Tweaking Norco Sight Mix and Match Linkages
monarchmason
Nevada City, CA, USA
Hey yall!
I have a question about the Norco Sight Gen 5 and its extra linkages you get if you buy a frameset. Originally I was running this bike with in the mullet configuration with the 27.5 rocker link and the 27.5 shock mount tabs. Now it was fine, except the rear end was short. I didnt love that.
So I got the grand idea of putting the 29er rocker linkage on the frame and keeping the 27.5 shock mounting tabs on the bike with the 27.5 wheel. To my surprise and not, it made the bike a lot more progressive and the rear end longer. This is a pro for me, as RockShox forgot to manufacture enough Vivid Air tokens. At least thats what my LBS says.
However, it had me wondering, What changed in this alteration? Is there more travel technically, or is there less? If I ran the 27.5 rocker link, with the 29er mounting tabs, would I get a regressive curve to my bike? I know the chainstay length is near the same as a 29er setup (my size 2 measures at 430mm now instead of 424). My head angle slackened a little and BB dropped a smidge. But the bike is still completely rideable because of the mile high stock BB.
I guess Im asking what happens when you mix up these linkages, if anyone can answer that.
I like this bike now with the linkages mismatched, however, something feels off, aside from my new Vivid coming with very little oil inside. I cannot do kinematics math. I need help.
Thank you!
Screenshot 2026-01-27 at 6.46.56%E2%80%AFAM 0.png?VersionId=MOwDp7zRva.
Screenshot 2026-01-27 at 6.50.45%E2%80%AFAM 0
5/4/2026 5:58am
Hey yall!I have a question about the Norco Sight Gen 5 and its extra linkages you get if you buy a frameset. Originally I was running...
Hey yall!
Thank you!
I'd actually love to know the answer to this as well if any of the illustrious Vital enginerds were so inclined
cmaac
Tahoe, CA, USA
5/4/2026 6:59am
I may give this a shot on the current rig!
Can you fit a 29 with the 27.5 rocker?
monarchmason
5/4/2026 7:04am
Unsure, I dont have a spare 29 rear wheel. I did swap it back because it was pretty slack for the terrain in my area. But if you have some steep hills, it turns it into a weapon.
monarchmason
5/7/2026 8:41pm
Hey yall!
Thank you!
Still waiting for one of those tech forum nerds to chime im lol.
5/7/2026 11:30pm
I don’t have the dimensions for both the mullet and 29 Sight set ups so can’t comment with 100% certainty. That said, typically mullet links on Horst bikes makes them less progressive. The lower shock mount position can be used to control progression. I would assume the mullet rocker link makes it less progressive and the lower shock mount is then used to offset that so that the mullet set up and 29 set ups have similar leverage curves. If that is all true, it would mean running the 29 link with the 27.5 lower shock mounts would indeed make the bike more progressive than the standard 29 or 27.5 set ups. The 27.5 link with 29 shock mounts would be less progressive, but I don’t think it would alter the curve so much that it would become regressive. I’ll try and find the dimensions for the 29 set up since that’s what I don’t have. Or at least approximate it. Then I can give a better answer.
monarchmason
5/8/2026 7:01am
I don’t have the dimensions for both the mullet and 29 Sight set ups so can’t comment with 100% certainty. That said, typically mullet links on...
Thank you for the input! There is definitely a perceivable difference, but I did not know if it had anything to do with change in travel or actual kinematics.
robrixon
PV, QLD, AU
5/22/2026 5:18pm
What dimensions do you need mate? I’ve just picked up a Sight and the 29/29 link today.
5/22/2026 5:53pm
These two triangles
IMG 3264
robrixon
PV, QLD, AU
5/24/2026 10:58pm Edited Date/Time 5/24/2026 11:00pm
These two triangles
These two triangles
IMG 3264
Double checked my real-life measurements on drawing below - after scaling it using the bearing dimensions - and they correlate pretty closely.
Part No.8 is the RH lower shock mount.
Artboard 1
AgrAde
., BV
5/31/2026 5:04pm
I'd been thinking I should look into making some new shock mounts for my Optic to slightly lower it and add progression. Colour me curious.
6/1/2026 5:20pm
Does anyone who's done this 29 link and 27.5 shock mounts have a BB height they can share? It has been a long time since I've looked at the Sight and don't have it in front of me to double check anything. By the dimensions I have, it would be an increase in travel, progression, and BB height.
7/6/2026 5:59am
Little late to the party with this but I'm building up a sight frame as full 29, my frame only showed up with the 29 shock mounts but no rocker link. I've fitted the lower mounts in anticipation. Is someone in the know enough to work out if/how this will affect the bike in terms of kinematics or am I just going to deal with a steeper head angle and taller bb until the 29 rocker shows up. Cheers all.
Post a reply to: Tweaking Norco Sight Mix and Match Linkages
