Charlottesville, VA
Hey everyone, looking to try something different after I wear out my Maxxis tires. Right now I’m running assegai maxx grip DD casing front, and a dh casing dhr2 maxx grip rear. I’m interested in the Michelin’s because of their weight. The assegai I run in the front weighs around 1400 grams, and the wild enduro supposedly is around 1000 grams. Does anyone have insight about how the casings and compounds compare? I’m hard on wheels and tires and like to have a durable tire. I also run cushcore front and rear.
Thanks
Thanks
Raced on them at Snowmass Big Mountain Enduro- pinged the front hard a few times (had cushcore in the back). Also took them to Moab for 3 days and ran into a lot of rocks.
They roll slow but so do Assegai/DHR2 (esp Maxxgrip). The rear tire wore out pretty fast (wore crazy fast in Moab). But they are really good on rock/roots.
I would definitely buy them again- I think they are cheaper ($49 on Jenson!) and as you said lighter than Maxxis equivalents.
FYI I regularly flat Maxxis DD casing at both ends of my bike.
Add on the stupidly quick wear rate and the not much above average grip, I'd not recommend them (especially if you are hard on tyres). I think in total they lasted 2 months before they needed to be replaced, so their cheap price is a bit of a false economy.
Another plus that you notice right away is the off camber performance, it hooks up so well I'm not worried about loosing the front end at all but the back has definitely stepped out on me a few times going through those sections of trail.
I ride every weekend for 3-4 hours and haven't noticed much wear at all. Haven't really noticed a difference in rolling resistance either.
The wilds are harder to flat than the DD maxxis, but they don't offer as much sidewall support. Hard to believe they are more reliable, but they have proven themselves in my experience.
I've been running the wilds for almost a year now, and have worn out a front and 4 rears. I went cushcore a couple weeks ago and Im never going back.
Wilds + cushcore is the ultimate pnw combo in my experience. Only issue: Loose over hard, or other genuinely very dry conditions. I say maxxis if you ride mostly dry and michelin if you ride mostly slop and hero like myself.
Post a reply to: Michelin Wild enduro vs Maxxis assegai/dhr2
