Cannondale sv2000 rear shock question
Hey guys! New to the forum but not new to MTB. I used to have a Schwinn sweet spot back in 2000. Haven't ridden in years and have gotten heavier than I used to be. I picked up a very very cherry sv2000 and want to get back into riding. It'll be road only till I drop some weight. Speaking of. I'd like to switch the rear shock to accommodate my 275 ass. I'd like to switch the air oil shock for a coil spring shock. If any of the tech savvy guys read this I'd welcome some good suggestions for a heavy duty rear shock to try.
Thanks in advance for your help
1000002623.jpg?VersionId=CZ6QA8larIyYxOt7n2WSY6
Buckets Up
Hancock, MI, USA
12/2/2025 5:01pm
You’d be much better served saving the money you’d use for a shock to invest in a modern bike.
As unique as that Cannondale was, full suspension bikes from the era are extremely outdated and not really ideal for any application.
I suggest looking at gravel bikes with more relaxed geometry or even something like a rigid bike-packing focused rig if you’re just going to be tooling around on the road for a while. Then when you’re ready you can buy a new mountain bike and have two awesome steeds.
If you can even mount a modern shock on that Cannondale, your going to spend at minimum ~$350 to end up with a bike that will pedal poorly on the road and would be equally frightening to ride in any modern mountain bike scenario.
It may sound harsh, but it’s not worth the investment.
12/2/2025 5:12pm
Hahaha you're right but because it's old and outdated and from my riding hay day I'm gonna keep it and up grade it. It'll get some looks on the trails. And someone has to keep the old tech alive and going. So come on folks send me some good suggestions please
Whattheheel
Spearfish, SD, USA
12/2/2025 5:25pm
Measure the length of the shock from the center of both bolts that mount it to the frame and that would be your eye to eye and then measure the end of the stanchion which would be the skinny part of the shock towards the rear derailleur and that would be your stroke. It is old so not sure if you would be able to find one tho.  Maybe send it to Specter Suspension and they can rebuild it to hold air and work better?  Tough to say to be honest and this coming from a guy that has worked/managed bikes shops since ‘02.
Revelstoke, BC, CA
12/2/2025 6:40pm
What's the eye to eye on the shock? Fox still makes the DPS in a variety of sizes to fix legacy bikes and I've had good luck finding modern options even for late 90's bikes. Otherwise, getting it serviced would work out well if you can find somewhere that has the ability would be great. Is that one a cane creek or a fox?
12/13/2025 4:46am
It's got a fox vanilla shock.
It's the 165mm
12/15/2025 7:55am
Hahaha you're right but because it's old and outdated and from my riding hay day I'm gonna keep it and up grade it. It'll get some...
I am going to totally agree that this bike is worth it. No where was budget mentioned so saving to invest in a newer bike does not seem to be the issue. I also just bought one of these. I am 180 so the stock shock worked for me. I swapped it to a 1x drivetrain and do exactly what you described. I ride it around as a commuter and on the many gravel paths around my house. I also ride mtb trails with my 6 year old on it. It is hilariously fun. It makes me wonder what a modern geo but similar layout version would be like. I have modern bikes, but this one delivers the smiles and funny looks on the trails.
I say ride the heck out of it. Unfortunately I do not have any useful recommendations for a shock. As others have mentioned there is a good chance you can rebuild the stock one. The dampers on fox shox from that era are reliable so MAYBE you can just do an air can service. My shock still has functional damping. The front shock, less so.IMG 6375
12/15/2025 8:16am
Dude that's badass!!! Least I'm not the only one rocking old tech. I enjoy it. And yeah it's the moped effect. Fun to ride till someone sees you 🤣
Post a reply to: Cannondale sv2000 rear shock question
