses than double-shear (ie through-bolt) type loads, and are
more prone to coming loose and/or breaking, because as soon as they come loose, the
bending stresses go through the roof. Through-bolts (double shear) are much stronger
and have greater tolerance to load when loose.
If you ever have pivot bolts that work loose or wear too fast they are almost always either single shear or wildly undersized (6802 or smaller etc). This is why Trunnion bolts are prone to coming loose if they are even slightly under torqued
Yeah, you won't see me putting them on any of my future designs unless I can't help it. I did a bit of a sanity check after the Vala got criticised for it, and checked all the bikes in my house. My brother's e-bike has one, but it's quite heavily braced in the area. The only other bike we have with single shear bolts had a failure where the aluminium insert de-bonded from the carbon rocker and wrote off the frame, and it didn't have a seat stay bridge either. All our other bikes are double shear, including my Vitus. We got the opportunity to test the new Ghost Poacha, and that has double shear as well.
owl-x
Shell Beach, CA, USA
7/23/2025 7:47pm
i love my 2023 Optic. It has a press fit BB and these Vala seat stay bolts. Quit talking about this stuff or else it’ll hear and disintegrate thx
7/24/2025 1:28am
owl-x wrote:
i love my 2023 Optic. It has a press fit BB and these Vala seat stay bolts. Quit talking about this stuff or else it’ll hear...
Do it creak tho? Also from what I can tell, the single shear bolts aren't so bad on a regular bike, only on e-bikes or when there's no seatstay bridge.
8/4/2025 5:11pm
Progress is being made on the frame design. I've got it set up to use as many off the shelf parts as possible to avoid the expense and weight of 3D printed bits, and I've got some tubes on the way. I should have a real one in my hands by the end of the year! Some of the bits have taken heavy inspiration from Devlin cycles (check him out he makes some cool stuff) and the down tube elbow has been made one piece with the shock mount to save weight and manufacture costs. I am very proud that the flip chip actually fits an m8 shock bolt, and is even able to hold a shock in both positions!
10000304321000030452 01000030454 01000030456 010000303251000030324.jpg?VersionId=u07v4UvHcCgScZjRVNM7hCY8SxgH1000030323.jpg?VersionId=vBYcl3Z5jCpPv
10/14/2025 7:04am
I've settled into my new digs at uni, and I've been told the uni DMLS printer only works with Alloy so my steel design won't be needed. Bit of a shame, but I'll live, i think I will have to be making my own tubes out of prepreg carbon sheets though. Making my own custom tubes is risky but gives me a lot of opportunities to control more parameters on my build. I'll see how things go from here.
1000033361.jpg?VersionId=0.3D.cKUKEUk6
earleb
North Vancouver, BC, CA
10/15/2025 2:18pm
FYI Tony Foale's book MOTORCYCLE HANDLING AND CHASSIS DESIGN is back in print and available. It's being printed by Amazon books.
https://www.instagram.com/p/DOqaPjmAkzj/
https://www.amazon.com/-/es/Tony-Foale-ebook/dp/B0FNSQV5WM
It's been referenced as the bible for frame and suspension design. I am keen to finally get my hands on a copy of it.
10/15/2025 2:30pm
earleb wrote:
FYI Tony Foale's book MOTORCYCLE HANDLING AND CHASSIS DESIGN is back in print and available. It's being printed by Amazon books. https://www.instagram.com/p/DOqaPjmAkzj/https://www.amazon.com/-/es/Tony-Foale-ebook/dp/B0FNSQV5WMIt's been referenced...
Thanks! I just came here to share it after posting on instagram too
highly recommend 💯
earleb
10/15/2025 2:38pm
highly recommend 💯
I saw your post in IG. I had just skimmed your post and scrolled past thinking "yeah that's been out of print for ages". Then I noticed you had linked to Tony's IG and I scrolled back as I had never seen anyone link to him on IG. On his profile I realized it was back in print. Instantly ordered a copy.
2/4/2026 8:16pm
To carry over a question I posed in the rumours thread to a more appropriate thread:
[In response to the new Crossworx Dash 290 MKII]
This bike brings to mind an inexperience-based question: What is the appeal of a linked-driven single pivot (LDSP)?  I have owned and ridden exactly one full-suspension bike, and it is a Horst link design.
I know that simplicity is a valuable thing in and of itself, but a linkage brings additional bearings and whatnot into play.  I know that other designs separate braking and suspension forces to various degrees in a way that a LDSP design cannot.  Given that LDSP bikes are still the preference for certain manufacturers in certain applications, though, I know that there must also be positive qualities that someview as outweighing the benefits of a Horst or what have you.
Are LDSP bikes poppier?  More supple/sensitive?  Do they create cool leverage curves or something that gives a bike a nice ride feel  Can some suspension/braking cross-talk actually be beneficial in some instances?  Is the axle path particularly nice?  What's the pitch?
2/4/2026 8:24pm Edited Date/Time 2/4/2026 8:25pm
To add to the above, I rode with a guy on an Evil Wreckening once, and he preached the Delta Link gospel with a level of gusto such that it seemed he may start speaking tongues. No detailed accounting, though, just 'It's awesome. It's the best at everything. This bike rules!"
What benefits might one realize with  LDSP vs a Horst or a twin-link variant or a split-pivot, etc.?
Thanks in advance to anyone who is willing to enlighten me on this. Cheers.
Eae903
Not Saying., WY, USA
2/4/2026 10:01pm Edited Date/Time 2/4/2026 10:06pm
To add to the above, I rode with a guy on an Evil Wreckening once, and he preached the Delta Link gospel with a level of...
For now I'll stick to just horst link and ldsp for the sake of simplicity. Like I said on the other forum, the most consistent difference between a Horst link design and a LDSP design is going to be the anti rise. Anti rise is more or less, a suspension platforms resistance to extending under forward weight transfer. Less anti rise the more the shock will extend, more anti rise, the less it will. This is usually felt the most when on the brakes, since your body and center of gravity will want to keep moving due to its inertia, shifting your weight forwards on the bike.
There are two things that are considered when tuning anti rise, preserving the geometry of the bike, and keeping the suspension active and plush. Horst link bikes generally have low anti rise (80% or lower). This results in the bikes geometry not being preserved, the shock extends and the bb rises up potentially shifting your weight forward even more. However, this allows the suspension to remain more active under braking, so that if you have the brake through rough terrain the suspension keeps working to absorb impacts and potentially keeps the rear wheel gripping better. LDSP bikes do the opposite with their generally high anti rise (100%+). They keep the geometry of the bike stable, not shifting or pitching, but consequently firming up the rear suspension, making it not work as well under braking. It becomes a trade off of geometry preservation and keeping suspension active, and both have their merits.
I personally love LDSP bikes. There is a predictability to them that is so easy to get along with. I'm on a Horst link bike right now, not even one with that low of anti rise, (Gen 4 Norco Sight about 80% anti rise on average) and there are definitely times I notice the slight pitch forwards, mostly when I'm tired or braking hard in a racing situation. It's not always the most confidence inspiring for me haha, but the rear end just tracks through the rough stuff and it's a pretty damn fast bike. On the Kona Process X that I had before the Norco I never noticed that. It was always rock solid under braking, no shifting forwards or anything like that, but it was skittery in the rough under braking, the rear wheel broke traction easier and bounced on top of braking bumps rather than tracking through them. All that said, I enjoyed riding the Kona more than I do the Norco, even though I know the Norco is arguably the faster bike. I crashed and broke the Konas frame, and had to replace it with the Norco pretty quickly, and it took me a long time to like it. If I could, I would give up the Norco go back to the Kona, no hesitation (If anyone would like to trade one hit me up haha).
As for the other questions, like if they're poppier or more plush or anything like that, all I can say is depends on how they're tuned. That's part of the reason why there are so many different LDSP designs, the delta link, all the flex stay xc bikes, Crossworx, anciollotis, the new Oranges, the V1 Forbiddens, all different to give different ride characteristics.
There are more things that we could discuss regarding LDSP bikes VS Horst links, like how split pivot bikes are just LDSP, or how you can use a floating brake arm to tune anti rise on either system, etc..., but those are topics for a different day.
2/5/2026 10:30pm
One thing to add when talking about antirise. You mention it oposes the weight transfer. That's true, but only for the weight transfer caused by the rear brake. If you move back and forth, if you ride steeper terrain or brake with the front brake only, the suspension will react freely (both front and rear) to the weight transfer. More antirise will only compress the rear when pulling on the rear brake.
Not sure how antirise is calculated (in linkage) because there are theoretically two components to it, just like with antirise. One is the axle path component, the more rearward it is, the more the rear wheel will be pulled back and thus into the travel, and the other being the torque reaction to braking, the caliper trying to rotate the brake link forward and thus enacting a torque on the complete suspension system. Depending on the rotation of the brake mounting link through the travel it can rotate forward (more antirise) or backwards (less antirise).
Theoretically 100 % antirise means the rear squats enough to just oppose the weight transfer. That should mean the suspension should stay around the sag point, ideally. In that regard it shouldn't lock the rear suspension, way more than 100 % would be needed for that. Maybe the difference in feel comes from the fact that a lower percentage has some weight transfer, opening up the rear suspension and moving into a softer area of the suspension curve? So it's not single pivots getting stiff, but Horst links getting soft under braking situation?
2/6/2026 3:07am
Ah and to add one more thing, the antirise and antisquat are based on the height of the CoG, which then in real life is dynamic. And the designed for height vs. actual height is not necessarily the same as well.
2/6/2026 6:49am
Excellent points, @Primroz. Since published anti-rise figures (and anti-squat as well) rely on assumed CoG of the rider, you cant really compare them brand to brand, or even within a brand over time. They usually publish a static figure, but its going to change from size to size within the same model too, since most companies have the same rear end and suspension linkage shared aross frame sizes, but of course its safe to assume larger sizes have riders with higher CoG, etc.
I wish, instead, brands published something like toqure applied to the suspension during braking, and plot that on a graph. Its easy to understand anti-rise if you think of floating brake arms, and how when you compress the suspension the floating link keeps the brake stationary. A Horst link is just a way to use the same links for suspension actuation and to float the brake mount, to whatever degree is intended by your design.
Sorry to keep ranting, but thats what most these 6 bar bikes are doing, like Intense, Specialized, Knolly, etc: use separate bars for managing suspension curves and managing anti-rise. It would be lighter and even more tunable if they just had 4 bars that only dialed in their axle path and compression curves, and then used a floating brake arm, but that doesnt look cool.
Post a reply to: Frame Design
