This might be a newb question but I was curious about getting my cracked frame repaired. I have a Nomad V4 aluminum that cracked on the seat tube weld. I was watching some of the Frameworks series and Neko was getting his frames repaired by Frank the Welder. Is this a thing that people are doing nowadays? Does anyone have experience with this?
Aside from that, I think the welding part is pretty standard TIG.
I would not ride the bike at all if I saw the cracks getting longer. Make sure you have good dental insurance.
The welding will decrease the structural integrity of the aluminium, so the frame would have to be heat treated again afterwards. That comes with it's own set of problems, as it could easily warp the frame out of alignment. On top of that you'd need to find shops that do the welding and heat treating for an acceptable price. Repairing the frame could end up costing close to what a new frame would cost.
And even if you did go get it repaired: The frame cracked for a reason. And if you continue riding like you did before hand, it's likely to crack again.
Bottom line: Just buy a new frame.
I'm in the "it isn't worth the effort to repair" camp, because it will probably break again, and it could be dangerous. If you are riding a Nomad, you probably aren't riding XC loops right?
My warranty case is closed and currently Santa Cruz has not offered any options for crash replacement or buying a new front triangle. I am the second owner of the bike and this is an interesting lesson in warranty management.
Post a reply to: Repairing cracked aluminum frame
