@Cascade Components - Homework Help
jma853
Kabul, AF
Screenshot 2025-10-22 at 22-13-31 HW 8.pdf .png?VersionId=kzd
Hi Cascade Components (or anybody else decent at Statics),
It would be an honor if you could lend us your linkage expertise in solving this homework assignment. We've been wracking our brains over this for a while and can't figure it out.
Thanks ๐Ÿ‘
10/22/2025 9:34pm
Start by finding the moment due to rider weight about the chainstay pivot on the front triangle. Since this is static, the sum of the moments about that point must be zero. This will allow you to find the reaction force at the seat stay. Remember since everything is pinned, the force can only be along the axis of that member. Similarly, you can then do a sum of moments about the upper link pivot on the front triangle to find the reaction force at the shock.
jma853
Kabul, AF
10/22/2025 10:02pm
Start by finding the moment due to rider weight about the chainstay pivot on the front triangle. Since this is static, the sum of the moments...
Right - so when you say everything is pinned, does that mean that point F only has a force acting vertically against the rider's weight divided by two? (i.e. no Fx and only Fy) If this is true, would this also mean that the shock is only feeling forces along its length?
10/22/2025 10:10pm
jma853 wrote:
Right - so when you say everything is pinned, does that mean that point F only has a force acting vertically against the rider's weight divided...
The rear wheel force would be half the rider weight as described here. In the case of a member thatโ€™s pinned on both sides, the force vector is along the axis that connects the two pinned points. So the shock can only experience tension/compression. That makes the second question about the direction of the force through the shock easy. The direction is the orientation of the shock.
jma853
Kabul, AF
10/22/2025 10:38pm
The rear wheel force would be half the rider weight as described here. In the case of a member thatโ€™s pinned on both sides, the force...
Ahh, I forgot about the force vector being along the axis that connects the two pinned points. That's my bad. Thanks to your help, I actually have an answer now, which is a significant improvement compared to ~an hour earlier. I didn't expect you to reply at all since I posted this thread half jokingly, but I honestly appreciate it ๐Ÿ‘
10/22/2025 10:43pm
jma853 wrote:
Ahh, I forgot about the force vector being along the axis that connects the two pinned points. That's my bad. Thanks to your help, I actually...
What did you get?
jma853
Kabul, AF
10/22/2025 11:09pm
What did you get?
While I was redoing my work to make it clearer, I realized I made a mistake while taking the moment about the chainstay pivot (literally the first step ๐Ÿ˜ญ)image 484
For some reason, my forces at the rear axle / seatstay sum to zero.
jma853
Kabul, AF
10/22/2025 11:38pm
jma853 wrote:
While I was redoing my work to make it clearer, I realized I made a mistake while taking the moment about the chainstay pivot (literally the...
Anyways, after throwing a bunch of shit at the wall, I got a variety of answers ranging from 150, 178, all the way to like 700-something. I'll probably regroup with my study group tomorrow and try to squeeze into office hours next week.
10/22/2025 11:43pm
The moment about the chain stay due to weight is correct at 82.5*465. The remainder of that equation needs to be for the seat stay. So youโ€™d see things like 175/459.62 (similar triangles like you are using but for the seat stay).
10/22/2025 11:45pm
jma853 wrote:
Anyways, after throwing a bunch of shit at the wall, I got a variety of answers ranging from 150, 178, all the way to like 700-something...
The 178 number is off by a very small amount. A fraction to be specific.
10/23/2025 7:52am
freeriding wrote:
155.08
This is what you get if you only account for the y component of the reaction force at the seat stay. If the rear axle were to be horizontal from the chain stay pivot that assumption holds, but in the case of it being offset, both the x and y components of the force contribute to the moment.
bstens
Seattle, WA, USA
10/23/2025 8:12am
would read again.
sweaman22
Calgary, AB, CA
10/23/2025 3:07pm
Yep. Fascinating diversion.
What school / collage grade is this?
jma853
Kabul, AF
10/23/2025 6:16pm
image 485
Oddly enough, the drawing of the diagram I sent in the first image was wrong - the rear axle should be coincident with the chainstay pivot as per the answer key. The free body diagram I have at the bottom of the page shows the corrected pivot points. Due to rounding errors, my answer came out as -169 but the answer key says it should be -164 point something; fortunately, the TAs are pretty generous with rounding so I'm just gonna leave it as that.
jma853
Kabul, AF
10/23/2025 6:17pm
Statics class, but honestly this is a fair question for Physics 1.
10/23/2025 6:49pm
jma853 wrote:
Oddly enough, the drawing of the diagram I sent in the first image was wrong - the rear axle should be coincident with the chainstay pivot...
image 485
Iโ€™m not sure about this diagram. Is whatโ€™s sketched here accurate? Because if so, the answer is 155.178. IMG 1303
jma853
Kabul, AF
10/23/2025 7:42pm Edited Date/Time 10/23/2025 7:53pm
image 485
image 486
Okay, after I redid it I got the same answer. I'm just as confused as you are as to why the diagram they gave us, which positions the rear axle below the chainstay pivot, is apparently drawn incorrectly according to the answer key. The diagram you sketched is correct according to the answer key, but at this point, I think it's probably fine to double-check with the professor to see if the answer key is wrong.
10/23/2025 7:53pm
jma853 wrote:
Okay, after I redid it I got the same answer. I'm just as confused as you are as to why the diagram they gave us, which...
image 486
The dimensions arenโ€™t well drawn to be honest. What I did there is a graphical approximation of leverage ratio by the way. If you dimension the shock ever so slightly shorter (in this case 0.01 mm) and then look at the vertical displacement of the rear axle and divide that number by the difference in shock length it gives you appropriate leverage ratio. As the difference in shock length approaches zero, the approximate leverage ratio approaches the actual leverage ratio.
jma853
Kabul, AF
10/23/2025 8:18pm Edited Date/Time 10/23/2025 10:26pm
image 486
The dimensions arenโ€™t well drawn to be honest. What I did there is a graphical approximation of leverage ratio by the way. If you dimension the...
Yeah, I agree that the drawing isn't great. Unfortunately, I don't have access to the answer key so I can't just reference it to see the work that we are actually expected to do; things will probably be clearer once I talk to the professor about it.
It's cool to see the way that leverage ratio is calculated. I'll definitely try to learn more about it in my own time
10/24/2025 12:09am Edited Date/Time 10/24/2025 12:13am
y.chainstay pivot = y.split pivot -----> 155.08
y.chainstay pivot = y.split pivot - 25 -----> 178.51
(ritter section applied)
jma853
Kabul, AF
10/27/2025 9:04pm
image 486
I checked with the professor today and it turns out the answer key accidentally used 425 instead of 465, which was what gave the incorrect answers.
Due to the unclear diagram, any answer close to 155 and 178 should be accepted. ๐Ÿ‘
Thanks for the help! Out of curiosity, how did you solve for the force through the shock in Solidworks?
10/28/2025 10:30am
jma853 wrote:
I checked with the professor today and it turns out the answer key accidentally used 425 instead of 465, which was what gave the incorrect answers.Due...
It's just an equation driven dimension on a line. The equation is (d/(l1-l2))*F where l1 is the initial shock length, l2 is a second shock length, d is vertical wheel displacement, and F is the axle load. This equation is an approximation of the actual leverage ratio. The smaller the difference between l1 and l2, the closer the approximation is to the actual leverage ratio. A difference of 0.01 mm is plenty small to get a very accurate number. The quick and dirty is make l2 1 mm less than l1 and then you wheel displacement is approximate leverage ratio, however it's a little less accurate than using a smaller step.
Post a reply to: @Cascade Components - Homework Help
