Anyone got a dhf 2.5 wt on a 30 id rim? Just wondering what the height and width of it is as my fork has crappy clearance. My onza ibex 2.4 is fine but I don't really want anything bigger and the minion is 2mm bigger etrto.
Ta
Hey
Anyone got a dhf 2.5 wt on a 30 id rim? Just wondering what the height and width of it is as my fork has...
Hey
Ta
On a 29mm rim, it's roughly 65mm wide and 60mm tall. Keep in mind I said roughly, this was eyeballed with a ruler and not measured with calipers.
On a 584mm diameter, 30mm internal width rim, I have measured the below on a 2.5WT DHF at 40psi after some initial stretching:
Tread width: 2.49" (63mm) @ 683mm diameter
On a 584mm diameter, 30mm [b]i[/b]nternal [b]w[/b]idth rim, I have measured the below on a 2.5WT DHF at 40psi after some initial stretching:
Tread width: 2.49"...
the height is more so the issue on my devile, did you get a look at that? i have 60/61 with my onza at the moment.
ta
Hey
Hey
Ta
ta
Post a reply to: Minion dhf wt aired up dimensions
