Cockpit Setup Puzzling
MoldyMTB
Calgary, AB, CA
Edited Date/Time 6/15/2026 4:56pm
Lately ive been struggling to carry speed in corners, it feels like my front wheel was on the verge of washing out. Lack of front wheel grip has lead me to lowering my handlebar rise, and try slightly longer stems. Nothing was really helping...
I then tried going the opposite way w/ my cockpit, threw a shorter stem and raised my bars a bit (41mm stem -> 31mm stem // 30mm rise -> 40mm rise). For some reason this seemed to be the magic cure, I was able to attack corners with way more confidence, i had way more grip and speed through corners, i was finally able to push and generate speed on exits.
I am struggling to understand how changing my cockpit so im theoretically further back on the bike somehow leads to more front end grip and confidence?
ntm95
Lloydminster, AB, CA
6/16/2026 7:56am
MoldyMTB wrote:
Lately ive been struggling to carry speed in corners, it feels like my front wheel was on the verge of washing out. Lack of front wheel...
What bike and size, and how tall are you ?
Can be suspension related too, if you have a fork that's piling up.
6/16/2026 8:17am Edited Date/Time 6/16/2026 8:18am
^^ This.
Maybe it's also the confidence part in your riding. Static and dynamic more upright stance could mean more confidence and less hanging from the back in every ride situation? It's all about your dynamic center of gravity.
MoldyMTB
Calgary, AB, CA
6/16/2026 12:28pm
Transition regulator - basically the motorized version of their sentinel in a large. And I'm 5ft 11in.
I did a bit more research after I made this post, and apparently the shortened reach might be more beneficial than trying to bring my position forward. It's still kinda hard to wrap my head around, but the longer reach might have caused straighter arms while riding. Shortened reach allows bent arms and a more natural body position which apparently really helps with cornering confidence.
It still seems counterintuitive to me but its working haha.
ntm95
6/16/2026 12:50pm
MoldyMTB wrote:
Transition regulator - basically the motorized version of their sentinel in a large. And I'm 5ft 11in. I did a bit more research after I made this...
The regulator has a pretty decently balanced f/r ratio.
Bikes like that are effected negatively in trying to ride it like older geo. You want to stay centered and ride through your feet/hips rather than through your hands/shoulders. Front grip comes from your feet, not your hands.
Hence, shorter reach and higher stack is beneficial. Forbidden has this pretty dialed on their e-bikes like the e-dreadnought, 461mm reach, 670mm stack on a large, corners like nothing else once you get used to how to ride them. The regulator's f/r ratio is pretty similar.
6/16/2026 12:54pm
I also think it could be partly tire choice. I was an Assegai user for many years and tried a Kryptotal last year, and I 100% preferred it. I had way more front wheel washouts or the sensation of losing the front with the Assegai, and feel way more confident and predictable with the Conti.
Kapolczer
6/16/2026 3:41pm
As some of the others have said above, I think that the body position the shorter stem and higher rise bars put you in is what’s leading to your added confidence. You’ve found a better “balance point” on the bike so to say, as in your ability to manage weighting the front and rear as needed. As you push into corners your fork will compress, and if you’re already quite stretched out on your bike, you’re naturally going to want to pull away from the front end because it feels like you’re off balance and getting pushed OTB, meaning you load the front wheel to initiate, and then start to lean back and unweight it, causing it to wash and/or understeer.
Having your bars higher and closer to you likely allows you to hold your dynamic body position better, without feeling like your getting pushed over the front of the bike, and therefore maintaining front end grip better and more consistently through the corner. You may also have more “arm travel”, meaning your arms have more bend to them for the same body position, so you have room to straighten them without pulling your COG forward.
Again, as some others have said, the FC/RC balance of the Regulator is in a good range. Longer rear centre's naturally put more weight on the front wheel without needing to dynamically shift your weight (compared to a short RC on the same bike), which usually means you can have a shorter reach/higher stack/shorter stem, and be in a more defensive or rearward body position, without sacrificing front end grip. This means you can still attack the front wheel if you want in corners, but can also be more static and centered in the bike and achieve front end grip.
If you have a bike with a short RC, and then shorten the reach/stem, you often shift your weight too far to the rear of the bike, making it very difficult to get enough front end grip unless you’re fully committed to the front wheel, which either goes great or terribly, rarely in between.
Post a reply to: Cockpit Setup Puzzling
