Suspension Guru Help - Rear Shock Body Thread Pitch
Buckets Up
Hancock, MI US
I’ve tried digging online and have had little success.
Specifically, I am trying to find the thread pitch on the shock body for the Marzocchi Bomber CR rear coil shock. It’s nice to know how much preload each revolution of the shock collar gives.
Are all Fox/Marz coil shock the same?
7/30/2025 10:10pm
Buckets Up wrote:
I’ve tried digging online and have had little success.Specifically, I am trying to find the thread pitch on the shock body for the Marzocchi Bomber CR...
If that’s what you’re looking for, I would just count ten threads and measure them with a set of calipers, then divide by ten to get your preload distance per shock collar revolution.
Did that make any sense? I only recommend the count ten threads then divide by ten thing to make the measurement a little more accurate than trying to eyeball one tiny thread on its own.
Buckets Up
Hancock, MI US
7/30/2025 11:02pm Edited Date/Time 7/31/2025 7:45am
If that’s what you’re looking for, I would just count ten threads and measure them with a set of calipers, then divide by ten to get...
Makes perfect sense. That’ll be the plan tomorrow. Thanks!
Still hoping someone (@TheSuspensionLabNZ ?) might have the official answer.
I know I’ve found in the past for the DVO Jade.
Buckets Up
Hancock, MI US
7/31/2025 7:45am
Most preload collars are 1mm pitch, makes it nice and simple!
Thank you!
arek
PL
8/1/2025 12:19pm
should be 24 tpi
8/1/2025 5:52pm
Use a pitch gauge Screw Pitch Gauge 4 To 62 Tpi, 0.25 To 6.0 Mm Combination With 55 Degree  And Metric 60 Degree at ₹ 110/piece | Size Control Thread Gauge in Ganaur |  ID: 2850227073733
Post a reply to: Suspension Guru Help - Rear Shock Body Thread Pitch
