Hancock, MI, USA
Long story medium, I am trying to source a hub solution for either 142mm or 148mm spacing and a 12mm axle, however, there is a caveat.
It needs to be able to secure itself (i.e., not a traditional thru-axle).
In a perfect world, the hub would be bolt on like Hope SS/Trials hub, but it appears they only make this in 10x135mm.
Surly makes a through axle with a bolt, but I question its clamping power:
https://surlybikes.com/parts/thru_axles
Another solution would be something like this Azonic axle in the proper width:
https://oneal.com/collections/azonic/products/azonic-recoil-axle
So, does any one know of a 12x142/148 bolt on hub, or thru-axle with nut provisions on both sides?
Thanks in advance!
Shimano AX76 looks like it might fit the bill?
Could you use a through axle for a 150x12 frame and add a couple of washers to make it smaller?
I know Hadley still makes them.
https://www.mcmaster.com/product/93275A057
Thank you all!
If/when this project get built I will make sure to post a bike check.
And getting a Dave Camp reply makes my LitterMag fanboy self happy!
Gotta love McMaster.
Post a reply to: Esoteric hub question - Do you know of a 12mm solution like described below?
