GR
6/23/2025 12:02pm
Hallo, i will install a new rockshox vivid r2c coil shock on my YT tues. 267X89 (10.5x3.5). What spring rate do you suggest? I am about 80-82kg race ready (175-180lbs).
Tftuned calculator suggests a 265 spring rate, which seems really low, even for a 267x89 shock.
The suspension lab indicates a 330.
Take those calculators with a big grain of salt, it's a rough guide at best.
Email YT customer support if it exist, ask their opinion. Consider that advise your starting point and accept the fact you may need to buy 2-3 springs before settling on a rate. Sprindex could be your friend here.
What year Tues?
Not sure how much they have changed in the last few years but they recommend a 300lb/in for a 2019ish one here - https://www.yt-industries.com/support/suspension-setup/
Here is 2015 vs 2024 leverage
Thanks guys! The tues is the first changed frame in 2012. Yt told me that they don't have don't have specific baseline recommendations for bikes from that era... I think i'll go for a 325, hope it's not that stiff.
I ran a 300lb spring on my 2015 at 190lbs bodyweight without kit. Also, the longer shaft shock has a higher shaft speed (lower leverage rate) deep in the travel which creates higher than normal damping, so don't over spring
My daughter and I both have MK3 Tues that use the same shock. I am 250lb and use a 400lb or 450lb spring on the bike compared to the 600lb to 650lb spring on my trail bike with a 205x5 shock. You definitely have to run a lower spring rate than normal with that giant shock.
Do you have the vivid r2c? I just don't want to have a wallowy soft feel, since the 267x89 vivid r2c is configured as low compression tune and also it hasn't any hsc damping. Do you reckon i would be ok with a 300 or should i get a 275? (supple ride with support and not harsh)
PS. the RS-VIVC-R2C-B3 has any differences with that of previous generations?
275 or 300? My opinion is get both.
Post a reply to: spring rate - YT tues
