2026 MTB Tech Rumors and Innovation - Longer and Slacker
4 hours ago
I'm curious to see the details on the new Revel, it's most likely the new Ranger.  I wish it weren't flex stay, but I understand that...
I'm curious to see the details on the new Revel, it's most likely the new Ranger.  I wish it weren't flex stay, but I understand that most of the bikes it will be comparable to also have flex stays.  I'll hold off on asking if it's coil compatible, I don't wanna start that again.
Simcik wrote:
I assume it's going to be CBF, so a solid rear triangle.
I'm a moron.  I'm so used to short travel bikes being Flex stay, I completely forgot that the CBF is a completely different suspension design that...
I'm a moron.  I'm so used to short travel bikes being Flex stay, I completely forgot that the CBF is a completely different suspension design that doesn't/can't use a flex stay.
I’m actually pretty pumped on a short travel bike that’s NOT flex stay.
Add that the reach is over 510 (finally!)
And it’s CBF?  And carbon and red?
Damn that’s a nice bike
JVP
Seattle, WA US
3 hours ago
I had a pipe dream that Revel was making an ebike named the RE.
jones007
SEASIDE, CA US
2 hours ago
possibly the most technological innovation that's not a rumor ever? solar AI ebikes are here for $1899. create memes on the top-tube mounted display?https://phosgo.com/pages/reserve-product
solarAI
I can't tell, is the solar charging intended to be through cells covering the wheel disks? If so, I'm curious how that's going to work out. The collection area (ignoring parts of the bike that shadow a portion of the arrays) is not large, roughly 0.5m^2 for the pair of wheels, minus some coverage losses since square cells fit into an annulus can't give 100% coverage. I'm not sure what cell technology they are using, but assuming something like 20% efficiency, in perfect conditions, mid-day in the long part of the year, with the axles pointed at the sun, you could get something like 90 W. If the bike was propped up on the kickstand, then it would be less than ideal mid-day, so maybe 50 or 60W. So for an 800 Wh battery, you could get maybe 40 to 50% charge in a full day, dusk to dawn. If the cells on each wheel are wired in series as a single array to an MPPT, any shadowing of one cell affects the power output of all cells, so chainstays, seat-stays, fork, kickstand, rotors all detract from charge performance. Seems like it might be useful to charge your phone, but if you're counting on it to get you home after a long ride, good luck.
Blake_Motley
Chula Vista, CA US
2 hours ago
jones007 wrote:
I can't tell, is the solar charging intended to be through cells covering the wheel disks? If so, I'm curious how that's going to work out...
The website claims 50 miles of base range with 17 miles per day of solar, so that’s a 34% charge. For the 360Wh battery, 34% is 122Wh. Over the course of an 8 hour day that’s only ~15W of solar. With modern solar tech that honestly sounds conservative to me, as disgusting as this whole webpage is
jones007
SEASIDE, CA US
1 hour ago
The website claims 50 miles of base range with 17 miles per day of solar, so that’s a 34% charge. For the 360Wh battery, 34% is...
I didn't see the Wh capacity of the battery - that's pretty small. Honestly, with the bike sitting upright, probably not aimed toward the sun well, and with partial cell-shadowing, 15W might be about right. Seems about like covering the roof of your EV in the hopes of extending range. Kind of a drop in the bucket. Cell survival on the wheels probably isn't great either. Seems like a wacky idea, but I'm sure plenty of folks will part with their money for it.
monarchmason
Nevada City, CA US
33 minutes ago
Man… this forum is screwed. Everything is turning crab, each new product launch is 1.25% better than the shitty unusable last generation, and now we are discussing solar capabilities on an ai bike that will more than likely be a kickstarter scam. The future looks great! 😃
FullSendy
High St, IL US
26 minutes ago
"each new product launch is 1.25% better than the last generation that was also pretty damn good"
FTFY. Sucks, but most stuff is good now, so we get small revisions.
monarchmason
Nevada City, CA US
5 minutes ago
FullSendy wrote:
"each new product launch is 1.25% better than the last generation that was also pretty damn good"FTFY. Sucks, but most stuff is good now, so we...
I know I was being sarcastic dick about the industry. 🥴
FullSendy
High St, IL US
2 minutes ago
Sometimes it is hard to tell given a few takes on here.
Post a reply to: 2026 MTB Tech Rumors and Innovation - Longer and Slacker
