Self servicing Vivid
Rockshox suggests servicing shock every 100h - I did it at the lbs and they told me to do it more often (50-75hrs) since based on their experience if you make it every 100h it's not enough.
The idea of bringing it for X days to lbs every 50hrs does not make sense to me. I used to do 50h service of superdeluxe by myself with no problem but I see two problems with vivid:
  • seems like you need some expensive proprietary tool to do it by yourself - any alternatives?
  • I can't find any video tutorials on youtube. There is a service manual from RS but it would be handy to see it on video - not every point is unequivocal to me.
Any experiences with intervals (100h or less?), proprietary tools (cheaper alternative?) or servicing by yourself?
Dave_Camp
7/21/2026 6:37am
I just did mine- full 200h damper rebuild as it was clunky, turned out the main piston came loose.
Anyway the 100h air can service is pretty easy- need vice, strap wrench and large crescent wrench or Knipex pliers.  Outer sleeve slides up a few mm exposes a snap ring- remove that then slide outer sleeve off.  Unthread silver sealhead with wrench, unthread inner airsleeve with strap wrench, pull it all off, clean, swap seals and reverse reassemble.
The 200h rebuild is harder, but I did manage mine without any of the special tools- I used some channel-lock pliers to unthread the seal head which is a huge gamble and scratched it all up, but in the end it worked.  Can set the IFP a few mm high and not have to use the threaded shaft extender tool.  All of that is no no according to SRAM but I designed the shock 5 years ago when I worked for them so I have plenty of experience rebuilding those haha.
7/21/2026 6:44am
I think your shop is trying to milk you.  Standard shock service interval is fine for it.
I serviced one of mine (2024 version, not new 2026).  It does require a number of tools that you don't need for like a Super Deluxe.  You might be able to do it without their own versions, but the big one is a large crow's foot which is machined to perfectly match the short sealhead height.  Then you need a typical assortment of vice soft jaw inserts, smaller crow's feet, plastic shaft protector, plastic picks, etc.  It didn't feel any more difficult than servicing a Super Deluxe, just a lot more steps and seals to replace.
The one thing that's kind of a headache if your shock is not a very recent 2025 version is that between when that style Vivid launched and when they switched over to the 2026 update, they went through 3 different iterations of the sealhead.  And each one used a different combination of o-rings and split washers.  So if you buy a service kit, it can be difficult to know if it will match the sealhead in your shock.  It might make sense to have its first service done by a suspension service specialist who can get the appropriate service kit and/or upgrade yours to the latest version.
7/22/2026 11:49pm
Thanks for the answers guys.
Rockshox puts a lot of pressure on being specific with torque (17Nm) for the crowfoot - I won't be able to do it with Knipex for sure. Do i need to invest in crowfoot + specific size tool?
Do you really have to swap seals every 100h? For superdeluxe 200h was enough...
7/23/2026 12:26pm Edited Date/Time 7/23/2026 12:30pm
Thanks for the answers guys.Rockshox puts a lot of pressure on being specific with torque (17Nm) for the crowfoot - I won't be able to do...
"Do you really have to swap seals every 100h?"
I don't know. I DO know that I don't want to do that, though!
So I tend to reach down once or twice per ride and wipe the dust off my fork stanchions. I figure if I do that then there's less material coming into contact with the seals, less material potentially getting across to the other side of the seals, and less contamination getting into my foam rings. When I did a fork lowers service last year, my foam rings were super clean still.
Also, I’ll tend to leave my bike upside down every so often and whenever I do I’ll push down on the fork to make sure to cycle some of the fork oil up to the foam rings and seals.
I send the fork off for a full service every year and they do the seals and rings at that time.
7/27/2026 1:03pm
Torque on a lot of shock parts is definitely critical - the fine threads means its very easy to overtighten them (a nightmare to undo in the future!) or they will work loose in use and lose air pressure. You can get a few different torque adapters which are a little more universal so you don't have to find a specific crowfoot that will only work for the vivid
Personally I find most people are fine to just do a 200 hour service or every year - some air shocks can get dry quite fast so it might suit some people to just clean them out and regrease but I don't think its critical to change seals at that point. You can check IFP pressure and damping at the same time
I also think a lot of people under-grease or don't clean things out properly and thats why shocks look bad after 100 hours. Or they use poor quality 3rd party seals which wear out too fast, but either way most genuine seals should last to 200 hours fine and that sounds more like user error to me
Dave_Camp
7/27/2026 2:09pm
I'd say if you service once a year- you're ahead of most.  It'll be fine unless you ride year round in Scotland or somewhere super muddy.
7/27/2026 3:45pm
Yup I agree - I had a Float X2 last week that came back after 14 months, it was a bit dry in the dust wiper and maybe some air in the damper but overall pretty OK - turned out it had done around 350 hours.....
I think RS stuff probably holds up better than fox in most cases as well
As for torque wrench thigns, an adapter like this is a handy way to convert any spanner for a torque wrench https://www.motionpro.com/product/08-0380
7/27/2026 4:02pm
Yup I agree - I had a Float X2 last week that came back after 14 months, it was a bit dry in the dust wiper...
This is an awesome tip. Didn't know things like this existed!
Post a reply to: Self servicing Vivid
