Tires and inserts
tylerb
Edgewater, CO, USA
6/28/2019 3:16pm
You feel you get a more damped experience from exo+ and cush core than DH tires?
(no sarcasm, generally curious as i haven't run cushcore ever)
To clarify, I am currently running EXO front and DD rear with Cuscore and have run DH casing no inserts in the past. I haven't tried EXO+ yet, but they are next up.
The feeling is somewhat similar, but I do feel like Cushcore has the edge here and has too many advantages not to run it. Rim protection, run flat capability in a race scenario, holding the tire bead on for cornering...All this has added up to me running Cushcore front and rear for almost 3 seasons now with EXO tires.
6/29/2019 6:51am
Tannus Armour, from the UK (via Kickstarter), has been selling relatively well in my area. This is probably because many riders here are still using tubes and also because Tannus Armour is less than half the price of Cushcore.
No, I don't work for these guys. Yes, it's a tire insert which only works with tubes. An old friend actually prefers this over his Huck Norris.
Has anybody tried it?
Chis1
6/29/2019 12:35pm
Chis1 wrote:
I’m currently running tubes with Tannus armour 🤭
Only had them about a week
I definitely want to hear more from people riding Tannus armor. Having the extra cushion right on the contact patch makes way more sense to me...
I definitely want to hear more from people riding Tannus armor. Having the extra cushion right on the contact patch makes way more sense to me for trail chatter vibration damping. I just want to make sure that the extra support is enough to prevent pinch flats before I pull the trigger
after two weeks of running them. No flats yet. i am riding mostly surrey hills though so not very rough.
I do have two weeks in scotland now though so will be a good test for them.
one disadvantage so far would be weight. I have gone for light weight tubes on their advise but it is defiantly heavier.
Weight have never really bothered me though.
Chis1
6/29/2019 12:37pm
Tannus Armour, from the UK (via Kickstarter), has been selling relatively well in my area. This is probably because many riders here are still using tubes...
running them now
6/29/2019 2:49pm Edited Date/Time 6/29/2019 2:52pm
No inserts yet, just stans race sealant with some not so secret extras. Going to give cushcore a try soon, although I am skeptical because people are still burping or losing tires with them. Might have to try some of that glue/sealant Marsh was using on Minnaars wheels at Ft William - https://www.youtube.com/watch?v=KB-kZv0rIzo
Does anyone know if tire manufacturers are working on integrating a foam cushion into the tire?
Any clue what Maxxis "Breaker" is?
The only report I've heard about Tannus is that the foam breaks down with use and pulls away from the inside of the tire, meanwhile it's still possible to pinch the baby tube they use.
Interesting to hear the difference in tire set-ups folks are running. I've always preferred DH tires, but usually that means slow rolling on the trail bike. I recently procured some 2.3 - 2.5 maxxis DD & DH combos that I am looking forward to trying soon, starting with a 2.3 DHR2 on the rear and 2.5 Assegai on the front, both maxxgrip. I have tried the 2.4 EXO+ DHR2 in maxxterra but it's not my favorite front tire as it tends to lose grip easily on wet roots. I can't feel the difference between the EXO and EXO+, but I have to run them both at higher pressure than dual plies to avoid rolling the tire or wrecking rims, so they all end up on my hardtail, which is mostly ridden on local trails with 5 miles of pavement to and fro home.
rockchomper
Rancho Cucamonga, CA, USA
10/19/2020 1:32pm Edited Date/Time 10/19/2020 1:45pm
Not so much a question of inserts but i gots a tire question!
I am looking for a DH tire with a long lasting compound and it must resemble the DHR 2 as thats my favorite rear tire!
so my problem is Maxxis only make they're DH tires in Maxxgrip so I bought the Michelin DH34 bike park compound only to find out the bike park compound has less protection and less "beefiness" than they're race compound.
so does any one know of a DH casing tire with a long lasting compound that somewhat resembles the DHR2 ?
10/19/2020 2:05pm
@rockchomper:
I ran the Michelin Wild Rock'R2 in Gum-X compound on the rear of my enduro bike and it's been a very good tire. It's also not very expensive, I guess.
However, this is not a DH casing tire and I am running it with CushCore, which is the shiznit for me. I don't know much about DD and EXO+ casings on Maxxis, since I never had them, but for me simple EXO with CushCore works just fine. The Michelin seems to be somewhere between EXO and DH casing on a Maxxis scale.
Cheers!
Mx
rockchomper
10/19/2020 2:28pm
@rockchomper: I ran the Michelin Wild Rock'R2 in Gum-X compound on the rear of my enduro bike and it's been a very good tire. It's also...
@rockchomper:
Cheers!
Mx
Exo with my rimpact inserts aren't cutting it for me, I currently have 4 plugs in my exo tires so never again will I run exo tires on a dh bike!
spoon_
Melbourne, AU
10/19/2020 7:55pm
Not so much a question of inserts but i gots a tire question! I am looking for a DH tire with a long lasting compound and...
Gwinions? DH casing one is closer to DD but with bead insert though, dunno if thats a good or bad thing
Post a reply to: Tires and inserts
