Cane creek kitsuma owners
Jakub_G
SK
Hi, any of forum users here run cc kitsuma shock? If so, could any on you kind folks measure piggyback size for me?
bigbrett
Salt Lake City, UT, USA
8/2/2026 10:58am
Surely you could just email CC? They have great customer service.
jbfiets
sailsbury, NC, USA
8/3/2026 4:22am
CC has a document showing which frames it has clearance for. I think they also give overall dimensions.
Jakub_G
SK
8/3/2026 4:43am
I checked, sadly diameter is not listed there 🤷🏻
thresh
San Jose, CA, USA
8/3/2026 1:07pm
kitsuma air gen1 210x55
piggyback diameter is about 28.5 mm
distance between a piggyback outer edge of and the eyelet center is about 60mm, dials are about 62mm
i have the coil version i have but I'd assume it's identical
hope this helps
Jakub_G
SK
8/4/2026 2:02am
thresh wrote:
kitsuma air gen1 210x55piggyback diameter is about 28.5 mmdistance between a piggyback outer edge of and the eyelet center is about 60mm, dials are about 62mmi...
hope this helps
Sweet, thank you, that's all I needed 👍🏻
8/9/2026 4:11am Edited Date/Time 9/6/2026 9:38am
Since the thread exists already, maybe we can use it for setups, tips and tricks etc.?
I am installing right now a Kitsuma coil on a Propain Tyee 5. Has anyone of you a good base setting for me?
XL-bike, the shock is a 210-55mm and I am using a 600lbs spring on it.
I weigh 90 kilos in bike clothes.
Robbeni1
oulu, FI
8/9/2026 7:13am
Anyone have problem with gen 1 kitsuma and hsc knock? My shock needs 6 cliks from full open hsc to stop knockking so it seems something is loose. I have assembled the shock many times now but cant seem to find anything wrong in it.
8/9/2026 1:54pm
Mo(n)arch wrote:
Since the thread exists already, maybe we can use it for setups, tips and tricks etc.?I am installing right now a Kitsuma coil on a Propain...
LSC 5, HSC 4, HSR 2, LSR 0
That’s basically the setting Cotic reccomended +- a few clicks here and there. It’s a gen 2 Kitsuma 550lb Coil, I weigh 87kg, on a Rocketmax gen 4 XL.
I’m kind of a set and forget guy, I expected to find the rebound too fast but not so. The riding I like doing is steep enduro type tracks but more often than not find myself on local off piste, which are often trying to get the most out of 60m of vert with little stump jumps and the like. I don’t do big jumps so my settings might be completely wrong for that!
8/9/2026 5:26pm
Robbeni1 wrote:
Anyone have problem with gen 1 kitsuma and hsc knock? My shock needs 6 cliks from full open hsc to stop knockking so it seems something...
It might just be the HSC spring has settled over time - which can happen - so is floating loose when the dial is fully open and needs a few clicks to secure it. I don't know if thats the issue for sure but I've seen the same thing in Float X2's of a certain age
8/10/2026 3:02am
I had something pretty similar on an older shock. Fully open, the adjuster had a bit of play, then after a couple of clicks it basically went away. Never knew if it was wear or just normal tolerance.
Post a reply to: Cane creek kitsuma owners
