Heavy Weight Pants
CNutt
Morristown, NJ, USA
After finally wearing through my last pair of Dakine Thrillium Heavyweight pants, I am in the market for a new pair of high-strength, durable riding pants. I am looking for a thick nylon, moto-style pant, without all the additional moto reinforcement. Any recommendations?
10/26/2026 7:53am
I have 2 pairs of the TLD Sprint pant and I'm really happy with those.  I picked them up when the designs/colors change and they mark them down pretty cheap.
nwberm
Seattle, WA, USA
10/26/2026 4:14pm
Looks like eBay still has some Dakine Thrillium Heavyweight pants
NWRider425
Spokane, WA, USA
10/26/2026 8:34pm
NF DP5. Not crazy heavy but durable af
10/27/2026 7:51am
NO ONE MAKES GOOD DURABLE GEAR ANYMORE!! buy og tld on ebay
10/28/2026 3:21am
I have TLD pants since the mid 2000's and like the brand a lot. However, durability isn't everything, as the rubber pieces on, say, the iconic GP's that Sam Hill was wearing anno '08 aren't as comfy by today's standards and they lack pockets. My go-to pant in the last 2 years were TLD Skylines and I also like the Ruckus Cargo quite a bit, although the cordura-style material was less resistant to tire marks than I thought. OG Sprints are also very very good.
Mx
JVP
Bellingham, WA, USA
10/28/2026 11:17am
Where are you looking for durability? Different options for different needs. You can go lighter and still have great durability, but there's always a tradeoff between ultimate abrasion resistance and weight/comfort/heat. I designed Abit Gear pants for everything below except the heavy fabric.  NF has good options if you want the pants equivalent of DH tires.
Things that make long-lasting pants/shorts:
-Waist adjuster (velcro clogging or wearing out): Get something that doesn't use velcro.
- Stitching and zips (most common failure): Find pants with YKK Zips and heavier nylon thread. Key stitches at the back need to be a stretch stitch vs standard top stitch.
- Keys/tools blowing out pocket bags: Something with bottom-of-pocket reinforcement.
- Fabric that survives a gnarly slide on rock: Heavy weight nylon fabric is your friend.
Choose nylon with 5-10% elastane/spandex for stretch. Avoid polyester pants. Nylon is 30% stronger at the same weight without the stiffness of poly and nylon is stank resistant. Poly dries faster, takes sublimation prints, doesn't expand when wet, and is cheaper - pros and cons to everything. Most pants from quality brands will be Nylon.
CNutt
Morristown, NJ, USA
10/28/2026 12:11pm
JVP wrote:
Where are you looking for durability? Different options for different needs. You can go lighter and still have great durability, but there's always a tradeoff between...
Mainly looking for abrasion resistance, most of the areas I ride are composed of rough decomposed granite, and corresponding granite sands. Realy eats up any gear that hits the ground.
10/28/2026 12:46pm
Fly f16 pants
JVP
Bellingham, WA, USA
10/28/2026 1:15pm
CNutt wrote:
Mainly looking for abrasion resistance, most of the areas I ride are composed of rough decomposed granite, and corresponding granite sands. Realy eats up any gear...
Fabric weight is your friend in this case. Get the heaviest nylon that you find tolerable. Many manufacturers like me don't list fabric weight since no one knows what it means. Fabric weight is spec'd in GSM (grams per square meter).
My pants are 160 GSM nylon with 8% spandex. I'd call these "medium light weight". This is as light as I could go, balancing durability and decent breathability for my personal preference. I get to design what I personally like Smile
Abit Gear shorts are a little heavier, and they can definitely take a hit. These are 190 GSM nylon with 10% spandex - I'd call them "medium weight".  Shorts have lots of airflow allowing a little more fabric weight fudge room. That said, I wouldn't wear my own shorts in a hot/humid climate like Houston. I'd go ultra-light polyester in that climate.
Balancing heat vs durability is always the trick, so I designed thigh pockets to double as vents on both pants and shorts. Pockets require zips and a lot of stitching = a lot of labor, so the downside to this design is higher cost - especially when stepping up the thread spec.
If you're looking for exceptional abrasion resistance, find something over 200 GSM nylon. I just looked at NF and they changed up their product line since I tried them a few years ago. Their DP4 pants were stout.
10/28/2026 7:07pm
Iv been running the Signature Rover pants through winter here in NZ. Picked up multiple pairs when onsite. Have been using for riding, trail work, just every day work pants. Have been really good so far. Are a heavier weight to the TLD skyline pants i normally ride in.
10/29/2026 6:45am
I'd love a pair of heavy weight pants that had adjustable cuff openings (wide enough to get over hiking boots, but with a strap to cinch them down over said boot tops to keep dirt out) for digging.  I've tried a few hiking pants for that purpose and they all seem to have some failing, like too light of fabric in the knees, not enough stretch, shitty pockets, low crotch that interferes with riding to dig site, or bad lower cuffs (weak elastic straps, too small an opening, etc.).
Post a reply to: Heavy Weight Pants
