Brake bleed isn’t working
finlayy
Edited Date/Time 4/24/2020 8:35pm
4/20/2020 7:57am
finlayy wrote:
[img]https://p.vitalmtb.com/photos/forums/2020/04/20/9466/s1200_454C3FDB_0995_4565_9BF6_F3471643993E.jpg[/img]
have you tried bleeding your brakes instead of your breaks?
Scrub
Elk Grove/Truckee, CA, USA
4/20/2020 8:45am
Did you take the cable out before putting the fluid in there?
finlayy
4/20/2020 8:57am
They originally had fluid in them then I changed the cable over and most the fluid came out.
4/20/2020 9:50am
Did you replace the olive and barb for the new hose before reattaching to the lever? (see photo)
If you did replace both olive and barb then can you describe exactly where the leak is coming from? Photos would help, as would more info on the type of brake and maybe some info on how you bled the system. Is the leak between the lever body and hose interface? Is it at the bleed port on the lever? Does the lever have a cap with a seal around it (like hope does)?
finlayy
4/20/2020 10:47am
Nic Cotton wrote:
Did you replace the olive and barb for the new hose before reattaching to the lever? (see photo) [img]https://p.vitalmtb.com/photos/forums/2020/04/20/9472/s1200_barb.jpg[/img] If you did replace both olive and...
I have put a new olive and barb in but the leak is coming from the Seal circles in the picture
I do a standard bleed by pushing new fluid in from the Caliper and the old fluid will come out of the bleed port on the lever into a syringe.
finlayy
4/20/2020 10:48am
finlayy wrote:
I have put a new olive and barb in but the leak is coming from the Seal circles in the picture [img]https://p.vitalmtb.com/photos/forums/2020/04/20/9473/s1200_CAEC9704_0F85_4160_A3C2_4D73CE2E785D.jpg[/img] I do a standard...
Also my my breaks are Shimano BR-M615
4/20/2020 10:58am
if you push fluid towards the lever (from the caliper) and the system is full and "closed" (as in no syringe in the lever, or you are pushing the syringe) you will blow those seals/gaskets..open that up and check everything is in place and not broken.. and re-bleed..cheers..
4/20/2020 12:43pm Edited Date/Time 4/20/2020 12:45pm
Eye think ewe mite have problems with the weigh yore bleating yore breaks it's better two bleat fromme the lever down to the CalPERS
finlayy
4/21/2020 5:12pm
luisgutrod wrote:
if you push fluid towards the lever (from the caliper) and the system is full and "closed" (as in no syringe in the lever, or you...
What happens if I’ve blow the seals as even if I bleed it from the lever to the calliper it still leaks from the Seals on the lever?
P_BATEMAN
NYC, NY, USA
4/22/2020 8:55am
You used DOT fluid didn't you. Take that cover off and inspect the seal.
4/22/2020 6:00pm
You and your first things first mentality. Logic strikes again.
4/22/2020 6:11pm
Ali Clarkson has experimented quite successfully with using Shimano Saint levers matched up to Magura callipers using standard mineral oil.
But If so, total and thorough reflush, Mineral Oil Only!
P_BATEMAN
NYC, NY, USA
4/22/2020 7:04pm
Ali Clarkson has experimented quite successfully with using Shimano Saint levers matched up to Magura callipers using standard mineral oil. But If so, total and thorough...
I loved her first album though I find country to be a bit reductionist. Phil Collins is more my taste.
You can run mineral oil against DOT seals but not the other way around.
I've never tried human blood to replace magura blood as I think it would boil too low, the smell would be heavenly though.
4/22/2020 8:14pm
Mixn' is bad. M'cay.
4/22/2020 9:44pm
So pumped that Patrick joined our conversation. I'd love to see his business card.
Eoin
4/23/2020 12:09am
Nice to see I'm not the only one losing my mind during the lockdown
finlayy
4/24/2020 5:27am
If I replace the lever as the seals are gone could I use a different lever with the same calliper that’s on my bike?
skypig
4/24/2020 5:34pm
It should work no problems.
If you did use DOT fluid, which damaged the seals in the lever (Master Cylinder), then the seals in the calliper might be affected.
I have more experience with motorcycles. The size of the piston affects the “feel”.
If the lever is designed for a 2 piston calliper, it might have a lot of lever movement with a 4 piston calliper - for EG.
If it was me, I’d consider shopping around for a complete XT 2 piston set up.
I’ve spent hours and hours trying to get brakes working to my satisfaction - then found a pre bled complete set up very reasonably priced on the net - bolt it on - perfect (Sometimes, you have to shorten the line - look for instructions online)
4/24/2020 8:35pm
Yes but seals are available parts usually
Post a reply to: Brake bleed isn’t working
